[GRASS-SVN] r45870 - grass/trunk/raster/simwe/simlib
svn_grass at osgeo.org
Fri Apr 8 03:22:38 EDT 2011
Author: mmetz
Date: 2011-04-08 00:22:38 -0700 (Fri, 08 Apr 2011)
New Revision: 45870
grass/trunk/raster/simwe/simlib/hydro.c
grass/trunk/raster/simwe/simlib/output.c
fix: arrays in C are zero-based
Modified: grass/trunk/raster/simwe/simlib/hydro.c
--- grass/trunk/raster/simwe/simlib/hydro.c 2011-04-08 06:30:18 UTC (rev 45869)
+++ grass/trunk/raster/simwe/simlib/hydro.c 2011-04-08 07:22:38 UTC (rev 45870)
@@ -89,6 +89,8 @@
float **dc, **tau, **er, **ct, **trap;
float **dif;
+/* suspected BUG below: fist array subscripts go from 1 to MAXW
+ * correct: from 0 to MAXW - 1, e.g for (lw = 0; lw < MAXW; lw++) */
double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3];
int iflag[MAXW];
@@ -199,26 +201,25 @@
/*G_debug(2, " gen,gen2,wei,wei2,mgen3,nmult: %f %f %f %f %d %d",gen,gen2,wei,wei2,mgen3,nmult);
for (iw = 1; iw <= mgen + 1; iw++) { /* assign walkers */
- ++lw;
- if (lw > MAXW)
+ if (lw >= MAXW) /* max valid value is MAXW - 1, not MAXW */
G_fatal_error(_("nwalk (%d) > maxw (%d)!"), lw, MAXW);
- w[lw][1] = x + stepx * (ulec() - 0.5);
- w[lw][2] = y + stepy * (ulec() - 0.5);
- w[lw][3] = wei;
+ w[lw][0] = x + stepx * (ulec() - 0.5);
+ w[lw][1] = y + stepy * (ulec() - 0.5);
+ w[lw][2] = wei;
- walkwe += w[lw][3];
- vavg[lw][1] = v1[k][l];
- vavg[lw][2] = v2[k][l];
- if (w[lw][1] >= xmin && w[lw][2] >= ymin &&
- w[lw][1] <= xmax && w[lw][2] <= ymax) {
+ walkwe += w[lw][2];
+ vavg[lw][0] = v1[k][l];
+ vavg[lw][1] = v2[k][l];
+ if (w[lw][0] >= xmin && w[lw][1] >= ymin &&
+ w[lw][0] <= xmax && w[lw][1] <= ymax) {
iflag[lw] = 0;
else {
iflag[lw] = 1;
+ lw++;
} /*DEFined area */
@@ -270,11 +271,11 @@
nwalka = 0;
nstack = 0;
- for (lw = 1; lw <= nwalk; lw++) {
- if (w[lw][3] > EPS) { /* check the walker weight */
+ for (lw = 0; lw < nwalk; lw++) {
+ if (w[lw][2] > EPS) { /* check the walker weight */
++nwalka;
- l = (int)((w[lw][1] + stxm) / stepx) - mx - 1;
- k = (int)((w[lw][2] + stym) / stepy) - my - 1;
+ l = (int)((w[lw][0] + stxm) / stepx) - mx - 1;
+ k = (int)((w[lw][1] + stym) / stepy) - my - 1;
if (l > mx - 1 || k > my - 1 || k < 0 || l < 0) {
@@ -291,28 +292,28 @@
if (infil != NULL) { /* infiltration part */
if (inf[k][l] - si[k][l] > 0.) {
- decr = pow(addac * w[lw][3], 3. / 5.); /* decreasing factor in m */
+ decr = pow(addac * w[lw][2], 3. / 5.); /* decreasing factor in m */
if (inf[k][l] > decr) {
inf[k][l] -= decr; /* decrease infilt. in cell and eliminate the walker */
- w[lw][3] = 0.;
+ w[lw][2] = 0.;
else {
- w[lw][3] -= pow(inf[k][l], 5. / 3.) / addac; /* use just proportional part of the walker weight */
