[GRASS-SVN] r43746 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Sep 30 13:23:06 EDT 2010
Author: martinl
Date: 2010-09-30 17:23:06 +0000 (Thu, 30 Sep 2010)
New Revision: 43746
grass/trunk/lib/init/variables.html
note cairo driver in variables man page
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2010-09-30 09:34:03 UTC (rev 43745)
+++ grass/trunk/lib/init/variables.html 2010-09-30 17:23:06 UTC (rev 43746)
@@ -23,10 +23,10 @@
There are a number of <i>shell</i> environment variable groups:
<ul>
+<li><a href="#cairo">Cairo driver</a></li>
<li><a href="#png">PNG driver</a></li>
<li><a href="#ps">PS driver (PostScript)</a></li>
<li><a href="#html">HTMLMAP driver</a></li>
-<!--<li><a href="#cairo">Cairo driver</a></li>-->
<li><a href="#dirrend">variables for direct rendering</a></li>
<li><a href="#internal">variables for internal use</a></li>
</ul>
@@ -275,124 +275,46 @@
Set to any value to disable the use of GLX Pixmaps.</dd>
</dl>
+<a name="cairo"></a>
+<h3>List of selected GRASS Cairo driver environment variables</h3>
+<blockquote>
+[ These variables control the function of the Cairo driver. ]
+</blockquote>
+See <a href="cairodriver.html">Cairo driver</a> manual page for detailed
+list of the variables.
<a name="png"></a>
<h3>List of selected GRASS PNG driver environment variables</h3>
<blockquote>
-[ These variables control the function of the PNG driver ]
+[ These variables control the function of the PNG driver. ]
</blockquote>
See <a href="pngdriver.html">PNG driver</a> manual page for detailed
- 2008/03 -- -- variables are described in PNG driver manual
- page. The link should be enough here.
- <P></P>
-<p>GRASS_PNGFILE
- <br> name of PNG output file. If it ends with ".ppm" a PPM file will be created.
-<p>GRASS_WIDTH
- <br> defines the width of GRASS monitor, see also GRASS_HEIGHT
-<p>GRASS_HEIGHT
- <br> defines the height of GRASS monitor, see also GRASS_WIDTH
-<p>GRASS_BACKGROUNDCOLOR
- <br> defines the background color of the image created by the PNG driver
-<p>GRASS_TRANSPARENT
- <br> if "TRUE", the image created by the PNG driver will have a
- transparent background
-<p>GRASS_PNG_COMPRESSION
- <br> compression level of PNG files (0 = none, 1 = fastest, 9 = best)
-<p>GRASS_TRUECOLOR
- <br> if "TRUE", the PNG driver generates a true-color image
-<p>GRASS_PNG_AUTO_WRITE
- <br> tells the PNG driver to write the image to a file whenever a
- client disconnects, rather than waiting until you stop the monitor
-<p>GRASS_PNG_READ
- <br> if "TRUE", the PNG driver will initialize the image from
- the contents of $GRASS_PNGFILE
-<p>GRASS_PNG_MAPPED
- <br> if "TRUE", the PNG driver will map $GRASS_PNGFILE as its framebuffer,
- rather than using memory; this only works with BMP files
<a name="ps"></a>
<h3>List of selected GRASS PS driver environment variables</h3>
<blockquote>
-[ These variables control the function of the PS driver ]
+[ These variables control the function of the PS driver. ]
</blockquote>
See <a href="psdriver.html">PS driver</a> manual page for detailed
- 2008/03 -- -- variables are described in PS driver manual
-<P></P>
-<p>GRASS_PSFILE
-<br> name of output file. If it ends with ".eps" an EPS file
-will be created.
-<p>GRASS_PAPER <br> sets the screen dimensions and margins to
-fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.
-<p>GRASS_WIDTH
-<br> defines the width of the screen, see also GRASS_HEIGHT
-<p>GRASS_HEIGHT
-<br> defines the height of the screen, see also GRASS_WIDTH
-<p>GRASS_TRUECOLOR
-<br> if "TRUE", the PS driver generates color output, otherwise
-monochrome.
-<p>GRASS_LANDSCAPE
-<br> if "TRUE", the screen is rotated 90 degrees
-counter-clockwise so that a "landscape" screen fits better on
-"portrait" paper.
-<p>GRASS_PS_HEADER
-<br> if "FALSE", the output is appended to any existing file,
-and no prolog or setup sections are generated.
-<p>GRASS_PS_TRAILER
-<br> if "FALSE", no trailer section is generated.
<a name="html"></a>
<h3>List of selected HTMLMAP driver environment variables</h3>
<blockquote>
-[ These variables control the function of the HTMLMAP driver ]
+[ These variables control the function of the HTMLMAP driver. ]
</blockquote>
-See <a href="htmlmapdriver.html">HTMLMAP driver</a> manual page for
+See <a href="htmldriver.html">HTMLMAP driver</a> manual page for
detailed list of the variables.
-<a name="cairo"></a>
-<h3>List of selected Cairo driver environment variables</h3>
-<blockquote>
-[ These variables control the function of the Cairo driver ]
-</blockquote>
-See <a href="cairodriver.html">Cairo driver</a> manual page for
-detailed list of the variables.
<a name="dirrend"></a>
<h3>List of selected GRASS environment variables for direct rendering</h3>
<blockquote>
