[GRASS-SVN] r43707 - grass/trunk/tools/g.html2man
Mon Sep 27 11:19:02 EDT 2010
Author: glynn
Date: 2010-09-27 15:19:02 +0000 (Mon, 27 Sep 2010)
New Revision: 43707
Added:
   grass/trunk/tools/g.html2man/groff.py
   grass/trunk/tools/g.html2man/html.py
   grass/trunk/tools/g.html2man/Makefile
   grass/trunk/tools/g.html2man/g.html2man.py
Refactor g.html2man
Modified: grass/trunk/tools/g.html2man/Makefile
--- grass/trunk/tools/g.html2man/Makefile	2010-09-27 15:02:31 UTC (rev 43706)
+++ grass/trunk/tools/g.html2man/Makefile	2010-09-27 15:19:02 UTC (rev 43707)
@@ -2,7 +2,9 @@
 include $(MODULE_TOPDIR)/include/Make/Other.make
-default: $(TOOLSDIR)/g.html2man.py
+TARGETS := $(patsubst %.py,$(TOOLSDIR)/%.py,html.py groff.py g.html2man.py)
-$(TOOLSDIR)/g.html2man.py: g.html2man.py
+default: $(TARGETS)
+$(TOOLSDIR)/%.py: %.py
 	$(INSTALL) $< $@
Modified: grass/trunk/tools/g.html2man/g.html2man.py
--- grass/trunk/tools/g.html2man/g.html2man.py	2010-09-27 15:02:31 UTC (rev 43706)
+++ grass/trunk/tools/g.html2man/g.html2man.py	2010-09-27 15:19:02 UTC (rev 43707)
@@ -1,484 +1,20 @@
 #!/usr/bin/env python
-# coding=iso-8859-1
 import sys
-import types
-import os
 import re
-from HTMLParser import HTMLParser, HTMLParseError
-from htmlentitydefs import entitydefs
+from html import HTMLParser, HTMLParseError
+from groff import Formatter
 from StringIO import StringIO
-try:
-    version = os.environ['VERSION_NUMBER']
-except:
-    version = ""
 entities = {
-    'lt': "<",
-    'gt': ">",
-    'amp': "&",
     'nbsp': " ",
-    'copy': "©",
-    'quot': "\"",
     'bull': "*"
-omit_start = ["body", "tbody", "head", "html"]
-single = ["area", "base", "basefont", "br", "col", "frame",
-	  "hr", "img", "input", "isindex", "link", "meta", "param"]
-single = frozenset(single)
-heading = ["h1", "h2", "h3", "h4", "h5", "h6"]
-fontstyle = ["tt", "i", "b", "u", "s", "strike", "big", "small"]
-phrase = [ "em", "strong", "dfn", "code", "samp", "kbd", "var", "cite", "abbr",
-	   "acronym"]
-special = [ "a", "img", "applet", "object", "font", "basefont", "br", "script",
-	    "map", "q", "sub", "sup", "span", "bdo", "iframe"]
-formctrl = [ "input", "select", "textarea", "label", "button"]
-list = [ "ul", "ol", " dir", "menu"]
-head_misc = [ "script", "style", "meta", "link", "object"]
-pre_exclusion = [ "img", "object", "applet", "big", "small", "sub", "sup",
-		  "font", "basefont"]
-block = [ "p", "pre", "dl", "div", "center", "noscript", "noframes",
-	  "blockquote", "form", "isindex", "hr", "table", "fieldset",
-	  "address"] + heading + list
-inline = fontstyle + phrase + special + formctrl
-flow = block + inline
-html_content = ["head", "body"]
-head_content = ["title", "isindex", "base"]
-def setify(d):
-    return dict([(key, frozenset(val)) for key, val in d.iteritems()])
-def omit(allowed, tags):
-    result = {}
-    for k, v in allowed.iteritems():
-	for t in tags:
-	    if t in v:
-		v = v.union(allowed[t])
-	result[k] = v
-    return result
-allowed = {
-    "a": inline,
-    "abbr": inline,
-    "acronym": inline,
-    "address": inline + ["p"],
-    "applet": flow + ["param"],
-    "b": inline,
