[GRASS-SVN] r46007 - grass/branches/develbranch_6/gui/scripts
svn_grass at osgeo.org
Sat Apr 16 09:03:16 EDT 2011
Author: martinl
Date: 2011-04-16 06:03:16 -0700 (Sat, 16 Apr 2011)
New Revision: 46007
grass/branches/develbranch_6/gui/scripts/g.extension.py
sync g.extension.py with trunk
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-04-16 13:00:24 UTC (rev 46006)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-04-16 13:03:16 UTC (rev 46007)
@@ -20,9 +20,7 @@
#%module
#% label: Tool to maintain the extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
-#% keywords: general
-#% keywords: installation
-#% keywords: extensions
+#% keywords: general, installation, extensions
#%end
#%option
@@ -78,7 +76,7 @@
#%end
#%flag
#% key: d
-#% description: Don't delete downloaded source code when installing new extension
+#% description: Download source code and exit
#%end
#%flag
#% key: i
@@ -122,7 +120,7 @@
return c
-def list_available_modules(svnurl, full = False, shell = False):
+def list_available_modules():
mlist = list()
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
@@ -131,14 +129,14 @@
'p', 'r', 'r3', 's', 'v']
nprefix = len(prefix)
for d in prefix:
- if shell:
+ if flags['g']:
grass.percent(i, nprefix, 1)
i += 1
modclass = expand_module_class_name(d)
grass.verbose(_("Checking for '%s' modules...") % modclass)
- url = '%s/%s' % (svnurl, modclass)
+ url = '%s/%s' % (options['svnurl'], modclass)
grass.debug("url = %s" % url, debug = 2)
f = urllib.urlopen(url)
if not f:
@@ -152,23 +150,23 @@
continue
name = sline.group(2).rstrip('/')
if name.split('.', 1)[0] == d:
- print_module_desc(name, url, full, shell)
+ print_module_desc(name, url)
mlist.append(name)
- mlist += list_wxgui_extensions(svnurl, full, shell)
+ mlist += list_wxgui_extensions()
- if shell:
+ if flags['g']:
grass.percent(1, 1, 1)
return mlist
-def list_wxgui_extensions(svnurl, full = False, shell = False, print_module = True):
+def list_wxgui_extensions(print_module = True):
mlist = list()
grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
grass.verbose(_("Checking for '%s' modules...") % 'gui/wxpython')
- url = '%s/%s' % (svnurl, 'gui/wxpython')
+ url = '%s/%s' % (options['svnurl'], 'gui/wxpython')
if not f:
@@ -183,17 +181,17 @@
if name not in ('..', 'Makefile'):
if print_module:
mlist.append(name)
return mlist
-def print_module_desc(name, url, full = False, shell = False):
- if not full and not shell:
+def print_module_desc(name, url):
+ if not flags['f'] and not flags['g']:
print name
return
- if shell:
+ if flags['g']:
print 'name=' + name
# check main.c first
@@ -201,11 +199,11 @@
if not desc:
desc = get_module_desc(url + '/' + name + '/main.c', script = False)
if not desc:
- if not shell:
+ if not flags['g']:
print name + '-'
return
- if shell:
+ if flags['g']:
print 'description=' + desc.get('description', '')
print 'keywords=' + ','.join(desc.get('keywords', list()))
else:
@@ -289,26 +287,26 @@
else:
grass.info(_("Path to the source code: '%s'") % tmpdir)
-def install_extension(svnurl, prefix, module, no_install):
+def install_extension():
gisbase = os.getenv('GISBASE')
if not gisbase:
grass.fatal(_('$GISBASE not defined'))
- if grass.find_program(module):
- grass.warning(_("Extension '%s' already installed. Will be updated...") % module)
+ if grass.find_program(options['extension']):
+ grass.warning(_("Extension '%s' already installed. Will be updated...") % options['extension'])
- gui_list = list_wxgui_extensions(svnurl, print_module = False)
+ gui_list = list_wxgui_extensions(print_module = False)
- if module not in gui_list:
- classchar = module.split('.', 1)[0]
+ if options['extension'] not in gui_list:
+ classchar = options['extension'].split('.', 1)[0]
