[GRASS-SVN] r43710 - grass/branches/releasebranch_6_4/vector/v.in.ogr
Mon Sep 27 14:03:56 EDT 2010
Author: mmetz
Date: 2010-09-27 18:03:56 +0000 (Mon, 27 Sep 2010)
New Revision: 43710
   grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c
   grass/branches/releasebranch_6_4/vector/v.in.ogr/global.h
   grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
Radim's TODO: split lines before breaking lines
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c	2010-09-27 18:02:01 UTC (rev 43709)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/geom.c	2010-09-27 18:03:56 UTC (rev 43710)
@@ -25,6 +25,8 @@
 #include "ogr_api.h"
 #include "global.h"
+int split_line(struct Map_info *Map, int otype, struct line_pnts *Points,
+	       struct line_cats *Cats);
 /* Add categories to centroids inside polygon */
 int
@@ -166,6 +168,35 @@
     return 0;
+/* count polygons and isles */
+int poly_count(OGRGeometryH hGeom)
+    int i, nr, ret;
+    OGRwkbGeometryType eType;
+    OGRGeometryH hRing;
+    eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
+    if (eType == wkbPolygon) {
+	G_debug(3, "Polygon");
+	nr = OGR_G_GetGeometryCount(hGeom);
+	n_polygon_boundaries += nr;
+    else if (eType == wkbGeometryCollection || eType == wkbMultiPolygon) {
+	G_debug(3, "GeometryCollection or MultiPolygon");
+	for (i = 0; i < nr; i++) {
+	    hRing = OGR_G_GetGeometryRef(hGeom, i);
+	    ret = poly_count(hRing);
+	    if (ret == -1) {
+		G_warning(_("Cannot read part of geometry"));
+    return 0;
 /* Write geometry to output map */
 int
 geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
@@ -223,7 +254,11 @@
 	    otype = GV_BOUNDARY;
 	else
 	    otype = GV_LINE;
-	Vect_write_line(Map, otype, Points, Cats);
+	if (split_distance > 0 && otype == GV_BOUNDARY)
+	    split_line(Map, otype, Points, Cats);
+	else
+	    Vect_write_line(Map, otype, Points, Cats);
     else if (eType == wkbPolygon) {
@@ -256,7 +291,7 @@
 	size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
 	if (size < min_area) {
-	    G_warning(_("Area size [%.1e], area not imported"), size);
+	    G_debug(2, "Area size [%.1e], area not imported", size);
 	    return 0;
@@ -264,8 +299,12 @@
 	    otype = GV_LINE;
 	else
-	Vect_write_line(Map, otype, Points, BCats);
+	    split_line(Map, otype, Points, BCats);
+	else
+	    Vect_write_line(Map, otype, Points, BCats);
 	/* Isles */
 	IPoints =
 	    (struct line_pnts **)G_malloc((nr - 1) *
@@ -298,7 +337,7 @@
 				      IPoints[valid_isles]->y,
 				      IPoints[valid_isles]->n_points);
-		    G_warning(_("Island size [%.1e], island not imported"),
+		    G_debug(2, "Island size [%.1e], island not imported",
 			      size);
 		else {
@@ -306,7 +345,11 @@
 			otype = GV_LINE;
 		    else
-		    Vect_write_line(Map, otype, IPoints[valid_isles], BCats);
+			split_line(Map, otype, IPoints[valid_isles], BCats);
+		    else
+			Vect_write_line(Map, otype, IPoints[valid_isles],
+					BCats);
 		valid_isles++;
@@ -383,3 +426,52 @@
     return 0;
+    int i;
+    double dist = 0., seg_dist, dx, dy;
+    struct line_pnts *OutPoints;
+    /* don't write zero length boundaries */
+    Vect_line_prune(Points);
+    if (Points->n_points < 2)
