[GRASS-SVN] r46095 - grass/trunk/locale/po
Sun Apr 24 22:18:38 EDT 2011
Author: neteler
Date: 2011-04-24 19:18:38 -0700 (Sun, 24 Apr 2011)
New Revision: 46095
   grass/trunk/locale/po/grassmods_pt_br.po
Fred Maranh?\195?\163o: cont'ed
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2011-04-25 02:18:17 UTC (rev 46094)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2011-04-25 02:18:38 UTC (rev 46095)
@@ -12,7 +12,7 @@
 "Project-Id-Version: grassmods_pt_br\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-04-23 15:35+0200\n"
-"PO-Revision-Date: 2011-04-18 00:20-0300\n"
+"PO-Revision-Date: 2011-04-23 21:55-0300\n"
 "Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
 "Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
@@ -126,38 +126,32 @@
 msgstr "Imprime informações básicas sobre uma camada de mapa 3D especificada pelo usuário."
 #: ../raster3d/r3.info/r3.info.main.c:88
-#, fuzzy
 msgid "Name of input 3D raster map"
-msgstr "Nome do Raster de entrada"
+msgstr "Nome do mapa raster 3D de entrada"
 #: ../raster3d/r3.info/r3.info.main.c:92 ../raster/r.info/main.c:79
 msgid "Print range only"
 msgstr "Imprime apenas o intervalo"
 #: ../raster3d/r3.info/r3.info.main.c:97
-#, fuzzy
 msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr "Imprime apenas a resolução (NS-res, EW-res)"
+msgstr "Imprime apenas a resolução do mapa raster 3D (res-NS, res-LO, res-TF)"
 #: ../raster3d/r3.info/r3.info.main.c:101
-#, fuzzy
 msgid "Print 3D raster map type (float/double) only"
-msgstr "Imprime apenas o tipo do mapa raster"
+msgstr "Imprime apenas o tipo (float/double) do mapa raster 3D"
 #: ../raster3d/r3.info/r3.info.main.c:105
-#, fuzzy
 msgid "Print 3D raster map region only"
-msgstr "Imprime apenas a região do mapa raster"
+msgstr "Imprime apenas a região do mapa raster 3D"
 #: ../raster3d/r3.info/r3.info.main.c:109
-#, fuzzy
 msgid "Print 3D raster history instead of info"
-msgstr "Mostra histórico do vetor ao invés de informações"
+msgstr "Imprime histórico do raster 3D ao invés de informações"
 #: ../raster3d/r3.info/r3.info.main.c:114
-#, fuzzy
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr "Mostra carimbo de data (dia.mês.ano hora:minuto:segundo)"
+msgstr "Imprime apenas o carimbo de data do mapa raster 3D (dia.mês.ano hora:min:seg)"
 #: ../raster3d/r3.info/r3.info.main.c:122 ../raster/r.walk/main.c:447
 #: ../raster/r.walk/main.c:452 ../raster/r.walk/main.c:817
@@ -188,9 +182,9 @@
 #: ../visualization/nviz2/cmd/surface.c:104 ../doc/raster/r.example/main.c:105
 #: ../imagery/i.gensigset/parse.c:42 ../imagery/i.gensig/parse.c:36
 #: ../imagery/i.group/main.c:202 ../imagery/i.group/main.c:241
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> not found"
-msgstr "mapa raster <%s> não encontrado"
+msgstr "Mapa raster <%s> não encontrado"
 #: ../raster3d/r3.info/r3.info.main.c:129 ../raster3d/r3.mkdspf/main.c:169
 #, c-format
@@ -230,9 +224,8 @@
 msgstr "Erro lendo intervalo para [%s]"
 #: ../raster3d/r3.info/r3.info.main.c:401
-#, fuzzy
 msgid "Error while reading history file"
-msgstr "Erro na leitura do arquivo de assinaturas."
+msgstr "Erro na leitura do arquivo de histórico"
 #: ../raster3d/r3.in.ascii/main.c:79
 msgid "Ascii raster map to be imported"
@@ -307,7 +300,7 @@
 msgstr "Diahora, diahora1/diahora2, ou nenhum"
 #: ../raster3d/r3.timestamp/r3.timestamp.main.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "Grid3 <%s> not found %s"
 msgstr "Grid3 <%s> não encontrada %s"
@@ -547,88 +540,81 @@
 msgstr "Memória Esgotada! (Out of Memory)"
 #: ../raster3d/r3.to.rast/main.c:288
-#, fuzzy, c-format
+#, c-format
 msgid "Creating %i raster maps"
-msgstr "Criando %i mapas raster\n"
+msgstr "Criando %i mapas raster"
 #: ../raster3d/r3.to.rast/main.c:294
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map %i Filename: %s"
-msgstr "Mapa raster %i Nome do arquivo: %s\n"
+msgstr "Nome do arquivo do mapa raster %i: %s"
 #: ../raster3d/r3.to.rast/main.c:297
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-msgstr "Varredura mapear"
+msgstr "Nome de arquivo %d de mapa raster: %s já existe. Será sobreescrito!"
