[GRASS-SVN] r46028 - in grass/branches/releasebranch_6_4: .
general/g.version include/Make lib/init
svn_grass at osgeo.org
Mon Apr 18 08:58:11 EDT 2011
Author: martinl
Date: 2011-04-18 05:58:11 -0700 (Mon, 18 Apr 2011)
New Revision: 46028
grass/branches/releasebranch_6_4/configure
grass/branches/releasebranch_6_4/configure.in
grass/branches/releasebranch_6_4/general/g.version/Makefile
grass/branches/releasebranch_6_4/general/g.version/main.c
grass/branches/releasebranch_6_4/include/Make/Grass.make.in
grass/branches/releasebranch_6_4/lib/init/Makefile
backport modified r45526 to relbr64, see #587
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/configure 2011-04-18 12:58:11 UTC (rev 46028)
@@ -1290,8 +1290,43 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
+GRASS_VERSION_SVN=
+# Extract the first word of "svnversion", so it can be a program name with args.
+set dummy svnversion; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:1298: checking for $ac_word" >&5
+case "$SVN_VERSION" in
+ ac_cv_path_SVN_VERSION="$SVN_VERSION" # Let the user override the test with a path.
+ ac_cv_path_SVN_VERSION="$SVN_VERSION" # Let the user override the test with a dos path.
+ IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
+ ac_dummy="$PATH"
+ for ac_dir in $ac_dummy; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/$ac_word; then
+ ac_cv_path_SVN_VERSION="$ac_dir/$ac_word"
+ break
+ fi
+ done
+ IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_SVN_VERSION" && ac_cv_path_SVN_VERSION="no"
+esac
+SVN_VERSION="$ac_cv_path_SVN_VERSION"
+if test -n "$SVN_VERSION"; then
+ echo "$ac_t""$SVN_VERSION" 1>&6
+else
+ echo "$ac_t""no" 1>&6
+fi
+if test "$SVN_VERSION" != "no" ; then
+ GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+fi
@@ -1299,6 +1334,10 @@
# Check for MacOSX App
# Check whether --enable-macosx-app or --disable-macosx-app was given.
@@ -1311,7 +1350,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1315: checking for MacOSX App" >&5
+echo "configure:1354: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1323,7 +1362,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1327: checking for MacOSX architectures" >&5
+echo "configure:1366: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1352,7 +1391,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1356: checking for MacOSX SDK" >&5
+echo "configure:1395: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1362,7 +1401,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1366: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1405: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1406,7 +1445,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1410: checking how to build libraries" >&5
+echo "configure:1449: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1449,7 +1488,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1453: checking for $ac_word" >&5
+echo "configure:1492: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1474,7 +1513,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1478: checking how to run the C preprocessor" >&5
+echo "configure:1517: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1487,13 +1526,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
cat > conftest.$ac_ext <<EOF
-#line 1491 "configure"
+#line 1530 "configure"
#include "confdefs.h"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1504,13 +1543,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1508 "configure"
+#line 1547 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1521,13 +1560,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1525 "configure"
+#line 1564 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1555,7 +1594,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1559: checking if 64bit support is requested" >&5
+echo "configure:1598: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1575,7 +1614,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1579: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1618: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1599,7 +1638,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1603: checking system version (for dynamic loading)" >&5
+echo "configure:1642: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1625,13 +1664,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1629: checking for dlopen in -ldl" >&5
+echo "configure:1668: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1635 "configure"
+#line 1674 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1642,7 +1681,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1689,7 +1728,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1693: checking for $ac_word" >&5
+echo "configure:1732: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1818,13 +1857,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1822: checking for gettimeofday in -lbsd" >&5
+echo "configure:1861: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1828 "configure"
+#line 1867 "configure"
@@ -1835,7 +1874,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1876,13 +1915,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1880: checking for inet_ntoa in -lbind" >&5
+echo "configure:1919: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1886 "configure"
+#line 1925 "configure"
@@ -1893,7 +1932,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1954,13 +1993,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1958: checking for shl_load in -ldld" >&5
+echo "configure:1997: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1964 "configure"
+#line 2003 "configure"
@@ -1971,7 +2010,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2036,13 +2075,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:2040: checking for shl_load in -ldld" >&5
+echo "configure:2079: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 2046 "configure"
+#line 2085 "configure"
@@ -2053,7 +2092,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2175,15 +2214,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2179: checking for dld.h" >&5
+echo "configure:2218: checking for dld.h" >&5
-#line 2182 "configure"
+#line 2221 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2243,15 +2282,15 @@
else
-echo "configure:2247: checking for dld.h" >&5
+echo "configure:2286: checking for dld.h" >&5
-#line 2250 "configure"
+#line 2289 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2348,9 +2387,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2352: checking for ELF" >&5
+echo "configure:2391: checking for ELF" >&5
-#line 2354 "configure"
+#line 2393 "configure"
#ifdef __ELF__
@@ -2380,15 +2419,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2384: checking for dlfcn.h" >&5
+echo "configure:2423: checking for dlfcn.h" >&5
-#line 2387 "configure"
+#line 2426 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2412,9 +2451,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2416: checking for ELF" >&5
+echo "configure:2455: checking for ELF" >&5
-#line 2418 "configure"
+#line 2457 "configure"
#ifdef __ELF__
@@ -2738,17 +2777,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2742: checking for ld accepts -Bexport flag" >&5
+echo "configure:2781: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2745 "configure"
+#line 2784 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3573,7 +3612,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3577: checking for additional include dirs" >&5
+echo "configure:3616: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3596,7 +3635,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3600: checking for additional library dirs" >&5
+echo "configure:3639: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3630,7 +3669,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3634: checking for a BSD compatible install" >&5
+echo "configure:3673: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3683,7 +3722,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3687: checking for $ac_word" >&5
+echo "configure:3726: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3714,13 +3753,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3718: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3757: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3724 "configure"
+#line 3763 "configure"
@@ -3731,7 +3770,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3756,7 +3795,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3760: checking for $ac_word" >&5
+echo "configure:3799: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3796,7 +3835,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3800: checking for $ac_word" >&5
+echo "configure:3839: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3827,7 +3866,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3831: checking for $ac_word" >&5
+echo "configure:3870: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3865,7 +3904,7 @@
-echo "configure:3869: checking for $ac_word" >&5
+echo "configure:3908: checking for $ac_word" >&5
@@ -3894,7 +3933,7 @@
-echo "configure:3898: checking for $ac_word" >&5
+echo "configure:3937: checking for $ac_word" >&5
@@ -3925,7 +3964,7 @@
-echo "configure:3929: checking for $ac_word" >&5
+echo "configure:3968: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3954,7 +3993,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3958: checking for $ac_word" >&5
+echo "configure:3997: checking for $ac_word" >&5
case "$PERL" in
@@ -3985,10 +4024,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3989: checking for ANSI C header files" >&5
+echo "configure:4028: checking for ANSI C header files" >&5
-#line 3992 "configure"
+#line 4031 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3996,7 +4035,7 @@
#include <float.h>
EOF
-{ (eval echo configure:4000: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4013,7 +4052,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4017 "configure"
+#line 4056 "configure"
#include <string.h>
EOF
@@ -4031,7 +4070,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4035 "configure"
+#line 4074 "configure"
#include <stdlib.h>
EOF
@@ -4052,7 +4091,7 @@
else
-#line 4056 "configure"
+#line 4095 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4063,7 +4102,7 @@
exit (0); }
EOF
-if { (eval echo configure:4067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -4090,15 +4129,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4094: checking for $ac_hdr" >&5
+echo "configure:4133: checking for $ac_hdr" >&5
-#line 4097 "configure"
+#line 4136 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4102: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4127,15 +4166,15 @@
do
-echo "configure:4131: checking for $ac_hdr" >&5
+echo "configure:4170: checking for $ac_hdr" >&5
-#line 4134 "configure"
+#line 4173 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4164,15 +4203,15 @@
do
-echo "configure:4168: checking for $ac_hdr" >&5
+echo "configure:4207: checking for $ac_hdr" >&5
-#line 4171 "configure"
+#line 4210 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4176: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4201,15 +4240,15 @@
do
-echo "configure:4205: checking for $ac_hdr" >&5
+echo "configure:4244: checking for $ac_hdr" >&5
-#line 4208 "configure"
+#line 4247 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4238,15 +4277,15 @@
do
-echo "configure:4242: checking for $ac_hdr" >&5
+echo "configure:4281: checking for $ac_hdr" >&5
-#line 4245 "configure"
+#line 4284 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4272,10 +4311,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4276: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4315: checking whether time.h and sys/time.h may both be included" >&5
-#line 4279 "configure"
+#line 4318 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4284,7 +4323,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4288: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4304,10 +4343,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4308: checking for off_t" >&5
+echo "configure:4347: checking for off_t" >&5
-#line 4311 "configure"
+#line 4350 "configure"