+	return 0;
+    /* can't split boundaries with only 2 vertices */
+    if (Points->n_points == 2) {
+	return 0;
+    OutPoints = Vect_new_line_struct();
+    Vect_append_point(OutPoints, Points->x[0], Points->y[0], Points->z[0]);
+    Vect_append_point(OutPoints, Points->x[1], Points->y[1], Points->z[1]);
+    dx = Points->x[1] - Points->x[0];
+    dy = Points->y[1] - Points->y[0];
+    dist = sqrt(dx * dx + dy * dy);
+    /* trying to keep line length smaller than split_distance
+     * alternative, less code: write line as soon as split_distance is exceeded */
+    for (i = 2; i < Points->n_points; i++) {
+	dx = Points->x[i] - Points->x[i - 1];
+	dy = Points->y[i] - Points->y[i - 1];
+	seg_dist = sqrt(dx * dx + dy * dy);
+	dist += seg_dist;
+	if (dist > split_distance) {
+	    Vect_write_line(Map, otype, OutPoints, Cats);
+	    Vect_reset_line(OutPoints);
+	    dist = seg_dist;
+	    Vect_append_point(OutPoints, Points->x[i - 1], Points->y[i - 1],
+			      Points->z[i - 1]);
+	Vect_append_point(OutPoints, Points->x[i], Points->y[i],
+			  Points->z[i]);
+    Vect_destroy_line_struct(OutPoints);
+    return 0;
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/global.h
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/global.h	2010-09-27 18:02:01 UTC (rev 43709)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/global.h	2010-09-27 18:03:56 UTC (rev 43710)
@@ -26,8 +26,12 @@
 #ifdef MAIN
 int n_polygons = 0;
+int n_polygon_boundaries;
+double split_distance;
 #else
 extern int n_polygons;
+extern int n_polygon_boundaries;
+extern double split_distance;
 #endif
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2010-09-27 18:02:01 UTC (rev 43709)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2010-09-27 18:03:56 UTC (rev 43710)
@@ -41,6 +41,7 @@
 	 double min_area, int type, int mk_centr);
 int centroid(OGRGeometryH hGeom, CENTR * Centr, SPATIAL_INDEX * Sindex,
 	     int field, int cat, double min_area, int type);
+int poly_count(OGRGeometryH hGeom);
 int main(int argc, char *argv[])
@@ -55,7 +56,7 @@
     struct Flag *list_flag, *no_clean_flag, *z_flag, *notab_flag,
 	*region_flag;
     struct Flag *over_flag, *extend_flag, *formats_flag, *tolower_flag;
-    char buf[2000], namebuf[2000];
+    char buf[2000], namebuf[2000], tempvect[2000];
     char *separator;
     struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
     struct Key_Value *proj_info, *proj_units;
@@ -63,7 +64,7 @@
     char error_msg[8192];
     /* Vector */
-    struct Map_info Map;
+    struct Map_info Map, Tmp;
     int cat;
     /* Attributes */
@@ -92,6 +93,7 @@
     int navailable_layers;
     int layer_id;
     int overwrite;
+    double area_size = 0.;
     G_gisinit(argv[0]);
@@ -456,6 +458,16 @@
 	cellhd.tb_res = 1.;
+    /* split boundaries only when cleaning */
+    if (no_clean_flag->answer) {
+	split_distance = -1.;
+    else {
+	split_distance = 0.;
+	area_size =
+	    sqrt((cellhd.east - cellhd.west) * (cellhd.north - cellhd.south));
     /* Fetch input map projection in GRASS form. */
     proj_info = NULL;
     proj_units = NULL;
@@ -586,10 +598,24 @@
     db_init_string(&strval);
     /* open output vector */
