[GRASS-SVN] r45852 - grass-addons/gui/wxpython/wx.psmap/gui_modules
svn_grass at osgeo.org
Mon Apr 4 16:16:06 EDT 2011
Author: annakrat
Date: 2011-04-04 13:16:06 -0700 (Mon, 04 Apr 2011)
New Revision: 45852
grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
small changes in generating preview
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py 2011-04-04 19:37:06 UTC (rev 45851)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py 2011-04-04 20:16:06 UTC (rev 45852)
@@ -357,9 +357,14 @@
instrFileFd.close()
temp = False
+ regOld = grass.region()
if not filename:
temp = True
filename = grass.tempfile()
+ if self.instruction.FindInstructionByType('map'):
+ mapId = self.instruction.FindInstructionByType('map').id
+ SetResolution(dpi = 100, width = self.instruction[mapId]['rect'][2],
+ height = self.instruction[mapId]['rect'][3])
cmd = ['ps.map', '--overwrite']
if os.path.splitext(filename)[1] == '.eps':
@@ -370,7 +375,8 @@
cmd.append('output=%s' % filename)
self.SetStatusText(_('Generating preview...'), 0)
- self.cmdThread.RunCmd(cmd, userData = {'instrFile' : instrFile, 'filename' : filename, 'temp' : temp })
+ self.cmdThread.RunCmd(cmd, userData = {'instrFile' : instrFile, 'filename' : filename,
+ 'temp' : temp, 'regionOld' : regOld})
def OnCmdDone(self, event):
"""!ps.map process finished"""
@@ -380,12 +386,13 @@
message = _("Ps.map exited with return code %s") % event.returncode)
return
- if haveImage:
+ if haveImage and event.userData['temp']:
+ RunCommand('g.region', cols = event.userData['regionOld']['cols'], rows = event.userData['regionOld']['rows'])
try:
im = Image.open(event.userData['filename'])
if self.instruction[self.pageId]['Orientation'] == 'Landscape':
im = im.rotate(270)
- im.save(self.imgName, format = 'png', optimize = 1)
+ im.save(self.imgName, format = 'png')
except IOError, e:
GError(parent = self,
@@ -825,7 +832,7 @@
self.instruction[id]['coords'][1] += extent[0]/2 * sin(rot/180*pi)
self.instruction[id]['coords'][0] += self.instruction[id]['xoffset']
- self.instruction[id]['coords'][1] += self.instruction[id]['yoffset']
+ self.instruction[id]['coords'][1] -= self.instruction[id]['yoffset']
coords = self.instruction[id]['coords']
self.instruction[id]['rect'] = bounds = self.getModifiedTextBounds(coords[0], coords[1], extent, rot)
self.canvas.DrawRotText(pdc = self.canvas.pdcObj, drawId = id,
@@ -1346,7 +1353,7 @@
elif itype == 'text':
x, y = self.instruction[id]['coords'][0] - self.instruction[id]['xoffset'],\
- self.instruction[id]['coords'][1] - self.instruction[id]['yoffset']
+ self.instruction[id]['coords'][1] + self.instruction[id]['yoffset']
extent = self.parent.getTextExtent(textDict = self.instruction[id])
rot = float(self.instruction[id]['rotate'])/180*pi if self.instruction[id]['rotate'] is not None else 0
if self.instruction[id]['ref'].split()[0] == 'lower':
