[GRASS-SVN] r43719 - in grass/trunk: db/db.columns db/db.connect db/db.copy db/db.createdb db/db.databases db/db.describe db/db.drivers db/db.dropdb db/db.droptable db/db.execute db/db.login db/db.select db/db.tables db/drivers/dbf db/drivers/dbf/dbf_catalog db/drivers/mysql db/drivers/odbc db/drivers/ogr db/drivers/postgres db/drivers/sqlite display/d.barscale display/d.colorlist display/d.colors display/d.colortable display/d.erase display/d.extract display/d.font display/d.fontlist display/d.geodesic display/d.graph display/d.grid display/d.his display/d.histogram display/d.info display/d.labels display/d.legend display/d.linegraph display/d.measure display/d.nviz display/d.path display/d.profile display/d.rast display/d.rast.arrow display/d.rast.num display/d.rgb display/d.rhumbline display/d.text display/d.thematic.area display/d.title display/d.vect display/d.vect.chart display/d.what.rast display/d.what.vect display/d.where display/d.zoom general/g.access general/g.cairoc omp general/g.copy general/g.dirseps general/g.filename general/g.findetc general/g.findfile general/g.gisenv general/g.gui general/g.list general/g.mapset general/g.mapsets general/g.message general/g.mkfontcap general/g.mlist general/g.mremove general/g.parser general/g.pnmcomp general/g.proj general/g.region general/g.remove general/g.rename general/g.setproj general/g.tempfile general/g.transform general/g.version general/manage general/manage/lister imagery/i.albedo imagery/i.atcorr imagery/i.atcorr/INFO imagery/i.atcorr/test_suite imagery/i.cca imagery/i.class imagery/i.cluster imagery/i.emissivity imagery/i.fft imagery/i.find imagery/i.gensig imagery/i.gensigset imagery/i.group imagery/i.his.rgb imagery/i.ifft imagery/i.latlong imagery/i.maxlik imagery/i.modis.qc imagery/i.ortho.photo imagery/i.ortho.photo/lib imagery/i.pca imagery/i.points imagery/i.rectify imagery/i.rgb.his imagery/i.smap imagery/i.sunhours imagery/i.target imagery/i.vi imagery/i.vpoints imagery/i.z c lib/arraystats lib/bitmap lib/btree lib/cairodriver lib/cdhc lib/cluster lib/datetime lib/db lib/db/dbmi_base lib/db/dbmi_client lib/db/dbmi_driver lib/db/sqlp lib/db/sqlp/test lib/db/stubs lib/display lib/driver lib/dspf lib/external lib/external/bwidget lib/external/bwidget/images lib/external/bwidget/lang lib/external/shapelib lib/fonts lib/fonts/fonts lib/form lib/g3d lib/gis lib/gis/colors lib/gmath lib/gpde lib/gpde/test lib/gtcltk lib/htmldriver lib/imagery lib/init lib/iostream lib/lidar lib/linkm lib/manage lib/nviz lib/ogsf lib/pngdriver lib/proj lib/psdriver lib/rowio lib/rst lib/rst/data lib/rst/interp_float lib/rst/qtree lib/segment lib/sites lib/stats lib/symbol lib/symbol/symbol lib/symbol/symbol/basic lib/symbol/symbol/demo lib/symbol/symbol/extra lib/vector/Vlib lib/vector/dglib lib/vector/dglib/examples lib/vector/diglib lib/vector/rtree lib/vector/rtree/docs lib/vector/transform misc/m.cogo ps/ps.map raster/r.basins.fill raster/r.bitpattern raster/r.buff er raster/r.carve raster/r.category raster/r.circle raster/r.clump raster/r.coin raster/r.colors raster/r.colors.out raster/r.composite raster/r.compress raster/r.contour raster/r.cost raster/r.covar raster/r.cross raster/r.describe raster/r.digit raster/r.distance raster/r.drain raster/r.external raster/r.external.out raster/r.fill.dir raster/r.flow raster/r.grow raster/r.grow.distance raster/r.gwflow raster/r.his raster/r.horizon raster/r.in.arc raster/r.in.ascii raster/r.in.bin raster/r.in.gdal raster/r.in.gridatb raster/r.in.mat raster/r.in.poly raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake raster/r.le raster/r.le/r.le.patch raster/r.le/r.le.pixel raster/r.le/r.le.setup raster/r.le/r.le.setup/polytocell raster/r.le/r.le.trace raster/r.li raster/r.li/r.li.cwed raster/r.li/r.li.daemon raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa raster/r.li/r.li.mps raster/r.li/r.li.padcv raster/r.li/r.li.padrange raster/r.li/r.li.padsd raster/r .li/r.li.patchdensity raster/r.li/r.li.patchnum raster/r.li/r.li.richness raster/r.li/r.li.setup raster/r.li/r.li.shannon raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.los raster/r.mapcalc raster/r.mfilter raster/r.mode raster/r.neighbors raster/r.null raster/r.out.arc raster/r.out.ascii raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb raster/r.out.mat raster/r.out.mpeg raster/r.out.png raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3 raster/r.out.tiff raster/r.out.vrml raster/r.out.vtk raster/r.param.scale raster/r.patch raster/r.profile raster/r.proj raster/r.quant raster/r.quantile raster/r.random raster/r.random.cells raster/r.random.surface raster/r.reclass raster/r.recode raster/r.region raster/r.report raster/r.resamp.interp raster/r.resamp.rst raster/r.resamp.stats raster/r.resample raster/r.rescale raster/r.rescale.eq raster/r.ros raster/r.series raster/r.slope.aspect raster/r.spread raster/r.spreadpath raster/r.statistics raster/r.statistics2 r aster/r.statistics3 raster/r.stats raster/r.sun raster/r.sunmask raster/r.support raster/r.support.stats raster/r.surf.area raster/r.surf.contour raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2 raster/r.surf.random raster/r.terraflow raster/r.texture raster/r.thin raster/r.timestamp raster/r.to.rast3 raster/r.to.rast3elev raster/r.to.vect raster/r.topidx raster/r.topmodel raster/r.transect raster/r.univar raster/r.uslek raster/r.usler raster/r.volume raster/r.walk raster/r.water.outlet raster/r.watershed raster/r.watershed/front raster/r.watershed/ram raster/r.watershed/seg raster/r.watershed/shed raster/r.what raster/r.what.color raster/simwe raster/simwe/r.sim.sediment raster/simwe/r.sim.water raster/simwe/simlib raster/wildfire raster3d/base raster3d/r3.cross.rast raster3d/r3.gwflow raster3d/r3.in.ascii raster3d/r3.in.v5d raster3d/r3.info raster3d/r3.mkdspf raster3d/r3.out.ascii raster3d/r3.out.v5d raster3d/r3.out.vtk raster3d/r3.showdspf ra ster3d/r3.stats raster3d/r3.timestamp raster3d/r3.to.rast scripts/v.in.geonames sites/s.in.ascii sites/s.out.ascii tools/timer vector/v.buffer vector/v.build vector/v.build.polylines vector/v.category vector/v.class vector/v.clean vector/v.clean/test vector/v.convert vector/v.db.connect vector/v.db.select vector/v.delaunay vector/v.distance vector/v.drape vector/v.edit vector/v.external vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.in.ascii vector/v.in.db vector/v.in.dwg vector/v.in.dxf vector/v.in.ogr vector/v.in.region vector/v.in.sites vector/v.info vector/v.kcv vector/v.kernel vector/v.label vector/v.label.sa vector/v.lidar.correction vector/v.lidar.edgedetection vector/v.lidar.growing vector/v.lrs vector/v.lrs/lib vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.mapcalc vector/v.mapcalc/plugins vector/v.mkgrid vector/v.neighbors vector/v.net vector/v.net.alloc vector/v.net.iso vector/v.net.path vector/v.net.salesman vector/v.net.steiner vector/v.net.visibility vector/v.normal vector/v.out.ascii vector/v.out.dxf vector/v.out.ogr vector/v.out.pov vector/v.out.svg vector/v.out.vtk vector/v.outlier vector/v.overlay vector/v.parallel vector/v.patch vector/v.perturb vector/v.proj vector/v.qcount vector/v.random vector/v.reclass vector/v.sample vector/v.segment vector/v.select vector/v.split vector/v.support vector/v.surf.bspline vector/v.surf.idw vector/v.surf.rst vector/v.to.3d vector/v.to.db vector/v.to.points vector/v.to.rast vector/v.to.rast3 vector/v.transform vector/v.type vector/v.univar vector/v.vol.rst vector/v.voronoi vector/v.what vector/v.what.rast visualization/nviz visualization/nviz/src visualization/nviz2/cmd visualization/wximgview visualization/xganim visualization/ximgview
Mon Sep 27 16:48:24 EDT 2010
Author: glynn
Date: 2010-09-27 20:48:23 +0000 (Mon, 27 Sep 2010)
New Revision: 43719
   grass/trunk/db/db.columns/
   grass/trunk/db/db.connect/
   grass/trunk/db/db.copy/
   grass/trunk/db/db.createdb/
   grass/trunk/db/db.databases/
   grass/trunk/db/db.describe/
   grass/trunk/db/db.drivers/
   grass/trunk/db/db.dropdb/
   grass/trunk/db/db.droptable/
   grass/trunk/db/db.execute/
   grass/trunk/db/db.login/
   grass/trunk/db/db.select/
   grass/trunk/db/db.tables/
   grass/trunk/db/drivers/dbf/
   grass/trunk/db/drivers/dbf/dbf_catalog/
   grass/trunk/db/drivers/mysql/
   grass/trunk/db/drivers/odbc/
   grass/trunk/db/drivers/ogr/
   grass/trunk/db/drivers/postgres/
   grass/trunk/db/drivers/sqlite/
   grass/trunk/display/d.barscale/
   grass/trunk/display/d.colorlist/
   grass/trunk/display/d.colors/
   grass/trunk/display/d.colortable/
   grass/trunk/display/d.erase/
   grass/trunk/display/d.extract/
   grass/trunk/display/d.font/
   grass/trunk/display/d.fontlist/
   grass/trunk/display/d.geodesic/
   grass/trunk/display/d.graph/
   grass/trunk/display/d.grid/
   grass/trunk/display/d.his/
   grass/trunk/display/d.histogram/
   grass/trunk/display/d.info/
   grass/trunk/display/d.labels/
   grass/trunk/display/d.legend/
   grass/trunk/display/d.linegraph/
   grass/trunk/display/d.measure/
   grass/trunk/display/d.nviz/
   grass/trunk/display/d.path/
   grass/trunk/display/d.profile/
   grass/trunk/display/d.rast.arrow/
   grass/trunk/display/d.rast.num/
   grass/trunk/display/d.rast/
   grass/trunk/display/d.rgb/
   grass/trunk/display/d.rhumbline/
   grass/trunk/display/d.text/
   grass/trunk/display/d.thematic.area/
   grass/trunk/display/d.title/
   grass/trunk/display/d.vect.chart/
   grass/trunk/display/d.vect/
   grass/trunk/display/d.what.rast/
   grass/trunk/display/d.what.vect/
   grass/trunk/display/d.where/
   grass/trunk/display/d.zoom/
   grass/trunk/general/g.access/
   grass/trunk/general/g.cairocomp/
   grass/trunk/general/g.copy/
   grass/trunk/general/g.dirseps/
   grass/trunk/general/g.filename/
   grass/trunk/general/g.findetc/
   grass/trunk/general/g.findfile/
   grass/trunk/general/g.gisenv/
   grass/trunk/general/g.gui/
   grass/trunk/general/g.list/
   grass/trunk/general/g.mapset/
   grass/trunk/general/g.mapsets/
   grass/trunk/general/g.message/
   grass/trunk/general/g.mkfontcap/
   grass/trunk/general/g.mlist/
   grass/trunk/general/g.mremove/
   grass/trunk/general/g.parser/
   grass/trunk/general/g.pnmcomp/
   grass/trunk/general/g.proj/
   grass/trunk/general/g.region/
   grass/trunk/general/g.remove/
   grass/trunk/general/g.rename/
   grass/trunk/general/g.setproj/
   grass/trunk/general/g.tempfile/
   grass/trunk/general/g.transform/
   grass/trunk/general/g.version/
   grass/trunk/general/manage/
   grass/trunk/general/manage/lister/
   grass/trunk/imagery/i.albedo/
   grass/trunk/imagery/i.atcorr/
   grass/trunk/imagery/i.atcorr/INFO/
   grass/trunk/imagery/i.atcorr/test_suite/
   grass/trunk/imagery/i.cca/
   grass/trunk/imagery/i.class/
   grass/trunk/imagery/i.cluster/
   grass/trunk/imagery/i.emissivity/
   grass/trunk/imagery/i.fft/
   grass/trunk/imagery/i.find/
   grass/trunk/imagery/i.gensig/
   grass/trunk/imagery/i.gensigset/
   grass/trunk/imagery/i.group/
   grass/trunk/imagery/i.his.rgb/
   grass/trunk/imagery/i.ifft/
   grass/trunk/imagery/i.latlong/
   grass/trunk/imagery/i.maxlik/
   grass/trunk/imagery/i.modis.qc/
   grass/trunk/imagery/i.ortho.photo/
   grass/trunk/imagery/i.ortho.photo/lib/
   grass/trunk/imagery/i.pca/
   grass/trunk/imagery/i.points/
   grass/trunk/imagery/i.rectify/
   grass/trunk/imagery/i.rgb.his/
   grass/trunk/imagery/i.smap/
   grass/trunk/imagery/i.sunhours/
   grass/trunk/imagery/i.target/
   grass/trunk/imagery/i.vi/
   grass/trunk/imagery/i.vpoints/
   grass/trunk/imagery/i.zc/
   grass/trunk/lib/arraystats/
   grass/trunk/lib/bitmap/
   grass/trunk/lib/btree/
   grass/trunk/lib/cairodriver/
   grass/trunk/lib/cdhc/
   grass/trunk/lib/cluster/
   grass/trunk/lib/datetime/
   grass/trunk/lib/db/
   grass/trunk/lib/db/dbmi_base/
   grass/trunk/lib/db/dbmi_client/
   grass/trunk/lib/db/dbmi_driver/
   grass/trunk/lib/db/sqlp/
   grass/trunk/lib/db/sqlp/test/
   grass/trunk/lib/db/stubs/
   grass/trunk/lib/display/
   grass/trunk/lib/driver/
   grass/trunk/lib/dspf/
   grass/trunk/lib/external/
   grass/trunk/lib/external/bwidget/
   grass/trunk/lib/external/bwidget/images/
   grass/trunk/lib/external/bwidget/lang/
   grass/trunk/lib/external/shapelib/
   grass/trunk/lib/fonts/
   grass/trunk/lib/fonts/fonts/
   grass/trunk/lib/form/
   grass/trunk/lib/g3d/
   grass/trunk/lib/gis/
   grass/trunk/lib/gis/colors/
   grass/trunk/lib/gmath/
   grass/trunk/lib/gpde/
   grass/trunk/lib/gpde/test/
   grass/trunk/lib/gtcltk/
   grass/trunk/lib/htmldriver/
   grass/trunk/lib/imagery/
   grass/trunk/lib/init/
   grass/trunk/lib/iostream/
   grass/trunk/lib/lidar/
