[GRASS-SVN] r45894 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sun Apr 10 17:12:17 EDT 2011
Author: martinl
Date: 2011-04-10 14:12:17 -0700 (Sun, 10 Apr 2011)
New Revision: 45894
grass/trunk/lib/gis/wind_scan.c
gislib: cosmetics in doxygen documentation
Modified: grass/trunk/lib/gis/wind_scan.c
--- grass/trunk/lib/gis/wind_scan.c 2011-04-10 21:04:34 UTC (rev 45893)
+++ grass/trunk/lib/gis/wind_scan.c 2011-04-10 21:12:17 UTC (rev 45894)
@@ -1,15 +1,15 @@
- * \file gis/wind_scan.c
- * \brief GIS Library - Window scanning functions.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
+ \file lib/gis/wind_scan.c
+ \brief GIS Library - Coordinate scanning functions.
+ (C) 2001-2009, 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL
#include <stdio.h>
#include <grass/gis.h>
@@ -17,18 +17,25 @@
static int scan_double(const char *, double *);
- * \brief ASCII northing to double.
- * Converts the ASCII "northing" coordinate string in <i>buf</i> to its
- * double representation (into <i>northing</i>).
- * \param buf buffer hold string northing
- * \param[out] northing northing
- * \param projection projection code
- * \return 0 on error
- * \return 1 on success
+ \brief ASCII northing to double.
+ Converts the ASCII "northing" coordinate string in <i>buf</i> to its
+ double representation (into <i>northing</i>).
+ Supported projection codes (see gis.h):
+ - PROJECTION_XY
+ - PROJECTION_UTM
+ - PROJECTION_SP
+ - PROJECTION_LL
+ - PROJECTION_OTHER
+ \param buf buffer hold string northing
+ \param[out] northing northing
+ \param projection projection code
+ \return 0 on error
+ \return 1 on success
int G_scan_northing(const char *buf, double *northing, int projection)
if (projection == PROJECTION_LL) {
@@ -44,18 +51,25 @@
- * \brief ASCII easting to double.
- * Converts the ASCII "easting" coordinate string in <i>buf</i> to its
- * double representation (into <i>easting</i>).
- * \param buf buffer containing string easting
- * \param[out] easting easting
+ \brief ASCII easting to double.
+ Converts the ASCII "easting" coordinate string in <i>buf</i> to its
+ double representation (into <i>easting</i>).
+ - PROJECTION_XY
+ - PROJECTION_UTM
+ - PROJECTION_SP
+ - PROJECTION_LL
+ \param buf buffer containing string easting
+ \param[out] easting easting
int G_scan_easting(const char *buf, double *easting, int projection)
@@ -75,18 +89,25 @@
- * \brief ASCII resolution to double.
- * Converts the ASCII "resolution" string in <i>buf</i> to its double
- * representation (into resolution).
- * \param buf buffer containing string resolution
- * \param[out] resolution resolution value
+ \brief ASCII resolution to double.
+ Converts the ASCII "resolution" string in <i>buf</i> to its double
+ representation (into resolution).
+ - PROJECTION_XY
+ - PROJECTION_UTM
+ - PROJECTION_SP
+ - PROJECTION_LL
+ \param buf buffer containing string resolution
+ \param[out] resolution resolution value
int G_scan_resolution(const char *buf, double *res, int projection)
