[GRASS-SVN] r45827 - grass-addons/display/d.barb
Sun Apr 3 01:03:30 EDT 2011
Author: hamish
Date: 2011-04-02 22:03:30 -0700 (Sat, 02 Apr 2011)
New Revision: 45827
   grass-addons/display/d.barb/draw.c
   grass-addons/display/d.barb/local_proto.h
   grass-addons/display/d.barb/main.c
   grass-addons/display/d.barb/points.c
add support for u,v vector maps
Modified: grass-addons/display/d.barb/draw.c
--- grass-addons/display/d.barb/draw.c	2011-04-03 04:11:46 UTC (rev 45826)
+++ grass-addons/display/d.barb/draw.c	2011-04-03 05:03:30 UTC (rev 45827)
@@ -6,10 +6,7 @@
 #include <grass/glocale.h>
 #include "local_proto.h"
-#define RpD ((2 * M_PI) / 360.)	/* radians/degree */
-#define D2R(d) (double)(d * RpD)	/* degrees->radians */
 /* draw a single barb at the given map coordinates */
 void draw_barb(double easting, double northing, double velocity,
 	       double compass_deg, int color, double scale, int style)
Modified: grass-addons/display/d.barb/local_proto.h
--- grass-addons/display/d.barb/local_proto.h	2011-04-03 04:11:46 UTC (rev 45826)
+++ grass-addons/display/d.barb/local_proto.h	2011-04-03 05:03:30 UTC (rev 45827)
@@ -10,6 +10,10 @@
 #define TYPE_BARB 1
 #define TYPE_ARROW 2
+#define RpD ((2 * M_PI) / 360.)		/* radians/degree */
+#define D2R(d) (double)(d * RpD)	/* degrees->radians */
+#define R2D(d) (double)(d / RpD)	/* radians->degrees */
 /* grid.c */
 void do_barb_grid(char *, char *, int, int, int, double, int, int);
Modified: grass-addons/display/d.barb/main.c
--- grass-addons/display/d.barb/main.c	2011-04-03 04:11:46 UTC (rev 45826)
+++ grass-addons/display/d.barb/main.c	2011-04-03 05:03:30 UTC (rev 45827)
@@ -173,7 +173,7 @@
     if (u_opt->answer && v_opt->answer) {
 	is_component = TRUE;
-	strncpy(dir_u_map, u_opt->answer, sizeof(dir_u_map) - 1);	/* FIXME: not well null terminated on overflow */
+	strncpy(dir_u_map, u_opt->answer, sizeof(dir_u_map) - 1);
 	strncpy(mag_v_map, v_opt->answer, sizeof(mag_v_map) - 1);
     else if (dir_opt->answer && magn_opt->answer) {
@@ -181,6 +181,8 @@
 	strncpy(dir_u_map, dir_opt->answer, sizeof(dir_u_map) - 1);
 	strncpy(mag_v_map, magn_opt->answer, sizeof(mag_v_map) - 1);
+    dir_u_map[sizeof(dir_u_map) - 1] = '\0'; /* strncpy() doesn't null-terminate on overflow */
+    mag_v_map[sizeof(mag_v_map) - 1] = '\0';
     if (vinput_opt->answer)
 	is_vector = TRUE;
@@ -231,8 +233,6 @@
     color = D_parse_color(color_opt->answer, 0);
-    /*////// do it ////////// */
     // is D_setup() actually needed?
     D_setup(0);
Modified: grass-addons/display/d.barb/points.c
--- grass-addons/display/d.barb/points.c	2011-04-03 04:11:46 UTC (rev 45826)
+++ grass-addons/display/d.barb/points.c	2011-04-03 05:03:30 UTC (rev 45827)
@@ -67,28 +67,11 @@
-    // to figure out:
-    //   also pass u,v columns and calc dir,mag prior to filling dirn,magn arrays
-    /* somehow check, load attributes            see d.vect  */
-       if(is_component) {
-       read u attrib;
-       read v attrib;
-       dir= ...calc;
-       velo= ...calc;
-       else {
-       read dir attrib;
-       read velo attrib;
-       if (aspect_type == TYPE_COMPASS)
-       dir = 90 - dir;
+    /* todone?
+    if (aspect_type == TYPE_COMPASS)
+           dir = 90 - dir;
     peak = max_magnitude(magn, num_pts);
     G_debug(0, "  peak = %.2f", peak);
     if (style == TYPE_BARB && peak > 150)
@@ -167,6 +150,7 @@
     dbDriver *driver = NULL;
     dbCatValArray cvarr_dir_u, cvarr_mag_v;
     dbCatVal *cv_dir_u = NULL, *cv_mag_v = NULL;
+    double theta, r;
     G_debug(0, "fill_arrays()");
@@ -248,9 +232,9 @@
 	G_debug(5, "  Xs[%d] = %.2f  Ys[%d] = %.2f  cat = %d", i, Xs[i],
 		i, Ys[i], Cats->cat[0]);
 	/* Read rotation from db */
-	if (db_CatValArray_get_value(&cvarr_dir_u, Cats->cat[0], &cv_dir_u) !=
-	    DB_OK)
+	if (db_CatValArray_get_value(&cvarr_dir_u, Cats->cat[0], &cv_dir_u) != DB_OK)
 	    Dirs[i] = 0.0 / 0.0;	/* NaN */
 	else
 	    Dirs[i] = cvarr_dir_u.ctype == DB_C_TYPE_INT ?
@@ -265,10 +249,20 @@
 	    else
 		Mags[i] = cvarr_mag_v.ctype == DB_C_TYPE_INT ?
 		    (double)cv_mag_v->val.i : cv_mag_v->val.d;
+	    if (!is_uv) {
+		if (Mags[i] < 0)  /* magnitude is scalar and can only be positive */
+		    Mags[i] = 0;
-	    if (Mags[i] < 0)	/* magnitude is scalar and can only be positive */
-		Mags[i] = 0;
+	if(is_uv) {
+	    /* now that we have the data loaded, cycle back and process it */
+	    theta = R2D(atan2(Mags[i], Dirs[i]));
+	    r = sqrt(Dirs[i]*Dirs[i] + Mags[i]*Mags[i]);
+	    Dirs[i] = theta;
+	    Mags[i] = r;
 	G_debug(5, "    Dirs[%d] = %.2f  Mags[%d] = %.2f", i, Dirs[i],
 		i, Mags[i]);
 	i++;