-    "bdo": inline,
-    "big": inline,
-    "blockquote": flow,
-    "body": flow + ["ins", "del"],
-    "button": flow,
-    "caption": inline,
-    "center": flow,
-    "cite": inline,
-    "code": inline,
-    "colgroup": ["col"],
-    "dd": flow,
-    "del": flow,
-    "dfn": inline,
-    "dir": ["li"],
-    "div": flow,
-    "dl": ["dt", "dd"],
-    "dt": inline,
-    "em": inline,
-    "fieldset": flow + ["legend"],
-    "font": inline,
-    "form": flow,
-    "frameset": ["frameset", "frame", "noframes"],
-    "h1": inline,
-    "h2": inline,
-    "h3": inline,
-    "h4": inline,
-    "h5": inline,
-    "h6": inline,
-    "head": head_content + head_misc,
-    "html": html_content,
-    "i": inline,
-    "iframe": flow,
-    "ins": flow,
-    "kbd": inline,
-    "label": inline,
-    "legend": inline,
-    "li": flow,
-    "map": block + ["area"],
-    "menu": ["li"],
-    "noframes": flow,
-    "noscript": flow,
-    "object": flow + ["param"],
-    "ol": ["li"],
-    "optgroup": ["option"],
-    "option": [],
-    "p": inline,
-    "pre": inline,
-    "q": inline,
-    "s": inline,
-    "samp": inline,
-    "script": [],
-    "select": ["optgroup", "option"],
-    "small": inline,
-    "span": inline,
-    "strike": inline,
-    "strong": inline,
-    "style": [],
-    "sub": inline,
-    "sup": inline,
-    "table": ["caption", "col", "colgroup", "thead", "tfoot", "tbody"],
-    "tbody": ["tr"],
-    "td": flow,
-    "textarea": [],
-    "tfoot": ["tr"],
-    "th": flow,
-    "thead": ["tr"],
-    "title": [],
-    "tr": ["th", "td"],
-    "tt": inline,
-    "u": inline,
-    "ul": ["li"],
-    "var": inline
-allowed = setify(allowed)
-allowed = omit(allowed, omit_start)
-excluded = {
-    "a": ["a"],
-    "button": formctrl + ["a", "form", "isindex", "fieldset", "iframe"],
-    "dir": block,
-    "form": ["form"],
-    "label": ["label"],
-    "menu": block,
-    "pre": pre_exclusion
-excluded = setify(excluded)
-styles = {
-    'b':        "\\fB@\\fR",
-    'i':        "\\fI@\\fR",
-    'em':       "\\fI@\\fR",
-    'code':     "\\fC@\\fR",
-    'span':     "\\fC@\\fR",
-    'sup':      "\\u@\\d",
-    'hr':       ""
-formats = {
-    'br':       "\n.br\n",
-    'h2':       "\n.SH @",
-    'h3':       "\n.SS @",
-    'h4':       "\n.SS @",
-    'dt':       ("\n.IP \"@\" 4m", 'no_nl'),
-    'dd':       "\n.br\n@",
-    'ul':       ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'menu':     ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'dir':      ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'ol':       ("\n.IP\n@\n.PP\n", 'index'),
-    'p':        "\n.PP\n@",
-    'pre':      ("\n.br\n.nf\n\\fC\n@\n\\fR\n.fi\n", 'preformat')
-formats.update(styles)
-def is_string(x):
-    return isinstance(x, types.StringType)
-def is_tuple(x):
-    return isinstance(x, types.TupleType)
-def is_list(x):
-    return isinstance(x, types.ListType)
-def is_blank(s):
-    return is_string(s) and s.strip() == ""
-def clean(content):
-    return [item for item in content if not is_blank(item)]
-class Formatter:
-    def __init__(self, filename, stream = sys.stdout):
