[GRASS-SVN] r46053 - in grass/trunk: db/db.login raster/r.in.arc
raster/r.in.gridatb raster/r.in.mat raster/r.in.png
raster/r.out.arc raster/r.out.bin raster/r.out.gridatb
raster/r.out.mpeg raster/r.out.pov raster/r.out.ppm3
raster3d/r3.out.v5d raster3d/r3.out.vtk vector/v.vol.rst
svn_grass at osgeo.org
Wed Apr 20 05:10:59 EDT 2011
Author: neteler
Date: 2011-04-20 02:10:59 -0700 (Wed, 20 Apr 2011)
New Revision: 46053
grass/trunk/db/db.login/main.c
grass/trunk/raster/r.in.arc/main.c
grass/trunk/raster/r.in.gridatb/main.c
grass/trunk/raster/r.in.mat/main.c
grass/trunk/raster/r.in.png/main.c
grass/trunk/raster/r.out.arc/main.c
grass/trunk/raster/r.out.bin/main.c
grass/trunk/raster/r.out.gridatb/main.c
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/raster/r.out.pov/main.c
grass/trunk/raster/r.out.ppm3/main.c
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/vector/v.vol.rst/main.c
some keyword cleanup
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/db/db.login/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -36,7 +36,7 @@
module = G_define_module();
G_add_keyword(_("database"));
- G_add_keyword(_("connection"));
+ G_add_keyword(_("connection settings"));
module->description = _("Sets user/password for driver/database.");
driver = G_define_standard_option(G_OPT_DB_DRIVER);
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.in.arc/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -58,6 +58,7 @@
G_add_keyword(_("raster"));
+ G_add_keyword(_("import"));
_("Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map.");
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.in.gridatb/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -43,6 +43,7 @@
/* Set description */
_("Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map");
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.in.mat/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -89,6 +89,7 @@
_("Imports a binary MAT-File(v4) to a GRASS raster.");
Modified: grass/trunk/raster/r.in.png/main.c
--- grass/trunk/raster/r.in.png/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.in.png/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -518,6 +518,8 @@
G_gisinit(argv[0]);
+ G_add_keyword(_("raster"));
module->description = "Import non-georeferenced PNG format image.";
inopt = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.arc/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -58,6 +58,7 @@
+ G_add_keyword(_("export"));
_("Converts a raster map layer into an ESRI ARCGRID file.");
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.bin/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -277,6 +277,7 @@
module->description = _("Exports a GRASS raster to a binary array.");
/* Define the different options */
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.gridatb/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -65,6 +65,7 @@
_("Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL).");
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.mpeg/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -100,6 +100,7 @@
G_add_keyword(_("animation"));
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.pov/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -119,6 +119,7 @@
_("Converts a raster map layer into a height-field file for POV-Ray.");
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster/r.out.ppm3/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -54,6 +54,7 @@
module->description = _("Converts 3 GRASS raster layers (R,G,B) to a PPM image file.");
for (i = 0; i < 3; i++) {
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -287,8 +287,8 @@
G_gisinit(argv[0]);
G_add_keyword(_("raster3d"));
+ G_add_keyword(_("voxel"));
- G_add_keyword(_("voxel"));
_("Converts a 3D raster map into a 3-dimensional Vis5D file.");
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -370,8 +370,8 @@
_("Converts 3D raster maps into the VTK-ASCII format.");
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2011-04-20 09:10:41 UTC (rev 46052)
+++ grass/trunk/vector/v.vol.rst/main.c 2011-04-20 09:10:59 UTC (rev 46053)
@@ -238,6 +238,9 @@
G_add_keyword(_("vector"));
+ G_add_keyword(_("surface"));
+ G_add_keyword(_("interpolation"));
+ G_add_keyword(_("RST"));
_("Interpolates point data to a G3D grid volume using "
"regularized spline with tension (RST) algorithm.");