 #: ../raster3d/r3.out.vtk/main.c:114
-#, fuzzy
 msgid "You have to specify top and bottom map"
-msgstr "para topo mapear"
+msgstr "Você tem que especificar mapas de topo e de fundo"
 #: ../raster3d/r3.out.vtk/main.c:121
-#, fuzzy, c-format
+#, c-format
 msgid "Top cell map <%s> not found"
+msgstr "mapa de células de topo <%s> não encontrado"
 #: ../raster3d/r3.out.vtk/main.c:130
-#, fuzzy, c-format
+#, c-format
 msgid "Bottom cell map <%s> not found"
+msgstr "mapa de células de fundo <%s> não encontrado"
 #: ../raster3d/r3.out.vtk/main.c:139
-#, fuzzy, c-format
+#, c-format
 msgid "Requested 3d raster map <%s> not found"
-msgstr "Mapa g3d solicitado não foi encontrado"
+msgstr "Mapa raster 3d <%s> solicitado não foi encontrado"
 #: ../raster3d/r3.out.vtk/main.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "Requested g3d RGB map <%s> not found"
+msgstr "Mapa g3d solicitado <%s> não foi encontrado"
 #: ../raster3d/r3.out.vtk/main.c:153
-#, fuzzy
 msgid "Please provide three g3d RGB maps"
-msgstr "RGB"
+msgstr "Favor fornecer três mapas RGB g3d"
 #: ../raster3d/r3.out.vtk/main.c:163
-#, fuzzy, c-format
+#, c-format
 msgid "Requested g3d vector map <%s> not found"
-msgstr "mapa vetorial <%s> não encontrado"
+msgstr "mapa vetorial g3d pedido <%s> não encontrado"
 #: ../raster3d/r3.out.vtk/main.c:167
 msgid "Please provide three g3d vector maps [x,y,z]"
 msgstr "Favor fornecer três mapas vetoriais g3d [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:174
-#, fuzzy
 msgid "No g3d data, RGB or xyz-vector maps are provided! Will only write the geometry."
-msgstr "Não RGB geometria."
+msgstr "Sem dados g3d, mapas RGB ou vetor-xyz são fornecidos! Vou escrever apenas a geometria."
 #: ../raster3d/r3.out.vtk/main.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "Open rgb 3d raster map %s"
-msgstr "Abrir mapa raster 3Draster %s"
+msgstr "Abrir mapa raster 3d rgb %s"
 #: ../raster3d/r3.out.vtk/main.c:207
-#, fuzzy
 msgid "No RGB Data will be created."
-msgstr "Erro abrindo Não RGB."
+msgstr "Nenhum dado RGB será criado."
 #: ../raster3d/r3.out.vtk/main.c:250
-#, fuzzy
 msgid "Error closing g3d rgb map."
-msgstr "Erro fechando arquivo g3d"
+msgstr "Erro fechando mapa rgb g3d"
 #: ../raster3d/r3.out.vtk/main.c:291
-#, fuzzy
 msgid "No vector data will be created."
-msgstr "Arquivo vetorial para criar"
+msgstr "Nenhum dado vetorial será criado."
 #: ../raster3d/r3.out.vtk/main.c:335
-#, fuzzy
 msgid "Error closing g3d vector map."
+msgstr "Erro fechando mapa de vetor g3d"
 #: ../raster3d/r3.out.vtk/main.c:376
 #, fuzzy
@@ -640,84 +626,70 @@
 msgstr "falha interpretando dp como inteiro"
 #: ../raster3d/r3.out.vtk/main.c:389 ../raster/r.out.ascii/main.c:126
-#, fuzzy
 msgid "dp has to be from 0 to 20"
-msgstr "para para"
+msgstr "dp tem valores de 0 a 20"
 #: ../raster3d/r3.out.vtk/main.c:449
 msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:541
-#, fuzzy
 msgid "Error closing 3d raster map, the VTK file may be incomplete."
-msgstr "Erro mapear."
+msgstr "Erro ao fechar mapa raster 3d, o arquivo VTK pode estar incompleto."