#if STDC_HEADERS
@@ -4334,10 +4373,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4338: checking for uid_t in sys/types.h" >&5
+echo "configure:4377: checking for uid_t in sys/types.h" >&5
-#line 4341 "configure"
+#line 4380 "configure"
EOF
@@ -4365,10 +4404,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4369: checking return type of signal handlers" >&5
+echo "configure:4408: checking return type of signal handlers" >&5
-#line 4372 "configure"
+#line 4411 "configure"
#include <signal.h>
@@ -4385,7 +4424,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4389: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4428: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4403,10 +4442,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4407: checking for Cygwin environment" >&5
+echo "configure:4446: checking for Cygwin environment" >&5
-#line 4410 "configure"
+#line 4449 "configure"
int main() {
@@ -4417,7 +4456,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4460: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4435,10 +4474,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4439: checking for $ac_func" >&5
+echo "configure:4478: checking for $ac_func" >&5
-#line 4442 "configure"
+#line 4481 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4461,7 +4500,7 @@
; return 0; }
EOF
-if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4487,10 +4526,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4491: checking for $ac_func" >&5
+echo "configure:4530: checking for $ac_func" >&5
-#line 4494 "configure"
+#line 4533 "configure"
@@ -4513,7 +4552,7 @@
; return 0; }
EOF
-if { (eval echo configure:4517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4539,10 +4578,10 @@
for ac_func in drand48
do
-echo "configure:4543: checking for $ac_func" >&5
+echo "configure:4582: checking for $ac_func" >&5
-#line 4546 "configure"
+#line 4585 "configure"
@@ -4565,7 +4604,7 @@
; return 0; }
EOF
-if { (eval echo configure:4569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4591,10 +4630,10 @@
for ac_func in putenv setenv
do
-echo "configure:4595: checking for $ac_func" >&5
+echo "configure:4634: checking for $ac_func" >&5
-#line 4598 "configure"
+#line 4637 "configure"
@@ -4617,7 +4656,7 @@
; return 0; }
EOF
-if { (eval echo configure:4621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4643,10 +4682,10 @@
for ac_func in nanosleep
do
-echo "configure:4647: checking for $ac_func" >&5
+echo "configure:4686: checking for $ac_func" >&5
-#line 4650 "configure"
+#line 4689 "configure"
@@ -4669,7 +4708,7 @@
; return 0; }
EOF
-if { (eval echo configure:4673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4694,13 +4733,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4698: checking whether setpgrp takes no argument" >&5
+echo "configure:4737: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4704 "configure"
+#line 4743 "configure"
#ifdef HAVE_UNISTD_H
@@ -4720,7 +4759,7 @@
EOF
-if { (eval echo configure:4724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4748,16 +4787,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4752: checking for long long int" >&5
+echo "configure:4791: checking for long long int" >&5
-#line 4754 "configure"
+#line 4793 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4800: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -4777,7 +4816,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4781: checking for W11" >&5
+echo "configure:4820: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4805,7 +4844,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4809: checking for X" >&5
+echo "configure:4848: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4865,12 +4904,12 @@
# First, try using that file with no special directory specified.
-#line 4869 "configure"
+#line 4908 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4939,14 +4978,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4943 "configure"
+#line 4982 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -5051,17 +5090,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5055: checking whether -R must be followed by a space" >&5
+echo "configure:5094: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5058 "configure"
+#line 5097 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -5077,14 +5116,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5081 "configure"
+#line 5120 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5116,13 +5155,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5120: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5159: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5126 "configure"
+#line 5165 "configure"
@@ -5133,7 +5172,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5154,13 +5193,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5158: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5197: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5164 "configure"
+#line 5203 "configure"
@@ -5171,7 +5210,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5199,10 +5238,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5203: checking for gethostbyname" >&5
+echo "configure:5242: checking for gethostbyname" >&5
-#line 5206 "configure"
+#line 5245 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5225,7 +5264,7 @@
; return 0; }
EOF
-if { (eval echo configure:5229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5245,13 +5284,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5249: checking for gethostbyname in -lnsl" >&5
+echo "configure:5288: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5255 "configure"
+#line 5294 "configure"
@@ -5262,7 +5301,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5291,10 +5330,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5295: checking for connect" >&5
+echo "configure:5334: checking for connect" >&5
-#line 5298 "configure"
+#line 5337 "configure"
which can conflict with char connect(); below. */
@@ -5317,7 +5356,7 @@
; return 0; }
EOF
-if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5337,13 +5376,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5341: checking for connect in -lsocket" >&5
+echo "configure:5380: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5347 "configure"
+#line 5386 "configure"
@@ -5354,7 +5393,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5377,10 +5416,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5381: checking for remove" >&5
+echo "configure:5420: checking for remove" >&5
-#line 5384 "configure"
+#line 5423 "configure"
which can conflict with char remove(); below. */
@@ -5403,7 +5442,7 @@
; return 0; }
EOF
-if { (eval echo configure:5407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5423,13 +5462,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5427: checking for remove in -lposix" >&5
+echo "configure:5466: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5433 "configure"
+#line 5472 "configure"
@@ -5440,7 +5479,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5463,10 +5502,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5467: checking for shmat" >&5
+echo "configure:5506: checking for shmat" >&5
-#line 5470 "configure"
+#line 5509 "configure"
which can conflict with char shmat(); below. */
@@ -5489,7 +5528,7 @@
; return 0; }
EOF
-if { (eval echo configure:5493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5509,13 +5548,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5513: checking for shmat in -lipc" >&5
+echo "configure:5552: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5519 "configure"
+#line 5558 "configure"
@@ -5526,7 +5565,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5558,13 +5597,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5562: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5601: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5568 "configure"
+#line 5607 "configure"
@@ -5575,7 +5614,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5613,7 +5652,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5617: checking whether to use Curses" >&5
+echo "configure:5656: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5632,15 +5671,15 @@
do
-echo "configure:5636: checking for $ac_hdr" >&5
+echo "configure:5675: checking for $ac_hdr" >&5
-#line 5639 "configure"
+#line 5678 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5671,10 +5710,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5675: checking curses.h WINDOW structure component" >&5
+echo "configure:5714: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5678 "configure"
+#line 5717 "configure"
#include <curses.h>
@@ -5683,7 +5722,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5687: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5726: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5692,7 +5731,7 @@
fi
rm -f conftest*
-#line 5696 "configure"
+#line 5735 "configure"
#include <curses.h>
@@ -5701,7 +5740,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5705: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5717,13 +5756,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5721: checking for initscr in -lncurses" >&5
+echo "configure:5760: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5727 "configure"
+#line 5766 "configure"
@@ -5734,7 +5773,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5753,13 +5792,13 @@
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5757: checking for initscr in -lcurses" >&5
+echo "configure:5796: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5763 "configure"
+#line 5802 "configure"
@@ -5770,7 +5809,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5799,13 +5838,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5803: checking for keypad in -lncurses" >&5
+echo "configure:5842: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5809 "configure"
+#line 5848 "configure"
@@ -5816,7 +5855,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5838,13 +5877,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5842: checking for keypad in -lcurses" >&5
+echo "configure:5881: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5848 "configure"
+#line 5887 "configure"
@@ -5855,7 +5894,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5885,13 +5924,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5889: checking for gtty in -lcompat" >&5
+echo "configure:5928: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5895 "configure"
+#line 5934 "configure"
@@ -5902,7 +5941,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5921,13 +5960,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5925: checking for gtty in -lbsd-compat" >&5
+echo "configure:5964: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5931 "configure"
+#line 5970 "configure"
@@ -5938,7 +5977,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5957,13 +5996,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5961: checking for gtty in -lbsd" >&5
+echo "configure:6000: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5967 "configure"
+#line 6006 "configure"
@@ -5974,7 +6013,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6008,12 +6047,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6012: checking for library containing cuserid" >&5
+echo "configure:6051: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 6017 "configure"
+#line 6056 "configure"
@@ -6024,7 +6063,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -6035,7 +6074,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 6039 "configure"
+#line 6078 "configure"
@@ -6046,7 +6085,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -6072,10 +6111,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6076: checking for xdrmem_create" >&5
+echo "configure:6115: checking for xdrmem_create" >&5
-#line 6079 "configure"
+#line 6118 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -6098,7 +6137,7 @@
; return 0; }
EOF
-if { (eval echo configure:6102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -6116,13 +6155,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6120: checking for xdrmem_create in -lsun" >&5
