[GRASS-SVN] r43703 - grass/trunk/tools/g.html2man
Mon Sep 27 10:34:14 EDT 2010
Author: glynn
Date: 2010-09-27 14:34:14 +0000 (Mon, 27 Sep 2010)
New Revision: 43703
Removed:
   grass/trunk/tools/g.html2man/g.html2man
Remove (unused) shell version of g.html2man
Deleted: grass/trunk/tools/g.html2man/g.html2man
--- grass/trunk/tools/g.html2man/g.html2man	2010-09-27 13:07:52 UTC (rev 43702)
+++ grass/trunk/tools/g.html2man/g.html2man	2010-09-27 14:34:14 UTC (rev 43703)
@@ -1,335 +0,0 @@
-#!/bin/sh  -- #perl, to stop looping
-eval 'exec $GRASS_PERL -S $0 ${1+"$@"}'
-    if 0;
-# MODULE:       g.html2man
-# AUTHOR(S):    Daniel Calvelo Aros
-# PURPOSE:      convert HTML formatted page to MAN page format
-# COPYRIGHT:    (C) 2004 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-# Note: the GRASS_PERL variables must be set!
-# Usage:
-#       perl g.html2man <html file> <man file> <section>
-our $preformat, $in_bu, $in_nb, @nb_n;
-our $suppress = 0;
-sub CvtTable {
-# converts <table> structures to tbl commands.
-# limitations: malformed (sloppy html) tables won't convert
-# properly, eg no closing tags are bad.
-# <th> headers are handled; nested <table>s are not
-# since tables may be line-formatted randomly, this function
-# works on a full file; thus, the original line-oriented
-# unbuffered design had to be changed.
-# modify $format if centered headings and left-aligned
-# contents don't suit you.
-# also, groff recognizes the tbl commands and preprocesses
-# accordingly; for other roff formatters that is uncertain.
-# it might be advisable to put a '.\" t' line at the beginning
-# of the output file
-# TODO: rewrite g.html2man using the HTML::Parser module
-  my $i = shift;
-  return $i unless $i =~ m|<table.*?>(.+?)</table>|is;
-  my $header = ".TS\nexpand box;\n";
-  $_ = $1;
-  ($one_row,) = m|<tr.*?>(.+?)</tr>|is ;
-  $ncols = -1 + scalar split /<td/i, $one_row;
-  $has_header = m|<th|i ;
-  s|[\n\r]||g;
-  s|</tr.*?>|\n.br\n|gis;
-  s|</td.*?>|\t|gis;
-  foreach $tag ( qw(<td.*?> <th.*?> </th> <tr.*?>) ){
-    s/$tag//gi;
-  $format = $has_header
-          ? "cb"x$ncols . "\n"."-"x$ncols . "\n"
-  $format .= "l"x$ncols . ".\n";
-  $i =~ s|<table.*?>.+?<table>|$header$format$_.TE\n|is;
-  return CvtTable($i);
-sub basename {
-  $slash = rindex($_[0], "/");
-  $suffix = rindex($_[0], $_[1]);
-  if ($suffix == -1) {$suffix=length($_[0])};
-  return substr($_[0], $slash+1, $suffix-$slash-1);
-sub GetTitle {
-  while (<INP>) {
-    if (m#<TITLE>.*MAN page for:#i) {
-      s#<TITLE>##i;
-      s#MAN page for:##i;
-      s#</TITLE>##i;
-      @TITLE = split;
-      return 1;
-    if (m#<TITLE>#i) {
-      return 1;
-  return 0;
-sub PrintHeader {
-      print OUT ".TH $_[0] $_[1] \"\" \"GRASS " . $ENV{'VERSION_NUMBER'} . "\" \"Grass User's Manual\"\n";
-##      print OUT ".so /usr/share/lib/tmac/sml\n";
-##      print OUT ".so /usr/share/lib/tmac/rsml\n";
-sub DoStrip {
-  if (m#<.*TITLE>#i) { return 1};
-  if (m/<.*HEADER>/i) { return 1};
-  if (m/<.*HEAD>/i) { return 1};
-  if (m/<.*BODY>/i) { return 1};
-  if (m/<.*BLINK>/i) { return 1};
-  if (m/^<A HREF="#toc/i) {return 1};
-  if (s#<A HREF=".*">##i) {
-      s#</A>##i;
-  return 0;
-sub DoLine {
-  if (m#</PRE>#i) {
-    s#</PRE>#\n.DE\n\\fR#i;
-    $preformat = 0;
-    return 1;
-###  if ($preformat) {return 1};
-  if (m#<PRE>#i) {
-    s#^.*<PRE>#\\fC\n.DS#i;
-    $preformat = 1;
-    return 1;
-  s#<IMG SRC=.*>##i;
-  if (m#<A NAME="toc">#i) {return 2};
-  s#<A NAME=".*">##i;
-  #s#<\!\-\-#.\\\" #i;
-  #s#\-\->##i;
-  if (m#^<HR.*>$#i) {return 0};
-  s#<HR>##i;
-  s#<HR .*>##i;
-  if (&DoStrip($_)) {return 0}
-  &DoFont($_);
-  if (! &DoList($_)) {return 0};
-  if (! &DoSection($_)) {return 0}
-  &DoEscape($_);
-  &DoPara($_);
-  if (! $preformat) {
-    if (m/^$/) {return 0};