 #: ../raster3d/r3.out.vtk/main.c:556 ../raster/r.out.vtk/main.c:282
 msgid "Error closing VTK-ASCII file"
 msgstr "Erro fechando arquivo VTK-ASCII"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:39
-#, fuzzy
 msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr "writeVTKStructuredElevationHeader: Escrevendo cabeçalho VTK"
+msgstr "write_vtk_structured_point_header: Escrevendo cabeçalho VTKStructuredPoint"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:95
-#, fuzzy
 msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
+msgstr "write_vtk_structured_grid_header: Escrevendo VTKStructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:116
-#, fuzzy
 msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
+msgstr "write_vtk_unstructured_grid_header: Escrevendo VTKUnstructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/errorHandling.c:65
-#, fuzzy
 msgid "unable to close input 3d raster map"
-msgstr "Não consegui fechar mapa de entrada"
+msgstr "Não consegui fechar mapa raster 3d de entrada"
 #: ../raster3d/r3.out.vtk/parameters.c:30
-#, fuzzy
 msgid "G3D map(s) to be converted to VTK-ASCII data format"
-msgstr "Mapa 3dcell para converter para formato VTK-ASCII"
+msgstr "Mapa(s) G3D para serem convertidos para formato de dados VTK-ASCII"
 #: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:41
 msgid "Name for VTK-ASCII output file"
 msgstr "Nome do arquivo VTK-ASCII de saída"
 #: ../raster3d/r3.out.vtk/parameters.c:41
-#, fuzzy
 msgid "Float value to represent no data cell/points"
-msgstr "Valor para representar célula sem dados"
+msgstr "Valor flutuante para representar nenhuma célula/ponto de dados"
 #: ../raster3d/r3.out.vtk/parameters.c:47
-#, fuzzy
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr "Criar dados pontual VTK ao invés de dado VTK celular (padrão)"
+msgstr "Criar dados pontuais (pointdata) VTK ao invés de dados de células (celldata) VTK (dados de célula é o padrão)"
 #: ../raster3d/r3.out.vtk/parameters.c:56
-#, fuzzy
 msgid "top surface 2D raster map"
-msgstr "Mapa raster de saída"
+msgstr "Mapa raster 2D de superfície de topo"
 #: ../raster3d/r3.out.vtk/parameters.c:65
-#, fuzzy
 msgid "bottom surface 2D raster map"
-msgstr "Mapa base raster"
+msgstr "Mapa raster 2D de superfície de fundo"
 #: ../raster3d/r3.out.vtk/parameters.c:71
-#, fuzzy
 msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr "topo solicitado."
+msgstr "Cria saída de elevação 3d com uma superfície de topo e piso, ambos os mapas raster sendo requisitados."
 #: ../raster3d/r3.out.vtk/parameters.c:82
-#, fuzzy
 msgid "Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr "3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, mapaverde, mapaazul]"
+msgstr "3 mapas raster (r,g,b) 3d que serão usado para criar valores rgb [mapavermelho, mapaverde, mapaazul]"
 #: ../raster3d/r3.out.vtk/parameters.c:92
-#, fuzzy
 msgid "Three (x,y,z) 3d raster maps to create vector values [xmap,ymap,zmap]"
@@ -733,14 +705,12 @@
 msgstr "Número de dígitos significativos (apenas ponto flutuante)"
 #: ../raster3d/r3.out.vtk/parameters.c:117
-#, fuzzy
 msgid "Use g3d mask (if exists) with input maps"
-msgstr "Usa máscara G3D (se existir) com o mapa de entrada"
+msgstr "Usa máscara g3d (se existir) com os mapas de entrada"
 #: ../raster3d/r3.out.vtk/parameters.c:122
-#, fuzzy
 msgid "Scale factor effects the origin"
-msgstr "Fator de escala para elevação"
+msgstr "Fator de escala afeta a origem"
 #: ../raster3d/r3.out.vtk/parameters.c:128
 #: ../raster/r.out.vtk/parameters.c:138 ../vector/v.out.vtk/main.c:90
@@ -748,35 +718,30 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/writeVTKData.c:123
-#, fuzzy
 msgid "write_vtk_points: Writing point coordinates"
-msgstr "writeVTKStructuredCoordinates: Escrevendo coordenadas"
+msgstr "write_vtk_points: Escrevendo coordenadas do ponto"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:254
-#, fuzzy
 msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+msgstr "write_vtk_unstructured_grid_cells: Gravando as células"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:332
-#, fuzzy, c-format
+#, c-format
 msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
-msgstr "G3dTovtk: Escrevendo Celldatafield %s com linhas %i colunas %i profundidades %i para arquivo VTK-ASCII"
+msgstr "write_vtk_data: Gravando dados de célula (celldata) %s com linhas %i colunas %i profundidades %i para arquivo vtk-ascii"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:390
-#, fuzzy
 msgid "write_vtk_rgb_data: writing rgb data"
-msgstr "writeVTKRGBImageData: Escrevendo cabeçalho VTK"
+msgstr "write_vtk_rgb_data: gravando dados rgb"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:427
 #: ../raster3d/r3.out.vtk/writeVTKData.c:460
-#, fuzzy
 msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr "Valores de mapa incorretos. Valores devem estar entre 0 e 255!\n"
+msgstr "Valores de mapa raster 3d incorretos! Valores devem estar entre 0 e 255!\n"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:490
-#, fuzzy
 msgid "write_vtk_vector_data: writing vector data"
-msgstr "writeVTKData: Escrevendo cabeçalho VTK"
+msgstr "write_vtk_vector_data: escrevendo dados vetoriais"
 #: ../raster3d/r3.gwflow/main.c:54
 msgid "Input 3d-raster map with initial piezometric heads in [m]"
@@ -833,9 +798,8 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
-#, fuzzy
 msgid "Use G3D mask (if exists)"
+msgstr "Usa máscara G3D (se existir)"
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
 msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
@@ -879,40 +843,36 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:281 ../raster/r.gwflow/main.c:542
-#, fuzzy
 msgid "Unable to create and solve the linear equation system"
-msgstr "Não consegui criar arquivo raster [%s]."