+echo "configure:6159: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 6126 "configure"
+#line 6165 "configure"
@@ -6133,7 +6172,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6152,13 +6191,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6156: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6195: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 6162 "configure"
+#line 6201 "configure"
@@ -6169,7 +6208,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6188,13 +6227,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6192: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6231: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6198 "configure"
+#line 6237 "configure"
@@ -6205,7 +6244,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6224,13 +6263,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6228: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6267: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6234 "configure"
+#line 6273 "configure"
@@ -6241,7 +6280,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6275,10 +6314,10 @@
for ac_func in asprintf
do
-echo "configure:6279: checking for $ac_func" >&5
+echo "configure:6318: checking for $ac_func" >&5
-#line 6282 "configure"
+#line 6321 "configure"
@@ -6301,7 +6340,7 @@
; return 0; }
EOF
-if { (eval echo configure:6305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6328,10 +6367,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6332: checking for atan" >&5
+echo "configure:6371: checking for atan" >&5
-#line 6335 "configure"
+#line 6374 "configure"
which can conflict with char atan(); below. */
@@ -6354,7 +6393,7 @@
; return 0; }
EOF
-if { (eval echo configure:6358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6372,13 +6411,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6376: checking for atan in -lm" >&5
+echo "configure:6415: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6382 "configure"
+#line 6421 "configure"
@@ -6389,7 +6428,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6416,10 +6455,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6420: checking for dlsym" >&5
+echo "configure:6459: checking for dlsym" >&5
-#line 6423 "configure"
+#line 6462 "configure"
which can conflict with char dlsym(); below. */
@@ -6442,7 +6481,7 @@
; return 0; }
EOF
-if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6460,13 +6499,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6464: checking for dlsym in -ldl" >&5
+echo "configure:6503: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6470 "configure"
+#line 6509 "configure"
@@ -6477,7 +6516,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6504,10 +6543,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6508: checking for iconv" >&5
+echo "configure:6547: checking for iconv" >&5
-#line 6511 "configure"
+#line 6550 "configure"
which can conflict with char iconv(); below. */
@@ -6530,7 +6569,7 @@
; return 0; }
EOF
-if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6548,13 +6587,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6552: checking for iconv in -liconv" >&5
+echo "configure:6591: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6558 "configure"
+#line 6597 "configure"
@@ -6565,7 +6604,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6584,13 +6623,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6588: checking for iconv in -lgiconv" >&5
+echo "configure:6627: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6594 "configure"
+#line 6633 "configure"
@@ -6601,7 +6640,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6620,10 +6659,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6624: checking for libiconv" >&5
+echo "configure:6663: checking for libiconv" >&5
-#line 6627 "configure"
+#line 6666 "configure"
which can conflict with char libiconv(); below. */
@@ -6646,7 +6685,7 @@
; return 0; }
EOF
-if { (eval echo configure:6650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6664,13 +6703,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6668: checking for libiconv in -liconv" >&5
+echo "configure:6707: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6674 "configure"
+#line 6713 "configure"
@@ -6681,7 +6720,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6700,13 +6739,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6704: checking for libiconv in -lgiconv" >&5
+echo "configure:6743: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6710 "configure"
+#line 6749 "configure"
@@ -6717,7 +6756,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6754,10 +6793,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6758: checking for socket" >&5
+echo "configure:6797: checking for socket" >&5
-#line 6761 "configure"
+#line 6800 "configure"
which can conflict with char socket(); below. */
@@ -6780,7 +6819,7 @@
; return 0; }
EOF
-if { (eval echo configure:6784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6798,13 +6837,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6802: checking for socket in -lsocket" >&5
+echo "configure:6841: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6808 "configure"
+#line 6847 "configure"
@@ -6815,7 +6854,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6863,7 +6902,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6867: checking for location of zlib includes" >&5
+echo "configure:6906: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6889,15 +6928,15 @@
do
-echo "configure:6893: checking for $ac_hdr" >&5
+echo "configure:6932: checking for $ac_hdr" >&5
-#line 6896 "configure"
+#line 6935 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6901: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6931,7 +6970,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6935: checking for location of zlib library" >&5
+echo "configure:6974: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6956,13 +6995,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6960: checking for deflate in -lz" >&5
+echo "configure:6999: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6966 "configure"
+#line 7005 "configure"
@@ -6973,7 +7012,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7021,7 +7060,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7025: checking for location of External PROJ.4 includes" >&5
+echo "configure:7064: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7047,15 +7086,15 @@
do
-echo "configure:7051: checking for $ac_hdr" >&5
+echo "configure:7090: checking for $ac_hdr" >&5
-#line 7054 "configure"
+#line 7093 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7092,7 +7131,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7096: checking External PROJ.4 version" >&5
+echo "configure:7135: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7100,7 +7139,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 7104 "configure"
+#line 7143 "configure"
#include <stdio.h>
@@ -7112,7 +7151,7 @@
EOF
-if { (eval echo configure:7116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -7137,7 +7176,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7141: checking for location of External PROJ.4 library" >&5
+echo "configure:7180: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7162,13 +7201,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7166: checking for pj_get_def in -lproj" >&5
+echo "configure:7205: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 7172 "configure"
+#line 7211 "configure"
@@ -7179,7 +7218,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7213,7 +7252,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7217: checking for location of External PROJ.4 data files" >&5
+echo "configure:7256: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7237,14 +7276,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7241: checking for epsg" >&5
+echo "configure:7280: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7248: checking for $PROJSHARE/epsg" >&5
+echo "configure:7287: checking for $PROJSHARE/epsg" >&5
@@ -7276,7 +7315,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:7280: checking for $ac_word" >&5
+echo "configure:7319: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7316,7 +7355,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7320: checking whether to use regex" >&5
+echo "configure:7359: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -7336,7 +7375,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7340: checking for location of regex includes" >&5
+echo "configure:7379: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7362,15 +7401,15 @@
do
-echo "configure:7366: checking for $ac_hdr" >&5
+echo "configure:7405: checking for $ac_hdr" >&5
-#line 7369 "configure"
+#line 7408 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7404,7 +7443,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7408: checking for location of regex library" >&5
+echo "configure:7447: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7429,10 +7468,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7433: checking for regcomp" >&5
+echo "configure:7472: checking for regcomp" >&5
-#line 7436 "configure"
+#line 7475 "configure"
which can conflict with char regcomp(); below. */
@@ -7455,7 +7494,7 @@
; return 0; }
EOF
-if { (eval echo configure:7459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7482,13 +7521,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7486: checking for regcomp in -lregex" >&5
+echo "configure:7525: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7492 "configure"
+#line 7531 "configure"
@@ -7499,7 +7538,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7549,7 +7588,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7553: checking whether to use Readline" >&5
+echo "configure:7592: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7570,7 +7609,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7574: checking for location of Readline includes" >&5
+echo "configure:7613: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7596,15 +7635,15 @@
do
-echo "configure:7600: checking for $ac_hdr" >&5
+echo "configure:7639: checking for $ac_hdr" >&5
-#line 7603 "configure"
+#line 7642 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7640,15 +7679,15 @@
do
-echo "configure:7644: checking for $ac_hdr" >&5
+echo "configure:7683: checking for $ac_hdr" >&5
-#line 7647 "configure"
+#line 7686 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7691: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7682,7 +7721,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7686: checking for location of Readline library" >&5
+echo "configure:7725: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7707,13 +7746,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7711: checking for readline in -lreadline" >&5
+echo "configure:7750: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7717 "configure"
+#line 7756 "configure"
#include "confdefs.h"
@@ -7724,7 +7763,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7759,13 +7798,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7763: checking for add_history in -lhistory" >&5
+echo "configure:7802: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7769 "configure"
+#line 7808 "configure"
@@ -7776,7 +7815,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7819,7 +7858,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7823: checking whether to use JPEG" >&5
+echo "configure:7862: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7839,7 +7878,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7843: checking for location of JPEG includes" >&5
+echo "configure:7882: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7865,15 +7904,15 @@
do
-echo "configure:7869: checking for $ac_hdr" >&5
+echo "configure:7908: checking for $ac_hdr" >&5
-#line 7872 "configure"
+#line 7911 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7877: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7907,7 +7946,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7911: checking for location of JPEG library" >&5
