[GRASS-SVN] r43667 - grass/trunk/tools
Fri Sep 24 08:32:11 EDT 2010
Author: glynn
Date: 2010-09-24 12:32:11 +0000 (Fri, 24 Sep 2010)
New Revision: 43667
   grass/trunk/tools/mkhtml.py
Revert attempts to parse HTML using regexps
Modified: grass/trunk/tools/mkhtml.py
--- grass/trunk/tools/mkhtml.py	2010-09-24 12:14:07 UTC (rev 43666)
+++ grass/trunk/tools/mkhtml.py	2010-09-24 12:32:11 UTC (rev 43667)
@@ -4,9 +4,8 @@
 # MODULE:       mkhtml.py
 # AUTHOR(S):    Markus Neteler, Glynn Clements
-#               TOC by Martin Landa <landa.martin gmail.com>
 # PURPOSE:      create HTML manual page snippets
-# COPYRIGHT:    (C) 2007,2009-2010 Glynn Clements and the GRASS Development Team
+# COPYRIGHT:    (C) 2007,2009 Glynn Clements and the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -57,64 +56,6 @@
 src_data = read_file(src_file)
-def get_toc_item(line, pattern):
-    found = pattern.search(line)
-    if found:
-        return found.group(2).strip()
-    return None
-def filter_toc_item(label):
-    return label.replace('"', '&quot;')
-def write_toc_level(line, src_list, pattern, pattern_level, level, idx):
-    indent = 4
-    text = get_toc_item(line, pattern)
-    if not text:
-        return False, level
-    if pattern_level > level:
-        for l in range(level, pattern_level):
-            sys.stdout.write('%s<li><ul>\n' % (' ' * l * indent))
-    elif level > pattern_level:
-        for l in range(level, pattern_level, -1):
-            sys.stdout.write('%s</ul></li>\n' % (' ' * (l - 1) * indent))
-    level = pattern_level
-    sys.stdout.write('%s<li><a href="#%s">%s</a></li>\n' % (' ' * level * indent,
-                                                       filter_toc_item(text), filter_toc_item(text)))
-    src_list[idx] = '<a name="%s"></a>' % filter_toc_item(text) + line
-    return True, level
-def write_toc():
-    global src_data
-    level  = 1
-    idx    = 0
-    indent = 4
-    sys.stdout.write('<a name="TOC"></a><h2>TABLE OF CONTENT</h2>\n\n<ul>\n')
-    src_list = src_data.splitlines()
-    for line in src_list:
-        found, level = write_toc_level(line, src_list,
-                                       re.compile(r"(<h2>)(.*)(</h2>)", re.IGNORECASE), 1,
-                                       level, idx)
-        if not found:
-                                           re.compile(r"(<h3>)(.*)(</h3>)", re.IGNORECASE), 2,
-                                           level, idx)
-        if not found:
-                                           re.compile(r"(<h4>)(.*)(</h4>)", re.IGNORECASE), 3,
-                                           level, idx)
-        idx += 1
-    for l in range(level, 0, -1):
-        sys.stdout.write('%s</ul>\n' % (' ' * (l - 1) * indent))
-    src_data = '\n'.join(src_list)
 if not re.search('<html>', src_data, re.IGNORECASE):
     tmp_data = read_file(tmp_file)
     if not re.search('<html>', tmp_data, re.IGNORECASE):
@@ -123,7 +64,6 @@
 	for line in tmp_data.splitlines(True):
 	    if not re.search('</body>|</html>', line, re.IGNORECASE):
 		sys.stdout.write(line)
-    write_toc()
 sys.stdout.write(src_data)
@@ -133,20 +73,22 @@
     sys.exit()
 index_names = {
-    'd' : 'display',
+    'd': 'display',
     'db': 'database',
-    'g' : 'general',
-    'i' : 'imagery',
-    'm' : 'misc',
+    'g': 'general',
+    'i': 'imagery',
+    'm': 'misc',
+    'pg': 'postGRASS',
     'ps': 'postscript',
-    'p' : 'paint',
-    'r' : 'raster',
+    'p': 'paint',
+    'r': 'raster',
     'r3': 'raster3D',
-    's' : 'sites',
-    'v' : 'vector'
+    's': 'sites',
+    'v': 'vector'
 mod_class = pgm.split('.', 1)[0]
 index_name = index_names.get(mod_class, mod_class)
 sys.stdout.write(footer_tmpl.substitute(INDEXNAME = index_name))