+msgstr "Não consegui criar e resolver o sistema de equações lineares"
 #: ../raster3d/r3.gwflow/main.c:370 ../raster3d/r3.stats/main.c:619
 #: ../raster/r.univar/r3.univar_main.c:158
 #: ../raster/r.univar/r3.univar_main.c:200
-#, fuzzy, c-format
+#, c-format
 msgid "Error opening g3d map <%s>"
-msgstr "Erro abrindo arquivo g3d"
+msgstr "Erro abrindo mapa g3d <%s>"
 #: ../raster3d/r3.gwflow/main.c:372
-#, fuzzy, c-format
+#, c-format
 msgid "Write the result to g3d map <%s>"
-msgstr "Título para o mapa raster resultante"
+msgstr "Escrever o resultado para o mapa g3d <%s>"
 #: ../raster3d/r3.gwflow/main.c:416
-#, fuzzy
 msgid "Error closing g3d file"
-msgstr "Erro fechando arquivo VTK-ASCII"
+msgstr "Erro fechando arquivo g3d"
 #: ../raster3d/r3.mkdspf/main.c:82
-#, fuzzy
 msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr "Cria uma exibição a partir de um arquivo grid3, de acordo com os limites especificados."
+msgstr "Cria um arquivo de exibição a partir de um arquivo grid3 existente, de acordo com os limiares especificados."
 #: ../raster3d/r3.mkdspf/main.c:90
 msgid "Name of an existing 3d raster map"
 msgstr "Nome do mapa 3dcell existente"
 #: ../raster3d/r3.mkdspf/main.c:97
-#, fuzzy
 msgid "Name of output display file"
-msgstr "Nome do arquivo de saída"
+msgstr "Nome do arquivo de exibição de saída"
 #: ../raster3d/r3.mkdspf/main.c:104
 msgid "List of thresholds for isosurfaces"
@@ -995,14 +955,12 @@
 msgstr "Estatísticas de transição de classe."
 #: ../raster3d/r3.stats/main.c:570
-#, fuzzy
 msgid "Generates volume statistics for raster3d maps."
-msgstr "Gera estatísticas areais para os mapas raster."
+msgstr "Gera estatísticas de volume para os mapas raster 3d."
 #: ../raster3d/r3.stats/main.c:581
-#, fuzzy
 msgid "Number of sub-ranges to collect stats from"
-msgstr "Número de intervalos fp para coletar estatísticas"
+msgstr "Número de sub-intervalos para coletar estatísticas"
 #: ../raster3d/r3.stats/main.c:587
 msgid "Calculate statistics based on equal value groups"
@@ -1014,14 +972,13 @@
 #: ../raster3d/r3.stats/main.c:612 ../raster/r.univar/r3.univar_main.c:151
 #: ../raster/r.univar/r3.univar_main.c:193
-#, fuzzy, c-format
+#, c-format
 msgid "Requested g3d map <%s> not found"
-msgstr "Arquivo g3d solicitado não foi encontrado"
+msgstr "Mapa g3d <%s> solicitado não encontrado"
 #: ../raster3d/r3.stats/main.c:666
-#, fuzzy
 msgid "Sort non-null values"
-msgstr "Não"
+msgstr "Ordenar valores não-nulo"
 #: ../raster3d/base/r3.null.main.c:55
 msgid "3d raster map for which to modify null values"
@@ -1036,9 +993,8 @@
 msgstr "O valor que substitui o valor nulo"
 #: ../raster3d/base/r3.null.main.c:85
-#, fuzzy
 msgid "Illegal value for null"
-msgstr "valor ilegal para NULO"
+msgstr "valor ilegal para null"
 #: ../raster3d/base/r3.null.main.c:110
 msgid "modifyNull: error opening map"
@@ -1049,14 +1005,12 @@
 msgstr "modifyNull: erro abrindo arquivo tmp"
 #: ../raster3d/base/r3.null.main.c:171
-#, fuzzy
 msgid "modifyNull: error flushing tiles in cube"
-msgstr "modifyNull: erro limpando mosaico."
+msgstr "modifyNull: erro limpando mosaico em cubo"
 #: ../raster3d/base/r3.null.main.c:177
-#, fuzzy
 msgid "modifyNull: error flushing all tiles"
+msgstr "modifyNull: erro limpando todo o mosaico."
