[GRASS-SVN] r45880 - grass/trunk
svn_grass at osgeo.org
Sat Apr 9 08:43:50 EDT 2011
Author: martinl
Date: 2011-04-09 05:43:50 -0700 (Sat, 09 Apr 2011)
New Revision: 45880
Removed:
grass/trunk/SUBMITTING_SCRIPTS
grass/trunk/SUBMITTING_DOCS
grass/trunk/SUBMITTING_PYTHON
update SUBMITTINGS for GRASS7, shell script rules removed
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING 2011-04-09 03:58:52 UTC (rev 45879)
+++ grass/trunk/SUBMITTING 2011-04-09 12:43:50 UTC (rev 45880)
@@ -1,19 +1,14 @@
-$Date$
NOTE: Please improve this list!
-Dear (new) GRASS Developer,
+Dear (new) GRASS developer,
-When submitting C code to GRASS SVN repository, please take care of
+when submitting C code to GRASS SVN repository, please take care of
following rules:
-[ see SUBMITTING_SCRIPTS for shell script hints ]
-[ see SUBMITTING_TCLTK for tcl and tk hints ]
-[ see SUBMITTING_DOCS for documentation ]
-[ see SUBMITTING_PYTHON for Python code hints ]
+[ see also SUBMITTING_PYTHON for Python code hints ]
+[ see alse SUBMITTING_DOCS for documentation ]
-1. Get and read the GRASS 6 Programmer's Manual here:
+1. Get and read the GRASS Programmer's Manual here:
http://grass.osgeo.org/programming7/
or generate it from this source code (the programmer's manual is
@@ -25,39 +20,32 @@
2. Use the directory structure to place your module appropriately into
the source tree
- libes go into lib/
- - raster goes into raster/
- - vector goes into vector/
+ - raster modules go into raster/
+ - vector modules go into vector/
Consider to take a look at "GNU Coding Standards"
http://www.gnu.org/prep/standards.html
- In future, there will be a centralized contribution directory.
+3. Add a header section to each file you submit and make sure you
+ include the copyright. The purpose section is meant to contain a
+ general overview of the code in the file to assist other
+ programmers that will need to make changes to your code. If you
+ are modifying an existing file you may under no circumstances
+ remove prior copyright or licensing text that is not your own,
+ even for a major rewrite. If any original code or code that is in
+ part derived from another's original work remains, it must be
+ properly cited.
-3. Add a header section to each file you submit and make sure you include
- the copyright. The purpose section is meant to contain a general
- overview of the code in the file to assist other programmers that will
- need to make changes to your code. If you are modifying an existing
- file you may under no circumstances remove prior copyright or licensing
- text that is not your own, even for a major rewrite. If any original
- code or code that is in part derived from another's original work
- remains, it must be properly cited.
Example (ficticious header for a file called color.c) :
- * MODULE: d.rast (or new higher level module name (eg GRASS core))
- * AUTHOR(S): Original author unknown - probably CERL
- * John Doe <jdoe at somewhere org>
- * PURPOSE: To provide storage and manipulation of colors used for
- * rendering the raster. The colors are stored in a doubly linked
- * list which must be initialized with InitColors() before it can
- * be used. Note that most linked list functionality (add,
- * remove, get) is supported, but there is no sorting
- * functionality.
- * COPYRIGHT: (C) 2010 by the GRASS Development Team
+ * MODULE: g.foo
+ * AUTHOR(S): John Doe <jdoe at somewhere org>
+ * PURPOSE: Provide short description of module here...
+ * COPYRIGHT: (C) 2010 by John Doe, and the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the COPYING file that comes with GRASS
@@ -69,8 +57,7 @@
License (www.gnu.org).
-4. - deleted.
- We don't want the $ID$ in source code any more as it causes problems
+4. We don't want the $ID$ in source code any more as it causes problems
for the SVN branches.
@@ -113,6 +100,8 @@
void G_something(void)
/* Snipped out code */
+ return;
int G_something_else(int x, int y)
@@ -123,7 +112,8 @@
-8. Module exit status is defined as EXIT_SUCCESS or EXIT_FAILURE, e.g.
+8. Module exit status is defined as EXIT_SUCCESS or EXIT_FAILURE
+ (declared in stdlib.h), e.g.