-	self.stream = stream
-	self.style = dict(preformat = False,
-			  in_ul = False,
-			  no_nl = False,
-			  in_table = False,
-			  in_tr = False,
-			  index = [])
-	self.stack = []
-	self.strip_re = re.compile("^[ \t]+")
-	self.filename = filename
-	self.at_bol = True
-    def warning(self, msg):
-	sys.stderr.write(msg + '\n')
-    def set(self, var, val):
-	self.style[var] = val
-    def get(self, var):
-	return self.style[var]
-    def push(self, **kwargs):
-	self.stack.append(self.style.copy())
-	self.style.update(**kwargs)
-    def pop(self):
-	self.style = self.stack.pop()
-    def show(self, s):
-	self.stream.write(s)
-	if s != '':
-	    self.at_bol = s.endswith('\n')
-    def pp_with(self, content, var, val):
-	self.push()
-	self.set(var, val)
-	self.pp(content)
-	self.pop()
-    def fmt(self, format, content, var = None):
-	# String.partition is only in 2.5+
-	# (pre,sep,post) = format.partition("@")
-	if self.get('no_nl') and '\n' in format:
-	    self.warning("can't handle line breaks in <dt>...</dt>")
-	    format = "@"
-	f = format.split('@', 1)
-	pre = f[0]
-	if len(f) > 1:
-	    sep = '@'
-	    post = f[1]
-	else:
-	    sep = ''
-	    post = ''
-	if pre != "":
-	    self.show(pre)
-	if sep != "":
-	    if var:
-		if var == 'index':
-		    val = self.get('index') + [0]
-		else:
-		    val = True
-		self.pp_with(content, var, val)
-	    else:
-		self.pp(content)
-	if post != "":
-	    self.show(post)
-    def pp_li(self, content):
-	if self.get('in_ul'):
-	    self.fmt("\n.IP \(bu 4n\n@", content)
-	else:
-	    idx = self.get('index')
-	    idx[-1] += 1
-	    sec = ".".join(map(str,idx))
-	    self.show("\n.IP \\fB%s\\fR\n" % sec)
-	    self.set('index', idx)
-	    self.pp(content)
-    def pp_title(self):
-	self.show("\n.TH " +
-		  os.path.basename(self.filename).replace(".html","") +
-		  " 1 \"\" \"GRASS " +
-		  version +
-		  "\" \"Grass User's Manual\"")
-    def pp_tr(self, content):
-	content = clean(content)
-	self.push(in_tr = True)
-	col = 0
-	for item in content:
-	    if not is_tuple(item):
-		self.warning("invalid item in table row: %s" % str(item))
-		continue
-	    (tag, tail) = item
-	    if tag not in ['td', 'th']:
-		self.warning("invalid tag in table row: %s" % tag)
-		continue
-	    if col > 0:
-		self.show("\t \t")
-	    self.show("T{\n")
-	    self.pp(tail)
-	    self.show("\nT}")
-	    col += 1
-	self.show("\n")
-	self.pop()
-    def pp_tbody(self, content):
-	    if is_tuple(item):
-		if tag in ['thead', 'tbody', 'tfoot']:
-		    self.pp_tbody(tail)
-		elif tag == 'tr':
-		    self.pp_tr(tail)
-		    self.show(".sp 1\n")
-    def count_cols(self, content):
-	cols = 0
-	    n = 0
-	    if is_blank(item):
-		pass
-	    elif is_tuple(item):
-		    n = self.count_cols(tail)
-		elif tag == 'tr':
-		    n = len(clean(tail))
-		cols = max(cols, n)
-	    else:
-		self.warning("invalid item in table: %s" % str(item))
-	return cols
-    def pp_table(self, content):
-	cols = self.count_cols(content)
-	if cols == 0:
-	    return
-	self.show("\n.TS\nexpand;\n")
-	self.show(" lw1 ".join(["lw60" for i in range(cols)]) + ".\n")
-	self.pp_tbody(content)