 #: ../raster3d/base/r3.null.main.c:185
 msgid "modifyNull: error closing map"
@@ -1067,7 +1021,6 @@
 msgstr "modifyNull: erro fechando arquivo tmp"
 #: ../raster3d/base/r3.null.main.c:205
-#, fuzzy
 msgid "Explicitly create the 3D NULL-value bitmap file."
 msgstr "Explicitamente cria o arquivo bitmap 3D com valores NULL"
@@ -1079,7 +1032,7 @@
 #: ../raster3d/base/mask_functions.c:100 ../raster/r.null/main.c:258
 #, fuzzy, c-format
 msgid "%s: illegal value spec"
-msgstr "%s=%s - nome ilegal"
+msgstr "%s: spec de valor ilegal"
 #: ../raster3d/base/r3.mask.main.c:64
 msgid "makeMask: error opening map."
@@ -1090,14 +1043,12 @@
 msgstr "makeMask: erro abrindo arquivo de máscara g3d."
 #: ../raster3d/base/r3.mask.main.c:104
-#, fuzzy
 msgid "makeMask: error flushing tiles in cube"
-msgstr "makeMask: erro limpando mosaico."
+msgstr "makeMask: erro limpando ladrilhos em cubo"
 #: ../raster3d/base/r3.mask.main.c:109
-#, fuzzy
 msgid "makeMask: error flushing all tiles"
+msgstr "makeMask: erro limpando todo o mosaico"
 #: ../raster3d/base/r3.mask.main.c:117
 msgid "makeMask: error closing g3d mask file"
@@ -1284,20 +1235,19 @@
 #: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
 #: ../raster/r.out.bin/main.c:462 ../raster/r.mapcalc/map3.c:126
 #: ../raster/r.mapcalc/map3.c:140 ../raster/r.mapcalc/map3.c:154
-#, fuzzy
 msgid "Error writing data"
-msgstr "Erro lendo coringa."
+msgstr "Erro escrevendo dados"
 #: ../raster/r.out.bin/main.c:139
-#, fuzzy, c-format
+#, c-format
 msgid "Header File = %s"
-msgstr "Abrir arquivo raster %s"
+msgstr "Arquivo de cabeçalho = %s"
 #: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
 #: ../raster/r.out.bin/main.c:408
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create file <%s>"
-msgstr "Não consegui criar arquivo [%s]"
+msgstr "Não consegui criar arquivo <%s>"
 #: ../raster/r.out.bin/main.c:223
 #, c-format
@@ -1327,29 +1277,24 @@
 msgstr "Valor para marcar dados nulos"
 #: ../raster/r.out.bin/main.c:311 ../raster/r.in.bin/main.c:286
-#, fuzzy
 msgid "Number of bytes per cell"
-msgstr "        Número de bytes por célula"
+msgstr "Número de bytes por célula"
 #: ../raster/r.out.bin/main.c:318 ../raster/r.in.bin/main.c:294
-#, fuzzy
 msgid "Output byte order"
-msgstr "Arquivo KeyFrame de saída"
+msgstr "Ordem de bytes de saída"
 #: ../raster/r.out.bin/main.c:323
-#, fuzzy
 msgid "Generate integer output"
-msgstr "Criando mapa raster 3D\n"
+msgstr "Gera saída inteira"
 #: ../raster/r.out.bin/main.c:327
-#, fuzzy
 msgid "Generate floating-point output"
-msgstr "Truncar dados em ponto flutuante"
+msgstr "Gera saída de ponto flutuante"
 #: ../raster/r.out.bin/main.c:331
-#, fuzzy
 msgid "Export array with GMT compatible header"
-msgstr "Exportar arquivo com cabeçalho compatível com o GMT"
+msgstr "Exportar array com cabeçalho compatível com GMT"
 #: ../raster/r.out.bin/main.c:335
 msgid "Generate BIL world and header files"
@@ -1365,14 +1310,12 @@
 msgstr "Valor inválido para null (apenas inteiros)"
 #: ../raster/r.out.bin/main.c:367
-#, fuzzy
 msgid "order= and -s are mutually exclusive"
-msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
+msgstr "order= e -s são mutuamente exclusivas"
 #: ../raster/r.out.bin/main.c:376
-#, fuzzy
 msgid "-i and -f are mutually exclusive"
+msgstr "-i e -f são mutuamente exclusivas"
 #: ../raster/r.out.bin/main.c:395
 msgid "Floating-point output requires bytes=4 or bytes=8"
@@ -1387,32 +1330,30 @@
 msgstr ""
 #: ../raster/r.out.bin/main.c:419
-#, fuzzy
 msgid "Creating BIL support files..."
-msgstr "Criando arquivos de suporte para %s..."
+msgstr "Criando arquivos de suporte BIL"
 #: ../raster/r.out.bin/main.c:436
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting raster as floating values (bytes=%d)"
+msgstr "Exportando raster como valores de ponto flutuante (bytes=%d)"
 #: ../raster/r.out.bin/main.c:438
 msgid "Writing GMT float format ID=1"
 msgstr ""
 #: ../raster/r.out.bin/main.c:441
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting raster as integer values (bytes=%d)"
-msgstr "Nome de um arquivo raster existente"
+msgstr "Exportando raster como valores inteiros (bytes=%d)"
 #: ../raster/r.out.bin/main.c:443
 msgid "Writing GMT integer format ID=2"
 msgstr ""
 #: ../raster/r.out.bin/main.c:446
-#, fuzzy
 msgid "Using the current region settings..."