+echo "configure:7950: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7934,13 +7973,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7938: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7977: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ljpeg $LIBS"
-#line 7944 "configure"
+#line 7983 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7951,7 +7990,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7970,13 +8009,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:7974: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:8013: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7980 "configure"
+#line 8019 "configure"
@@ -7987,7 +8026,7 @@
; return 0; }
EOF
-if { (eval echo configure:7991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8036,7 +8075,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8040: checking whether to use GDAL" >&5
+echo "configure:8079: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -8054,7 +8093,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8058: checking for $ac_word" >&5
+echo "configure:8097: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -8109,14 +8148,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8113 "configure"
+#line 8152 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -8125,14 +8164,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8129 "configure"
+#line 8168 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:8136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -8164,7 +8203,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8168: checking whether to use GEOS" >&5
+echo "configure:8207: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -8182,7 +8221,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:8186: checking for $ac_word" >&5
+echo "configure:8225: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -8230,15 +8269,15 @@
do
-echo "configure:8234: checking for $ac_hdr" >&5
+echo "configure:8273: checking for $ac_hdr" >&5
-#line 8237 "configure"
+#line 8276 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8274,13 +8313,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8278: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:8317: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 8284 "configure"
+#line 8323 "configure"
@@ -8291,7 +8330,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8327,13 +8366,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8331: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8370: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 8337 "configure"
+#line 8376 "configure"
@@ -8344,7 +8383,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8389,7 +8428,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8393: checking whether to use TIFF" >&5
+echo "configure:8432: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8409,7 +8448,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8413: checking for location of TIFF includes" >&5
+echo "configure:8452: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8435,15 +8474,15 @@
do
-echo "configure:8439: checking for $ac_hdr" >&5
+echo "configure:8478: checking for $ac_hdr" >&5
-#line 8442 "configure"
+#line 8481 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8477,7 +8516,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8481: checking for location of TIFF library" >&5
+echo "configure:8520: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8508,13 +8547,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8512: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8551: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8518 "configure"
+#line 8557 "configure"
@@ -8525,7 +8564,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8544,13 +8583,13 @@
-echo "configure:8548: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8587: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8554 "configure"
+#line 8593 "configure"
@@ -8561,7 +8600,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8580,13 +8619,13 @@
-echo "configure:8584: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8623: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8590 "configure"
+#line 8629 "configure"
@@ -8597,7 +8636,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8616,13 +8655,13 @@
-echo "configure:8620: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8659: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8626 "configure"
+#line 8665 "configure"
@@ -8633,7 +8672,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8676: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8652,13 +8691,13 @@
-echo "configure:8656: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8695: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8662 "configure"
+#line 8701 "configure"
@@ -8669,7 +8708,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8688,13 +8727,13 @@
-echo "configure:8692: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8731: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8698 "configure"
+#line 8737 "configure"
@@ -8705,7 +8744,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8724,13 +8763,13 @@
-echo "configure:8728: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8767: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8734 "configure"
+#line 8773 "configure"
@@ -8741,7 +8780,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8760,13 +8799,13 @@
-echo "configure:8764: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8803: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8770 "configure"
+#line 8809 "configure"
@@ -8777,7 +8816,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8875,7 +8914,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8879: checking whether to use PNG" >&5
+echo "configure:8918: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8894,7 +8933,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8898: checking for location of PNG includes" >&5
+echo "configure:8937: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8920,15 +8959,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8924: checking for $ac_hdr" >&5
+echo "configure:8963: checking for $ac_hdr" >&5
-#line 8927 "configure"
+#line 8966 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8962,7 +9001,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8966: checking for location of PNG library" >&5
+echo "configure:9005: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8987,13 +9026,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8991: checking for png_read_image in -lpng" >&5
+echo "configure:9030: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8997 "configure"
+#line 9036 "configure"
@@ -9004,7 +9043,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:9008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9046,7 +9085,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9050: checking whether to use PostgreSQL" >&5
+echo "configure:9089: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9073,7 +9112,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9077: checking for location of PostgreSQL includes" >&5
+echo "configure:9116: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9099,15 +9138,15 @@
do
-echo "configure:9103: checking for $ac_hdr" >&5
+echo "configure:9142: checking for $ac_hdr" >&5
-#line 9106 "configure"
+#line 9145 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9145,7 +9184,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9149: checking for location of PostgreSQL library" >&5
+echo "configure:9188: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9174,13 +9213,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9178: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9217: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9184 "configure"
+#line 9223 "configure"
@@ -9191,7 +9230,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9210,13 +9249,13 @@
-echo "configure:9214: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9253: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9220 "configure"
+#line 9259 "configure"
@@ -9227,7 +9266,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9246,13 +9285,13 @@
-echo "configure:9250: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9289: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9256 "configure"
+#line 9295 "configure"
@@ -9263,7 +9302,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9282,13 +9321,13 @@
-echo "configure:9286: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9325: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9292 "configure"
+#line 9331 "configure"
@@ -9299,7 +9338,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9356,13 +9395,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9360: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9399: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9366 "configure"
+#line 9405 "configure"
@@ -9373,7 +9412,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9395,13 +9434,13 @@
-echo "configure:9399: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9438: checking for PQcmdTuples in -lpq" >&5
-#line 9405 "configure"
+#line 9444 "configure"
@@ -9412,7 +9451,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9455,7 +9494,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9459: checking whether to use MySQL" >&5
+echo "configure:9498: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9475,7 +9514,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9479: checking for location of MySQL includes" >&5
+echo "configure:9518: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9501,15 +9540,15 @@
do
-echo "configure:9505: checking for $ac_hdr" >&5
+echo "configure:9544: checking for $ac_hdr" >&5
-#line 9508 "configure"
+#line 9547 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9546,7 +9585,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9550: checking for location of MySQL library" >&5
+echo "configure:9589: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9577,13 +9616,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9581: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9620: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9587 "configure"
+#line 9626 "configure"
@@ -9594,7 +9633,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9613,13 +9652,13 @@
-echo "configure:9617: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9656: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9623 "configure"
+#line 9662 "configure"
@@ -9630,7 +9669,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9649,13 +9688,13 @@
-echo "configure:9653: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9692: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9659 "configure"
+#line 9698 "configure"
@@ -9666,7 +9705,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9685,13 +9724,13 @@
-echo "configure:9689: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9728: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9695 "configure"
+#line 9734 "configure"
@@ -9702,7 +9741,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9721,13 +9760,13 @@
-echo "configure:9725: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9764: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9731 "configure"
+#line 9770 "configure"
@@ -9738,7 +9777,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9757,13 +9796,13 @@
-echo "configure:9761: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9800: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9767 "configure"
+#line 9806 "configure"
@@ -9774,7 +9813,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9793,13 +9832,13 @@
-echo "configure:9797: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9836: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9803 "configure"
+#line 9842 "configure"
@@ -9810,7 +9849,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9829,13 +9868,13 @@
-echo "configure:9833: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9872: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9839 "configure"
+#line 9878 "configure"
@@ -9846,7 +9885,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9936,7 +9975,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9940: checking for $ac_word" >&5