-	self.show("\n.TE\n")
-    def pp_tag(self, tag, content):
-	if self.get('in_tr') and tag not in styles:
-	    self.pp(content)
-	elif tag in formats:
-	    spec = formats[tag]
-	    if is_string(spec):
-		self.fmt(spec, content)
-	    else:
-		(fmt, var) = spec
-		self.fmt(fmt, content, var)
-	elif tag == 'table':
-	    if self.get('in_table'):
-		self.warning("cannot handle nested tables")
-		return
-	    self.push(in_table = True)
-	    self.pp_table(content)
-	    self.pop()
-	elif tag == 'li':
-	    self.pp_li(content)
-	elif tag == 'title':
-	    self.pp_title()
-	else:
-	    self.pp(content)
-    def pp_string(self, content):
-	if content == "":
-	    return
-	s = content
-	if self.get('no_nl'):
-	    s = s.replace("\n"," ")
-	s = s.replace("\\", "\\(rs")
-	s = s.replace("'", "\\(cq")
-	s = s.replace("\"", "\\(dq")
-	s = s.replace("`", "\\(ga")
-	s = s.replace("-", "\\-")
-	if self.at_bol and s[0] in [".","'"]:
-	    s = "\\&" + s
-	self.show(s)
-    def pp_text(self, content):
-	if content == "":
-	    return
-	lines = content.splitlines(True)
-	if len(lines) != 1:
-	    for line in lines:
-		self.pp_text(line)
-	    return
-	else:
-	    content = lines[0]
-	if self.at_bol and not self.get('preformat'):
-	    content = self.strip_re.sub('', content)
-	self.pp_string(content)
-    def pp_list(self, content):
-	    self.pp(item)
-    def pp(self, content):
-	if is_list(content):
-	    self.pp_list(content)
-	elif is_tuple(content):
-	    (head, tail) = content
-	    self.pp_tag(head, tail)
-	elif is_string(content):
-	    self.pp_text(content)
-class MyHTMLParser(HTMLParser):
-    def __init__(self):
-	HTMLParser.__init__(self)
-	self.tag_stack = []
-	self.excluded = frozenset()
-	self.excluded_stack = []
-	self.data = []
-	self.data_stack = []
-    def top(self):
-	if self.tag_stack == []:
-	    return None
-	else:
-	    return self.tag_stack[-1]
-    def pop(self):
-	self.excluded = self.excluded_stack.pop()
-	data = self.data
-	self.data = self.data_stack.pop()
-	tag = self.tag_stack.pop()
-	self.append((tag, data))
-	return tag
-    def push(self, tag):
-	self.tag_stack.append(tag)
-	self.excluded_stack.append(self.excluded)
-	if tag in excluded:
-	    self.excluded = self.excluded.union(excluded[tag])
-	self.data_stack.append(self.data)
-	self.data = []
-    def append(self, item):
-	self.data.append(item)
-    def is_allowed(self, tag):
-	return tag not in self.excluded and tag in allowed[self.top()]
-    def handle_starttag(self, tag, attrs):
-	if self.tag_stack != []:
-	    while not self.is_allowed(tag):
-		self.pop()
-	if tag not in single:
-	    self.push(tag)
-	else:
-	    self.append((tag,None))
-    def handle_entityref(self, name):
-	if name in entities:
-	    self.handle_data(entities[name])
-	elif name in entitydefs:
-	    self.handle_data(entitydefs[name])
-	else:
-	    sys.stderr.write("unrecognized entity: %s\n" % name)
-    def handle_charref(self, name):
-	sys.stderr.write('unsupported character reference <%s>' % name);
-    def handle_data(self, data):
-	self.append(data)
-    def handle_endtag(self, tag):
-	while True:
-	    if self.pop() == tag:
-		break