moduleclass = expand_module_class_name(classchar)
- url = svnurl + '/' + moduleclass + '/' + module
+ url = options['svnurl'] + '/' + moduleclass + '/' + options['extension']
else:
- url = svnurl + '/gui/wxpython/' + module
+ url = options['svnurl'] + '/gui/wxpython/' + options['extension']
if not flags['s']:
grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
- grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
+ grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % options['extension'])
global tmpdir
os.chdir(tmpdir)
if grass.verbosity() == 0:
@@ -318,16 +316,19 @@
if grass.call(['svn', 'checkout',
url], stdout = outdev) != 0:
- grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
+ grass.fatal(_("GRASS Addons '%s' not found in repository") % options['extension'])
+ if flags['d']:
+ return
- os.chdir(os.path.join(tmpdir, module))
+ os.chdir(os.path.join(tmpdir, options['extension']))
- grass.message(_("Compiling '%s'...") % module)
- bin_dir = os.path.join(tmpdir, module, 'bin')
- docs_dir = os.path.join(tmpdir, module, 'docs')
+ grass.message(_("Compiling '%s'...") % options['extension'])
+ bin_dir = os.path.join(tmpdir, options['extension'], 'bin')
+ docs_dir = os.path.join(tmpdir, options['extension'], 'docs')
html_dir = os.path.join(docs_dir, 'html')
- man_dir = os.path.join(tmpdir, module, 'man')
+ man_dir = os.path.join(tmpdir, options['extension'], 'man')
man1_dir = os.path.join(man_dir, 'man1')
for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir):
os.mkdir(d)
@@ -346,35 +347,35 @@
if ret != 0:
grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
- if no_install or module in gui_list:
+ if flags['i'] or options['extension'] in gui_list:
return
- grass.message(_("Installing '%s'...") % module)
+ grass.message(_("Installing '%s'...") % options['extension'])
ret = grass.call(['make',
'MODULE_TOPDIR=%s' % gisbase,
- 'ARCH_DISTDIR=%s' % os.path.join(tmpdir, module),
- 'INST_DIR=%s' % prefix,
+ 'ARCH_DISTDIR=%s' % os.path.join(tmpdir, options['extension']),
+ 'INST_DIR=%s' % options['prefix'],
'install'],
stdout = outdev)
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
else:
- grass.message(_("Installation of '%s' successfully finished.") % module)
+ grass.message(_("Installation of '%s' successfully finished.") % options['extension'])
-def remove_extension(prefix, module):
+def remove_extension():
# is module available?
- if not os.path.exists(os.path.join(prefix, 'bin', module)):
- grass.fatal(_("Module '%s' not found") % module)
+ if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
+ grass.fatal(_("Module '%s' not found") % options['extension'])
- for file in [os.path.join(prefix, 'bin', module),
- os.path.join(prefix, 'scripts', module),
- os.path.join(prefix, 'docs', 'html', module + '.html')]:
+ for file in [os.path.join(options['prefix'], 'bin', options['extension']),
+ os.path.join(options['prefix'], 'scripts', options['extension']),
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
if os.path.isfile(file):
os.remove(file)
- grass.message(_("'%s' successfully uninstalled.") % module)
+ grass.message(_("'%s' successfully uninstalled.") % options['extension'])
def create_dir(path):
if os.path.isdir(path):
@@ -398,7 +399,7 @@
# list available modules
if flags['l'] or flags['f'] or flags['g']:
- list_available_modules(options['svnurl'], full = flags['f'], shell = flags['g'])
+ list_available_modules()
return 0
else:
if not options['extension']:
@@ -424,9 +425,9 @@
remove_tmpdir = False
if options['operation'] == 'add':
- install_extension(options['svnurl'], options['prefix'], options['extension'], flags['i'])
+ install_extension()
else: # remove
- remove_extension(options['prefix'], options['extension'])
+ remove_extension()
return 0