-    if (z_flag->answer)
+    /* open temporary vector, do the work in the temporary vector
+     * at the end copy alive lines to output vector
+     * in case of polygons this reduces the coor file size by a factor of 2 to 5
+     * only needed for polygons, but the presence of polygons can be detected
+     * only during OGR feature import, not before */
+    sprintf(buf, "%s", out_opt->answer);
+    /* strip any @mapset from vector output name */
+    G_find_vector(buf, G_mapset());
+    sprintf(tempvect, "%s_tmp", buf);
+    G_verbose_message(_("Using temporary vector <%s>"), tempvect);
+    if (z_flag->answer) {
 	Vect_open_new(&Map, out_opt->answer, 1);
-    else
+	Vect_open_new(&Tmp, tempvect, 1);
+    else {
 	Vect_open_new(&Map, out_opt->answer, 0);
+	Vect_open_new(&Tmp, tempvect, 0);
     Vect_hist_command(&Map);
@@ -622,7 +648,7 @@
 	    if (ncnames > 0) {
 		cat_col_name = cnames_opt->answers[0];
-	    Vect_map_add_dblink(&Map, layer + 1, NULL, Fi->table,
+	    Vect_map_add_dblink(&Map, layer + 1, layer_names[layer], Fi->table,
 				cat_col_name, Fi->database, Fi->driver);
 	    ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
@@ -782,9 +808,45 @@
 	cat = 1;
 	nogeom = 0;
 	OGR_L_ResetReading(Ogr_layer);
-	G_important_message(_("Importing map %d features..."),
-			    OGR_L_GetFeatureCount(Ogr_layer, 1));
+	unsigned int n_features = 0, feature_count = 0;
+	n_polygon_boundaries = 0;
+	n_features = OGR_L_GetFeatureCount(Ogr_layer, 1);
+	/* estimate distance for boundary splitting --> */
+	if (split_distance > -0.5) {
+	    /* count polygons and isles */
+	    G_message(_("Counting polygons for %d features..."), n_features);
+	    while ((Ogr_feature = OGR_L_GetNextFeature(Ogr_layer)) != NULL) {
+		G_percent(feature_count++, n_features, 1);	/* show something happens */
+		/* Geometry */
+		Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
+		if (Ogr_geometry != NULL) {
+		    poly_count(Ogr_geometry);
+		OGR_F_Destroy(Ogr_feature);
+	    /* rewind layer */
+	    OGR_L_ResetReading(Ogr_layer);
+	    feature_count = 0;
+	G_debug(1, "n polygon boundaries: %d", n_polygon_boundaries);
+	if (split_distance > -0.5 && n_polygon_boundaries > 50) {
+	    split_distance =
+		area_size / log(n_polygon_boundaries);
+	    /* divisor is the handle: increase divisor to decrease split_distance */
+	    split_distance = split_distance / 4.;
+	    G_debug(1, "root of area size: %f", area_size);
+	    G_verbose_message(_("Boundary splitting distance in map units: %G"),
+		      split_distance);
+	/* <-- estimate distance for boundary splitting */
+	G_important_message(_("Importing map %d features..."), n_features);
 	    /* Geometry */
 	    if (Ogr_geometry == NULL) {
@@ -795,7 +857,7 @@
 		if (dim > 2)
 		    with_z = 1;
-		geom(Ogr_geometry, &Map, layer + 1, cat, min_area, type,
+		geom(Ogr_geometry, &Tmp, layer + 1, cat, min_area, type,
 		     no_clean_flag->answer);
@@ -869,6 +931,7 @@
 	    cat++;
+	G_percent(n_features, n_features, 1);	/* finish it */
 	if (!notab_flag->answer) {
 	    db_commit_transaction(driver);
@@ -885,10 +948,11 @@
     G_message("%s", separator);
     /* TODO: is it necessary to build here? probably not, consumes time */