-msgstr "Mostra a extensão da região atual"
+msgstr "Usando as configurações da região atual..."
 #: ../raster/r.out.bin/main.c:447
 #, c-format
@@ -1506,9 +1447,9 @@
 #: ../display/d.his/main.c:173 ../display/d.colortable/main.c:137
 #: ../display/d.histogram/main.c:174 ../display/d.rast/display.c:23
 #: ../display/d.rast.num/main.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "Color file for <%s> not available"
-msgstr "Arquivo de cores para [%s] não disponível"
+msgstr "Arquivo de cores para <%s> não disponível"
 #: ../raster/r.out.mat/main.c:64
 msgid "Exports a GRASS raster to a binary MAT-File."
@@ -1522,29 +1463,28 @@
 #: ../raster/r.out.png/main.c:205 ../raster/r.support/main.c:166
 #: ../raster/r.colors.out/main.c:99 ../raster/r.out.vrml/main.c:141
 #: ../general/g.pnmcat/main.c:174 ../general/g.cairocomp/main.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open output file <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>."
+msgstr "Não consegui abrir arquivo de saída <%s>"
 #: ../raster/r.out.mat/main.c:115
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting <%s>"
-msgstr "Escrevendo [%s]..."
+msgstr "Exportando <%s>"
 #: ../raster/r.out.mat/main.c:175
-#, fuzzy
 msgid "Using the Current Region settings:"
+msgstr "Usando as configurações da Região atual:"
 #: ../raster/r.out.mat/main.c:176 ../raster/r.in.mat/main.c:397
-#, fuzzy, c-format
+#, c-format
 msgid "northern edge=%f"
-msgstr "Valor para a borda norte"
+msgstr "borda norte=%f"
 #: ../raster/r.out.mat/main.c:177 ../raster/r.in.mat/main.c:398
-#, fuzzy, c-format
+#, c-format
 msgid "southern edge=%f"
-msgstr "Valor para a borda sul"
+msgstr "borda sul=%f"
 #: ../raster/r.out.mat/main.c:178 ../raster/r.in.mat/main.c:399
 #, c-format
@@ -1567,24 +1507,22 @@
 msgstr ""
 #: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:403
-#, fuzzy, c-format
+#, c-format
 msgid "rows=%d"
-msgstr "Grupo:    %s\n"
+msgstr "linhas=%d"
 #: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:404
-#, fuzzy, c-format
+#, c-format
 msgid "cols=%d"
-msgstr "coluna(s)"
+msgstr "cols=%d"
 #: ../raster/r.out.mat/main.c:250
-#, fuzzy
 msgid "Exporting raster as integer values"
+msgstr "Exportando raster como valores inteiros"
 #: ../raster/r.out.mat/main.c:255
-#, fuzzy
 msgid "Exporting raster as floating point values"
+msgstr "Exportando raster como valores de ponto flutuante"
 #: ../raster/r.out.mat/main.c:260
 #, fuzzy
@@ -1592,29 +1530,25 @@
 msgstr "Coluna %d definida como inteiro só possui valores double"
 #: ../raster/r.out.mat/main.c:303
-#, fuzzy
 msgid "Reading in map ... "
-msgstr "Lendo imagem ... "
+msgstr "Lendo mapa ... "
 #: ../raster/r.out.mat/main.c:316
-#, fuzzy
 msgid "Writing out map..."
+msgstr "Escrevendo mapa..."
 #: ../raster/r.out.mat/main.c:376
-#, fuzzy, c-format
+#, c-format
 msgid "%ld bytes written to '%s'"
-msgstr "%d pontos escritos no vetor"
+msgstr "%ld bytes escritos em '%s'"
 #: ../raster/r.in.poly/main.c:32
-#, fuzzy
 msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr "Cria mapas raster a partir de arquivos de linhas e polígonos ASCII no diretório atual."
+msgstr "Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
 #: ../raster/r.in.poly/main.c:36
-#, fuzzy
 msgid "Name of input file; or \"-\" to read from stdin"
-msgstr "Arquivo ASCII contendo assinaturas espectrais"
+msgstr "Nome do arquivo de entrada; ou \"-\" para ler da stdin"
 #: ../raster/r.in.poly/main.c:45 ../raster/r.in.gdal/main.c:118
 #: ../raster/r.in.bin/main.c:279 ../raster/r.external/main.c:552
@@ -1627,9 +1561,8 @@
 msgstr "Número de linhas para manter na memória"
 #: ../raster/r.in.poly/main.c:60
-#, fuzzy
 msgid "Minimum number of rows to hold in memory is 1"
-msgstr "Número de linhas para manter na memória"
+msgstr "Número mínimo de linhas para manter na memória é 1"
 #: ../raster/r.in.poly/get_item.c:76
 #, fuzzy, c-format
@@ -2131,7 +2064,7 @@
 #: ../vector/v.out.ascii/main.c:96
 #, fuzzy, c-format
 msgid "Unable to open file <%s>"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo de células <%s>"
 #: ../raster/r.out.ascii/main.c:176
 #, fuzzy, c-format
@@ -2217,7 +2150,7 @@
 #: ../raster/r.out.png/main.c:257
 #, fuzzy, c-format
 msgid "Converting <%s>..."
