[GRASS-SVN] r43687 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules xml
svn_grass at osgeo.org
Sat Sep 25 15:09:36 EDT 2010
Author: martinl
Date: 2010-09-25 19:09:36 +0000 (Sat, 25 Sep 2010)
New Revision: 43687
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: Python export implemented as class (WritePythonFile)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-09-25 18:45:14 UTC (rev 43686)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-09-25 19:09:36 UTC (rev 43687)
@@ -30,6 +30,7 @@
- ItemCheckListCtrl
- ModelCondition
- ModelConditionDialog
+ - WritePythonFile
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
@@ -1088,7 +1089,7 @@
if not filename:
return
# check for extension
if filename[-3:] != ".py":
filename += ".py"
@@ -1103,10 +1104,10 @@
return
dlg.Destroy()
fd = open(filename, "w")
try:
- self._writePython(fd)
+ WritePythonFile(fd, self.model)
finally:
fd.close()
@@ -1115,133 +1116,6 @@
self.SetStatusText(_("Model exported to <%s>") % filename)
- def _writePython(self, fd):
- """!Write model to file"""
- properties = self.model.GetProperties()
- fd.write(
-r"""#!/usr/bin/env python
-# MODULE: %s
-# AUTHOR(S): %s
-# PURPOSE: %s
-# DATE: %s
-""" % (properties['name'],
- properties['author'],
- properties['description'],
- time.asctime()))
- fd.write(
-r"""
-import sys
-import os
-import atexit
-import grass.script as grass
- # cleanup()
- rast, vect, rast3d, msg = self.model.GetIntermediateData()
- fd.write(
-r"""
-def cleanup():
- if rast:
- fd.write(
-r""" grass.run_command('g.remove',
- rast=%s)
-""" % ','.join(map(lambda x: "'" + x + "'", rast)))
- if vect:
- fd.write(
- vect = %s)
-""" % ','.join(map(lambda x: "'" + x + "'", vect)))
- if rast3d:
- fd.write(
- rast3d = %s)
-""" % ','.join(map(lambda x: "'" + x + "'", rast3d)))
- if not rast and not vect and not rast3d:
- fd.write(' pass\n')
- fd.write("\ndef main():\n")
- indent = 4
- for item in self.model.GetItems():
- if isinstance(item, ModelAction):
- if item.GetLoopId():
- continue
- self._writePythonAction(fd, item, indent)
- elif isinstance(item, ModelLoop):
- # substitute conditiond
- variables = self.model.GetVariables()
- cond = item.GetText()
- for variable in variables:
- pattern= re.compile('%' + variable)
- if pattern.search(cond):
- value = variables[variable].get('value', '')
- if variables[variable].get('type', 'string') == 'string':
- value = '"' + value + '"'
- cond = pattern.sub(value, cond)
- fd.write('%sfor %s:\n' % (' ' * indent, cond))
- indent += 4
- for action in item.GetItems():
- self._writePythonAction(fd, action, indent)
- indent -= 4
- fd.write("\n return 0\n")
- fd.write(
-r"""
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- sys.exit(main())
- def _writePythonAction(self, fd, item, indent):
- task = menuform.GUI().ParseCommand(cmd = item.GetLog(string = False),
- show = None)
- opts = task.get_options()
- flags = ''
- params = list()
- strcmd = "%sgrass.run_command(" % (' ' * indent)
- cmdIndent = len(strcmd)
- for f in opts['flags']:
- if f.get('value', False) == True:
- name = f.get('name', '')
- if len(name) > 1:
- params.append('%s = True' % name)
- else:
- flags += name
- for p in opts['params']:
- name = p.get('name', None)
- value = p.get('value', None)
- if name and value:
- ptype = p.get('type', 'string')
- if ptype == 'string':
- params.append('%s = "%s"' % (name, value))
- else:
- params.append("%s = %s" % (name, value))
- fd.write(strcmd + '"%s"' % task.get_name())
- if flags:
- fd.write(",\n%sflags = '%s'" % (' ' * cmdIndent, flags))
- if len(params) > 0:
- fd.write(",\n")
- for opt in params[:-1]:
- fd.write("%s%s,\n" % (' ' * cmdIndent, opt))
- fd.write("%s%s)\n" % (' ' * cmdIndent, params[-1]))
- else:
- fd.write(")\n")
def _validateModel(self):
"""!Validate model"""
self.SetStatusText(_('Validating model...'), 0)
@@ -4486,7 +4360,165 @@
"""!Get items"""
return { 'if' : self.itemListIf.GetItems(),
'else' : self.itemListElse.GetItems() }
+class WritePythonFile:
+ def __init__(self, fd, model):
+ """!Class for exporting model to Python script
+ @param fd file desciptor
+ self.fd = fd
+ self.model = model
+ self.indent = 4
+ self._writePython()
+ def _writePython(self):
+ """!Write model to file"""
+ properties = self.model.GetProperties()
+ self.fd.write(
+r"""#!/usr/bin/env python
+# MODULE: %s
+# AUTHOR(S): %s
+# PURPOSE: %s
+# DATE: %s
+""" % (properties['name'],
+ properties['author'],
+ properties['description'],
+ time.asctime()))
+ self.fd.write(
+r"""
+import sys
+import os
+import atexit
+import grass.script as grass
+ # cleanup()
+ rast, vect, rast3d, msg = self.model.GetIntermediateData()
+ self.fd.write(
+r"""
+def cleanup():
+ if rast:
+ self.fd.write(
+r""" grass.run_command('g.remove',
+ rast=%s)
+""" % ','.join(map(lambda x: "'" + x + "'", rast)))
+ if vect:
+ self.fd.write(
+ vect = %s)
+""" % ','.join(map(lambda x: "'" + x + "'", vect)))
+ if rast3d:
+ self.fd.write(
+ rast3d = %s)
+""" % ','.join(map(lambda x: "'" + x + "'", rast3d)))
+ if not rast and not vect and not rast3d:
+ self.fd.write(' pass\n')
+ self.fd.write("\ndef main():\n")
+ for item in self.model.GetItems():
+ self._writePythonItem(item)
+ self.fd.write("\n return 0\n")
+ self.fd.write(
+r"""
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
+ def _writePythonItem(self, item, ignoreBlock = True):
+ """!Write model object to Python file"""
+ if isinstance(item, ModelAction):
+ if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
+ return
+ self._writePythonAction(item)
+ elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
+ # substitute condition
+ variables = self.model.GetVariables()
+ cond = item.GetText()
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ if pattern.search(cond):
+ value = variables[variable].get('value', '')
+ if variables[variable].get('type', 'string') == 'string':
+ value = '"' + value + '"'
+ cond = pattern.sub(value, cond)
+ if isinstance(item, ModelLoop):
+ self.fd.write('%sfor %s:\n' % (' ' * self.indent, cond))
+ self.indent += 4
+ for action in item.GetItems():
+ self._writePythonItem(action, ignoreBlock = False)
+ self.indent -= 4
+ else: # ModelCondition
+ self.fd.write('%sif %s:\n' % (' ' * self.indent, cond))
+ self.indent += 4
+ condItems = item.GetItems()
+ for action in condItems['if']:
+ if condItems['else']:
+ self.indent -= 4
+ self.fd.write('%selse:\n' % (' ' * self.indent))
+ self.indent += 4
+ for action in condItems['else']:
+ self.indent += 4
+ def _writePythonAction(self, item):
+ """!Write model action to Python file"""
+ task = menuform.GUI().ParseCommand(cmd = item.GetLog(string = False),
+ show = None)
+ opts = task.get_options()
+ flags = ''
+ params = list()
+ strcmd = "%sgrass.run_command(" % (' ' * self.indent)
+ cmdIndent = len(strcmd)
+ for f in opts['flags']:
+ if f.get('value', False) == True:
+ name = f.get('name', '')
+ if len(name) > 1:
+ params.append('%s = True' % name)
+ else:
+ flags += name
+ for p in opts['params']:
+ name = p.get('name', None)
+ value = p.get('value', None)
+ if name and value:
+ ptype = p.get('type', 'string')
+ if ptype == 'string':
+ params.append('%s = "%s"' % (name, value))
+ else:
+ params.append("%s = %s" % (name, value))
+ self.fd.write(strcmd + '"%s"' % task.get_name())
+ if flags:
+ self.fd.write(",\n%sflags = '%s'" % (' ' * cmdIndent, flags))
+ if len(params) > 0:
+ self.fd.write(",\n")
+ for opt in params[:-1]:
+ self.fd.write("%s%s,\n" % (' ' * cmdIndent, opt))
+ self.fd.write("%s%s)\n" % (' ' * cmdIndent, params[-1]))
+ else:
+ self.fd.write(")\n")
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml 2010-09-25 18:45:14 UTC (rev 43686)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata_modeler.xml 2010-09-25 19:09:36 UTC (rev 43687)
@@ -41,7 +41,7 @@
<label>Export to Python</label>
<help>Export model to Python script</help>
<handler>OnExportPython</handler>
- <shortcut>Ctrl+E</shortcut>
+ <shortcut>Ctrl+P</shortcut>
</menuitem>
<separator />
<menuitem>
