[GRASS-SVN] r45822 - grass/trunk/gui/wxpython
Fri Apr 1 16:08:25 EDT 2011
Author: martinl
Date: 2011-04-01 13:08:25 -0700 (Fri, 01 Apr 2011)
New Revision: 45822
   grass/trunk/gui/wxpython/gis_set.py
#1340 (wxGUI uses improper .grassrc syntax and may cause .grassrc file
corruption)
(merge r45821 from devbr6)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2011-04-01 20:04:14 UTC (rev 45821)
+++ grass/trunk/gui/wxpython/gis_set.py	2011-04-01 20:08:25 UTC (rev 45822)
@@ -394,7 +394,7 @@
                     grassrc[key.strip()] = utils.DecodeString(val.strip())
             finally:
                 rc.close()
         return grassrc
     def GetRCValue(self, value):
@@ -609,11 +609,11 @@
                 self.listOfMapsetsSelectable += line.split(' ')
         except:
             gcmd.RunCommand("g.gisenv",
-                            set =  "GISDBASE = %s" % self.gisdbase)
+                            set = "GISDBASE=%s" % self.gisdbase)
-                            set = "LOCATION_NAME = %s" % locationName)
+                            set = "LOCATION_NAME=%s" % locationName)
-                            set = "MAPSET = PERMANENT")
+                            set = "MAPSET=PERMANENT")
             # first run only
             self.listOfMapsetsSelectable = copy.copy(self.listOfMapsets)
@@ -737,13 +737,13 @@
     def OnStart(self, event):
         """'Start GRASS' button clicked"""
-                        set = "GISDBASE = %s" % \
+                        set = "GISDBASE=%s" % \
                             self.tgisdbase.GetValue())
-                        set = "LOCATION_NAME = %s" % \
+                        set = "LOCATION_NAME=%s" % \
                             self.listOfLocations[self.lblocations.GetSelection()])
-                        set = "MAPSET = %s" % \
+                        set = "MAPSET=%s" % \
                             self.listOfMapsets[self.lbmapsets.GetSelection()])
         self.Destroy()
