[GRASS-SVN] r45926 - grass-addons/gui/wxpython/wx.psmap/docs
Tue Apr 12 16:10:46 EDT 2011
Author: martinl
Date: 2011-04-12 13:10:46 -0700 (Tue, 12 Apr 2011)
New Revision: 45926
   grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html
wx.psmap: cosmetics, indent manual page
Modified: grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html
--- grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html	2011-04-12 20:03:47 UTC (rev 45925)
+++ grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html	2011-04-12 20:10:46 UTC (rev 45926)
@@ -5,19 +5,28 @@
 <p>
 <b>Hardcopy Map Utility</b> also called wx.psmap is
-a <em><a href="wxGUI.html">wxGUI</a></em> extension which allows the user to create interactively hardcopy map outputs. This tool generates <a href="ps.map.html">ps.map</a> configuration file and then runs <a href="ps.map.html">ps.map</a> to create PostScript output. There are two modes - <em>Draft mode</em> for map composing and <em>Preview mode</em> to see the final output. In draft mode map features (like legend or scalebar) are represented by a colored rectangle with a label.
+a <em><a href="wxGUI.html">wxGUI</a></em> extension which allows the
+user to create interactively hardcopy map outputs. This tool
+generates <em><a href="ps.map.html">ps.map</a></em> configuration file
+and then runs <em><a href="ps.map.html">ps.map</a></em> to create
+PostScript output. There are two modes - <em>Draft mode</em> for map
+composing and <em>Preview mode</em> to see the final output. In draft
+mode map features (like legend or scalebar) are represented by a
+colored rectangle with a label.
 <p>
 Possible output files:
 <ul>
-  <li> <a href="ps.map.html">ps.map</a> instructions file
+  <li> <em><a href="ps.map.html">ps.map</a></em> instructions file
   <li> PostScript/EPS file
 </ul>
 <p>
-Hardcopy Map Utility enables to load in saved instructions file. It works better with files created by wx.psmap (more tested).
+Hardcopy Map Utility enables to load in saved instructions file. It
+works better with files created by wx.psmap (more tested).
 <p>
-Currently supported <a href="ps.map.html">ps.map</a> instructions:
+Currently supported <em><a href="ps.map.html">ps.map</a></em> instructions:
 <ul>
   <li> paper
@@ -155,7 +164,7 @@
     <em>Show preview</em></dt>
   <dd> Generates output and switches to Preview mode to see the result. Be patient, it can take a while.</dd>
-  <dt><img src="icons/grass/ps-script.png">&nbsp;
+  <dt><img src="icons/grass/script-load.png">&nbsp;
     <em>Generate instructions file</em></dt>
   <dd> Generates and saves instructions file.</dd>
   <dt><img src="icons/grass/ps-export.png">&nbsp;
@@ -164,8 +173,6 @@
 </dl>
 <h2>SEE ALSO</h2>
 <em>
@@ -181,6 +188,9 @@
   <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
 </em>
+<p>
+See also <a href="http://grass.osgeo.org/wiki/GUI_for_ps.map">wiki</a> page.
 <h2>AUTHORS</h2>
 Anna Kratochvilova, CTU in Prague, Czech Republic (bachelor's final project 2011, mentor: Martin Landa)
