[GRASS-SVN] r45820 - grass-addons/vector/v.rast.stats2
svn_grass at osgeo.org
Fri Apr 1 09:57:32 EDT 2011
Author: mmetz
Date: 2011-04-01 06:57:32 -0700 (Fri, 01 Apr 2011)
New Revision: 45820
grass-addons/vector/v.rast.stats2/v.rast.stats2
avoid array usage
Modified: grass-addons/vector/v.rast.stats2/v.rast.stats2
--- grass-addons/vector/v.rast.stats2/v.rast.stats2 2011-04-01 13:41:01 UTC (rev 45819)
+++ grass-addons/vector/v.rast.stats2/v.rast.stats2 2011-04-01 13:57:32 UTC (rev 45820)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#!/bin/sh
@@ -259,6 +259,7 @@
fi
unset ADDCOLS
+unset COLNAMES
for i in $BASECOLS $EXTRACOLS ; do
# check if column already present
if [ $DBFDRIVER -eq 1 ] ; then
@@ -266,6 +267,11 @@
else
CURRCOLUMN="${COLPREFIX}_${i}"
fi
+ if [ -n "$COLNAMES" ] ; then
+ COLNAMES="${COLNAMES},$CURRCOLUMN"
+ else
+ COLNAMES="$CURRCOLUMN"
+ fi
v.info -c $VECTORFULL layer="$GIS_OPT_LAYER" --quiet | sed 's+^+|+g' | sed 's+$+|+g' | \
grep "|$CURRCOLUMN|" --quiet
if [ $? -eq 0 ] ; then
@@ -335,26 +341,29 @@
eval "$PERCCOL=\$percentile_$GIS_OPT_PERCENTILE"
fi
-for var in $BASECOLS $EXTRACOLS ; do
- eval value=\${$var}
- if [ $DBFDRIVER -eq 1 ] ; then
- colname="`echo "${COLPREFIX}_${var}" | cut -b1-10`"
- else
- colname="${COLPREFIX}_${var}"
- fi
- echo "$colname" >> "$COLNAMETMP"
-done
# create array with new column names
-col=`cat "$COLNAMETMP" | tr '\n' ' '`
+col1="`echo $COLNAMES | cut -f1 -d','`"
+col2="`echo $COLNAMES | cut -f2 -d','`"
+col3="`echo $COLNAMES | cut -f3 -d','`"
+col4="`echo $COLNAMES | cut -f4 -d','`"
+col5="`echo $COLNAMES | cut -f5 -d','`"
+col6="`echo $COLNAMES | cut -f6 -d','`"
+col7="`echo $COLNAMES | cut -f7 -d','`"
+col8="`echo $COLNAMES | cut -f8 -d','`"
+col9="`echo $COLNAMES | cut -f9 -d','`"
+if [ $GIS_FLAG_E -eq 1 ] ; then
+ col10="`echo $COLNAMES | cut -f10 -d','`"
+ col11="`echo $COLNAMES | cut -f11 -d','`"
+ col12="`echo $COLNAMES | cut -f12 -d','`"
+ col13="`echo $COLNAMES | cut -f13 -d','`"
+fi
# create SQL file for extended and normal statistics
g.message -v "Creating SQL file ..."
- sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col[0]}' = %i , '${col[1]}' = %.2f , '${col[2]}' = %.2f , '${col[3]}' = %.2f , '${col[4]}' = %.2f , '${col[5]}' = %.2f , '${col[6]}' = %.2f , '${col[7]}' = %.2f , '${col[8]}' = %.2f , '${col[9]}' = %.2f , '${col[10]}' = %.2f , '${col[11]}' = %2f , '${col[12]}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$1}' > "$SQLTMP"
+ sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f , '${col10}' = %.2f , '${col11}' = %.2f , '${col12}' = %2f , '${col13}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$1}' > "$SQLTMP"
else
- sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col[0]}' = %i , '${col[1]}' = %.2f , '${col[2]}' = %.2f , '${col[3]}' = %.2f , '${col[4]}' = %.2f , '${col[5]}' = %.2f , '${col[6]}' = %.2f , '${col[7]}' = %.2f , '${col[8]}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
+ sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
fi
g.message -v "Updating the database ..."
