[GRASS-SVN] r43701 - grass-addons/vector/v.in.gshhs
Mon Sep 27 08:10:46 EDT 2010
Author: neteler
Date: 2010-09-27 12:10:46 +0000 (Mon, 27 Sep 2010)
New Revision: 43701
   grass-addons/vector/v.in.gshhs/gshhs.h
   grass-addons/vector/v.in.gshhs/main.c
updated to GSHHS 2.1.0
Modified: grass-addons/vector/v.in.gshhs/gshhs.h
--- grass-addons/vector/v.in.gshhs/gshhs.h	2010-09-27 11:47:55 UTC (rev 43700)
+++ grass-addons/vector/v.in.gshhs/gshhs.h	2010-09-27 12:10:46 UTC (rev 43701)
@@ -1,11 +1,11 @@
-/*	$Id: gshhs.h,v 1.17 2008/01/23 03:22:49 guru Exp $
+/*	$Id: gshhs.h,v 1.31 2010/07/18 03:16:01 guru Exp $
  * Include file defining structures used in gshhs.c
  * Paul Wessel, SOEST
- *	Copyright (c) 1996-2008 by P. Wessel and W. H. F. Smith
- *	See COPYING file for copying and redistribution conditions.
+ *	Copyright (c) 1996-2010 by P. Wessel and W. H. F. Smith
+ *	See LICENSE.TXT file for copying and redistribution conditions.
  *	This program is free software; you can redistribute it and/or modify
  *	it under the terms of the GNU General Public License as published by
@@ -27,9 +27,12 @@
  *	28-AUG-2007.  PW: Version 1.6.  no format change
  *			  For use with version 1.6 of GSHHS which now has WDBII
  *			  borders and rivers.
- * may need updating for new GSHHS versions
+ *	03-JUL-2008.  PW: Version 1.11. New -I<id> option to pull out a single pol
+ *	27-MAY-2009.  PW: Version 1.12. Now includes container polygon ID in header,
+ *			  an ancestor ID, and area of the reduced polygon. Works on
+ *			  GSHHS 2.0 data.
+ *			  Header is now 44 bytes (all 4-byte integers)
+ *	24-MAY-2010.  PW: Data version is now 2.1.0. [no change to format]
 #ifndef _GSHHS
@@ -38,8 +41,13 @@
 #include <stdio.h>
 #include <stdlib.h>
+#include <ctype.h>
 #include <math.h>
+#ifdef WIN32
+#pragma warning( disable : 4996 )
+#endif
 #ifndef M_PI
 #define M_PI          3.14159265358979323846
 #endif
@@ -48,31 +56,17 @@
 #define SEEK_CUR 1
 #endif
-#define GSHHS_DATA_RELEASE	7	/* For v2.0 data set */
-#define GSHHS_DATA_VERSION	"2.0"	/* For v2.0 data set */
+#define GSHHS_DATA_RELEASE	8	/* For v2.1.0 data set */
+#define GSHHS_DATA_VERSION	"2.1.0"	/* For v2.1.0 data set */
 #define GSHHS_PROG_VERSION	"1.12"
-#define GSHHS_SCL	1.0e-6	/* COnvert micro-degrees to degrees */
+#define GSHHS_SCL	1.0e-6	/* Convert micro-degrees to degrees */
 /* For byte swapping on little-endian systems (GSHHS is defined to be bigendian) */
 #define swabi4(i4) (((i4) >> 24) + (((i4) >> 8) & 65280) + (((i4) & 65280) << 8) + (((i4) & 255) << 24))
-struct GSHHS1 {	/* Global Self-consistent Hierarchical High-resolution Shorelines */
-	int id;				/* Unique polygon id number, starting at 0 */
-	int n;				/* Number of points in this polygon */
-	int flag;			/* = level + version << 8 + greenwich << 16 + source << 24 */
-	/* flag contains 4 items, one in each byte, as follows:
-	 * low byte:	level = flag & 255: Values: 1 land, 2 lake, 3 island_in_lake, 4 pond_in_island_in_lake
-	 * 2nd byte:	version = (flag >> 8) & 255: Values: Should be 4 for GSHHS version 1.4
-	 * 3rd byte:	greenwich = (flag >> 16) & 255: Values: Greenwich is 1 if Greenwich is crossed
