[GRASS-SVN] r45912 - grass/branches/develbranch_6/vector/v.out.ogr
svn_grass at osgeo.org
Tue Apr 12 03:07:57 EDT 2011
Author: martinl
Date: 2011-04-12 00:07:57 -0700 (Tue, 12 Apr 2011)
New Revision: 45912
grass/branches/develbranch_6/vector/v.out.ogr/main.c
v.out.ogr: support transactions (major speed up)
(merge r45911 from trunk)
Modified: grass/branches/develbranch_6/vector/v.out.ogr/main.c
--- grass/branches/develbranch_6/vector/v.out.ogr/main.c 2011-04-12 06:53:23 UTC (rev 45911)
+++ grass/branches/develbranch_6/vector/v.out.ogr/main.c 2011-04-12 07:07:57 UTC (rev 45912)
@@ -375,8 +375,7 @@
else {
if (otype & GV_POINT)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+ num_to_export += Vect_get_num_primitives(&In, GV_POINT);
if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
@@ -385,8 +384,7 @@
else {
if (otype & GV_LINE)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+ num_to_export += Vect_get_num_primitives(&In, GV_LINE);
if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
@@ -396,8 +394,7 @@
else {
if (otype & GV_BOUNDARY)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+ num_to_export += Vect_get_num_primitives(&In, GV_BOUNDARY);
if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
@@ -406,7 +403,7 @@
else {
if (otype & GV_AREA)
- num_to_export = num_to_export + Vect_get_num_areas(&In);
+ num_to_export += Vect_get_num_areas(&In);
if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
@@ -416,8 +413,7 @@
else {
if (otype & GV_CENTROID)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+ num_to_export += Vect_get_num_primitives(&In, GV_CENTROID);
if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
@@ -426,8 +422,7 @@
else {
if (otype & GV_FACE)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+ num_to_export += Vect_get_num_primitives(&In, GV_FACE);
if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
@@ -436,8 +431,7 @@
else {
if (otype & GV_KERNEL)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+ num_to_export += Vect_get_num_primitives(&In, GV_KERNEL);
if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
@@ -446,7 +440,7 @@
else {
if (otype & GV_VOLUME)
- num_to_export = num_to_export + Vect_get_num_volumes(&In);
+ num_to_export += Vect_get_num_volumes(&In);
G_debug(1, "Requested to export %d geometries", num_to_export);
@@ -582,7 +576,7 @@
CSLDestroy(papszLCO);
if (Ogr_layer == NULL)
G_fatal_error(_("Unable to create OGR layer"));
db_init_string(&dbstring);
/* Vector attributes -> OGR fields */
@@ -680,7 +674,6 @@
fout = fskip = nocat = noatt = nocatskip = 0;
/* Fetch all attribute records */
if (doatt) {
sprintf(buf, "SELECT * FROM %s", Fi->table);
@@ -692,8 +685,10 @@
cat);
+ if (OGR_L_TestCapability(Ogr_layer, OLCTransactions))
+ OGR_L_StartTransaction(Ogr_layer);
/* Lines (run always to count features of different type) */
if ((otype & GV_POINTS) || (otype & GV_LINES)) {
G_message(_("Exporting %i geometries..."), Vect_get_num_lines(&In));
@@ -979,6 +974,9 @@
G_warning(_("Export of volumes not implemented yet. Skipping."));
+ OGR_L_CommitTransaction(Ogr_layer);
OGR_DS_Destroy(Ogr_ds);
Vect_close(&In);