   grass/trunk/lib/linkm/
   grass/trunk/lib/manage/
   grass/trunk/lib/nviz/
   grass/trunk/lib/ogsf/
   grass/trunk/lib/pngdriver/
   grass/trunk/lib/proj/
   grass/trunk/lib/psdriver/
   grass/trunk/lib/rowio/
   grass/trunk/lib/rst/
   grass/trunk/lib/rst/data/
   grass/trunk/lib/rst/interp_float/
   grass/trunk/lib/rst/qtree/
   grass/trunk/lib/segment/
   grass/trunk/lib/sites/
   grass/trunk/lib/stats/
   grass/trunk/lib/symbol/
   grass/trunk/lib/symbol/symbol/
   grass/trunk/lib/symbol/symbol/basic/
   grass/trunk/lib/symbol/symbol/demo/
   grass/trunk/lib/symbol/symbol/extra/
   grass/trunk/lib/vector/Vlib/
   grass/trunk/lib/vector/dglib/
   grass/trunk/lib/vector/dglib/examples/
   grass/trunk/lib/vector/diglib/
   grass/trunk/lib/vector/rtree/
   grass/trunk/lib/vector/rtree/docs/
   grass/trunk/lib/vector/transform/
   grass/trunk/misc/m.cogo/
   grass/trunk/ps/ps.map/
   grass/trunk/raster/r.basins.fill/
   grass/trunk/raster/r.bitpattern/
   grass/trunk/raster/r.buffer/
   grass/trunk/raster/r.carve/
   grass/trunk/raster/r.category/
   grass/trunk/raster/r.circle/
   grass/trunk/raster/r.clump/
   grass/trunk/raster/r.coin/
   grass/trunk/raster/r.colors.out/
   grass/trunk/raster/r.colors/
   grass/trunk/raster/r.composite/
   grass/trunk/raster/r.compress/
   grass/trunk/raster/r.contour/
   grass/trunk/raster/r.cost/
   grass/trunk/raster/r.covar/
   grass/trunk/raster/r.cross/
   grass/trunk/raster/r.describe/
   grass/trunk/raster/r.digit/
   grass/trunk/raster/r.distance/
   grass/trunk/raster/r.drain/
   grass/trunk/raster/r.external.out/
   grass/trunk/raster/r.external/
   grass/trunk/raster/r.fill.dir/
   grass/trunk/raster/r.flow/
   grass/trunk/raster/r.grow.distance/
   grass/trunk/raster/r.grow/
   grass/trunk/raster/r.gwflow/
   grass/trunk/raster/r.his/
   grass/trunk/raster/r.horizon/
   grass/trunk/raster/r.in.arc/
   grass/trunk/raster/r.in.ascii/
   grass/trunk/raster/r.in.bin/
   grass/trunk/raster/r.in.gdal/
   grass/trunk/raster/r.in.gridatb/
   grass/trunk/raster/r.in.mat/
   grass/trunk/raster/r.in.poly/
   grass/trunk/raster/r.in.xyz/
   grass/trunk/raster/r.info/
   grass/trunk/raster/r.kappa/
   grass/trunk/raster/r.lake/
   grass/trunk/raster/r.le/
   grass/trunk/raster/r.le/r.le.patch/
   grass/trunk/raster/r.le/r.le.pixel/
   grass/trunk/raster/r.le/r.le.setup/
   grass/trunk/raster/r.le/r.le.setup/polytocell/
   grass/trunk/raster/r.le/r.le.trace/
   grass/trunk/raster/r.li/
   grass/trunk/raster/r.li/r.li.cwed/
   grass/trunk/raster/r.li/r.li.daemon/
   grass/trunk/raster/r.li/r.li.dominance/
   grass/trunk/raster/r.li/r.li.edgedensity/
   grass/trunk/raster/r.li/r.li.mpa/
   grass/trunk/raster/r.li/r.li.mps/
   grass/trunk/raster/r.li/r.li.padcv/
   grass/trunk/raster/r.li/r.li.padrange/
   grass/trunk/raster/r.li/r.li.padsd/
   grass/trunk/raster/r.li/r.li.patchdensity/
   grass/trunk/raster/r.li/r.li.patchnum/
   grass/trunk/raster/r.li/r.li.richness/
   grass/trunk/raster/r.li/r.li.setup/
   grass/trunk/raster/r.li/r.li.shannon/
   grass/trunk/raster/r.li/r.li.shape/
   grass/trunk/raster/r.li/r.li.simpson/
   grass/trunk/raster/r.los/
   grass/trunk/raster/r.mapcalc/
   grass/trunk/raster/r.mfilter/
   grass/trunk/raster/r.mode/
   grass/trunk/raster/r.neighbors/
   grass/trunk/raster/r.null/
   grass/trunk/raster/r.out.arc/
   grass/trunk/raster/r.out.ascii/
   grass/trunk/raster/r.out.bin/
   grass/trunk/raster/r.out.gdal/
   grass/trunk/raster/r.out.gridatb/
   grass/trunk/raster/r.out.mat/
   grass/trunk/raster/r.out.mpeg/
   grass/trunk/raster/r.out.png/
   grass/trunk/raster/r.out.pov/
   grass/trunk/raster/r.out.ppm/
   grass/trunk/raster/r.out.ppm3/
   grass/trunk/raster/r.out.tiff/
   grass/trunk/raster/r.out.vrml/
   grass/trunk/raster/r.out.vtk/
   grass/trunk/raster/r.param.scale/
   grass/trunk/raster/r.patch/
   grass/trunk/raster/r.profile/
   grass/trunk/raster/r.proj/
   grass/trunk/raster/r.quant/
   grass/trunk/raster/r.quantile/
   grass/trunk/raster/r.random.cells/
   grass/trunk/raster/r.random.surface/
   grass/trunk/raster/r.random/
   grass/trunk/raster/r.reclass/
   grass/trunk/raster/r.recode/
   grass/trunk/raster/r.region/
   grass/trunk/raster/r.report/
   grass/trunk/raster/r.resamp.interp/
   grass/trunk/raster/r.resamp.rst/
   grass/trunk/raster/r.resamp.stats/
   grass/trunk/raster/r.resample/
   grass/trunk/raster/r.rescale.eq/
   grass/trunk/raster/r.rescale/
   grass/trunk/raster/r.ros/
   grass/trunk/raster/r.series/
   grass/trunk/raster/r.slope.aspect/
   grass/trunk/raster/r.spread/
   grass/trunk/raster/r.spreadpath/
   grass/trunk/raster/r.statistics/
   grass/trunk/raster/r.statistics2/
   grass/trunk/raster/r.statistics3/
   grass/trunk/raster/r.stats/
   grass/trunk/raster/r.sun/
   grass/trunk/raster/r.sunmask/
   grass/trunk/raster/r.support.stats/
   grass/trunk/raster/r.support/
   grass/trunk/raster/r.surf.area/
   grass/trunk/raster/r.surf.contour/
   grass/trunk/raster/r.surf.fractal/
   grass/trunk/raster/r.surf.gauss/
   grass/trunk/raster/r.surf.idw/
   grass/trunk/raster/r.surf.idw2/
   grass/trunk/raster/r.surf.random/
   grass/trunk/raster/r.terraflow/
   grass/trunk/raster/r.texture/
   grass/trunk/raster/r.thin/
   grass/trunk/raster/r.timestamp/
   grass/trunk/raster/r.to.rast3/
   grass/trunk/raster/r.to.rast3elev/
   grass/trunk/raster/r.to.vect/
   grass/trunk/raster/r.topidx/
   grass/trunk/raster/r.topmodel/
   grass/trunk/raster/r.transect/
   grass/trunk/raster/r.univar/
   grass/trunk/raster/r.uslek/
   grass/trunk/raster/r.usler/
   grass/trunk/raster/r.volume/
   grass/trunk/raster/r.walk/
   grass/trunk/raster/r.water.outlet/
   grass/trunk/raster/r.watershed/
   grass/trunk/raster/r.watershed/front/
   grass/trunk/raster/r.watershed/ram/
   grass/trunk/raster/r.watershed/seg/
   grass/trunk/raster/r.watershed/shed/
   grass/trunk/raster/r.what.color/
   grass/trunk/raster/r.what/
   grass/trunk/raster/simwe/
   grass/trunk/raster/simwe/r.sim.sediment/
   grass/trunk/raster/simwe/r.sim.water/
   grass/trunk/raster/simwe/simlib/
   grass/trunk/raster/wildfire/
   grass/trunk/raster3d/base/
   grass/trunk/raster3d/r3.cross.rast/
   grass/trunk/raster3d/r3.gwflow/
   grass/trunk/raster3d/r3.in.ascii/
   grass/trunk/raster3d/r3.in.v5d/