-	 * 4th byte:	source = (flag >> 24) & 255: Values: 0 = CIA WDBII, 1 = WVS
-	int west, east, south, north;	/* min/max extent in micro-degrees */
-	int area;			/* Area of polygon in 1/10 km^2 */
-struct GSHHS2 {	/* Global Self-consistent Hierarchical High-resolution Shorelines */
+struct GSHHS {	/* Global Self-consistent Hierarchical High-resolution Shorelines */
 	int flag;	/* = level + version << 8 + greenwich << 16 + source << 24 + river << 25 */
@@ -90,7 +84,7 @@
 	int ancestor;	/* Id of ancestor polygon in the full resolution set that was the source of this polygon (-1 if none) */
-struct GSHHS_POINT {	/* Each lon, lat pair is stored in micro-degrees in 4-byte integer format */
+struct	GSHHS_POINT {	/* Each lon, lat pair is stored in micro-degrees in 4-byte integer format */
 	int	x;
 	int	y;
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c	2010-09-27 11:47:55 UTC (rev 43700)
+++ grass-addons/vector/v.in.gshhs/main.c	2010-09-27 12:10:46 UTC (rev 43701)
@@ -36,6 +36,7 @@
 /* updating to a newer GSHHS version can be as easy as replacing
  * struct GSHHS2 und updating GSHHS_DATA_RELEASE in gshhs.h
  * if not too many changes were introduced */
+/* TODO 9/2010: GSHHS1 and GSHHS2 have been unified in gshhs.h, simplify code here */
 #include "gshhs.h"
 /* GSHHS version 1.x import */
@@ -61,7 +62,7 @@
     FILE *fp;
     int i, n_read, flip, version;
     int cnt = 0;
-    struct GSHHS1 h;
+    struct GSHHS h;
     /* GRASS specific */
     struct Key_Value *out_proj_keys, *out_unit_keys;
     int zone;
@@ -257,7 +258,7 @@
     /* read header from GSHHS database */
-    n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS1), (size_t) 1, fp);
+    n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
     version = (h.flag >> 8) & 255;
     /* Take as sign that byte-swapping is needed */
@@ -378,7 +379,7 @@
     int max_east = 180000000;	/* max_east = 270000000: confuses GRASS */
     int cnt = 0, getme = 0;
     struct GSHHS_POINT p;	/* renamed to avoid conflict */
-    struct GSHHS1 h;
+    struct GSHHS h;
     int type;
     struct line_pnts *Points, **BPoints;
@@ -386,7 +387,7 @@
     int use_bpoints, n_bpoints, bpoints_alloc = 10;
@@ -676,7 +677,7 @@
 	/* max_east = 180000000; */ /* Only Eurasiafrica needs 270 */
 	n_read =
-	    fread((void *)&h, (size_t) sizeof(struct GSHHS1), (size_t) 1, fp);
+	    fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
     Vect_destroy_line_struct(Points);
@@ -690,6 +691,7 @@
 /* GSHHS version 2.x import, works with data release 7 */
 /* the only difference between gshhs_import1 and gshhs_import2 is
  * the use of struct GSHHS1 or struct GSHHS2, respectively */
 int gshhs_import2(struct Map_info *Map, FILE *fp, int limit_to_region,
 		  double minx, double maxx, double miny, double maxy)
@@ -700,7 +702,7 @@
-    struct GSHHS2 h;
+    struct GSHHS h;
     int type;
@@ -708,7 +710,7 @@
-    n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS2), (size_t) 1, fp);
@@ -998,7 +1000,7 @@
 	n_read =
-	    fread((void *)&h, (size_t) sizeof(struct GSHHS2), (size_t) 1, fp);
