[GRASS-SVN] r46051 - in grass/branches/develbranch_6: db/base
db/db.login raster/r.in.arc raster/r.in.gridatb
raster/r.in.mat raster/r.out.arc raster/r.out.gridatb
raster/r.out.mpeg raster/r.out.png raster/r.out.pov
raster/r.out.ppm3 raster/r.out.vtk vector/v.mkgrid
vector/v.out.vtk vector/v.patch vector/v.surf.rst vector/v.vol.rst
svn_grass at osgeo.org
Wed Apr 20 05:09:41 EDT 2011
Author: neteler
Date: 2011-04-20 02:09:41 -0700 (Wed, 20 Apr 2011)
New Revision: 46051
grass/branches/develbranch_6/db/base/connect.c
grass/branches/develbranch_6/db/db.login/main.c
grass/branches/develbranch_6/raster/r.in.arc/main.c
grass/branches/develbranch_6/raster/r.in.gridatb/main.c
grass/branches/develbranch_6/raster/r.in.mat/main.c
grass/branches/develbranch_6/raster/r.out.arc/main.c
grass/branches/develbranch_6/raster/r.out.gridatb/main.c
grass/branches/develbranch_6/raster/r.out.mpeg/main.c
grass/branches/develbranch_6/raster/r.out.png/r.out.png.c
grass/branches/develbranch_6/raster/r.out.pov/main.c
grass/branches/develbranch_6/raster/r.out.ppm3/main.c
grass/branches/develbranch_6/raster/r.out.vtk/main.c
grass/branches/develbranch_6/vector/v.mkgrid/main.c
grass/branches/develbranch_6/vector/v.out.vtk/main.c
grass/branches/develbranch_6/vector/v.patch/main.c
grass/branches/develbranch_6/vector/v.surf.rst/main.c
grass/branches/develbranch_6/vector/v.vol.rst/main.c
some keyword cleanup
Modified: grass/branches/develbranch_6/db/base/connect.c
--- grass/branches/develbranch_6/db/base/connect.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/db/base/connect.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -42,7 +42,7 @@
/* Set description */
module = G_define_module();
- module->keywords = _("database, attribute table");
+ module->keywords = _("database, attribute table, connection settings");
module->description =
_("Prints/sets general DB connection for current mapset and exits.");
Modified: grass/branches/develbranch_6/db/db.login/main.c
--- grass/branches/develbranch_6/db/db.login/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/db/db.login/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
- module->keywords = _("database, SQL");
+ module->keywords = _("database, connection settings");
module->description = _("Sets user/password for driver/database.");
driver = G_define_standard_option(G_OPT_DRIVER);
Modified: grass/branches/develbranch_6/raster/r.in.arc/main.c
--- grass/branches/develbranch_6/raster/r.in.arc/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.in.arc/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -56,7 +56,7 @@
G_gisinit(argv[0]);
- module->keywords = _("raster");
+ module->keywords = _("raster, import");
_("Converts an ESRI ARC/INFO ascii raster file (GRID) "
"into a (binary) raster map layer.");
Modified: grass/branches/develbranch_6/raster/r.in.gridatb/main.c
--- grass/branches/develbranch_6/raster/r.in.gridatb/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.in.gridatb/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -38,7 +38,7 @@
_("Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map");
Modified: grass/branches/develbranch_6/raster/r.in.mat/main.c
--- grass/branches/develbranch_6/raster/r.in.mat/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.in.mat/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -89,7 +89,7 @@
G_gisinit(argv[0]);
_("Imports a binary MAT-File(v4) to a GRASS raster.");
Modified: grass/branches/develbranch_6/raster/r.out.arc/main.c
--- grass/branches/develbranch_6/raster/r.out.arc/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.arc/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -57,7 +57,7 @@
G_gisinit(argv[0]);
+ module->keywords = _("raster, export");
_("Converts a raster map layer into an ESRI ARCGRID file.");
Modified: grass/branches/develbranch_6/raster/r.out.gridatb/main.c
--- grass/branches/develbranch_6/raster/r.out.gridatb/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.gridatb/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -41,7 +41,7 @@