   grass/trunk/raster3d/r3.info/
   grass/trunk/raster3d/r3.mkdspf/
   grass/trunk/raster3d/r3.out.ascii/
   grass/trunk/raster3d/r3.out.v5d/
   grass/trunk/raster3d/r3.out.vtk/
   grass/trunk/raster3d/r3.showdspf/
   grass/trunk/raster3d/r3.stats/
   grass/trunk/raster3d/r3.timestamp/
   grass/trunk/raster3d/r3.to.rast/
   grass/trunk/scripts/v.in.geonames/
   grass/trunk/sites/s.in.ascii/
   grass/trunk/sites/s.out.ascii/
   grass/trunk/tools/timer/
   grass/trunk/vector/v.buffer/
   grass/trunk/vector/v.build.polylines/
   grass/trunk/vector/v.build/
   grass/trunk/vector/v.category/
   grass/trunk/vector/v.class/
   grass/trunk/vector/v.clean/
   grass/trunk/vector/v.clean/test/
   grass/trunk/vector/v.convert/
   grass/trunk/vector/v.db.connect/
   grass/trunk/vector/v.db.select/
   grass/trunk/vector/v.delaunay/
   grass/trunk/vector/v.distance/
   grass/trunk/vector/v.drape/
   grass/trunk/vector/v.edit/
   grass/trunk/vector/v.external/
   grass/trunk/vector/v.extract/
   grass/trunk/vector/v.extrude/
   grass/trunk/vector/v.generalize/
   grass/trunk/vector/v.hull/
   grass/trunk/vector/v.in.ascii/
   grass/trunk/vector/v.in.db/
   grass/trunk/vector/v.in.dwg/
   grass/trunk/vector/v.in.dxf/
   grass/trunk/vector/v.in.ogr/
   grass/trunk/vector/v.in.region/
   grass/trunk/vector/v.in.sites/
   grass/trunk/vector/v.info/
   grass/trunk/vector/v.kcv/
   grass/trunk/vector/v.kernel/
   grass/trunk/vector/v.label.sa/
   grass/trunk/vector/v.label/
   grass/trunk/vector/v.lidar.correction/
   grass/trunk/vector/v.lidar.edgedetection/
   grass/trunk/vector/v.lidar.growing/
   grass/trunk/vector/v.lrs/
   grass/trunk/vector/v.lrs/lib/
   grass/trunk/vector/v.lrs/v.lrs.create/
   grass/trunk/vector/v.lrs/v.lrs.label/
   grass/trunk/vector/v.lrs/v.lrs.segment/
   grass/trunk/vector/v.lrs/v.lrs.where/
   grass/trunk/vector/v.mapcalc/
   grass/trunk/vector/v.mapcalc/plugins/
   grass/trunk/vector/v.mkgrid/
   grass/trunk/vector/v.neighbors/
   grass/trunk/vector/v.net.alloc/
   grass/trunk/vector/v.net.iso/
   grass/trunk/vector/v.net.path/
   grass/trunk/vector/v.net.salesman/
   grass/trunk/vector/v.net.steiner/
   grass/trunk/vector/v.net.visibility/
   grass/trunk/vector/v.net/
   grass/trunk/vector/v.normal/
   grass/trunk/vector/v.out.ascii/
   grass/trunk/vector/v.out.dxf/
   grass/trunk/vector/v.out.ogr/
   grass/trunk/vector/v.out.pov/
   grass/trunk/vector/v.out.svg/
   grass/trunk/vector/v.out.vtk/
   grass/trunk/vector/v.outlier/
   grass/trunk/vector/v.overlay/
   grass/trunk/vector/v.parallel/
   grass/trunk/vector/v.patch/
   grass/trunk/vector/v.perturb/
   grass/trunk/vector/v.proj/
   grass/trunk/vector/v.qcount/
   grass/trunk/vector/v.random/
   grass/trunk/vector/v.reclass/
   grass/trunk/vector/v.sample/
   grass/trunk/vector/v.segment/
   grass/trunk/vector/v.select/
   grass/trunk/vector/v.split/
   grass/trunk/vector/v.support/
   grass/trunk/vector/v.surf.bspline/
   grass/trunk/vector/v.surf.idw/
   grass/trunk/vector/v.surf.rst/
   grass/trunk/vector/v.to.3d/
   grass/trunk/vector/v.to.db/
   grass/trunk/vector/v.to.points/
   grass/trunk/vector/v.to.rast/
   grass/trunk/vector/v.to.rast3/
   grass/trunk/vector/v.transform/
   grass/trunk/vector/v.type/
   grass/trunk/vector/v.univar/
   grass/trunk/vector/v.vol.rst/
   grass/trunk/vector/v.voronoi/
   grass/trunk/vector/v.what.rast/
   grass/trunk/vector/v.what/
   grass/trunk/visualization/nviz/
   grass/trunk/visualization/nviz/src/
   grass/trunk/visualization/nviz2/cmd/
   grass/trunk/visualization/wximgview/
   grass/trunk/visualization/xganim/
   grass/trunk/visualization/ximgview/
Fix svn:ignore properties: *OBJ* => OBJ.*
Property changes on: grass/trunk/db/db.columns
___________________________________________________________________
Modified: svn:ignore
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.connect
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.copy
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.createdb
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.databases
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.describe
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.drivers
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.dropdb
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.droptable
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.execute
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.login
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.select
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/db.tables
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/dbf
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/dbf/dbf_catalog
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/mysql
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/odbc
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/ogr
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/postgres
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/db/drivers/sqlite
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.barscale
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.colorlist
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.colors
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.colortable
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.erase
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.extract
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.font
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.fontlist
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.geodesic
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.graph
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.grid
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.his
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.histogram
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.info
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.labels
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.legend
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.linegraph
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.measure
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.nviz
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.path
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.profile