 def main():
     # parse HTML
     infile = sys.argv[1]
     inf = file(infile)
-    p = MyHTMLParser()
+    p = HTMLParser(entities)
     for n, line in enumerate(inf):
 	try:
 	    p.feed(line)
@@ -486,7 +22,7 @@
 	    sys.stderr.write('%s:%d:%d: Parse error: %s\n' % (infile, err.lineno, err.offset, err.msg))
 	    sys.exit(1)
 	except Exception, err:
-	    sys.stderr.write('%s:%d:0: Error (%s): %s\n' % (infile, n + 1, err.__dict__, line))
+	    sys.stderr.write('%s:%d:0: Error (%s): %s\n' % (infile, n + 1, repr(err), line))
 	    sys.exit(1)
     p.close()
     inf.close()
Added: grass/trunk/tools/g.html2man/groff.py
--- grass/trunk/tools/g.html2man/groff.py	                        (rev 0)
+++ grass/trunk/tools/g.html2man/groff.py	2010-09-27 15:19:02 UTC (rev 43707)
@@ -0,0 +1,265 @@
+import sys
+import os
+import re
+__all__ = ["Formatter"]
+try:
+    version = os.environ['VERSION_NUMBER']
+except:
+    version = ""
+styles = {
+    'b':        "\\fB@\\fR",
+    'i':        "\\fI@\\fR",
+    'em':       "\\fI@\\fR",
+    'code':     "\\fC@\\fR",
+    'span':     "\\fC@\\fR",
+    'sup':      "\\u@\\d",
+    'hr':       ""
+formats = {
+    'br':       "\n.br\n",
+    'h2':       "\n.SH @",
+    'h3':       "\n.SS @",
+    'h4':       "\n.SS @",
+    'dt':       ("\n.IP \"@\" 4m", 'no_nl'),
+    'dd':       "\n.br\n@",
+    'ul':       ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'menu':     ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'dir':      ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'ol':       ("\n.IP\n@\n.PP\n", 'index'),
+    'p':        "\n.PP\n@",
+    'pre':      ("\n.br\n.nf\n\\fC\n@\n\\fR\n.fi\n", 'preformat')
+formats.update(styles)
+def is_string(x):
+    return isinstance(x, str)
+def is_tuple(x):
+    return isinstance(x, tuple)
+def is_list(x):
+    return isinstance(x, list)
+def is_blank(s):
+    return is_string(s) and s.strip() == ""
+def clean(content):
+    return [item for item in content if not is_blank(item)]
+class Formatter:
+    def __init__(self, filename, stream = sys.stdout):
+	self.stream = stream
+	self.style = dict(preformat = False,
+			  in_ul = False,
+			  no_nl = False,
+			  in_table = False,
+			  in_tr = False,
+			  index = [])
+	self.stack = []
+	self.strip_re = re.compile("^[ \t]+")
+	self.filename = filename
+	self.at_bol = True
+    def warning(self, msg):
+	sys.stderr.write(msg + '\n')
+    def set(self, var, val):
+	self.style[var] = val
+    def get(self, var):
+	return self.style[var]
+    def push(self, **kwargs):
+	self.stack.append(self.style.copy())
+	self.style.update(**kwargs)
+    def pop(self):
+	self.style = self.stack.pop()
+    def show(self, s):
+	self.stream.write(s)
+	if s != '':
+	    self.at_bol = s.endswith('\n')
+    def pp_with(self, content, var, val):
+	self.push()
+	self.set(var, val)
+	self.pp(content)
+	self.pop()
+    def fmt(self, format, content, var = None):
+	# String.partition is only in 2.5+
+	# (pre,sep,post) = format.partition("@")
+	if self.get('no_nl') and '\n' in format:
+	    self.warning("can't handle line breaks in <dt>...</dt>")
+	    format = "@"
