[GRASS-SVN] r45936 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Wed Apr 13 07:31:56 EDT 2011
Author: martinl
Date: 2011-04-13 04:31:56 -0700 (Wed, 13 Apr 2011)
New Revision: 45936
grass/branches/releasebranch_6_4/lib/python/array.py
grass/branches/releasebranch_6_4/lib/python/core.py
grass/branches/releasebranch_6_4/lib/python/db.py
grass/branches/releasebranch_6_4/lib/python/pythonlib.dox
grass/branches/releasebranch_6_4/lib/python/vector.py
pythonlib: sync with devbr6
Modified: grass/branches/releasebranch_6_4/lib/python/array.py
--- grass/branches/releasebranch_6_4/lib/python/array.py 2011-04-13 11:30:28 UTC (rev 45935)
+++ grass/branches/releasebranch_6_4/lib/python/array.py 2011-04-13 11:31:56 UTC (rev 45936)
@@ -1,6 +1,6 @@
"""!@package grass.script.array
- at brief GRASS Python scripting module
+ at brief GRASS Python scripting module (rasters with numpy)
Functions to use GRASS rasters with NumPy.
@@ -11,7 +11,7 @@
@endcode
-(C) 2010 by Glynn Clements and the GRASS Development Team
+(C) 2010-2011 by Glynn Clements and the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -26,46 +26,59 @@
# i18N
import gettext
-gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
class array(numpy.memmap):
def __new__(cls, dtype = numpy.double):
+ """!Define new numpy array
+ @param cls
+ @param dtype data type (default: numpy.double)
reg = grass.region()
r = reg['rows']
c = reg['cols']
shape = (r, c)
filename = grass.tempfile()
self = numpy.memmap.__new__(
cls,
filename = filename,
dtype = dtype,
mode = 'w+',
shape = shape)
self.filename = filename
return self
def _close(self):
numpy.memmap._close(self)
if isinstance(self, array):
grass.try_remove(self.filename)
def read(self, mapname, null = None):
+ """!Read raster map into array
+ @param mapname name of raster map to be read
+ @param null null value
+ @return 0 on success
+ @return non-zero code on failure
kind = self.dtype.kind
size = self.dtype.itemsize
if kind == 'f':
flags = 'f'
elif kind in 'biu':
flags = 'i'
else:
- raise ValueError(_('invalid kind <%s>') % kind)
+ raise ValueError(_('Invalid kind <%s>') % kind)
if size not in [1,2,4,8]:
- raise ValueError(_('invalid size <%d>') % size)
+ raise ValueError(_('Invalid size <%d>') % size)
return grass.run_command(
'r.out.bin',
flags = flags,
@@ -75,28 +88,37 @@
null = null,
quiet = True)
+ def write(self, mapname, title = None, null = None, overwrite = None):
+ """!Write array into raster map
- def write(self, mapname, title = None, null = None, overwrite = None):
+ @param mapname name for raster map
+ @param title title for raster map
+ @param overwrite True for overwritting existing raster maps
if kind == 'f':
if size == 4:
flags = 'f'
elif size == 8:
flags = 'd'
else:
- raise ValueError(_('invalid FP size <%d>') % size)
+ raise ValueError(_('Invalid FP size <%d>') % size)
size = None
elif kind in 'biu':
if size not in [1,2,4]:
- raise ValueError(_('invalid integer size <%d>') % size)
+ raise ValueError(_('Invalid integer size <%d>') % size)
flags = None
else:
'r.in.bin',
flags = flags,
@@ -113,3 +135,4 @@
west = reg['w'],
rows = reg['rows'],
cols = reg['cols'])
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2011-04-13 11:30:28 UTC (rev 45935)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2011-04-13 11:31:56 UTC (rev 45936)
@@ -13,14 +13,14 @@
@endcode
-(C) 2008-2010 by the GRASS Development Team
+(C) 2008-2011 by the GRASS Development Team
for details.