+msgstr "Escrevendo <%s>..."
 #: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:182
 #, fuzzy, c-format
@@ -2742,7 +2675,7 @@
 #: ../raster/r.in.gdal/main.c:666 ../imagery/i.rectify/target.c:32
 #, fuzzy, c-format
 msgid "Mapset <%s> in target location <%s> - "
-msgstr "Grupo [%s] destinado para locação [%s], mapset [%s]\n"
+msgstr "Grupo <%s> destinado para locação <%s>, mapset [%s]\n"
 #: ../raster/r.in.gdal/main.c:668 ../raster/r.proj/main.c:286
 #: ../imagery/i.rectify/target.c:33
@@ -2950,7 +2883,7 @@
 #: ../raster/r.in.bin/main.c:447
 #, fuzzy, c-format
 msgid "Unable to open <%s>"
 #: ../raster/r.in.bin/main.c:466
 #, c-format
@@ -3311,9 +3244,9 @@
 #: ../raster/r.watershed/shed/com_line.c:266 ../general/g.copy/main.c:80
 #: ../general/g.rename/main.c:78 ../imagery/i.landsat.toar/main.c:483
 #: ../imagery/i.landsat.acca/main.c:189
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is an illegal file name"
-msgstr "[%s] é um nome ilegal"
+msgstr "<%s> é um nome de arquivo ilegal"
 #: ../raster/r.drain/main.c:215
 #, fuzzy
@@ -3650,7 +3583,7 @@
 #: ../raster/r.grow.distance/main.c:355
 #, fuzzy, c-format
 msgid "Unable to read color table for raster map <%s>"
+msgstr "Não consegui criar arquivo raster <%s>."
 #: ../raster/r.stats/main.c:105
 msgid "Generates area statistics for raster map layers."
@@ -3729,7 +3662,7 @@
 #: ../db/db.select/main.c:130
 #, fuzzy, c-format
 msgid "Unable to open file <%s> for writing"
 #: ../raster/r.stats/main.c:214
 #, c-format
@@ -3903,9 +3836,8 @@
 msgstr ""
 #: ../raster/r.sun/main.c:234
-#, fuzzy
 msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, comprimento do dia) são guardados num arquivo texto. Alternativamente, um horário local pode ser especificado para calcular ângulo de incidência e/ou mapas de irradiância. O efeito de sombreamento da topografia também pode ser opcionalmente incorporado."
+msgstr "Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, comprimento do dia) são guardados num arquivo de histórico de mapa. Alternativamente, um horário local pode ser especificado para calcular ângulo de incidência solar e/ou mapas raster de irradiância. O efeito de sombreamento da topografia também pode ser opcionalmente incorporado."
 #: ../raster/r.sun/main.c:248 ../raster/r.horizon/main.c:198
 msgid "Name of the input elevation raster map [meters]"
@@ -4272,29 +4204,26 @@
 msgstr "writeVTKPolygonalElevationHeader: Escrevendo cabeçalho VTK"
 #: ../raster/r.out.vtk/writeascii.c:139
-#, fuzzy
 msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr "writeVTKCellHeader: Escrevendo cabeçalho VTK"
+msgstr "write_vtk_celldata_header: Escrevendo VTK-DataHeader"
 #: ../raster/r.out.vtk/writeascii.c:148
 #, fuzzy
 msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr "writeVTKPointHeader: Escrevendo cabeçalho VTK"
+msgstr "writeVTKPointHeader: Escrevendo VTK-DataHeader"
 #: ../raster/r.out.vtk/writeascii.c:169
 #, fuzzy
 msgid "write_vtk_structured_coordinates: Writing Coordinates"
+msgstr "write_vtk_structured_coordinates: Escrevendo coordenadas"
 #: ../raster/r.out.vtk/writeascii.c:225
-#, fuzzy
 msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr "writeVTKPolygonalCoordinates: Escrevendo dados poligonais VTK"
+msgstr "write_vtk_polygonal_coordinates: Escrevendo dados poligonais VTK"
 #: ../raster/r.out.vtk/writeascii.c:334
-#, fuzzy
 msgid "write_vtk_data: Writing VTK-Data"
+msgstr "write_vtk_data: Escrevendo dados VTK"
 #: ../raster/r.out.vtk/writeascii.c:384
 #, fuzzy
@@ -5578,7 +5507,7 @@
 #: ../raster/r.random/main.c:64
 #, fuzzy
 msgid "Name of cover raster map"
-msgstr "Nome do mapa raster"
+msgstr "Nome do mapa raster de cobertura"
 #: ../raster/r.random/main.c:71
 msgid "The number of points to allocate"
@@ -5660,9 +5589,9 @@
 #: ../imagery/i.landsat.toar/main.c:474 ../imagery/i.landsat.acca/main.c:57
 #: ../imagery/i.landsat.acca/algorithm.c:372
 #: ../imagery/i.landsat.acca/tools.c:126
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open raster map <%s>"
-msgstr "Não consegui abrir mapa raster [%s]."