+echo "configure:9979: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9977,10 +10016,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9981: checking for mysql_server_init" >&5
+echo "configure:10020: checking for mysql_server_init" >&5
-#line 9984 "configure"
+#line 10023 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10003,7 +10042,7 @@
; return 0; }
EOF
-if { (eval echo configure:10007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10041,7 +10080,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10045: checking whether to use SQLite" >&5
+echo "configure:10084: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10061,7 +10100,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10065: checking for location of SQLite includes" >&5
+echo "configure:10104: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10087,15 +10126,15 @@
do
-echo "configure:10091: checking for $ac_hdr" >&5
+echo "configure:10130: checking for $ac_hdr" >&5
-#line 10094 "configure"
+#line 10133 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10138,7 +10177,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10142: checking for location of SQLite library" >&5
+echo "configure:10181: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10167,13 +10206,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10171: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10210: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10177 "configure"
+#line 10216 "configure"
@@ -10184,7 +10223,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10203,13 +10242,13 @@
-echo "configure:10207: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10246: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10213 "configure"
+#line 10252 "configure"
@@ -10220,7 +10259,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10239,13 +10278,13 @@
-echo "configure:10243: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10282: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10249 "configure"
+#line 10288 "configure"
@@ -10256,7 +10295,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10275,13 +10314,13 @@
-echo "configure:10279: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10318: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10285 "configure"
+#line 10324 "configure"
@@ -10292,7 +10331,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10361,7 +10400,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10365: checking whether to use FFMPEG" >&5
+echo "configure:10404: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10381,7 +10420,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10385: checking for location of FFMPEG includes" >&5
+echo "configure:10424: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10407,15 +10446,15 @@
do
-echo "configure:10411: checking for $ac_hdr" >&5
+echo "configure:10450: checking for $ac_hdr" >&5
-#line 10414 "configure"
+#line 10453 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10451,15 +10490,15 @@
do
-echo "configure:10455: checking for $ac_hdr" >&5
+echo "configure:10494: checking for $ac_hdr" >&5
-#line 10458 "configure"
+#line 10497 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10495,15 +10534,15 @@
do
-echo "configure:10499: checking for $ac_hdr" >&5
+echo "configure:10538: checking for $ac_hdr" >&5
-#line 10502 "configure"
+#line 10541 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10546,7 +10585,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10550: checking for location of FFMPEG library" >&5
+echo "configure:10589: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10573,13 +10612,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10577: checking for av_free in -lavutil" >&5
+echo "configure:10616: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10583 "configure"
+#line 10622 "configure"
@@ -10590,7 +10629,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10609,13 +10648,13 @@
-echo "configure:10613: checking for av_free in -lavutil" >&5
+echo "configure:10652: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10619 "configure"
+#line 10658 "configure"
@@ -10626,7 +10665,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10671,13 +10710,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10675: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10714: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10681 "configure"
+#line 10720 "configure"
@@ -10688,7 +10727,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10707,13 +10746,13 @@
-echo "configure:10711: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10750: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10717 "configure"
+#line 10756 "configure"
@@ -10724,7 +10763,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10769,13 +10808,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10773: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10812: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10779 "configure"
+#line 10818 "configure"
@@ -10786,7 +10825,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10805,13 +10844,13 @@
-echo "configure:10809: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10848: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10815 "configure"
+#line 10854 "configure"
@@ -10822,7 +10861,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10881,7 +10920,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10885: checking whether to use OpenGL" >&5
+echo "configure:10924: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10915,7 +10954,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10919: checking for location of OpenGL includes" >&5
+echo "configure:10958: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10941,15 +10980,15 @@
do
-echo "configure:10945: checking for $ac_hdr" >&5
+echo "configure:10984: checking for $ac_hdr" >&5
-#line 10948 "configure"
+#line 10987 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10992: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10983,7 +11022,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10987: checking for location of OpenGL library" >&5
+echo "configure:11026: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11012,13 +11051,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11016: checking for glBegin in -lGL" >&5
+echo "configure:11055: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11022 "configure"
+#line 11061 "configure"
@@ -11029,7 +11068,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11048,13 +11087,13 @@
-echo "configure:11052: checking for glBegin in -lGL" >&5
+echo "configure:11091: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11058 "configure"
+#line 11097 "configure"
@@ -11065,7 +11104,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11084,13 +11123,13 @@
-echo "configure:11088: checking for glBegin in -lGL" >&5
+echo "configure:11127: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11094 "configure"
+#line 11133 "configure"
@@ -11101,7 +11140,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11120,13 +11159,13 @@
-echo "configure:11124: checking for glBegin in -lGL" >&5
+echo "configure:11163: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11130 "configure"
+#line 11169 "configure"
@@ -11137,7 +11176,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11199,13 +11238,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11203: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11242: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11209 "configure"
+#line 11248 "configure"
@@ -11216,7 +11255,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11235,13 +11274,13 @@
-echo "configure:11239: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11278: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11245 "configure"
+#line 11284 "configure"
@@ -11252,7 +11291,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11296,10 +11335,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11300: checking for glXCreatePbuffer" >&5
+echo "configure:11339: checking for glXCreatePbuffer" >&5
-#line 11303 "configure"
+#line 11342 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11322,7 +11361,7 @@
; return 0; }
EOF
-if { (eval echo configure:11326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11344,10 +11383,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11348: checking for glXCreateGLXPixmap" >&5
+echo "configure:11387: checking for glXCreateGLXPixmap" >&5
-#line 11351 "configure"
+#line 11390 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11370,7 +11409,7 @@
; return 0; }
EOF
-if { (eval echo configure:11374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11409,7 +11448,7 @@
-echo "configure:11413: checking for location of OpenGL includes" >&5
+echo "configure:11452: checking for location of OpenGL includes" >&5
@@ -11435,15 +11474,15 @@
do
-echo "configure:11439: checking for $ac_hdr" >&5
+echo "configure:11478: checking for $ac_hdr" >&5
-#line 11442 "configure"
+#line 11481 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11478,10 +11517,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11482: checking for glBegin" >&5
+echo "configure:11521: checking for glBegin" >&5
-#line 11485 "configure"
+#line 11524 "configure"
which can conflict with char glBegin(); below. */
@@ -11504,7 +11543,7 @@
; return 0; }
EOF
-if { (eval echo configure:11508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11519,10 +11558,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11523: checking for gluBeginCurve" >&5
+echo "configure:11562: checking for gluBeginCurve" >&5
-#line 11526 "configure"
+#line 11565 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11545,7 +11584,7 @@
; return 0; }
EOF
-if { (eval echo configure:11549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11589,7 +11628,7 @@
-echo "configure:11593: checking for location of OpenGL includes" >&5
+echo "configure:11632: checking for location of OpenGL includes" >&5
@@ -11615,15 +11654,15 @@
do
-echo "configure:11619: checking for $ac_hdr" >&5
+echo "configure:11658: checking for $ac_hdr" >&5
-#line 11622 "configure"
+#line 11661 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11657,7 +11696,7 @@
-echo "configure:11661: checking for location of OpenGL library" >&5
+echo "configure:11700: checking for location of OpenGL library" >&5
@@ -11682,18 +11721,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11686: checking for OpenGL library" >&5
+echo "configure:11725: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11690 "configure"
+#line 11729 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11717,18 +11756,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11721: checking for GLU library" >&5
+echo "configure:11760: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11725 "configure"
+#line 11764 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11777,7 +11816,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11781: checking whether to use Tcl/Tk" >&5
+echo "configure:11820: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11797,7 +11836,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11801: checking for location of Tcl/Tk includes" >&5
+echo "configure:11840: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11823,15 +11862,15 @@
do
-echo "configure:11827: checking for $ac_hdr" >&5
+echo "configure:11866: checking for $ac_hdr" >&5
-#line 11830 "configure"
+#line 11869 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11868,15 +11907,15 @@
do
-echo "configure:11872: checking for $ac_hdr" >&5
+echo "configure:11911: checking for $ac_hdr" >&5
-#line 11875 "configure"
+#line 11914 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11909,7 +11948,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11913: checking Tcl version" >&5
+echo "configure:11952: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11917,7 +11956,7 @@
else
-#line 11921 "configure"
+#line 11960 "configure"
#include <stdio.h>
@@ -11929,7 +11968,7 @@
EOF
-if { (eval echo configure:11933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11947,7 +11986,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11951: checking Tk version" >&5
