[GRASS-SVN] r45829 - grass/branches/releasebranch_6_4/gui/wxpython
Sun Apr 3 03:41:40 EDT 2011
Author: martinl
Date: 2011-04-03 00:41:39 -0700 (Sun, 03 Apr 2011)
New Revision: 45829
   grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
#1340 (wxGUI uses improper .grassrc syntax and may cause .grassrc file
corruption)
(merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py	2011-04-03 05:05:07 UTC (rev 45828)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py	2011-04-03 07:41:39 UTC (rev 45829)
@@ -393,7 +393,7 @@
                     grassrc[key.strip()] = val.strip()
             finally:
                 rc.close()
         return grassrc
     def GetRCValue(self, value):
@@ -608,11 +608,11 @@
                 self.listOfMapsetsSelectable +=  line.split(' ')
         except:
             gcmd.RunCommand("g.gisenv",
-                            set =  "GISDBASE = %s" % self.gisdbase)
+                            set = "GISDBASE=%s" % self.gisdbase)
-                            set = "LOCATION_NAME = %s" % locationName)
+                            set = "LOCATION_NAME=%s" % locationName)
-                            set = "MAPSET = PERMANENT")
+                            set = "MAPSET=PERMANENT")
             # first run only
             self.listOfMapsetsSelectable = copy.copy(self.listOfMapsets)
@@ -737,13 +737,13 @@
     def OnStart(self, event):
         """'Start GRASS' button clicked"""
-                        set = "GISDBASE = %s" % \
+                        set = "GISDBASE=%s" % \
                             self.tgisdbase.GetValue())
-                        set = "LOCATION_NAME = %s" % \
+                        set = "LOCATION_NAME=%s" % \
                             self.listOfLocations[self.lblocations.GetSelection()])
-                        set = "MAPSET = %s" % \
+                        set = "MAPSET=%s" % \
                             self.listOfMapsets[self.lbmapsets.GetSelection()])
         self.Destroy()