+ w[lw][2] -= pow(inf[k][l], 5. / 3.) / addac; /* use just proportional part of the walker weight */
inf[k][l] = 0.;
- gama[k][l] += (addac * w[lw][3]); /* add walker weigh to water depth or conc. */
+ gama[k][l] += (addac * w[lw][2]); /* add walker weigh to water depth or conc. */
d1 = gama[k][l] * conn;
hhc = pow(d1, 3. / 5.);
if (hhc > hhmax && wdepth == NULL) { /* increased diffusion if w.depth > hhmax */
dif[k][l] = (halpha + 1) * deldif;
- velx = vavg[lw][1];
- vely = vavg[lw][2];
+ velx = vavg[lw][0];
+ vely = vavg[lw][1];
else {
dif[k][l] = deldif;
@@ -334,29 +335,29 @@
gaux = gasdev();
gauy = gasdev();
- w[lw][1] += (velx + dif[k][l] * gaux); /* move the walker */
- w[lw][2] += (vely + dif[k][l] * gauy);
+ w[lw][0] += (velx + dif[k][l] * gaux); /* move the walker */
+ w[lw][1] += (vely + dif[k][l] * gauy);
- vavg[lw][1] = hbeta * (vavg[lw][1] + v1[k][l]);
- vavg[lw][2] = hbeta * (vavg[lw][2] + v2[k][l]);
+ vavg[lw][0] = hbeta * (vavg[lw][0] + v1[k][l]);
+ vavg[lw][1] = hbeta * (vavg[lw][1] + v2[k][l]);
- if (w[lw][1] <= xmin || w[lw][2] <= ymin || w[lw][1]
- >= xmax || w[lw][2] >= ymax) {
- w[lw][3] = 1e-10; /* eliminate walker if it is out of area */
+ if (w[lw][0] <= xmin || w[lw][1] <= ymin || w[lw][0]
+ >= xmax || w[lw][1] >= ymax) {
+ w[lw][2] = 1e-10; /* eliminate walker if it is out of area */
else {
if (wdepth != NULL) {
- w[lw][3] *= sigma[k][l];
+ w[lw][2] *= sigma[k][l];
} /* else */
} /*DEFined area */
else {
} /* lw loop */
@@ -367,21 +368,21 @@
if ((i == miter || i == iter1)) {
nstack = 0;
/* Compute the elevation raster map index */
/* Check for correct elevation raster map index */
if(l < 0 || l >= mx || k < 0 || k >= my)
continue;
- if (w[lw][3] > EPS && zz[k][l] != UNDEF) {
+ if (w[lw][2] > EPS && zz[k][l] != UNDEF) {
/* Save the 3d position of the walker */
- stack[nstack][1] = mixx / conv + w[lw][1] / conv;
- stack[nstack][2] = miyy / conv + w[lw][2] / conv;
- stack[nstack][3] = zz[k][l];
+ stack[nstack][0] = mixx / conv + w[lw][0] / conv;
+ stack[nstack][1] = miyy / conv + w[lw][1] / conv;
+ stack[nstack][2] = zz[k][l];
nstack++;
Modified: grass/trunk/raster/simwe/simlib/output.c
--- grass/trunk/raster/simwe/simlib/output.c 2011-04-08 06:30:18 UTC (rev 45869)
+++ grass/trunk/raster/simwe/simlib/output.c 2011-04-08 07:22:38 UTC (rev 45870)
@@ -46,9 +46,9 @@
Cats = Vect_new_cats_struct();
for (i = 0; i < nstack; i++) {
- x = (float)stack[i][1];
- y = (float)stack[i][2];
- z = (float)stack[i][3];
+ x = stack[i][0];
+ y = stack[i][1];
+ z = stack[i][2];
Vect_reset_line(Points);
Vect_reset_cats(Cats);