_("Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)");
Modified: grass/branches/develbranch_6/raster/r.out.mpeg/main.c
--- grass/branches/develbranch_6/raster/r.out.mpeg/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.mpeg/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -387,7 +387,7 @@
int i, j, k, numi, wildnum;
- module->keywords = _("raster, animation");
+ module->keywords = _("raster, export, animation");
module->description = _("Raster File Series to MPEG Conversion.");
*numviews = *numframes = 0;
Modified: grass/branches/develbranch_6/raster/r.out.png/r.out.png.c
--- grass/branches/develbranch_6/raster/r.out.png/r.out.png.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.png/r.out.png.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -107,7 +107,7 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, png");
+ module->keywords = _("raster, export, png");
_("Export GRASS raster as non-georeferenced PNG image.");
Modified: grass/branches/develbranch_6/raster/r.out.pov/main.c
--- grass/branches/develbranch_6/raster/r.out.pov/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.pov/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -118,7 +118,7 @@
G_gisinit(argv[0]);
_("Converts a raster map layer into a height-field file for POVRAY.");
Modified: grass/branches/develbranch_6/raster/r.out.ppm3/main.c
--- grass/branches/develbranch_6/raster/r.out.ppm3/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.ppm3/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -54,7 +54,7 @@
G_gisinit(argv[0]);
_("Converts 3 GRASS raster layers (R,G,B) to a PPM image file "
"at the pixel resolution of the CURRENTLY DEFINED REGION.");
Modified: grass/branches/develbranch_6/raster/r.out.vtk/main.c
--- grass/branches/develbranch_6/raster/r.out.vtk/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/raster/r.out.vtk/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -145,7 +145,7 @@
G_gisinit(argv[0]);
module->description = _("Converts raster maps into the VTK-Ascii format");
/* Get parameters from user */
Modified: grass/branches/develbranch_6/vector/v.mkgrid/main.c
--- grass/branches/develbranch_6/vector/v.mkgrid/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/vector/v.mkgrid/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -60,7 +60,7 @@
- module->keywords = _("vector");
+ module->keywords = _("vector, geometry");
_("Creates a GRASS vector map of a user-defined grid.");
Modified: grass/branches/develbranch_6/vector/v.out.vtk/main.c
--- grass/branches/develbranch_6/vector/v.out.vtk/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/vector/v.out.vtk/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -43,7 +43,7 @@
G_gisinit(argv[0]);
+ module->keywords = _("vector, export");
_("Converts a GRASS binary vector map to VTK ASCII output.");
Modified: grass/branches/develbranch_6/vector/v.patch/main.c
--- grass/branches/develbranch_6/vector/v.patch/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/vector/v.patch/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -65,7 +65,7 @@
G_gisinit(argv[0]);
module->description = _("Create a new vector map layer "
"by combining other vector map layers.");
Modified: grass/branches/develbranch_6/vector/v.surf.rst/main.c
--- grass/branches/develbranch_6/vector/v.surf.rst/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/vector/v.surf.rst/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -161,7 +161,7 @@
G_gisinit(argv[0]);
+ module->keywords = _("vector, interpolation");
_("Spatial approximation and topographic analysis from given "
"point or isoline data in vector format to floating point "
Modified: grass/branches/develbranch_6/vector/v.vol.rst/main.c
--- grass/branches/develbranch_6/vector/v.vol.rst/main.c 2011-04-20 07:33:51 UTC (rev 46050)
+++ grass/branches/develbranch_6/vector/v.vol.rst/main.c 2011-04-20 09:09:41 UTC (rev 46051)
@@ -199,7 +199,7 @@
G_gisinit(argv[0]);
_("Interpolates point data to a G3D grid volume using "
"regularized spline with tension (RST) algorithm.");