+	f = format.split('@', 1)
+	pre = f[0]
+	if len(f) > 1:
+	    sep = '@'
+	    post = f[1]
+	else:
+	    sep = ''
+	    post = ''
+	if pre != "":
+	    self.show(pre)
+	if sep != "":
+	    if var:
+		if var == 'index':
+		    val = self.get('index') + [0]
+		else:
+		    val = True
+		self.pp_with(content, var, val)
+	    else:
+		self.pp(content)
+	if post != "":
+	    self.show(post)
+    def pp_li(self, content):
+	if self.get('in_ul'):
+	    self.fmt("\n.IP \(bu 4n\n@", content)
+	else:
+	    idx = self.get('index')
+	    idx[-1] += 1
+	    sec = ".".join(map(str,idx))
+	    self.show("\n.IP \\fB%s\\fR\n" % sec)
+	    self.set('index', idx)
+	    self.pp(content)
+    def pp_title(self):
+	self.show("\n.TH " +
+		  os.path.basename(self.filename).replace(".html","") +
+		  " 1 \"\" \"GRASS " +
+		  version +
+		  "\" \"Grass User's Manual\"")
+    def pp_tr(self, content):
+	content = clean(content)
+	self.push(in_tr = True)
+	col = 0
+	for item in content:
+	    if not is_tuple(item):
+		self.warning("invalid item in table row: %s" % str(item))
+		continue
+	    (tag, attrs, body) = item
+	    if tag not in ['td', 'th']:
+		self.warning("invalid tag in table row: %s" % tag)
+		continue
+	    if col > 0:
+		self.show("\t \t")
+	    self.show("T{\n")
+	    self.pp(body)
+	    self.show("\nT}")
+	    col += 1
+	self.show("\n")
+	self.pop()
+    def pp_tbody(self, content):
+	    if is_tuple(item):
+		if tag in ['thead', 'tbody', 'tfoot']:
+		    self.pp_tbody(body)
+		elif tag == 'tr':
+		    self.pp_tr(body)
+		    self.show(".sp 1\n")
+    def count_cols(self, content):
+	cols = 0
+	    n = 0
+	    if is_blank(item):
+		pass
+	    elif is_tuple(item):
+		    n = self.count_cols(body)
+		elif tag == 'tr':
+		    n = len(clean(body))
+		cols = max(cols, n)
+	    else:
+		self.warning("invalid item in table: %s" % str(item))
+	return cols
+    def pp_table(self, content):
+	cols = self.count_cols(content)
+	if cols == 0:
+	    return
+	self.show("\n.TS\nexpand;\n")
+	self.show(" lw1 ".join(["lw60" for i in range(cols)]) + ".\n")
+	self.pp_tbody(content)
+	self.show("\n.TE\n")
+    def pp_tag(self, tag, content):
+	if self.get('in_tr') and tag not in styles:
+	    self.pp(content)
+	elif tag in formats:
+	    spec = formats[tag]
+	    if is_string(spec):
+		self.fmt(spec, content)
+	    else:
+		(fmt, var) = spec
+		self.fmt(fmt, content, var)
+	elif tag == 'table':
+	    if self.get('in_table'):
+		self.warning("cannot handle nested tables")
+		return
+	    self.push(in_table = True)
+	    self.pp_table(content)
+	    self.pop()
+	elif tag == 'li':
+	    self.pp_li(content)
+	elif tag == 'title':
+	    self.pp_title()
+	else:
+	    self.pp(content)
+    def pp_string(self, content):
+	if content == "":
+	    return
+	s = content
+	if self.get('no_nl'):
+	    s = s.replace("\n"," ")
+	s = s.replace("\\", "\\(rs")
+	s = s.replace("'", "\\(cq")
+	s = s.replace("\"", "\\(dq")
+	s = s.replace("`", "\\(ga")
+	s = s.replace("-", "\\-")
+	if self.at_bol and s[0] in [".","'"]:
+	    s = "\\&" + s
+	self.show(s)
+    def pp_text(self, content):
+	if content == "":
+	    return
+	lines = content.splitlines(True)
