[GRASS-SVN] r45938 - in grass-addons/gui/wxpython/wx.psmap: docs
gui_modules
svn_grass at osgeo.org
Wed Apr 13 07:38:46 EDT 2011
Author: annakrat
Date: 2011-04-13 04:38:46 -0700 (Wed, 13 Apr 2011)
New Revision: 45938
grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html
grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
wx.psmap minor changes of manual page
Modified: grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html
--- grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html 2011-04-13 11:32:26 UTC (rev 45937)
+++ grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html 2011-04-13 11:38:46 UTC (rev 45938)
@@ -10,7 +10,7 @@
generates <em><a href="ps.map.html">ps.map</a></em> configuration file
and then runs <em><a href="ps.map.html">ps.map</a></em> to create
PostScript output. There are two modes - <em>Draft mode</em> for map
-composing and <em>Preview mode</em> to see the final output. In draft
+composing and <em>Preview mode</em> to see how the result will look like. In draft
mode map features (like legend or scalebar) are represented by a
colored rectangle with a label.
@@ -47,9 +47,17 @@
<h3>HARDCOPY MAP UTILITY TOOLBAR</h3>
<dl>
- <dt><img src="icons/grass/settings.png">
+ <dt><img src="icons/grass/script-save.png">
+ <em>Generate instructions file</em></dt>
+ <dd>Generates and saves text file with mapping instructions.</dd>
+ <dt><img src="icons/grass/script-load.png">
+ <em>Load instructions file</em></dt>
+ <dd>Load text file with mapping instructions.</dd>
+ <dt><img src="icons/grass/page-settings.png">
<em>Page setup</em></dt>
- <dd>Specify paper size, margins and orientation</dd>
+ <dd>Specify paper size, margins and orientation.</dd>
<dt><img src="icons/grass/pointer.png">
<em>Pointer</em></dt>
@@ -145,9 +153,9 @@
<dt><img src="icons/grass/legend-add.png">
<em>Add legend</em></dt>
<dl>Add raster or vector legend or edit their properties.</dl>
- <dt><img src="icons/grass/legend-add.png">
+ <dt><img src="icons/grass/map-info.png">
<em>Add map info</em></dt>
- <dl>Add information about region, grid and scale or edit properties.</dl>
+ <dl>Add information about region, grid and scale or edit map info properties.</dl>
<dt><img src="icons/grass/scalebar-add.png">
<em>Add scalebar</em></dt>
<dl>Add scalebar or edit its properties.</dl>
@@ -164,9 +172,7 @@
<em>Show preview</em></dt>
<dd> Generates output and switches to Preview mode to see the result. Be patient, it can take a while.</dd>
- <dt><img src="icons/grass/script-load.png">
- <em>Generate instructions file</em></dt>
- <dd> Generates and saves instructions file.</dd>
<dt><img src="icons/grass/ps-export.png">
<em>Generate hardcopy map output </em></dt>
<dd> Generates hardcopy map output in PostScript/EPS file.</dd>
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py 2011-04-13 11:32:26 UTC (rev 45937)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py 2011-04-13 11:38:46 UTC (rev 45938)
@@ -1251,6 +1251,8 @@
newWidth = width + diffX
newHeight = height + diffY
+ if newWidth < 10 or newHeight < 10:
+ return
bounds = wx.Rect(x, y, newWidth, newHeight)
self.Draw(pen = self.pen[type], brush = self.brush[type], pdc = self.pdcObj, drawid = self.dragId,