+echo "configure:11990: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11955,7 +11994,7 @@
else
-#line 11959 "configure"
+#line 11998 "configure"
#include <stdio.h>
@@ -11967,7 +12006,7 @@
EOF
-if { (eval echo configure:11971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:12010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11998,7 +12037,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:12002: checking for location of Tcl/Tk library" >&5
+echo "configure:12041: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -12038,13 +12077,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:12042: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12081: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 12048 "configure"
+#line 12087 "configure"
@@ -12055,7 +12094,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12074,13 +12113,13 @@
-echo "configure:12078: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12117: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 12084 "configure"
+#line 12123 "configure"
@@ -12091,7 +12130,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12118,13 +12157,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12122: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12161: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12128 "configure"
+#line 12167 "configure"
@@ -12135,7 +12174,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12154,13 +12193,13 @@
-echo "configure:12158: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12197: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12164 "configure"
+#line 12203 "configure"
@@ -12171,7 +12210,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12198,13 +12237,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12202: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12241: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12208 "configure"
+#line 12247 "configure"
@@ -12215,7 +12254,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12234,13 +12273,13 @@
-echo "configure:12238: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12277: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12244 "configure"
+#line 12283 "configure"
@@ -12251,7 +12290,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12329,13 +12368,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12333: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12372: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12339 "configure"
+#line 12378 "configure"
@@ -12346,7 +12385,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12365,13 +12404,13 @@
-echo "configure:12369: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12408: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12375 "configure"
+#line 12414 "configure"
@@ -12382,7 +12421,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12409,13 +12448,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12413: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12452: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12419 "configure"
+#line 12458 "configure"
@@ -12426,7 +12465,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12445,13 +12484,13 @@
-echo "configure:12449: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12488: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12455 "configure"
+#line 12494 "configure"
@@ -12462,7 +12501,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12489,13 +12528,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12493: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12532: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12499 "configure"
+#line 12538 "configure"
@@ -12506,7 +12545,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12525,13 +12564,13 @@
-echo "configure:12529: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12568: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12535 "configure"
+#line 12574 "configure"
@@ -12542,7 +12581,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12632,13 +12671,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12636: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12675: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12642 "configure"
+#line 12681 "configure"
@@ -12649,7 +12688,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12698,7 +12737,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12702: checking whether to use ODBC" >&5
+echo "configure:12741: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12717,7 +12756,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12721: checking for location of ODBC includes" >&5
+echo "configure:12760: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12743,15 +12782,15 @@
do
-echo "configure:12747: checking for $ac_hdr" >&5
+echo "configure:12786: checking for $ac_hdr" >&5
-#line 12750 "configure"
+#line 12789 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12755: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12785,7 +12824,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12789: checking for location of ODBC library" >&5
+echo "configure:12828: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12810,13 +12849,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12814: checking for SQLConnect in -lodbc" >&5
+echo "configure:12853: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12820 "configure"
+#line 12859 "configure"
#include "confdefs.h"
@@ -12827,7 +12866,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12852,13 +12891,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12856: checking for SQLConnect in -liodbc" >&5
+echo "configure:12895: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12862 "configure"
+#line 12901 "configure"
@@ -12869,7 +12908,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12894,11 +12933,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12898: checking for ODBC library" >&5
+echo "configure:12937: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12902 "configure"
+#line 12941 "configure"
#include <windows.h>
#include <sql.h>
@@ -12906,7 +12945,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12955,7 +12994,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12959: checking whether to use FFTW" >&5
+echo "configure:12998: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12974,7 +13013,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12978: checking for location of FFTW includes" >&5
+echo "configure:13017: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -13000,15 +13039,15 @@
do
-echo "configure:13004: checking for $ac_hdr" >&5
+echo "configure:13043: checking for $ac_hdr" >&5
-#line 13007 "configure"
+#line 13046 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13036,15 +13075,15 @@
do
-echo "configure:13040: checking for $ac_hdr" >&5
+echo "configure:13079: checking for $ac_hdr" >&5
-#line 13043 "configure"
+#line 13082 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13072,15 +13111,15 @@
do
-echo "configure:13076: checking for $ac_hdr" >&5
+echo "configure:13115: checking for $ac_hdr" >&5
-#line 13079 "configure"
+#line 13118 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13123: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13126,7 +13165,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13130: checking for location of FFTW library" >&5
+echo "configure:13169: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13151,13 +13190,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13155: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13194: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13161 "configure"
+#line 13200 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13168,7 +13207,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13193,13 +13232,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13197: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13236: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13203 "configure"
+#line 13242 "configure"
@@ -13210,7 +13249,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13235,13 +13274,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13239: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13278: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13245 "configure"
+#line 13284 "configure"
@@ -13252,7 +13291,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13309,7 +13348,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13313: checking whether to use BLAS" >&5
+echo "configure:13352: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13330,7 +13369,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13334: checking for location of BLAS includes" >&5
+echo "configure:13373: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13350,7 +13389,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13354: checking for location of BLAS library" >&5
+echo "configure:13393: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13376,15 +13415,15 @@
do
-echo "configure:13380: checking for $ac_hdr" >&5
+echo "configure:13419: checking for $ac_hdr" >&5
-#line 13383 "configure"
+#line 13422 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13388: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13419,13 +13458,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13423: checking for dnrm2_ in -lblas" >&5
+echo "configure:13462: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13429 "configure"
+#line 13468 "configure"
@@ -13436,7 +13475,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13455,13 +13494,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13459: checking for dnrm2_ in -lblas" >&5
+echo "configure:13498: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13465 "configure"
+#line 13504 "configure"
@@ -13472,7 +13511,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13516,13 +13555,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13520: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13559: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13526 "configure"
+#line 13565 "configure"
@@ -13533,7 +13572,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13548,13 +13587,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13552: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13591: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13558 "configure"
+#line 13597 "configure"
@@ -13565,7 +13604,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13580,13 +13619,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13584: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13623: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13590 "configure"
+#line 13629 "configure"
@@ -13597,7 +13636,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13643,16 +13682,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13647: checking for sgemm in $vlib_flags" >&5
+echo "configure:13686: checking for sgemm in $vlib_flags" >&5
-#line 13649 "configure"
+#line 13688 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13670,13 +13709,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13674: checking for sgemm_ in -lblas" >&5
+echo "configure:13713: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13680 "configure"
+#line 13719 "configure"
@@ -13687,7 +13726,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13702,13 +13741,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13706: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13745: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13712 "configure"
+#line 13751 "configure"
@@ -13719,7 +13758,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13734,13 +13773,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13738: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13777: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13744 "configure"
+#line 13783 "configure"
@@ -13751,7 +13790,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13785,13 +13824,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13789: checking for acosp in -lsunmath" >&5