@author Glynn Clements
@author Martin Landa <landa.martin gmail.com>
- at author Michael Barton <michael.barton at asu.edu>
+ at author Michael Barton <michael.barton asu.edu>
import os
@@ -30,6 +30,7 @@
import atexit
import subprocess
import shutil
+import locale
import codecs
# i18N
@@ -39,15 +40,15 @@
# subprocess wrapper that uses shell on Windows
class Popen(subprocess.Popen):
- def __init__(self, args, bufsize=0, executable=None,
- stdin=None, stdout=None, stderr=None,
- preexec_fn=None, close_fds=False, shell=None,
- cwd=None, env=None, universal_newlines=False,
- startupinfo=None, creationflags=0):
+ def __init__(self, args, bufsize = 0, executable = None,
+ stdin = None, stdout = None, stderr = None,
+ preexec_fn = None, close_fds = False, shell = None,
+ cwd = None, env = None, universal_newlines = False,
+ startupinfo = None, creationflags = 0):
if shell == None:
shell = (sys.platform == "win32")
subprocess.Popen.__init__(self, args, bufsize, executable,
stdin, stdout, stderr,
preexec_fn, close_fds, shell,
@@ -57,7 +58,7 @@
PIPE = subprocess.PIPE
STDOUT = subprocess.STDOUT
-class ScriptException(Exception):
+class ScriptError(Exception):
def __init__(self, msg):
self.value = msg
@@ -76,6 +77,13 @@
"preexec_fn", "close_fds", "cwd", "env",
"universal_newlines", "startupinfo", "creationflags"]
+def _decode(string):
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ return string.decode(enc)
+ return string
def _make_val(val):
if isinstance(val, types.StringType) or \
isinstance(val, types.UnicodeType):
@@ -86,6 +94,12 @@
return _make_val(list(val))
return str(val)
+def _get_error(string):
+ try:
+ return string.split('\n')[-2]
+ except:
+ return ''
def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
"""!Return a list of strings suitable for use as the args parameter to
Popen() or call(). Example:
@@ -173,9 +187,23 @@
@return exit code (0 for success)
+ if get_raise_on_error():
+ kwargs['stderr'] = PIPE
+ env = os.getenv('GRASS_MESSAGE_FORMAT')
+ os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
ps = start_command(*args, **kwargs)
- return ps.wait()
+ err = ps.communicate()[1]
+ if env:
+ os.environ['GRASS_MESSAGE_FORMAT'] = env
+ if ps.returncode != 0:
+ raise ScriptError(_("Error in %s(%s): %s") % ('run_command', args[0], _get_error(err)))
+ return ps.returncode
+ else:
+ return ps.wait()
def pipe_command(*args, **kwargs):
"""!Passes all arguments to start_command(), but also adds
"stdout = PIPE". Returns the Popen object.
@@ -222,8 +250,22 @@
@return stdout
ps = pipe_command(*args, **kwargs)
- return ps.communicate()[0]
+ out, err = ps.communicate()
+ if env:
+ raise ScriptError(_("Error in %s(%s): %s") % ('read_command', args[0], _get_error(err)))
+ return _decode(out)
+ else:
+ return _decode(ps.communicate()[0])
def parse_command(*args, **kwargs):
"""!Passes all arguments to read_command, then parses the output by
@@ -266,11 +308,26 @@
@return return code
stdin = kwargs['stdin']
p = feed_command(*args, **kwargs)
p.stdin.write(stdin)
- p.stdin.close()
- return p.wait()
+ err = p.communicate()[1]
+ if env:
+ p.stdin.close()
+ if p.returncode != 0:
+ raise ScriptError(_("Error in %s(%s): %s") % ('write_command', args[0], _get_error(err)))
+ return p.returncode
+ else:
+ p.stdin.close()
+ return p.wait()
def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
"""!Interface to os.execvpe(), but with the make_command() interface.
@@ -353,7 +410,7 @@
global raise_on_error
if raise_on_error:
- raise ScriptException(msg)
+ raise ScriptError(msg)
else:
message(msg, flag = 'e')
@@ -368,7 +425,7 @@
def set_raise_on_error(raise_exp = True):
"""!Define behaviour on error (error() called)
- @param raise_exp True to raise ScriptException instead of calling
+ @param raise_exp True to raise ScriptError instead of calling
error()
@return current status
@@ -376,7 +433,17 @@
tmp_raise = raise_on_error
raise_on_error = raise_exp
+ return tmp_raise
+def get_raise_on_error():
+ """!Get raise_on_error status
+ @return True to raise exception
+ global raise_on_error
+ return raise_on_error
# interface to g.parser
def _parse_opts(lines):
@@ -945,7 +1012,7 @@
datum = None, desc = None):
"""!Create new location
- Raise ScriptException on error.
+ Raise ScriptError on error.