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.rast.arrow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.rast.num
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.rgb
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.rhumbline
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.text
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.thematic.area
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.title
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.vect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.vect.chart
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.what.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.what.vect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.where
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/display/d.zoom
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.access
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.cairocomp
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.copy
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.dirseps
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.filename
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.findetc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.findfile
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.gisenv
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.gui
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.list
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.mapset
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.mapsets
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.message
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.mkfontcap
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.mlist
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.mremove
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.parser
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.pnmcomp
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.proj
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.region
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.remove
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.rename
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.setproj
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.tempfile
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.transform
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/g.version
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/manage
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/general/manage/lister
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.albedo
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.atcorr
   - *OBJ*
*.pyc
   + OBJ.*
*.pyc
Property changes on: grass/trunk/imagery/i.atcorr/INFO
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.atcorr/test_suite
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.cca
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.class
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.cluster
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.emissivity
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.fft
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.find
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.gensig
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.gensigset
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.group
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.his.rgb
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.ifft
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.latlong
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.maxlik
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.modis.qc
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.ortho.photo
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.ortho.photo/lib
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.pca
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.points
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.rectify
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.rgb.his
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.smap
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.sunhours
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.target
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.vi
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.vpoints
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/imagery/i.zc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/arraystats
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/bitmap
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/btree
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/cairodriver
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/cdhc
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/cluster
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/datetime
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/db
   - *OBJ*
html
latex
   + OBJ.*
html
latex
Property changes on: grass/trunk/lib/db/dbmi_base
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/db/dbmi_client
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/db/dbmi_driver
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/db/sqlp
   - *OBJ*
sqlp.tab.c
sqlp.tab.h
sqlp.output
sqlp.yy.c
   + OBJ.*
sqlp.tab.c
sqlp.tab.h
sqlp.output
sqlp.yy.c
Property changes on: grass/trunk/lib/db/sqlp/test
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/db/stubs
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/display
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/driver
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/dspf
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/external
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/external/bwidget
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/external/bwidget/images
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/external/bwidget/lang
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/external/shapelib
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/fonts
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/fonts/fonts
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/form
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/g3d
   - *OBJ*
latex
html
   + OBJ.*
latex
html
Property changes on: grass/trunk/lib/gis
   - *OBJ*
