[GRASS-SVN] r45977 - in grass-addons/grass7/display: . d.mon
svn_grass at osgeo.org
Thu Apr 14 11:16:57 EDT 2011
Author: hamish
Date: 2011-04-14 08:16:57 -0700 (Thu, 14 Apr 2011)
New Revision: 45977
Added:
grass-addons/grass7/display/d.mon/
grass-addons/grass7/display/d.mon/d.mon.html
grass-addons/grass7/display/d.mon/d.mon.py
a little experiment to see if we can make the ximgview, wximgview, and wxpyimgview programs a bit simpler to start up.
Added: grass-addons/grass7/display/d.mon/d.mon.html
--- grass-addons/grass7/display/d.mon/d.mon.html (rev 0)
+++ grass-addons/grass7/display/d.mon/d.mon.html 2011-04-14 15:16:57 UTC (rev 45977)
@@ -0,0 +1,19 @@
+<h2>DESCRIPTION</h2>
+This is just a little experiment to see if we can make the ximgview,
+wximgview, and wxpyimgview programs a bit simpler to start up.
+<p>
+Add this to your ~/.grass.bashrc file:
+<pre>
+ alias d.mon='eval `d.mon.py -b`'
+</pre>
+<h2>AUTHOR</h2>
+Hamish Bowman<br>
+Dunedin, New Zealand
+<br>
+<p>
+<i>Last changed: $Date$</i></p>
Property changes on: grass-addons/grass7/display/d.mon/d.mon.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass7/display/d.mon/d.mon.py
--- grass-addons/grass7/display/d.mon/d.mon.py (rev 0)
+++ grass-addons/grass7/display/d.mon/d.mon.py 2011-04-14 15:16:57 UTC (rev 45977)
@@ -0,0 +1,131 @@
+#!/usr/bin/env python
+# MODULE: d.mon(.py)
+# AUTHOR: M. Hamish Bowman, Dunedin, New Zealand
+# PURPOSE: Front end wrapper to emulate d.mon from earlier GRASSes
+# COPYRIGHT: (c) 2011 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Starts a graphics display monitor which can be controlled from the command line.
+#% keywords: display
+#% keywords: CLI
+#%End
+#%Option
+#% key: width
+#% type: integer
+#% description: Width for display monitor if not set by GRASS_WIDTH
+#% answer: 800
+#%End
+#%Option
+#% key: height
+#% type: integer
+#% description: Height for display monitor if not set by GRASS_HEIGHT
+#% answer: 600
+#%End
+#%Option
+#% key: handler
+#% type: string
+#% description: Window program to use
+#% options: ximgview,wximgview,wxpyimgview,qiv
+#% answer: wximgview
+#%End
+#%option
+#% key: percent
+#% type: integer
+#% description: Percentage of CPU time to use
+#% answer: 10
+#%end
+#%option
+#% key: color
+#% type: string
+#% description: Background color, either a standard GRASS color or R:G:B triplet (separated by colons)
+#% answer: white
+#% gisprompt: old_color,color,color
+#%end
+#%Flag
+#% key: c
+#% description: Use the Cario driver to render images
+#%End
+#%Flag
+#% key: b
+#% description: output Bourne shell code to set up display
+#%End
+#%Flag
+#% key: d
+#% description: output DOS code to set up display
+#%End
+import sys
+import os
+from grass.script import core as grass
+def main():
+ handler = options['handler']
+ use_cairo = flags['c']
+ img_tmp = grass.tempfile()
+ os.remove(img_tmp)
+ img_tmp += ".bmp"
+ if flags['b']:
+ print('GRASS_PNGFILE="%s"' % img_tmp)
+ if not os.environ.has_key("GRASS_WIDTH"):
+ print('GRASS_WIDTH=%s' % options['width'])
+ if not os.environ.has_key("GRASS_HEIGHT"):
+ print('GRASS_HEIGHT=%s' % options['height'])
+ if flags['c']:
+ print('GRASS_RENDER_IMMEDIATE=cairo')
+ else:
+ print('GRASS_RENDER_IMMEDIATE=PNG')
+ print('GRASS_PNG_MAPPED=TRUE')
+ print('GRASS_PNG_READ=TRUE')
+ print('export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_PNG_MAPPED GRASS_PNG_READ;')
+ print('d.erase color=%s;' % options['color'])
+ if handler == "qiv":
+ print('qiv -T "%s" &' % img_tmp) # add --center ?
+ else:
+ print('%s image="%s" percent=%s &' % ( handler, img_tmp, options['percent']) )
+ sys.exit(0)
+ ## rest of this won't work, as parent can't inherit from the child..
+ ## (unless we do some ugly g.gisenv)
+ ## ... any ideas? end by running grass.call(['bash'])?
+ if not grass.find_program(handler, ['--help']):
+ grass.fatal(_("'%s' not found.") % handler)
+ os.environ['GRASS_PNGFILE'] = img_tmp
+ os.environ['GRASS_WIDTH'] = options['width']
+ os.environ['GRASS_HEIGHT'] = options['height']
+ if flags['c']:
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ os.environ['GRASS_PNG_MAPPED'] = 'TRUE'
+ os.environ['GRASS_PNG_READ'] = 'TRUE'
+ #? os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
+ grass.run_command('d.erase', color = options['color'])
+ ret = grass.call(['qiv', '-T', img_tmp])
+ else:
+ ret = grass.exec_command(handler, image = img_tmp, percent = options['percent'])
+ sys.exit(ret)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
+po
Property changes on: grass-addons/grass7/display/d.mon/d.mon.py
Added: svn:executable
+ text/x-python
+ native