-    s#^[ \t]*##;
-    s#<[^>]*>##g;
-  return 1;
-sub DoEscape {
-  s#&gt;#>#i;
-  s#&lt;#<#i;
-  s#&amp;#&#i;
-  s#&quot;#"#i;
-  s#&nbsp;# #i;
-  s#&copy;#©#i;
-  s#&auml;#ä#i;
-  s#&uuml;#ü#i;
-  s#&lt;#<#i;
-  s#&gt;#>#i;
-sub DoSection {
-  if (m#^ *Table of Contents *$#i) {return 0};
-  if (m#^<A NAME=".*">$#i) {return 0;}
-  s#^.*<H2>#.SH #i;
-  s#^.*<H3>#.SS #i;
-  s#^.*<H4>#.SS #i;
-  if (m#^</[^>]*>$#i) {return 0};
-  s#</[^>]*>##ig;
-  s#^<BR>$#.br#i;
-  s#<BR>#\n.br\n#i;
-  return 1;
-# Paragraph breaks: <P>
-sub DoPara {
-  s/^ *<P>/.PP\n/i;
-  s/<P>/\n.PP\n/ig;
-  return;
-# Lists
-#    <DL><DT><DD>
-sub DoList {
-  if (m#^ *</DT> *$#i) {return 0};
-  if (m#<DT> *$#i) {chop};
-  s#^ *<DT>#.IP \"#i;
-  s#<DT>#\n.IP \"#i;
-  s#</DT>#\" 4m#i;
-  if (m#^ *<DD> *$#i) {return 0};
-  if (m#^ *</DD> *$#i) {return 0};
-  if (m#^</LI>$#i) {return 0};
-  s#<DD>#\n.br\n#i;
-  s#</DD>##i;
-  s#^.*<DL> *$##i;
-  s#<DL>#\n.VL 4m\n#i;
-  s#^.*</DL> *$#.PP#i;
-  s#<DL>#\n.IP\n#i;
-  s|<UL>|\n.RS\n|i and $in_bu=1;
-  s|</UL>|\n.RE\n|i and $in_bu=0;
-  s|<OL>|\n..IP\n|i and ($in_nb++,$nb_n[$in_nb]=1); # @nb_n is a stack allowing for nested <ol>'s
-  s|</OL>|\n.PP\n|i and ($nb_n[$in_nb]=0,$in_nb--);
-  s|</LI>||i;
-  if(/<li>/){
-    $in_bu and s|<LI>|\n.IP\n|i;
-    $in_nb and (                          # since we're hand-composing the ordered lists (not using mm's .AL),
-      $n=(join ".", (                     # we use a uniform indentation and x.y.z numbering
-        (map {$_-1} @nb_n[1..($in_nb-1)]) # nb_n's are one beyond the current number for the levels above current
-	$nb_n[$in_nb])),                  # and exact for the current level
-      s|<li>|\n.IP \\fB$n\\fR\n|i,
-      $nb_n[$in_nb]++                     # because we post-increment after encountering each <li>
-  # move into CvtTable()  ??
-  s/<TD.*?>/\t| /gi;
-  s/<TR.*?>/\n.br\n/i;
-  return 1;
-# Font transitions:
-#   <B>  => \fB
-#   </B> => \fR
-#   <I>  => \fI
-#   </I> => \fR
-sub DoFont {
-  s# *</B> *_ *<B> *#_#ig;
-  s#</B> *<B># #ig;
-  s#<B>#\\fB#ig;
-  s#</B>#\\fR#ig;
-  s#<SUP>#\\u#ig;
-  s#</SUP>#\\d#ig;
-  s# *</I> *_ *<I> *#_#ig;
-  s#</I> *<I># #ig;
-  s#<I>#\\fI#ig;
-  s#</I>#\\fR#ig;
-  s# *</CODE> *_ *<CODE> *#_#ig;
-  s#</CODE> *<CODE># #ig;
-  s#<CODE>#\\fI#ig;
-  s#</CODE>#\\fR#ig;
-  s# *</EM> *_ *<EM> *#_#ig;
-  s#</EM> *<EM># #ig;
-  s#<EM>#\\fI#ig;
-  s#</EM>#\\fR#ig;
-  s/&NBSP;/ /ig;
-  return;
-# Process HTML file
-$infile = $ARGV[0];
-$outfile = $ARGV[1];
-$preformat = 0;
-$page = &basename($ARGV[0], ".html");
-$sect = $ARGV[2];
-open(INP,$infile) || die "Can't open '$infile' for reading: $!";
-if (! &GetTitle($page,$sect)) {
-  print "$infile: Did not find a valid <TITLE> line\n";
-  close(INP);
-  exit;
-open(OUT,"> $outfile") || die "Can't open '$outfile' for writing: $!";
-print "Converting: $infile to $outfile\n";
-&PrintHeader($page,$sect,$TITLE[0]);
-while (<INP>) {
-  # for intro pages which lack a module NAME (for whois entry)
-  if ($_ =~ s/<!-- meta page description:(.*)-->/$1/) {
-	print OUT ".SH NAME\n$page -$_\n";
-  s/\\/\\(rs/g;
-  $result = &DoLine($_);
-  if ($result == 2) {
-    close(INP);
-    close(OUT);
-    return;
-  if (&DoLine($_) == 1) {
-    s#&lt#<#g;
-    s#&gt#>#g;
-    s#^'#\\(cq#gm;
-    s#^"#\\(dq#gm;
-    s#`#\\(ga#g;
-    # this part removes the comments
-    $line = $_;
-    $line =~ s/<!--.*-->//g; #
-    if ($line =~ s/(.*)<!--.*/$1/) {
-        $suppress = 1;
-        $out .= $line;
-    if ($line =~ s/.*\-\-\>(.*)/$1/g) {
-        print $line
-        $suppress = 0;
-    if ($suppress != 0) {
-        $line = "";
-    # end of comment part
-    $out .= $line;
-    if ($preformat == 1) {
-      $out .= ".br\n";
-$out =~ s/\n+/\n/gm;
-print OUT CvtTable($out);
-close(INP);
-close(OUT);
-exit;