+echo "configure:13828: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13795 "configure"
+#line 13834 "configure"
@@ -13802,7 +13841,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13817,13 +13856,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13821: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13860: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13827 "configure"
+#line 13866 "configure"
@@ -13834,7 +13873,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13864,13 +13903,13 @@
# Generic BLAS library
-echo "configure:13868: checking for sgemm_ in -lblas" >&5
+echo "configure:13907: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13874 "configure"
+#line 13913 "configure"
@@ -13881,7 +13920,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13920,7 +13959,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13924: checking whether to use LAPACK" >&5
+echo "configure:13963: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13945,7 +13984,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13949: checking for location of LAPACK includes" >&5
+echo "configure:13988: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13965,7 +14004,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13969: checking for location of LAPACK library" >&5
+echo "configure:14008: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13991,15 +14030,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13995: checking for $ac_hdr" >&5
+echo "configure:14034: checking for $ac_hdr" >&5
-#line 13998 "configure"
+#line 14037 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14031,10 +14070,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:14035: checking for dsegv_" >&5
+echo "configure:14074: checking for dsegv_" >&5
-#line 14038 "configure"
+#line 14077 "configure"
which can conflict with char dsegv_(); below. */
@@ -14057,7 +14096,7 @@
; return 0; }
EOF
-if { (eval echo configure:14061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -14084,13 +14123,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14088: checking for desgv_ in -llapack" >&5
+echo "configure:14127: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 14094 "configure"
+#line 14133 "configure"
@@ -14101,7 +14140,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:14105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14133,13 +14172,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14137: checking for dgesv_ in -llapack" >&5
+echo "configure:14176: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 14143 "configure"
+#line 14182 "configure"
@@ -14150,7 +14189,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14169,13 +14208,13 @@
-echo "configure:14173: checking for dgesv_ in -llapack" >&5
+echo "configure:14212: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14179 "configure"
+#line 14218 "configure"
@@ -14186,7 +14225,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14242,7 +14281,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14246: checking whether to use Motif" >&5
+echo "configure:14285: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14261,7 +14300,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14265: checking for location of Motif includes" >&5
+echo "configure:14304: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14287,15 +14326,15 @@
do
-echo "configure:14291: checking for $ac_hdr" >&5
+echo "configure:14330: checking for $ac_hdr" >&5
-#line 14294 "configure"
+#line 14333 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14338: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14329,7 +14368,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14333: checking for location of Motif library" >&5
+echo "configure:14372: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14354,13 +14393,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14358: checking for XmStringCreate in -lXm" >&5
+echo "configure:14397: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14364 "configure"
+#line 14403 "configure"
@@ -14371,7 +14410,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14412,7 +14451,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14416: checking whether to use Cairo" >&5
+echo "configure:14455: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14438,7 +14477,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14442: checking for location of cairo includes" >&5
+echo "configure:14481: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14464,15 +14503,15 @@
do
-echo "configure:14468: checking for $ac_hdr" >&5
+echo "configure:14507: checking for $ac_hdr" >&5
-#line 14471 "configure"
+#line 14510 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14508,7 +14547,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14512: checking for location of cairo library" >&5
+echo "configure:14551: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14528,7 +14567,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14532: checking for cairo linking flags" >&5
+echo "configure:14571: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14544,10 +14583,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14548: checking for cairo_create" >&5
+echo "configure:14587: checking for cairo_create" >&5
-#line 14551 "configure"
+#line 14590 "configure"
which can conflict with char cairo_create(); below. */
@@ -14570,7 +14609,7 @@
; return 0; }
EOF
-if { (eval echo configure:14574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14604,10 +14643,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14608: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14647: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14611 "configure"
+#line 14650 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14630,7 +14669,7 @@
; return 0; }
EOF
-if { (eval echo configure:14634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14672,7 +14711,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14676: checking whether to use GLw" >&5
+echo "configure:14715: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14691,7 +14730,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14695: checking for location of GLw includes" >&5
+echo "configure:14734: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14717,15 +14756,15 @@
do
-echo "configure:14721: checking for $ac_hdr" >&5
+echo "configure:14760: checking for $ac_hdr" >&5
-#line 14724 "configure"
+#line 14763 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14729: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14753,15 +14792,15 @@
do
-echo "configure:14757: checking for $ac_hdr" >&5
+echo "configure:14796: checking for $ac_hdr" >&5
-#line 14760 "configure"
+#line 14799 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14801,7 +14840,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14805: checking for location of GLw library" >&5
+echo "configure:14844: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14826,13 +14865,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14830: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14869: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14836 "configure"
+#line 14875 "configure"
@@ -14843,7 +14882,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14868,13 +14907,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14872: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14911: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14878 "configure"
+#line 14917 "configure"
@@ -14885,7 +14924,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14910,13 +14949,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14914: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14953: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14920 "configure"
+#line 14959 "configure"
@@ -14927,7 +14966,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14952,13 +14991,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14956: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14995: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14962 "configure"
+#line 15001 "configure"
@@ -14969,7 +15008,7 @@
; return 0; }
EOF
-if { (eval echo configure:14973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14994,13 +15033,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14998: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:15037: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15004 "configure"
+#line 15043 "configure"
@@ -15011,7 +15050,7 @@
; return 0; }
EOF
-if { (eval echo configure:15015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15036,13 +15075,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15040: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:15079: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15046 "configure"
+#line 15085 "configure"
@@ -15053,7 +15092,7 @@
; return 0; }
EOF
-if { (eval echo configure:15057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15080,13 +15119,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15084: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15123: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15090 "configure"
+#line 15129 "configure"
@@ -15097,7 +15136,7 @@
; return 0; }
EOF
-if { (eval echo configure:15101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15116,13 +15155,13 @@
-echo "configure:15120: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15159: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15126 "configure"
+#line 15165 "configure"
@@ -15133,7 +15172,7 @@
; return 0; }
EOF
-if { (eval echo configure:15137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15160,13 +15199,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15164: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15203: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15170 "configure"
+#line 15209 "configure"
@@ -15177,7 +15216,7 @@
; return 0; }
EOF
-if { (eval echo configure:15181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15196,13 +15235,13 @@
-echo "configure:15200: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15239: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15206 "configure"
+#line 15245 "configure"
@@ -15213,7 +15252,7 @@
; return 0; }
EOF
-if { (eval echo configure:15217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15326,7 +15365,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15330: checking whether to use FreeType" >&5
+echo "configure:15369: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15345,7 +15384,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15349: checking for location of FreeType includes" >&5
+echo "configure:15388: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15371,15 +15410,15 @@
do
-echo "configure:15375: checking for $ac_hdr" >&5
+echo "configure:15414: checking for $ac_hdr" >&5
-#line 15378 "configure"
+#line 15417 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15383: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15413,7 +15452,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15417: checking for location of FreeType library" >&5
+echo "configure:15456: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15438,13 +15477,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15442: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15481: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15448 "configure"
+#line 15487 "configure"
@@ -15455,7 +15494,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15496,7 +15535,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15500: checking whether to use NLS" >&5
+echo "configure:15539: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15516,10 +15555,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15520: checking for gettext" >&5
+echo "configure:15559: checking for gettext" >&5
-#line 15523 "configure"
+#line 15562 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15542,7 +15581,7 @@
; return 0; }
EOF
-if { (eval echo configure:15546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15560,13 +15599,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15564: checking for gettext in -lintl" >&5