html
latex
   + OBJ.*
html
latex
Property changes on: grass/trunk/lib/gis/colors
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/gmath
   - *OBJ*
latex
html
   + OBJ.*
latex
html
Property changes on: grass/trunk/lib/gpde
   - *OBJ*
html
latex
   + OBJ.*
html
latex
Property changes on: grass/trunk/lib/gpde/test
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/gtcltk
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/htmldriver
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/imagery
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/init
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/iostream
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/lidar
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/linkm
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/manage
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/nviz
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/ogsf
   - *OBJ*
latex
html
   + OBJ.*
latex
html
Property changes on: grass/trunk/lib/pngdriver
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/proj
   - *OBJ*
latex
html
   + OBJ.*
latex
html
Property changes on: grass/trunk/lib/psdriver
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/rowio
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/rst
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/rst/data
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/rst/interp_float
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/rst/qtree
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/segment
   - *OBJ*
latex
html
   + OBJ.*
latex
html
Property changes on: grass/trunk/lib/sites
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/stats
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/symbol
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/symbol/symbol
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/symbol/symbol/basic
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/symbol/symbol/demo
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/symbol/symbol/extra
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/vector/Vlib
   - *OBJ*
.break_polygons.c.swp
.write.c.swp
   + OBJ.*
.write.c.swp
Property changes on: grass/trunk/lib/vector/dglib
   - html
latex
*OBJ*
   + html
latex
OBJ.*
Property changes on: grass/trunk/lib/vector/dglib/examples
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/vector/diglib
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/vector/rtree
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/vector/rtree/docs
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/lib/vector/transform
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/misc/m.cogo
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/ps/ps.map
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.basins.fill
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.bitpattern
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.buffer
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.carve
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.category
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.circle
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.clump
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.coin
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.colors
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.colors.out
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.composite
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.compress
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.contour
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.cost
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.covar
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.cross
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.describe
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.digit
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.distance
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.drain
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.external
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.external.out
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.fill.dir
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.flow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.grow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.grow.distance
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.gwflow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.his
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.horizon
   - *.tmp.html
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.arc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.bin
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.gdal
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.gridatb
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.mat
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.poly
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.in.xyz
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.info
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.kappa
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.lake
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le/r.le.patch
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le/r.le.pixel
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le/r.le.setup
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le/r.le.setup/polytocell
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.le/r.le.trace
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.cwed
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.daemon
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.dominance
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.edgedensity
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.mpa
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.mps
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.padcv
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.padrange
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.padsd
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.patchdensity
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.patchnum
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.richness
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.setup