@@ -135,13 +125,13 @@
-9. Use fprintf instead of printf. But:
+9. Use fprintf() instead of printf()
For errors and warnings please use the G_fatal_error() and
G_warning() functions. General messages for the user should use
G_message() while debug messages should use G_debug() whenever
possible. There are two variants to G_message(): G_verbose_message()
- which will only display the message if in verbose mode, and
+ which will only display the message if in --verbose mode, and
G_important_message() which will always show the message unless
the module is running in --quiet mode. G_fatal_error() and
G_warning() will always be displayed regardless of verbosity setting.
@@ -194,7 +184,6 @@
G_setenv() instead of setenv()
G_unsetenv() instead of unsetenv()
G_sleep() instead of sleep()
- G_system() instead of system()
Could somebody please add others (please verify that they are
useful and safe first)
@@ -289,7 +278,7 @@
Examples: see below examples or others
raster/r.info/Makefile
- vector/v.digit/Makefile
+ vector/v.edit/Makefile
If you are unsure, please ask on the GRASS Developers list.
@@ -311,7 +300,6 @@
23. Add/update, if required the related GUI menus:
- gui/tcltk/gis.m/gmmenu.tcl
gui/wxpython/xml/menudata.xml
@@ -374,7 +362,7 @@
Consider to subscribe to the GRASS Quality Assessment System to
get immediate notification about the code quality:
- http://www.grass-gis.org/mailman/listinfo/grass-qa
+ http://lists.osgeo.org/mailman/listinfo/grass-qa
29. When submitting new files to the repository set SVN properties,
@@ -428,6 +416,8 @@
(please update the list...)
+ For your convenience use the tools/module_svn_propset.sh script.
30. Use doxygen style for source code documentation. It is required
for GRASS libraries, but also recommended for GRASS modules.
@@ -438,26 +428,23 @@
For files
\file snap.c
\brief Vector library - Clean vector map (snap lines)
(C) 2001-2008 by the GRASS Development Team
- This program is free software under the
- GNU General Public License (>=v2).
- Read the file COPYING that comes with GRASS
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
for details.
\author Radim Blazek
- \date 2001-2008
For functions
\brief Snap lines in vector map to existing vertex in threshold
For details see Vect_snap_lines_list()
@@ -481,7 +468,7 @@
32. In case of questions feel free to contact the developers at the above
mailing list.
- http://www.grass-gis.org/devel/index.php#submission
+ http://grass.osgeo.org/devel/index.php#submission
[please add further hints if required]
Modified: grass/trunk/SUBMITTING_DOCS
--- grass/trunk/SUBMITTING_DOCS 2011-04-09 03:58:52 UTC (rev 45879)
+++ grass/trunk/SUBMITTING_DOCS 2011-04-09 12:43:50 UTC (rev 45880)
@@ -1,15 +1,11 @@
-$Date$
-When submitting documentation to GRASS SVN repository, please take
+when submitting documentation to GRASS SVN repository, please take
care of following rules:
-[ see SUBMITTING for C hints ]
+[ see SUBMITTING for C hints ]
@@ -17,7 +13,7 @@
There are two types of documentation
- Libraries programmers docs: we use doxygen and document the functions
- directly in the source code. See lib/*/*.c and lib/*/*.dox for examples
+ directly in the source code. See lib/gis/*.c and lib/gis/gislib.dox for examples
- User manual: we write it in simple HTML, storing the manual in a
file '<module>.html' within the subdirectory of the module.
@@ -75,7 +71,7 @@
Examples (please add some) should be coded like this:
<div class="code"><pre>
- v.to.db map=soils type=area option=area col=area_size unit=h
+ v.to.db map=soils type=area option=area column=area_size unit=h
</pre></div>
The online WWW man pages is updated every Saturday (from SVN
@@ -85,9 +81,9 @@
3. Usage of limited HTML tags
Since the MAN conversion of g.html2man is limited, please use
no other HTML tags than:
- <A> <B> <BLINK> <BODY> <BR> <CODE> <DD> <DL> <DT> <EM>
- <H2> <H3> <H4> <HEAD> <HEADER> <HR> <I> <IMG> <LI> <OL> <P>
- <PRE> <SUP> <TABLE> <TD> <TH> <TITLE> <TR> <UL>
+ <a> <b> <blink> <body> <br> <code> <dd> <dl> <dt> <em>
+ <h2> <h3> <h4> <head> <header> <hr> <i> <img> <li> <ol> <p>
+ <pre> <sup> <table> <td> <th> <title> <tr> <ul>
4. Suggested HTML markup protocol:
Modified: grass/trunk/SUBMITTING_PYTHON
--- grass/trunk/SUBMITTING_PYTHON 2011-04-09 03:58:52 UTC (rev 45879)
+++ grass/trunk/SUBMITTING_PYTHON 2011-04-09 12:43:50 UTC (rev 45880)
@@ -1,114 +1,186 @@
-$Date$
-When submitting Python code to GRASS SVN repository, please take
+when submitting Python code to GRASS SVN repository, please take
-1. Indentation
+0. Indentation
- As Python determines nesting based upon indentation, it
- isn't just a stylistic issue.
