[GRASS-SVN] r43734 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Thu Sep 30 01:41:40 EDT 2010
Author: hamish
Date: 2010-09-30 05:41:40 +0000 (Thu, 30 Sep 2010)
New Revision: 43734
grass/branches/develbranch_6/scripts/g.extension/g.extension
somewhat experimental attempt at fixing #1180:
- default install back to GRASS_ADDON_PATH
- make a GRASS_ADDON_PATH if needed
- symlink binary into ADDON_PATH if that's the destination
- minor cosmetics
- test if install dir is writable
- also remove if in scripts/ or base dir
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-09-30 02:30:42 UTC (rev 43733)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-09-30 05:41:40 UTC (rev 43734)
@@ -50,14 +50,18 @@
#% type: string
#% key_desc: path
#% description: Prefix where to install extension
-#% answer: $GISBASE
-#% required: yes
+#% answer: $GRASS_ADDON_PATH
+#% required: no
#%end
#%flag
#% key: l
#% description: List available modules in the GRASS Addons SVN repository
#% guisection: Print
#%end
+#%flag
+#% key: s
+#% description: Install system-wide (may need system administrator rights)
+#%end
if [ -z "$GISBASE" ] ; then
@@ -199,10 +203,22 @@
exit 1
fi
-if [ "$PREFIX" = '$GISBASE' ] ; then
+if [ "$PREFIX" == '$GRASS_ADDON_PATH' ] ; then
+ if [ -z "$GRASS_ADDON_PATH" ] ; then
+ g.message -w message="GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/"
+ #g.message message="Suggest you set GRASS_ADDON_PATH and GRASS_ADDON_ETC to ..."
+ ## will GRASS_ADDON_ETC help for man/ and docs/ ?
+ ## maybe have g.manual search in GRASS_ADDON_ETC/../ ? :-/
+ mkdir -p ~/.grass6/addons
+ GRASS_ADDON_PATH=~/.grass6/addons
+ fi
+ PREFIX="$GRASS_ADDON_PATH"
+elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] ; then
PREFIX="$GISBASE"
fi
if [ -d "$PREFIX" ] ; then
MYINST_DIR="$PREFIX"
else
@@ -210,14 +226,27 @@
exit 1
fi
+if [ ! -w "$PREFIX" ] ; then
+ g.message -e "'$PREFIX' is not writable (are you logged in as the system administator?)"
+ exit 1
+fi
if [ "$GIS_OPT_OPERATION" = "remove" ] ; then
g.message message="Removing <$MODULE>..."
if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
rm -f "${MYINST_DIR}/bin/${MODULE}"
fi
+ if test -f "$MYINST_DIR/scripts/$MODULE" ; then
+ rm -f "$MYINST_DIR/scripts/$MODULE"
+ fi
+ if test -f "$MYINST_DIR/$MODULE" ; then
+ rm -f "$MYINST_DIR/$MODULE"
+ fi
if test -f "${MYINST_DIR}/docs/html/${MODULE}.html" ; then
rm -f "${MYINST_DIR}/docs/html/${MODULE}.html"
+ #also html/$MODULE*.jpg, html/$MODULE*.png
fi
if test -f "${MYINST_DIR}/man/man1/${MODULE}.1" ; then
rm -f "${MYINST_DIR}/man/man1/${MODULE}.1"
@@ -233,22 +262,22 @@
svn co "${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}"
if [ $? -ne 0 ] ; then
- g.message -e message="GRASS Addon ${MODULE} not found in repository or no network connection or another problem"
+ g.message -e message="GRASS Add-on $MODULE not found in repository or no network connection or another problem"
exit 1
fi
cd "$TMPDIR/$MODULE"
-g.message message="Compiling <${MODULE}>..."
+g.message message="Compiling <$MODULE>..."
make MODULE_TOPDIR="$GISBASE"
g.message -e message="Compilation failed, sorry. Please check above error messages."
cleanup
exit 1
else
- g.message message="Installing ${MODULE}..."
+ g.message message="Installing <$MODULE>..."
# is it a script?
- grep "default: script" "$TMPDIR/$MODULE/Makefile" 2>&1 >/dev/null
+ grep "default: script" "$TMPDIR/$MODULE/Makefile" 2>&1 > /dev/null
if [ $? -eq 0 ] ; then
PROGTYPE=scripts
else
@@ -267,27 +296,36 @@
if test ! -d "${MYINST_DIR}/man/man1" ; then
mkdir -p "${MYINST_DIR}/man/man1"
fi
+ # use `test -w` instead of touch?
touch "${MYINST_DIR}/`basename $0`.$$"
g.message -e message="Cannot write to <$MYINST_DIR>, installation failed"
exit 1
- else
- rm -f "${MYINST_DIR}/`basename $0`.$$"
- if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
- rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
- fi
- make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR" install
- if [ $? -ne 0 ] ; then
- g.message -e message="Installation failed, sorry. Please check above error messages."
- cleanup
- exit 1
- fi
- if [ ! -x "${MYINST_DIR}/$PROGTYPE/${MODULE}" ] ; then
- g.message -e "Module did not install properly"
- cleanup
- exit 1
- fi
fi
+ rm -f "${MYINST_DIR}/`basename $0`.$$"
+ if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
+ rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
+ fi
+ make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR" install
+ if [ $? -ne 0 ] ; then
+ g.message -e message="Installation failed, sorry. Please check above error messages."
+ cleanup
+ exit 1
+ fi
+ if [ ! -x "${MYINST_DIR}/$PROGTYPE/${MODULE}" ] ; then
+ g.message -e "Module did not install properly"
+ cleanup
+ exit 1
+ fi
+ if [ "$MYINST_DIR" = "$GRASS_ADDON_PATH" ] ; then
+ # symlink into path which is actually in the $PATH
+ ln -s "$MYINST_DIR/$PROGTYPE/$MODULE" "$MYINST_DIR/"
+ fi
fi
cleanup