+	if len(lines) != 1:
+	    for line in lines:
+		self.pp_text(line)
+	    return
+	else:
+	    content = lines[0]
+	if self.at_bol and not self.get('preformat'):
+	    content = self.strip_re.sub('', content)
+	self.pp_string(content)
+    def pp_list(self, content):
+	    self.pp(item)
+    def pp(self, content):
+	if is_list(content):
+	    self.pp_list(content)
+	elif is_tuple(content):
+	    (tag, attrs, body) = content
+	    self.pp_tag(tag, body)
+	elif is_string(content):
+	    self.pp_text(content)
Added: grass/trunk/tools/g.html2man/html.py
--- grass/trunk/tools/g.html2man/html.py	                        (rev 0)
+++ grass/trunk/tools/g.html2man/html.py	2010-09-27 15:19:02 UTC (rev 43707)
@@ -0,0 +1,214 @@
+import sys
+import HTMLParser as base
+import htmlentitydefs
+HTMLParseError = base.HTMLParseError
+__all__ = ["HTMLParser", "HTMLParseError"]
+omit_start = ["body", "tbody", "head", "html"]
+single = ["area", "base", "basefont", "br", "col", "frame",
+	  "hr", "img", "input", "isindex", "link", "meta", "param"]
+single = frozenset(single)
+heading = ["h1", "h2", "h3", "h4", "h5", "h6"]
+fontstyle = ["tt", "i", "b", "u", "s", "strike", "big", "small"]
+phrase = [ "em", "strong", "dfn", "code", "samp", "kbd", "var", "cite", "abbr",
+	   "acronym"]
+special = [ "a", "img", "applet", "object", "font", "basefont", "br", "script",
+	    "map", "q", "sub", "sup", "span", "bdo", "iframe"]
+formctrl = [ "input", "select", "textarea", "label", "button"]
+lists = [ "ul", "ol", " dir", "menu"]
+head_misc = [ "script", "style", "meta", "link", "object"]
+pre_exclusion = [ "img", "object", "applet", "big", "small", "sub", "sup",
+		  "font", "basefont"]
+block = [ "p", "pre", "dl", "div", "center", "noscript", "noframes",
+	  "blockquote", "form", "isindex", "hr", "table", "fieldset",
+	  "address"] + heading + lists
+inline = fontstyle + phrase + special + formctrl
+flow = block + inline
+html_content = ["head", "body"]
+head_content = ["title", "isindex", "base"]
+def setify(d):
+    return dict([(key, frozenset(val)) for key, val in d.iteritems()])
+def omit(allowed, tags):
+    result = {}
+    for k, v in allowed.iteritems():
+	for t in tags:
+	    if t in v:
+		v = v.union(allowed[t])
+	result[k] = v
+    return result
+allowed = {
+    "a": inline,
+    "abbr": inline,
+    "acronym": inline,
+    "address": inline + ["p"],
+    "applet": flow + ["param"],
+    "b": inline,
+    "bdo": inline,
+    "big": inline,
+    "blockquote": flow,
+    "body": flow + ["ins", "del"],
+    "button": flow,
+    "caption": inline,
+    "center": flow,
+    "cite": inline,
+    "code": inline,
+    "colgroup": ["col"],
+    "dd": flow,
+    "del": flow,
+    "dfn": inline,
+    "dir": ["li"],
+    "div": flow,
+    "dl": ["dt", "dd"],
+    "dt": inline,
+    "em": inline,
+    "fieldset": flow + ["legend"],
+    "font": inline,
+    "form": flow,
+    "frameset": ["frameset", "frame", "noframes"],
+    "h1": inline,
+    "h2": inline,
+    "h3": inline,
+    "h4": inline,
+    "h5": inline,
+    "h6": inline,
+    "head": head_content + head_misc,
+    "html": html_content,