+ As Python determines nesting based upon indentation, it isn't just
+ a stylistic issue.
Please use 4-space indentation (GNU Emacs python-mode default).
See also "Python Style Guide" by Guido van Rossum
http://www.python.org/doc/essays/styleguide.html
+1. Instructions for the GRASS script parser can be found in the g.parser
+ module's help page.
+ http://grass.osgeo.org/grass70/manuals/html70_user/g.parser.html
-2. Add a header section to the script you submit and make sure you
+2. Use the directory structure to place your script appropriately into
+ the source tree
+ - scripts go into scripts/
+ Also add a Makefile and a <module>.html file into this directory.
+ See existing Python scripts for examples.
+3. Add a header section to the script you submit and make sure you
general over view of the code in the file to assist other
programmers that will need to make changes to your code. For this
purpose use Python Docstring, see
http://epydoc.sourceforge.net/docstrings.html
- Example (fictitious header for a script called r.myscript):
+ Example (fictitious header for a script called g.myscript):
-MODULE: r.myscript
+MODULE: g.myscript
-AUTHOR(S): Me <email AT some domain>
+AUTHOR(S): John Doe <email AT some domain>
-PURPOSE: Calculates univariate statistics from a GRASS raster map
+PURPOSE: Describe your script here...
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007 John Doe, and by the GRASS Development Team
for details.
- The copyright protects your rights according to GNU General Public
- License (www.gnu.org).
+ The copyright protects your rights according to GNU General Public
+ License (www.gnu.org).
+ You can easily autogenerate the header and parameters from an existing
+ module using the --script flag. Example:
-3. - deleted.
- We don't want the $ ID $ in source code any more as it causes problems
+ d.rast --script
+ Just select an existing module which is close to your application to save
+ efforts.
+4. We don't want the $ ID $ in source code any more as it causes problems
for the branches.
+5. Create and use secure temporary files and directories. Use the
+ grass.tempfile() or grass.tempdir() functions to do this. e.g.
-4. PLEASE take the time to add comments throughout your code explaining what
+ # setup temporary file
+ TMP = grass.tempfile()
+ if TMP is None:
+ grass.fatal("Unable to create temporary files")
+6. Use grass.findfile() when there is a need to test if a map exists.
+ # test for input raster map
+ result = grass.find_file(name = map_name, element = 'cell', quiet = True)
+ if not result['file']
+ grass.fatal("Raster map <%s> not found" % map_name)
+ # test for input vector map
+ result = grass.find_file(name = map_name, element = 'vector', quiet = True)
+ grass.fatal("Vector map <%s> not found" % map_name)
+ ... and so forth. See 'g.manual g.findfile' for details.
+7. For any informational output, use the grass.message()
+ function. For error messages should be used grass.fatal_error() or
+ grass.error() and for warnings grass.warning(). For debugging
+ purposes grass.debug().
+ #normal message:
+ grass.message("Done")
+ # warning:
+ grass.warning("No input values found, using default values")
+ # error:
+ grass.error("No map found")
+ # fatal error:
+ grass.fatal_error("No map found, exiting")
+ # debug output (use g.gisenv to enable/disable)
+ grass.debug("Our calculated value is: %d" % value)
+ Try to omit any usage of the 'print' command for informational output.
+8. PLEASE take the time to add comments throughout your code explaining what
the code is doing. It will save a HUGE amount of time and frustration for
other programmers that may have to change your code in the future.
-5. Make sure a new line is at the end of each file.
+9. Make sure a new line is at the end of each file.
