[GRASS-SVN] r43690 - grass/branches/releasebranch_6_4/lib/init
svn_grass at osgeo.org
Sun Sep 26 07:30:27 EDT 2010
Author: marisn
Date: 2010-09-26 11:30:27 +0000 (Sun, 26 Sep 2010)
New Revision: 43690
grass/branches/releasebranch_6_4/lib/init/gis_set.tcl
tcltk: provide smaller satrup screen for small screen users; prevent failure if grab fails. (Sync to develbranch_6 r43689)
Modified: grass/branches/releasebranch_6_4/lib/init/gis_set.tcl
--- grass/branches/releasebranch_6_4/lib/init/gis_set.tcl 2010-09-25 20:34:46 UTC (rev 43689)
+++ grass/branches/releasebranch_6_4/lib/init/gis_set.tcl 2010-09-26 11:30:27 UTC (rev 43690)
@@ -34,6 +34,10 @@
set GRASSVERSION [read -nonewline $fp]
close $fp
+# If window height is smaller, then consider it a small window
+# 660px is approximate full welcome screen height
+set small_window 670
proc searchGISRC { filename } {
@@ -168,6 +172,7 @@
global grassrc_list
global gisrc_name
global refresh
+ global small_window
set refresh 0
@@ -185,22 +190,42 @@
-relief {raised}]
set titlefrm [frame .frame0.intro -borderwidth 2 ]
- set introimg [label $titlefrm.img -image [image create photo -file \
- "$env(GISBASE)/etc/gui/images/gintro.gif"]]
- set introtitle [text $titlefrm.msg -height 5 \
- -relief flat -fg darkgreen \
- -bg #dddddd \
- -font introfont \
- -width 50 ]
pack $titlefrm -side top
+ # Don't show picture on small screens
+ if { [info exists env(GRASS_HEIGHT)] } {
+ set screen_height $env(GRASS_HEIGHT)
+ } else {
+ set screen_height [winfo screenheight .]
+ if { $screen_height > $small_window } {
+ set introimg [label $titlefrm.img -image [image create photo -file \
+ "$env(GISBASE)/etc/gui/images/gintro.gif"]]
pack $introimg -side top
+ set introtitle [text $titlefrm.msg -height 5 \
+ -relief flat -fg darkgreen \
+ -bg #dddddd \
+ -font introfont \
+ -width 50 ]
+ } else {
+ set introtitle [text $titlefrm.msg -height 2 \
+ -bg #dddddd \
+ -font introfont \
+ -width 50 ]
pack $introtitle -side top
.frame0.intro.msg tag configure all -justify center
- .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS Version"]
- .frame0.intro.msg insert end [G_msg " $GRASSVERSION\n"]
- .frame0.intro.msg insert end [G_msg "The world's leading open source GIS\n\n"]
+ # Welcome text takes too much space on small screens
+ .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS Version"]
+ .frame0.intro.msg insert end [G_msg " $GRASSVERSION\n"]
+ .frame0.intro.msg insert end [G_msg "The world's leading open source GIS\n\n"]
.frame0.intro.msg insert end [G_msg "Select an existing project location and mapset\n"]
.frame0.intro.msg insert end [G_msg "or define a new location\n"]
.frame0.intro.msg tag add all 1.0 end
@@ -697,7 +722,7 @@
exit 2
- grab .
+ catch { grab . }
tkwait window .
Property changes on: grass/branches/releasebranch_6_4/lib/init/gis_set.tcl
___________________________________________________________________
Added: svn:mergeinfo
+ /grass/branches/develbranch_6/lib/init/gis_set.tcl:34936-43689
