[GRASS-SVN] r43654 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Sep 23 16:48:43 EDT 2010
Author: martinl
Date: 2010-09-23 20:48:43 +0000 (Thu, 23 Sep 2010)
New Revision: 43654
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI/modeler: ignore missing parameters (show warning)
(merge r43653 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-09-23 20:44:29 UTC (rev 43653)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-09-23 20:48:43 UTC (rev 43654)
@@ -2843,8 +2843,10 @@
cmd.append('%s=%s' % (name,
self._filterValue(self._getNodeText(p, 'value'))))
- task = menuform.GUI().ParseCommand(cmd = cmd,
- show = None)
+ task, err = menuform.GUI().ParseCommand(cmd = cmd,
+ show = None, checkError = True)
+ if err:
+ GWarning(os.linesep.join(err))
for opt, name in parameterized:
if opt == 'flag':
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-09-23 20:44:29 UTC (rev 43653)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-09-23 20:48:43 UTC (rev 43654)
@@ -1875,7 +1875,7 @@
return processTask(tree).GetTask()
def ParseCommand(self, cmd, gmpath = None, completed = None, parentframe = None,
- show = True, modal = False):
+ show = True, modal = False, centreOnParent = True, checkError = False):
"""!Parse command
Note: cmd is given as list
@@ -1908,6 +1908,7 @@
if 'flags' in dcmd_params:
self.grass_task.flags = dcmd_params['flags']
+ err = list()
# update parameters if needed && validate command
if len(cmd) > 1:
i = 0
@@ -1928,8 +1929,13 @@
value = option
else:
raise ValueError, _("Unable to parse command %s") % ' '.join(cmd)
- element = self.grass_task.get_param(key)['element']
+ element = self.grass_task.get_param(key, raiseError = False)
+ if not element:
+ err.append(_("%s: parameter '%s' not available") % (cmd[0], key))
+ continue
+ element = element['element']
if element in ['cell', 'vector']:
# mapname -> mapname at mapset
if '@' not in value:
@@ -1969,7 +1975,10 @@
self.cmd = cmd
- return self.grass_task
+ if checkError:
+ return self.grass_task, err
+ else:
def GetCommandInputMapParamKey(self, cmd):
"""!Get parameter key for input raster/vector map