@param dbase path to GRASS database
@param location location name to create
@@ -1007,7 +1074,7 @@
set = 'GISDBASE=%s' % gisdbase)
if ps.returncode != 0 and error:
- raise ScriptException(repr(error))
+ raise ScriptError(repr(error))
try:
fd = codecs.open(os.path.join(dbase, location,
@@ -1019,12 +1086,12 @@
fd.write(os.linesep)
fd.close()
except OSError, e:
- raise ScriptException(repr(e))
+ raise ScriptError(repr(e))
def _create_location_xy(database, location):
"""!Create unprojected location
@param database GRASS database where to create new location
@@ -1066,8 +1133,23 @@
os.chdir(cur_dir)
except OSError, e:
+# interface to g.version
+def version():
+ """!Get GRASS version as dictionary
+ @code
+ version()
+ {'date': '2011', 'libgis_revision': '38990', 'version': '6.5.svn',
+ 'libgis_date': '2009-09-05 19:01:13 +0200 (Sat, 05 Sep 2009)'}
+ @endcode
+ return parse_command('g.version',
+ flags = 'rg')
# get debug_level
if find_program('g.gisenv', ['--help']):
debug_level = int(gisenv().get('DEBUG', 0))
Modified: grass/branches/releasebranch_6_4/lib/python/db.py
--- grass/branches/releasebranch_6_4/lib/python/db.py 2011-04-13 11:30:28 UTC (rev 45935)
+++ grass/branches/releasebranch_6_4/lib/python/db.py 2011-04-13 11:31:56 UTC (rev 45936)
@@ -9,7 +9,6 @@
@code
from grass.script import db as grass
-grass.parser()
grass.db_describe(table)
@endcode
@@ -23,6 +22,8 @@
+import tempfile as pytempfile # conflict with core.tempfile
from core import *
# i18N
@@ -48,7 +49,8 @@
s = read_command('db.describe', flags = 'c', table = table, **args)
if not s:
- return None
+ fatal(_("Unable to describe table <%s>") % table)
cols = []
result = {}
for l in s.splitlines():
@@ -63,6 +65,7 @@
else:
result[key] = f[1:]
result['cols'] = cols
return result
# run "db.connect -p" and parse output
@@ -80,3 +83,30 @@
s = read_command('db.connect', flags = 'p')
return parse_key_val(s, sep = ':')
+def db_select(table, sql, file = False, **args):
+ """!Perform SQL select statement
+ @param table table name
+ @param sql SQL select statement (string or file)
+ @param file True if sql is filename
+ @param args see db.select arguments
+ ofile = pytempfile.NamedTemporaryFile(mode = 'w+b')
+ if not file:
+ ret = run_command('db.select', quiet = True,
+ flags = 'c',
+ table = table,
+ sql = sql,
+ output = ofile.name)
+ else: # -> sql is file
+ flags = 'c',
+ table = table,
+ input = sql,
+ if ret != 0:
+ fatal(_("Fetching data from table <%s> failed") % table)
+ return ofile.readlines()
Modified: grass/branches/releasebranch_6_4/lib/python/pythonlib.dox
--- grass/branches/releasebranch_6_4/lib/python/pythonlib.dox 2011-04-13 11:30:28 UTC (rev 45935)
+++ grass/branches/releasebranch_6_4/lib/python/pythonlib.dox 2011-04-13 11:31:56 UTC (rev 45936)
@@ -15,6 +15,8 @@
- db.py
- raster.py
- vector.py
+- setup.py
+- array.py
<b>Table of content</b>
@@ -24,17 +26,21 @@
- \subpage pythonDb
- \subpage pythonRaster
- \subpage pythonVector
+ - \subpage pythonSetup
+ - \subpage pythonArray
\section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
-Usage:
+Statement
\code
import grass.script as grass
\endcode
-or just import selected module, e.g.
+imports core.py, db.py, raster.py and vector.py modules.
+To import only selected module
\code
from grass.script import core as grass
\endcode
@@ -171,6 +177,10 @@
- mapsets()
+<b>Interface to g.version</b>
+ - python::core::version()
<b>Color parsing</b>
- parse_color()
@@ -245,6 +255,22 @@
- vector_layer_db()
+\section pythonSetup Setup
+\code
+from grass.script import setup as gsetup
+\endcode
+ - python::setup::init()
+\section pythonArray Array
+\code
+from grass.script import array as garray
+\endcode
+ - python::array::array
\section pythonAuthors Authors
Glynn Clements
Modified: grass/branches/releasebranch_6_4/lib/python/vector.py
--- grass/branches/releasebranch_6_4/lib/python/vector.py 2011-04-13 11:30:28 UTC (rev 45935)
+++ grass/branches/releasebranch_6_4/lib/python/vector.py 2011-04-13 11:31:56 UTC (rev 45936)
@@ -9,7 +9,6 @@
@code
from grass.script import vector as grass
-grass.parser()
grass.vector_db(map)
@endcode