-6. For consistency, use README rather than README.txt for any README files.
+10. For consistency, use README rather than README.txt for any README files.
-7. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
- You can re-check before submission with 'svn diff':
+11. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
+ You can re-check before submission with 'svn diff':
- Be sure to create unified ("diff -u") format. "Plain" diffs (the default
- format) are risky, because they will apply without warning to code which
- has been substantially changed; they are also harder to read than unified.
+ Be sure to create unified ("diff -u") format. "Plain" diffs (the default
+ format) are risky, because they will apply without warning to code which
+ has been substantially changed; they are also harder to read than unified.
- Such diffs should be made from the top-level directory, e.g.
- "svn diff gui/wxpython/wxgui.py"; that way, the diff will
- include the pathname rather than just "wxgui.py".
+ Such diffs should be made from the top-level directory, e.g.
+ "svn diff gui/wxpython/wxgui.py"; that way, the diff will
+ include the pathname rather than just "wxgui.py".
-8. When submitting new files to the repository set SVN properties,
- usually for directory
+12. When submitting new files to the repository set SVN properties,
+ usually for directory
svn:ignore : *.pyc
- or e.g. for Python file
+ or e.g. for Python file
svn:mime-type : text/python
svn:keywords : Author Date Id
svn:eol-style : native
- See
- http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
+ See
+ http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
-9. wxGUI (gui/wxpython)
+13. wxGUI (gui/wxpython)
- See http://wiki.wxpython.org/wxPython_Style_Guide
+ See http://wiki.wxpython.org/wxPython_Style_Guide
+ Major rules:
-10. Tell the other developers about the new code using the following e-mail:
- grass-dev at lists.osgeo.org
+ - use named parameters in functions, e.g.
+ dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
+ wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
+ instead of
+ dlg = wx.FileDialog(self, _("Choose file to save current workspace"),
+ _("GRASS Workspace File (*.gxw)|*.gxw"), wx.FD_SAVE)
+ - use wx.ID_ANY instead of `-1`
+ - use gcmd.GError(), gcmd.GWarning and gcmd.GMessage instead of wx.MessageBox()
+ - use gcmd.RunCommand() instead of grass.run_command() or grass.read_command()
+14. Tell the other developers about the new code using the following e-mail:
+ grass-dev at lists.osgeo.org
- To subscribe to this mailing list, see
- http://lists.osgeo.org/mailman/listinfo/grass-dev
+ To subscribe to this mailing list, see
+ http://lists.osgeo.org/mailman/listinfo/grass-dev
-11. In case of questions feel free to contact the developers at the above
- mailing list.
+15. In case of questions feel free to contact the developers at the above
+ mailing list.
Deleted: grass/trunk/SUBMITTING_SCRIPTS
--- grass/trunk/SUBMITTING_SCRIPTS 2011-04-09 03:58:52 UTC (rev 45879)
+++ grass/trunk/SUBMITTING_SCRIPTS 2011-04-09 12:43:50 UTC (rev 45880)
@@ -1,250 +0,0 @@
-$Date$
-NOTE: Please improve this list!
-When submitting SHELL scripts to GRASS SVN repositiory,
-please take care of following rules:
-[ see SUBMITTING for C code hints ]
-0. Instructions for the GRASS script parser can be found in the g.parser
- module's help page.
- http://grass.osgeo.org/grass63/manuals/html63_user/g.parser.html
-1. Use the directory structure to place your script appropriately into
- the source tree
- - scripts go into scripts/
- Consider to take a look at [please suggest Shell tutorial].
- Also add a Makefile and a description.html file into this directory.
- See existing scripts for examples.
-2. Add a header section to the script you submit and make sure you include
- Example (ficticious header for a script called r.myscript) :
-#!/bin/sh
-# MODULE: r.myscript
-# AUTHOR(S): Me <email AT some domain>
-# PURPOSE: Calculates univariate statistics from a GRASS raster map
-# COPYRIGHT: (C) 2005 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
- You can easily autogenerate the header and parameters from an existing
- module using the --script flag. Example:
- d.rast --script
- Just select an existing module which is close to your application to save
- efforts.
-3. - deleted.
- We don't want the $ ID $ in scripts any more as it
- causes problems for the SVN branches.
-4. As a general principle, shell variables should almost always be quoted.