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.shannon
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.shape
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.li/r.li.simpson
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.los
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.mapcalc
   - *OBJ*
mapcalc.tab.c
mapcalc.tab.h
mapcalc.yy.c
mapcalc.output
   + OBJ.*
mapcalc.tab.c
mapcalc.tab.h
mapcalc.yy.c
mapcalc.output
Property changes on: grass/trunk/raster/r.mfilter
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.mode
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.neighbors
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.null
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.arc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.bin
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.gdal
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.gridatb
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.mat
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.mpeg
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.png
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.pov
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.ppm
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.ppm3
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.tiff
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.vrml
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.out.vtk
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.param.scale
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.patch
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.profile
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.proj
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.quant
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.quantile
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.random
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.random.cells
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.random.surface
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.reclass
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.recode
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.region
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.report
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.resamp.interp
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.resamp.rst
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.resamp.stats
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.resample
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.rescale
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.rescale.eq
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.ros
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.series
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.slope.aspect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.spread
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.spreadpath
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.statistics
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.statistics2
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.statistics3
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.stats
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.sun
   - *.tmp.html
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.sunmask
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.support
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.support.stats
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.area
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.contour
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.fractal
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.gauss
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.idw
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.idw2
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.surf.random
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.terraflow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.texture
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.thin
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.timestamp
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.to.rast3
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.to.rast3elev
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.to.vect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.topidx
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.topmodel
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.transect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.univar
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.uslek
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.usler
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.volume
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.walk
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.water.outlet
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.watershed
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.watershed/front
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.watershed/ram
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.watershed/seg
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.watershed/shed
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.what
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/r.what.color
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/simwe
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/simwe/r.sim.sediment
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/simwe/r.sim.water
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/simwe/simlib
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster/wildfire
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/base
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.cross.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.gwflow
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.in.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.in.v5d
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.info
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.mkdspf
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.out.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.out.v5d
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.out.vtk