-    Vect_build(&Map);
+    /* GV_BUILD_BASE is sufficient to toggle boundary cleaning */
+    Vect_build_partial(&Tmp, GV_BUILD_BASE);
     if (!no_clean_flag->answer &&
-	Vect_get_num_primitives(&Map, GV_BOUNDARY) > 0) {
+	Vect_get_num_primitives(&Tmp, GV_BOUNDARY) > 0) {
 	int ret, centr, ncentr, otype, n_overlaps, n_nocat;
 	CENTR *Centr;
 	SPATIAL_INDEX si;
@@ -902,15 +966,10 @@
 	G_warning(_("Cleaning polygons, result is not guaranteed!"));
-	Vect_set_release_support(&Map);
-	Vect_close(&Map);
-	Vect_open_update(&Map, out_opt->answer, G_mapset());
-	Vect_build_partial(&Map, GV_BUILD_BASE);	/* Downgrade topo */
 	if (snap >= 0) {
 	    G_message(_("Snap boundaries (threshold = %.3e):"), snap);
-	    Vect_snap_lines(&Map, GV_BOUNDARY, snap, NULL);
+	    Vect_snap_lines(&Tmp, GV_BOUNDARY, snap, NULL);
 	/* It is not to clean to snap centroids, but I have seen data with 2 duplicate polygons
@@ -924,57 +983,64 @@
 	G_message(_("Break polygons:"));
-	Vect_break_polygons(&Map, GV_BOUNDARY, NULL);
+	Vect_break_polygons(&Tmp, GV_BOUNDARY, NULL);
-	/* It is important to remove also duplicate centroids in case of duplicate imput polygons */
+	/* It is important to remove also duplicate centroids in case of duplicate input polygons */
 	G_message(_("Remove duplicates:"));
-	Vect_remove_duplicates(&Map, GV_BOUNDARY | GV_CENTROID, NULL);
+	Vect_remove_duplicates(&Tmp, GV_BOUNDARY | GV_CENTROID, NULL);
+	/* split boundaries here ? */
 	/* Vect_clean_small_angles_at_nodes() can change the geometry so that new intersections
 	 * are created. We must call Vect_break_lines(), Vect_remove_duplicates()
-	 * and Vect_clean_small_angles_at_nodes() until no more small dangles are found */
+	 * and Vect_clean_small_angles_at_nodes() until no more small angles are found */
 	do {
 	    G_message(_("Break boundaries:"));
-	    Vect_break_lines(&Map, GV_BOUNDARY, NULL);
+	    Vect_break_lines(&Tmp, GV_BOUNDARY, NULL);
-	    Vect_remove_duplicates(&Map, GV_BOUNDARY, NULL);
+	    Vect_remove_duplicates(&Tmp, GV_BOUNDARY, NULL);
 	    G_message(_("Clean boundaries at nodes:"));
 	    nmodif =
-		Vect_clean_small_angles_at_nodes(&Map, GV_BOUNDARY, NULL);
+		Vect_clean_small_angles_at_nodes(&Tmp, GV_BOUNDARY, NULL);
 	} while (nmodif > 0);
 	if (type & GV_BOUNDARY) {	/* that means lines were converted boundaries */
 	    G_message(_("Change boundary dangles to lines:"));
-	    Vect_chtype_dangles(&Map, -1.0, NULL);
+	    Vect_chtype_dangles(&Tmp, -1.0, NULL);
 	else {
 	    G_message(_("Change dangles to lines:"));
-	    Vect_remove_dangles(&Map, GV_BOUNDARY, -1.0, NULL);
+	    Vect_remove_dangles(&Tmp, GV_BOUNDARY, -1.0, NULL);
 	    G_message(_("Change boundary bridges to lines:"));
-	    Vect_chtype_bridges(&Map, NULL);
+	    Vect_chtype_bridges(&Tmp, NULL);
 	else {
 	    G_message(_("Remove bridges:"));
-	    Vect_remove_bridges(&Map, NULL);
+	    Vect_remove_bridges(&Tmp, NULL);
+	/* merge boundaries */
+	G_message("%s", separator);
+	G_message(_("Merge boundaries:"));
+	Vect_merge_lines(&Tmp, GV_BOUNDARY, NULL, NULL);
 	/* Boundaries are hopefully clean, build areas */
-	Vect_build_partial(&Map, GV_BUILD_ATTACH_ISLES);