- Use only secure temp files, see g.tempfile and scripts/* for examples.
-5. [This rule is currently under review] If you search for a command in $PATH, do NOT
- use the "which" command or the "type -p" command. Both commands are not
- supported on all platforms, thus causing problems for some people. As an
- alternative, please use code similar to the following shell script snippet
- which will perform the same function. In this case, the path of the grass60
- command is saved if grass60 is found in $PATH. This won't recognize aliased
- command name.
- # Search for grass5 command in user's path
- for i in `echo $PATH | sed 's/^:/.:/
- s/::/:.:/g
- s/:$/:./
- s/:/ /g'`
- do
- if [ -f $i/grass5 ] ; then
- # Save the path of the grass60 command
- GRASS_PATH=$i/grass60
- # Use the first one in user's path
- break
- fi
- done
- If you must use "which", use as follows:
- # check if we have awk
- if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
- fi
-6. Add a test to check if the user is in GRASS before starting main part
- of script. Result of running the script is unpredicable otherwise.
- if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
- fi
- This is the only case, where g.message module (see below) can not be used.
- In all other cases, you should prefer it's usage over the 'echo' command.
-7. Create and use secure temporary files and directories. Use the g.tempfile
- module to do this. e.g.
- # setup temporary file
- TMP="`g.tempfile pid=$$`"
- if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- g.message -e "unable to create temporary files"
- exit 1
- fi
- For temportary directories remove the newly created file and mkdir using
- the same name. Beware of commands like "rm -f ${TMP}*" as this becomes
- "rm -f *" if $TMP is unset (hence the test above).
-8. Testing the existence of variables. For portability, use
- if [ -z "$VARIABLE" ] ; then
- instead of
- if [ "$VARIABLE" == "" ] ; then
- and
- if [ -n "$VARIABLE" ] ; then
- instead of
- if [ "$VARIABLE" != "" ] ; then
-9. Internationalization proofing Awk: In some areas (e.g. some European
- countries) the decimal place is held with a comma instead of a dot.
- When scanning variables awk doesn't understand this, so scripts need to
- temporarily discard locale settings before calling awk.
- # set environment so that awk works properly in all languages
- unset LC_ALL
- LC_NUMERIC=C
- export LC_NUMERIC
- awk '{print $1}'
-10. Use g.findfile when there is a need to test if a map exists.
- # test for input raster map
- g.findfile element=cell file="$INPUT" > /dev/null
- if [ $? -eq 0 ] ; then
- g.message -e "Raster map <$GIS_OPT_MAP> not found in mapset search path"
- exit 1
- fi
- # test for input vector map
- eval `g.findfile element=vector file=$GIS_OPT_MAP`
- if [ ! "$file" ] ; then
- g.message -e "Vector map <$GIS_OPT_MAP> not found in mapset search path"
- exit 1
- fi
- ... and so forth. See 'g.manual g.findfile' for details.
-11. For any informational output, use the g.message modul. This module should
- be also used for error messages and warnings. You can also use it for
- debugging purposes.
- #normal message:
- g.message "Done"
- # warning:
- g.message -w "No input values found, using default values"
- # error:
- g.message -e "No map found, exiting."
- # debug output (use g.gisenv to enable/disable)
- g.message -d "Our calculated value is: $value"
- Try to omit any usage of the 'echo' command for informational output.
-12. For consistency, use README rather than README.txt for any README files.
-13. Be sure to develop on top of the LATEST GRASS code (which is in SVN).
- You can re-check before submission with 'cvs diff':
- diffs (the default format) are risky, because they will apply without
- warning to code which has been substantially changed; they are also
- harder to read than unified.
- "cvs diff display/d.vect/main.c"; that way, the diff will
- include the pathname rather than just "main.c".
-14. For portability, scripts must work on any POSIX compliant shell, and
- therefore may not include any Bashisms. Test with ash for errors:
- ash -n scriptname
-15. When submitting new files to the repository set SVN properties,
- svn:ignore : *.tmp.html
- or e.g. for script file
- svn:executable : *
- svn:mime-type : text/x-sh
- svn:keywords : Author Date Id
- svn:eol-style : native
- See
-16. Tell the other developers about the new code using the following e-mail:
-17. In case of questions feel free to contact the developers at the above
- mailing list.
-[please add further hints if required]
-"Your attention to detail is appreciated."
