[GRASS-SVN] r45824 - grass-addons/gui/wxpython/wx.psmap/gui_modules
Sat Apr 2 05:21:43 EDT 2011
Author: annakrat
Date: 2011-04-02 02:21:43 -0700 (Sat, 02 Apr 2011)
New Revision: 45824
   grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
   grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
xwGUI/psmap: fixed a few bugs
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-01 20:17:04 UTC (rev 45823)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-02 09:21:43 UTC (rev 45824)
@@ -386,7 +386,7 @@
                 im = Image.open(event.userData['filename'])
                 if self.instruction[self.pageId]['Orientation'] == 'Landscape':
                     im = im.rotate(270)
-                im.save(self.imgName)
+                im.save(self.imgName, format = 'png', optimize = 1)
             except IOError, e:
                 GError(parent = self,
@@ -796,6 +796,7 @@
             ids = [id]
         for id in ids:
             itype = self.instruction[id].type
             if itype in ('scalebar', 'mapinfo'):
                 drawRectangle = self.canvas.CanvasPaperCoordinates(
                                     rect = self.instruction[id]['rect'], canvasToPaper = False)
@@ -855,7 +856,7 @@
                 self.canvas.RedrawSelectBox(id)
                 self.canvas.pdcTmp.RemoveId(self.canvas.idZoomBoxTmp)
                 # redraw to get map to the bottom layer
-                self.canvas.Zoom(zoomFactor = 1, view = (0, 0))
+                #self.canvas.Zoom(zoomFactor = 1, view = (0, 0))
             if itype == 'rasterLegend':
                 if self.instruction[id]['rLegend']:
@@ -1276,7 +1277,8 @@
                                                         map = self.instruction[mapId]['map'],
                                                         mapType = self.instruction[mapId]['mapType'],
                                                         rect = self.instruction[mapId]['rect'])
-                        if self.instruction[mapId]['scaleType'] == 1:
+                        elif self.instruction[mapId]['scaleType'] == 1:
                             scale, foo, rect = AutoAdjust(self, scaleType = 1,
                                                         region = self.instruction[mapId]['region'],
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py	2011-04-01 20:17:04 UTC (rev 45823)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py	2011-04-02 09:21:43 UTC (rev 45824)
@@ -316,7 +316,8 @@
         vectorMapNumber = 1
         file.seek(0)
         for line in file:
+            if not line.strip():
+                continue
             line = line.strip()
             if isBuffer:
                 buffer.append(line)
@@ -656,7 +657,7 @@
         # scale
         if self.instruction['scaleType'] == 3: #fixed scale
-            scaleInstruction = "scale 1:%.0f" % 1/self.instruction['scale']
+            scaleInstruction = "scale 1:%.0f" % (1/self.instruction['scale'])
             instr += scaleInstruction
             instr += '\n'
         # border
@@ -862,7 +863,7 @@
     def __str__(self):
         text = self.instruction['text'].replace('\n','\\n')
-        instr = "text %.3f %.3f" % (self.instruction['east'], self.instruction['north'])
+        instr = "text %s %s" % (self.instruction['east'], self.instruction['north'])
         instr += " %s\n" % text
         instr += string.Template("    font $font\n    fontsize $fontsize\n    color $color\n").substitute(self.instruction)
         instr += string.Template("    hcolor $hcolor\n").substitute(self.instruction)
@@ -920,9 +921,9 @@
                 elif sub == 'rotate':
                     instr['rotate'] = float(line.split(None, 1)[1])
                 elif sub == 'xoffset':
-                    instr['xoffset'] = float(line.split(None, 1)[1])
+                    instr['xoffset'] = int(line.split(None, 1)[1])
                 elif sub == 'yoffset':
-                    instr['yoffset'] = float(line.split(None, 1)[1])
+                    instr['yoffset'] = int(line.split(None, 1)[1])
                 elif sub == 'opaque':
                     if line.split(None, 1)[1].lower() in ('n', 'none'):
                         instr['background'] = 'none'
@@ -1507,7 +1508,7 @@
             if line.startswith('lpos'):
                 instr['lpos'] = int(line.split()[1])
             elif line.startswith('label'):
-                instr['label'] = line.split()[1]
+                instr['label'] = line.split(None, 1)[1]
             elif line.startswith('layer'):
                 instr['layer'] = line.split()[1]
             elif line.startswith('masked'):
@@ -2466,6 +2467,7 @@
         if notebook:
             self.parent.AddPage(page = self, text = _("Vector maps"))
+            self.parent = self.parent.GetParent()
     def _layout(self):
         """!Do layout"""
@@ -5051,18 +5053,12 @@
         #effects
         if self.effect['backgroundCtrl'].GetValue():
             background = self.effect['backgroundColor'].GetColour()
-##            if background.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
-##                self.textDict['background'] = background.GetAsString(wx.C2S_NAME)
-##            else:
             self.textDict['background'] = convertRGB(background)
         else:
             self.textDict['background'] = 'none'
         if self.effect['borderCtrl'].GetValue():
             border = self.effect['borderColor'].GetColour()
-##            if border.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
-##                self.textDict['border'] = border.GetAsString(wx.C2S_NAME)
-##            else:
             self.textDict['border'] = convertRGB(border)
         else:
             self.textDict['border'] = 'none'
@@ -5071,9 +5067,6 @@
         if self.effect['highlightCtrl'].GetValue():
             highlight = self.effect['highlightColor'].GetColour()
-##            if highlight.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
-##                self.textDict['hcolor'] = highlight.GetAsString(wx.C2S_NAME)
-##            else:
             self.textDict['hcolor'] = convertRGB(highlight)
         else:
             self.textDict['hcolor'] = 'none'