+    "i": inline,
+    "iframe": flow,
+    "ins": flow,
+    "kbd": inline,
+    "label": inline,
+    "legend": inline,
+    "li": flow,
+    "map": block + ["area"],
+    "menu": ["li"],
+    "noframes": flow,
+    "noscript": flow,
+    "object": flow + ["param"],
+    "ol": ["li"],
+    "optgroup": ["option"],
+    "option": [],
+    "p": inline,
+    "pre": inline,
+    "q": inline,
+    "s": inline,
+    "samp": inline,
+    "script": [],
+    "select": ["optgroup", "option"],
+    "small": inline,
+    "span": inline,
+    "strike": inline,
+    "strong": inline,
+    "style": [],
+    "sub": inline,
+    "sup": inline,
+    "table": ["caption", "col", "colgroup", "thead", "tfoot", "tbody"],
+    "tbody": ["tr"],
+    "td": flow,
+    "textarea": [],
+    "tfoot": ["tr"],
+    "th": flow,
+    "thead": ["tr"],
+    "title": [],
+    "tr": ["th", "td"],
+    "tt": inline,
+    "u": inline,
+    "ul": ["li"],
+    "var": inline
+allowed = setify(allowed)
+allowed = omit(allowed, omit_start)
+excluded = {
+    "a": ["a"],
+    "button": formctrl + ["a", "form", "isindex", "fieldset", "iframe"],
+    "dir": block,
+    "form": ["form"],
+    "label": ["label"],
+    "menu": block,
+    "pre": pre_exclusion
+excluded = setify(excluded)
+class HTMLParser(base.HTMLParser):
+    def __init__(self, entities = None):
+	base.HTMLParser.__init__(self)
+	self.tag_stack = []
+	self.excluded = frozenset()
+	self.excluded_stack = []
+	self.data = []
+	self.data_stack = []
+        self.decls = []
+        if entities:
+            self.entities = entities
+        else:
+            self.entities = {}
+    def top(self):
+	if self.tag_stack == []:
+	    return None
+	else:
+	    return self.tag_stack[-1][0]
+    def pop(self):
+	self.excluded = self.excluded_stack.pop()
+	data = self.data
+	self.data = self.data_stack.pop()
+	(tag, attrs) = self.tag_stack.pop()
+	self.append((tag, attrs, data))
+	return tag
+    def push(self, tag, attrs):
+	self.tag_stack.append((tag, attrs))
+	self.excluded_stack.append(self.excluded)
+	if tag in excluded:
+	    self.excluded = self.excluded.union(excluded[tag])
+	self.data_stack.append(self.data)
+	self.data = []
+    def append(self, item):
+	self.data.append(item)
+    def is_allowed(self, tag):
+	return tag not in self.excluded and tag in allowed[self.top()]
+    def handle_starttag(self, tag, attrs):
+	if self.tag_stack != []:
+	    while not self.is_allowed(tag):
+		self.pop()
+	if tag not in single:
+	    self.push(tag, attrs)
+	else:
+	    self.append((tag, attrs, None))
+    def handle_entityref(self, name):
+	if name in self.entities:
+	    self.handle_data(self.entities[name])
+	elif name in htmlentitydefs.entitydefs:
+	    self.handle_data(htmlentitydefs.entitydefs[name])
+	else:
+	    sys.stderr.write("unrecognized entity: %s\n" % name)
+    def handle_charref(self, name):
+	sys.stderr.write('unsupported character reference <%s>' % name);
+    def handle_data(self, data):
+	self.append(data)
+    def handle_endtag(self, tag):
+	while True:
+	    if self.pop() == tag:
+		break
+    def handle_decl(self, decl):
+        self.decls.append(decl)