+echo "configure:15603: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15570 "configure"
+#line 15609 "configure"
@@ -15577,7 +15616,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15612,7 +15651,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15616: checking whether to use C++" >&5
+echo "configure:15655: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15628,7 +15667,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15632: checking for $ac_word" >&5
+echo "configure:15671: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15657,7 +15696,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15661: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15700: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15668,12 +15707,12 @@
cat > conftest.$ac_ext << EOF
-#line 15672 "configure"
+#line 15711 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15699,19 +15738,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15703: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15742: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15708: checking whether we are using GNU C++" >&5
+echo "configure:15747: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15729,7 +15768,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15733: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15772: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15770,7 +15809,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15774: checking whether to use openDWG" >&5
+echo "configure:15813: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15790,7 +15829,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15794: checking for location of openDGW includes" >&5
+echo "configure:15833: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15816,15 +15855,15 @@
do
-echo "configure:15820: checking for $ac_hdr" >&5
+echo "configure:15859: checking for $ac_hdr" >&5
-#line 15823 "configure"
+#line 15862 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15858,7 +15897,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15862: checking for location of openDWG library" >&5
+echo "configure:15901: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15905,7 +15944,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15909: checking for special C compiler options needed for large files" >&5
+echo "configure:15948: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15913,7 +15952,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15917 "configure"
+#line 15956 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15929,7 +15968,7 @@
; return 0; }
EOF
-if { (eval echo configure:15933: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15972: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15938,7 +15977,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15942 "configure"
+#line 15981 "configure"
@@ -15954,7 +15993,7 @@
; return 0; }
EOF
-if { (eval echo configure:15958: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15974,11 +16013,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15978: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:16017: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15982 "configure"
+#line 16021 "configure"
@@ -15994,14 +16033,14 @@
; return 0; }
EOF
-if { (eval echo configure:15998: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 16005 "configure"
+#line 16044 "configure"
#define _FILE_OFFSET_BITS 64
@@ -16019,7 +16058,7 @@
; return 0; }
EOF
-if { (eval echo configure:16023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -16038,11 +16077,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16042: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:16081: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 16046 "configure"
+#line 16085 "configure"
@@ -16058,14 +16097,14 @@
; return 0; }
EOF
-if { (eval echo configure:16062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16069 "configure"
+#line 16108 "configure"
#define _LARGE_FILES 1
@@ -16083,7 +16122,7 @@
; return 0; }
EOF
-if { (eval echo configure:16087: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -16102,25 +16141,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16106: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16110 "configure"
+#line 16149 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16117: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16124 "configure"
+#line 16163 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16129,7 +16168,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16133: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16150,10 +16189,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16154: checking if system supports Large Files at all" >&5
+echo "configure:16193: checking if system supports Large Files at all" >&5
-#line 16157 "configure"
+#line 16196 "configure"
#include <stdio.h>
@@ -16185,7 +16224,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16189: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16228: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16214,7 +16253,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16218: checking whether to use Python" >&5
+echo "configure:16257: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16234,7 +16273,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16238: checking for $ac_word" >&5
+echo "configure:16277: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16276,15 +16315,15 @@
do
-echo "configure:16280: checking for $ac_hdr" >&5
+echo "configure:16319: checking for $ac_hdr" >&5
-#line 16283 "configure"
+#line 16322 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16288: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16354,7 +16393,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16358: checking whether to use wxWidgets" >&5
+echo "configure:16397: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16375,7 +16414,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16379: checking for $ac_word" >&5
+echo "configure:16418: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16423,7 +16462,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16427: checking wxWidgets version" >&5
+echo "configure:16466: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16446,15 +16485,15 @@
do
-echo "configure:16450: checking for $ac_hdr" >&5
+echo "configure:16489: checking for $ac_hdr" >&5
-#line 16453 "configure"
+#line 16492 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16633,12 +16672,14 @@
s%@ARCH@%$ARCH%g
s%@GISBASE@%$GISBASE%g
s%@GRASS_BIN@%$GRASS_BIN%g
+s%@SVN_VERSION@%$SVN_VERSION%g
s%@GRASS_VERSION_FILE@%$GRASS_VERSION_FILE%g
s%@GRASS_VERSION_MAJOR@%$GRASS_VERSION_MAJOR%g
s%@GRASS_VERSION_MINOR@%$GRASS_VERSION_MINOR%g
s%@GRASS_VERSION_RELEASE@%$GRASS_VERSION_RELEASE%g
s%@GRASS_VERSION_NUMBER@%$GRASS_VERSION_NUMBER%g
s%@GRASS_VERSION_DATE@%$GRASS_VERSION_DATE%g
+s%@GRASS_VERSION_SVN@%$GRASS_VERSION_SVN%g
s%@NAME_VER@%$NAME_VER%g
s%@LIB_VER@%$LIB_VER%g
s%@MACOSX_APP@%$MACOSX_APP%g
Modified: grass/branches/releasebranch_6_4/configure.in
--- grass/branches/releasebranch_6_4/configure.in 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/configure.in 2011-04-18 12:58:11 UTC (rev 46028)
@@ -124,12 +124,19 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
changequote([,])
+GRASS_VERSION_SVN=
+AC_PATH_PROG(SVN_VERSION, svnversion, no)
+if test "$SVN_VERSION" != "no" ; then
+ GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+fi
AC_SUBST(GRASS_VERSION_FILE)
AC_SUBST(GRASS_VERSION_MAJOR)
AC_SUBST(GRASS_VERSION_MINOR)
AC_SUBST(GRASS_VERSION_RELEASE)
AC_SUBST(GRASS_VERSION_NUMBER)
AC_SUBST(GRASS_VERSION_DATE)
+AC_SUBST(GRASS_VERSION_SVN)
AC_SUBST(NAME_VER)
AC_SUBST(LIB_VER)
Modified: grass/branches/releasebranch_6_4/general/g.version/Makefile
--- grass/branches/releasebranch_6_4/general/g.version/Makefile 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/general/g.version/Makefile 2011-04-18 12:58:11 UTC (rev 46028)
@@ -10,6 +10,7 @@
EXTRA_CFLAGS = \
-DGRASS_VERSION_NUMBER=\"'$(GRASS_VERSION_NUMBER)'\" \
-DGRASS_VERSION_DATE=\"'$(GRASS_VERSION_DATE)'\" \
+ -DGRASS_VERSION_SVN=\"'$(GRASS_VERSION_SVN)'\" \
-DGRASS_VERSION_UPDATE_PKG=\"'$(GRASS_VERSION_UPDATE_PKG)'\" \
-I$(OBJDIR)
Modified: grass/branches/releasebranch_6_4/general/g.version/main.c
--- grass/branches/releasebranch_6_4/general/g.version/main.c 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/general/g.version/main.c 2011-04-18 12:58:11 UTC (rev 46028)
@@ -1,4 +1,3 @@
* MODULE: g.version
@@ -7,7 +6,7 @@
* Justin Hickey - Thailand - jhickey hpcc.nectec.or.th
* PURPOSE: Output GRASS version number, date and copyright message.
-* COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
+* COPYRIGHT: (C) 2000-2011 by the GRASS Development Team
* This program is free software under the GPL (>=v2)
* Read the file COPYING that comes with GRASS for details.
@@ -34,34 +33,45 @@
int main(int argc, char *argv[])
struct GModule *module;
- struct Flag *copyright, *build, *gish_rev;
+ struct Flag *copyright, *build, *gish_rev, *shell;
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("general");
+ module->keywords = _("general, version");
module->description = _("Displays version and copyright information.");
copyright = G_define_flag();
copyright->key = 'c';
- copyright->description = _("Print the copyright message");
+ copyright->description = _("Print also the copyright message");
build = G_define_flag();
build->key = 'b';
- build->description = _("Print the GRASS build information");
+ build->description = _("Print also the GRASS build information");
gish_rev = G_define_flag();
gish_rev->key = 'r';
gish_rev->description =
- _("Print the GIS library revision number and time");
+ _("Print also the GIS library revision number and time");
+ shell = G_define_flag();
+ shell->key = 'g';
+ shell->description = _("Print info in shell script style");
if (argc > 1 && G_parser(argc, argv))
exit(EXIT_FAILURE);
- fprintf(stdout, "GRASS %s (%s) %s\n",
- GRASS_VERSION_NUMBER, GRASS_VERSION_DATE,
- GRASS_VERSION_UPDATE_PKG);
+ if (shell->answer) {
+ fprintf(stdout, "version=%s\n", GRASS_VERSION_NUMBER);
+ fprintf(stdout, "revision=%s\n", GRASS_VERSION_SVN);
+ fprintf(stdout, "date=%s\n", GRASS_VERSION_DATE);
+ else {
+ fprintf(stdout, "GRASS %s%s (%s) %s\n",
+ GRASS_VERSION_NUMBER, GRASS_VERSION_SVN,
+ GRASS_VERSION_DATE, GRASS_VERSION_UPDATE_PKG);
if (copyright->answer) {
fprintf(stdout, "\n");
@@ -75,10 +85,15 @@
if (gish_rev->answer) {
- /* fprintf(stdout, "%s\n%s\n", GIS_H_VERSION, GIS_H_DATE); */
char **rev_ver = G_tokenize(GIS_H_VERSION, "$");
char **rev_time = G_tokenize(GIS_H_DATE, "$");
- fprintf(stdout, "%s\n%s\n", rev_ver[1], rev_time[1]);
+ fprintf(stdout, "libgis_revision=%s\n", strstr(rev_ver[1], " ") + 1);
+ fprintf(stdout, "libgis_date=\"%s\"\n", strstr(rev_time[1], " ") + 1);
+ else {
+ fprintf(stdout, "%s\n%s\n", rev_ver[1], rev_time[1]);
G_free_tokens(rev_ver);
G_free_tokens(rev_time);
Modified: grass/branches/releasebranch_6_4/include/Make/Grass.make.in
--- grass/branches/releasebranch_6_4/include/Make/Grass.make.in 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/include/Make/Grass.make.in 2011-04-18 12:58:11 UTC (rev 46028)
@@ -71,6 +71,7 @@
GRASS_VERSION_MINOR = @GRASS_VERSION_MINOR@
GRASS_VERSION_RELEASE = @GRASS_VERSION_RELEASE@
GRASS_VERSION_DATE = @GRASS_VERSION_DATE@
+GRASS_VERSION_SVN = @GRASS_VERSION_SVN@
GRASS_VERSION_NUMBER = $(GRASS_VERSION_MAJOR).$(GRASS_VERSION_MINOR).$(GRASS_VERSION_RELEASE)
GRASS_VERSION_NAME = $(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)$(GRASS_VERSION_RELEASE)
Modified: grass/branches/releasebranch_6_4/lib/init/Makefile
--- grass/branches/releasebranch_6_4/lib/init/Makefile 2011-04-18 11:37:56 UTC (rev 46027)
+++ grass/branches/releasebranch_6_4/lib/init/Makefile 2011-04-18 12:58:11 UTC (rev 46028)
@@ -127,7 +127,11 @@
$(ETC)/VERSIONNUMBER:
rm -f $@
- echo "$(GRASS_VERSION_NUMBER)" > $@
+ @if [ -n "$(GRASS_VERSION_SVN)" ] ; then \
+ echo "$(GRASS_VERSION_NUMBER) r$(GRASS_VERSION_SVN)" > $@ ; \
+ else \
+ echo "$(GRASS_VERSION_NUMBER)" > $@ ; \
+ fi
chmod +r $@
$(ETC)/grass_intro: grass_intro.txt version.sed