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.showdspf
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.stats
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.timestamp
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/raster3d/r3.to.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/scripts/v.in.geonames
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/sites/s.in.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/sites/s.out.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/tools/timer
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.buffer
   - *.tmp.html
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.build
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.build.polylines
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.category
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.class
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.clean
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.clean/test
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.convert
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.db.connect
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.db.select
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.delaunay
   - *.tmp.html
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.distance
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.drape
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.edit
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.external
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.extract
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.extrude
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.generalize
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.hull
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.db
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.dwg
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.dxf
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.ogr
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.region
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.in.sites
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.info
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.kcv
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.kernel
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.label
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.label.sa
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lidar.correction
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lidar.edgedetection
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lidar.growing
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs/lib
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs/v.lrs.create
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs/v.lrs.label
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs/v.lrs.segment
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.lrs/v.lrs.where
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.mapcalc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.mapcalc/plugins
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.mkgrid
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.neighbors
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.alloc
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.iso
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.path
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.salesman
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.steiner
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.net.visibility
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.normal
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.ascii
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.dxf
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.ogr
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.pov
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.svg
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.out.vtk
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.outlier
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.overlay
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.parallel
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.patch
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.perturb
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.proj
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.qcount
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.random
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.reclass
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.sample
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.segment
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.select
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.split
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.support
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.surf.bspline
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.surf.idw
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.surf.rst
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.to.3d
   - *.tmp.html
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.to.db
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.to.points
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.to.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.to.rast3
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.transform
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.type
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.univar
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.vol.rst
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.voronoi
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.what
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/vector/v.what.rast
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/visualization/nviz
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/visualization/nviz/src
   - nvwish
*OBJ*
   + nvwish
OBJ.*
Property changes on: grass/trunk/visualization/nviz2/cmd
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/visualization/wximgview
   - *OBJ*
   + OBJ.*
Property changes on: grass/trunk/visualization/xganim
*OBJ*
   + OBJ.*
Property changes on: grass/trunk/visualization/ximgview
*OBJ*
   + OBJ.*