+	Vect_build_partial(&Tmp, GV_BUILD_ATTACH_ISLES);
 	/* Calculate new centroids for all areas, centroids have the same id as area */
-	ncentr = Vect_get_num_areas(&Map);
+	ncentr = Vect_get_num_areas(&Tmp);
 	G_debug(3, "%d centroids/areas", ncentr);
 	Centr = (CENTR *) G_calloc(ncentr + 1, sizeof(CENTR));
@@ -982,7 +1048,7 @@
 	for (centr = 1; centr <= ncentr; centr++) {
 	    Centr[centr].valid = 0;
 	    Centr[centr].cats = Vect_new_cats_struct();
-	    ret = Vect_get_point_in_area(&Map, centr, &x, &y);
+	    ret = Vect_get_point_in_area(&Tmp, centr, &x, &y);
 	    if (ret < 0) {
 		G_warning(_("Cannot calculate area centroid"));
 		continue;
@@ -999,6 +1065,7 @@
 	/* Go through all layers and find centroids for each polygon */
 	for (layer = 0; layer < nlayers; layer++) {
 	    G_message(_("Layer: %s"), layer_names[layer]);
 	    layer_id = layers[layer];
 	    Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
@@ -1019,12 +1086,17 @@
 	/* Write centroids */
+	G_message(_("Write centroids:"));
 	n_overlaps = n_nocat = 0;
 	total_area = overlap_area = nocat_area = 0.0;
 	    double area;
+	    G_percent(centr, ncentr, 2);
-	    area = Vect_get_area_area(&Map, centr);
+	    area = Vect_get_area_area(&Tmp, centr);
 	    total_area += area;
 	    if (!(Centr[centr].valid)) {
@@ -1050,17 +1122,19 @@
 		otype = GV_POINT;
 	    else
 		otype = GV_CENTROID;
-	    Vect_write_line(&Map, otype, Points, Centr[centr].cats);
+	    Vect_write_line(&Tmp, otype, Points, Centr[centr].cats);
 	if (Centr)
 	    G_free(Centr);
-	G_message("%s", separator);
-	Vect_build_partial(&Map, GV_BUILD_NONE);
+	Vect_spatial_index_destroy(&si);
-	Vect_build(&Map);
+	/* G_message("%s", separator); */
+	/* Vect_build_partial(&Map, GV_BUILD_NONE); */
+	/* not needed */
+	   Vect_build(&Map); */
 	if (n_overlaps > 0) {
 	    G_warning(_("%d areas represent more (overlapping) features, because polygons overlap "
@@ -1069,29 +1143,42 @@
 		      n_overlaps, nlayers + 1);
-	sprintf(buf, _("%d input polygons"), n_polygons);
-	G_message(buf);
+	Vect_hist_write(&Map, separator);
+	Vect_hist_write(&Map, "\n");
+	sprintf(buf, _("%d input polygons\n"), n_polygons);
+	G_message(_("%d input polygons"), n_polygons);
 	Vect_hist_write(&Map, buf);
-	sprintf(buf, _("Total area: %e (%d areas)"), total_area, ncentr);
-	G_message(buf);
+	sprintf(buf, _("Total area: %G (%d areas)\n"), total_area, ncentr);
+	G_message(_("Total area: %G (%d areas)"), total_area, ncentr);
-	sprintf(buf, _("Overlapping area: %e (%d areas)"), overlap_area,
+	sprintf(buf, _("Overlapping area: %G (%d areas)\n"), overlap_area,
 		n_overlaps);
-	G_message(buf);
+	G_message(_("Overlapping area: %G (%d areas)"), overlap_area,
+		  n_overlaps);
-	sprintf(buf, _("Area without category: %e (%d areas)"), nocat_area,
+	sprintf(buf, _("Area without category: %G (%d areas)\n"), nocat_area,
 		n_nocat);
-	G_message(buf);
+	G_message(_("Area without category: %G (%d areas)"), nocat_area,
+		  n_nocat);
     /* needed?
      * OGR_DS_Destroy( Ogr_ds );
+    /* Copy temporary vector to output vector */
+    Vect_copy_map_lines(&Tmp, &Map);
+    Vect_close(&Tmp);
+    Vect_delete(tempvect);
+    Vect_build(&Map);
     Vect_close(&Map);
