[GRASS-SVN] r46079 -
grass/branches/releasebranch_6_4/vector/v.buffer2
svn_grass at osgeo.org
Fri Apr 22 03:28:19 EDT 2011
Author: mmetz
Date: 2011-04-22 00:28:19 -0700 (Fri, 22 Apr 2011)
New Revision: 46079
grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
backport r45857
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2011-04-22 06:58:47 UTC (rev 46078)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2011-04-22 07:28:19 UTC (rev 46079)
@@ -74,19 +74,32 @@
struct line_pnts **iPoints;
-int point_in_buffer(struct buf_contours *arr_bc, int buffers_count,
+int point_in_buffer(struct buf_contours *arr_bc, SPATIAL_INDEX *si,
double x, double y)
int i, j, ret, flag;
+ BOUND_BOX bbox;
+ static struct ilist *List = NULL;
- for (i = 0; i < buffers_count; i++) {
- ret = Vect_point_in_poly(x, y, arr_bc[i].oPoints);
+ if (List == NULL)
+ List = Vect_new_list();
+ /* select outer contours overlapping with centroid (x, y) */
+ bbox.W = bbox.E = x;
+ bbox.N = bbox.S = y;
+ bbox.T = PORT_DOUBLE_MAX;
+ bbox.B = -PORT_DOUBLE_MAX;
+ Vect_spatial_index_select(si, &bbox, List);
+ for (i = 0; i < List->n_values; i++) {
+ ret = Vect_point_in_poly(x, y, arr_bc[List->value[i]].oPoints);
if (ret == 0)
continue;
flag = 1;
- for (j = 0; j < arr_bc[i].inner_count; j++) {
- ret = Vect_point_in_poly(x, y, arr_bc[i].iPoints[j]);
+ for (j = 0; j < arr_bc[List->value[i]].inner_count; j++) {
+ ret = Vect_point_in_poly(x, y, arr_bc[List->value[i]].iPoints[j]);
if (ret != 0) { /* inside inner contour */
flag = 0;
break;
@@ -121,6 +134,8 @@
int field;
struct buf_contours *arr_bc;
int buffers_count;
+ SPATIAL_INDEX si;
+ BOUND_BOX bbox;
/* Attributes if sizecol is used */
int nrec, ctype;
@@ -354,12 +369,23 @@
/* Create buffers' boundaries */
- nlines = Vect_get_num_lines(&In);
- nareas = Vect_get_num_areas(&In);
- /* TODO: don't allocate so much space */
- buffers_count = 0;
- arr_bc = G_malloc((nlines + nareas) * sizeof(struct buf_contours));
+ nlines = nareas = 0;
+ if ((type & GV_POINTS) || (type & GV_LINES))
+ nlines += Vect_get_num_primitives(&In, type);
+ if (type & GV_AREA)
+ nareas = Vect_get_num_areas(&In);
+ if (nlines + nareas == 0) {
+ G_warning(_("No features available for buffering. "
+ "Check type option and features available in the input vector."));
+ exit(EXIT_SUCCESS);
+ buffers_count = 1;
+ arr_bc = G_malloc((nlines + nareas + 1) * sizeof(struct buf_contours));
+ Vect_spatial_index_init(&si);
/* Lines (and Points) */
if ((type & GV_POINTS) || (type & GV_LINES)) {
int ltype;
@@ -408,7 +434,8 @@
G_debug(2, _("The tolerance in map units: %g"),
unit_tolerance);
+ Vect_line_prune(Points);
if (ltype & GV_POINTS || Points->n_points == 1) {
Vect_point_buffer2(Points->x[0], Points->y[0], da, db, dalpha,
!(straight_flag->answer), unit_tolerance,
@@ -491,9 +518,14 @@
/* write all buffer contours */
+ G_message(_("Writting buffers..."));
+ for (i = 1; i < buffers_count; i++) {
G_percent(i, buffers_count, 2);
Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
+ dig_line_box(arr_bc[i].oPoints, &bbox);
+ Vect_spatial_index_add_item(&si, i, &bbox);
Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
@@ -514,20 +546,27 @@
G_message(_("Removing duplicates..."));
Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
- G_message(_("Breaking boundaries..."));
- Vect_break_lines(&Out, GV_BOUNDARY, NULL);
+ do {
+ G_message(_("Breaking boundaries..."));
+ Vect_break_lines(&Out, GV_BOUNDARY, NULL);
- G_message(_("Removing duplicates..."));
- Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
+ G_message(_("Removing duplicates..."));
+ Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
+ G_message(_("Cleaning boundaries at nodes"));
+ } while (Vect_clean_small_angles_at_nodes(&Out, GV_BOUNDARY, NULL) > 0);
/* Dangles and bridges don't seem to be necessary if snapping is small enough. */
+ /* Still needed for larger buffer distances ? */
- G_message ( "Removing dangles..." );
- Vect_remove_dangles ( &Out, GV_BOUNDARY, -1, NULL, stderr );
+ G_message(_("Removing dangles..."));
+ Vect_remove_dangles(&Out, GV_BOUNDARY, -1, NULL);
- G_message ( "Removing bridges..." );
- Vect_remove_bridges ( &Out, NULL, stderr );
+ G_message (_("Removing bridges..."));
+ Vect_remove_bridges(&Out, NULL);
G_message(_("Attaching islands..."));
Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES);
@@ -535,6 +574,7 @@
/* Calculate new centroids for all areas */
nareas = Vect_get_num_areas(&Out);
Areas = (char *)G_calloc(nareas + 1, sizeof(char));
+ G_message(_("Calculating centroids for areas..."));
G_percent(0, nareas, 2);
for (area = 1; area <= nareas; area++) {
double x, y;
@@ -552,7 +592,7 @@
continue;
- ret = point_in_buffer(arr_bc, buffers_count, x, y);
+ ret = point_in_buffer(arr_bc, &si, x, y);
if (ret) {
G_debug(3, " -> in buffer");
@@ -565,6 +605,7 @@
G_debug(3, "nlines = %d", nlines);
Lines = (char *)G_calloc(nlines + 1, sizeof(char));
+ G_message(_("Generating list of boundaries to be deleted..."));
for (line = 1; line <= nlines; line++) {
int j, side[2], areas[2];
@@ -597,12 +638,26 @@
G_free(Areas);
/* Delete boundaries */
+ G_message(_("Deleting boundaries..."));
G_percent(line, nlines, 2);
+ if (!Vect_line_alive(&Out, line))
+ continue;
if (Lines[line]) {
G_debug(3, " delete line %d", line);
Vect_delete_line(&Out, line);
+ else {
+ /* delete incorrect boundaries */
+ int side[2];
+ Vect_get_line_areas(&Out, line, &side[0], &side[1]);
+ if (!side[0] && !side[1])
+ Vect_delete_line(&Out, line);
G_free(Lines);
@@ -612,6 +667,7 @@
Vect_cat_set(Cats, 1, 1);
double x, y;
@@ -628,7 +684,7 @@
continue;
if (ret) {
Vect_reset_line(Points);
@@ -646,6 +702,8 @@
G_free(arr_bc[i].iPoints);
+ Vect_spatial_index_destroy(&si);
Vect_close(&In);
Vect_build_partial(&Out, GV_BUILD_NONE);