+msgstr "Não consegui abrir mapa raster <%s>"
 #: ../raster/r.random/random.c:99
 msgid "Cannot create new table"
@@ -7248,28 +7177,24 @@
 msgstr "Imprime informações básicas sobre uma camada de mapa especificada pelo usuário."
 #: ../raster/r.info/main.c:84
-#, fuzzy
 msgid "Print raster map resolution (NS-res, EW-res) only"
+msgstr "Imprime apenas a resolução do mapa raster(res-NS, res-LO)"
 #: ../raster/r.info/main.c:88
 msgid "Print raster map type only"
 #: ../raster/r.info/main.c:92
-#, fuzzy
 msgid "Print map region only"
+msgstr "Imprime apenas a região do mapa"
 #: ../raster/r.info/main.c:96
-#, fuzzy
 msgid "Print raster history instead of info"
+msgstr "Imprime histórico do raster ao invés de informações"
 #: ../raster/r.info/main.c:100
-#, fuzzy
 msgid "Print raster map data units only"
+msgstr "Imprime apenas unidades de dados do mapa raster"
 #: ../raster/r.info/main.c:104
 #, fuzzy
@@ -7513,7 +7438,7 @@
 #: ../raster/r.solute.transport/main.c:125
 msgid "Top surface of the aquifer in [m]"
-msgstr ""
+msgstr "superfície de topo do aquífero em [m]"
 #: ../raster/r.solute.transport/main.c:129
 #, fuzzy
@@ -9027,9 +8952,8 @@
 msgstr ""
 #: ../raster/r.statistics/read_stats.c:20
-#, fuzzy
 msgid "Reading r.stats output"
-msgstr "Problema na leitura da saída r.stats"
+msgstr "Lendo a saída do r.stats"
 #: ../raster/r.li/r.li.padcv/padcv.c:38
 #, fuzzy
@@ -10665,7 +10589,7 @@
 #: ../raster/r.reclass/reclass.c:238
 #, fuzzy, c-format
 msgid "Cannot create raster map <%s>"
 #: ../raster/r.timestamp/main.c:36
 #, fuzzy
@@ -11733,7 +11657,7 @@
 #: ../raster/r.composite/main.c:163
 #, fuzzy, c-format
 msgid "Unable to read color file of raster map <%s>"
 #: ../raster/r.composite/main.c:285
 #, fuzzy
@@ -13732,7 +13656,7 @@
 #: ../general/g.mapset/main.c:198
 msgid "Your shell continues to use the history for the old mapset"
-msgstr ""
+msgstr "Seu shell continua a usar o histórico para o mapset antigo"
 #: ../general/g.mapset/main.c:202
 #, c-format
@@ -13740,6 +13664,8 @@
 "You can switch the history by commands:\n"
 "history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 msgstr ""
+"Você pode alternar o histórico com os comandos:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
 #: ../general/g.mapset/main.c:207
 #, c-format
@@ -13747,6 +13673,8 @@
 "history -S; history -L %s/.history; setenv histfile=%s/.history"
 msgstr ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
 #: ../general/g.mapset/main.c:213
 #, fuzzy, c-format
@@ -21887,16 +21815,16 @@
 #: ../vector/v.support/main.c:118
 msgid "Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
+msgstr "Linha de comando para guardar no arquivo de histórico de mapa vetorial (usado para scripts de vetor)"
 #: ../vector/v.support/main.c:122
 msgid "Replace comment instead of appending it"
 msgstr ""
 #: ../vector/v.support/main.c:183
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open history file for vector map <%s>"
-msgstr "Não consegui abrir cursor de seleção: '%s'"
+msgstr "Não consegui abrir arquivo de histórico para mapa de vetores <%s>"
 #: ../vector/v.select/main.c:52
 msgid "spatial query"
@@ -33080,6 +33008,3719 @@
 msgid "raster, png"
+#, fuzzy
+msgid "Location of input raster map"
+msgstr "Localização do mapa de entrada"
+#, fuzzy
+msgid "Mapset of input raster map"
+msgstr "Nome do Raster de entrada"
+#, fuzzy
+msgid "Checking location <%s>, mapset <%s>..."
+msgstr "Mapa raster de entrada"
+msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
+msgstr " %d.%02d.%02d, dianum %d, hora: %02i:%02i:%02i (hora decimal: %f)\n"
+msgid " long: %f, lat: %f, timezone: %f\n"
+msgstr " long: %f, lat: %f, fuso horário: %f\n"
+msgid ""
+" Solar position: sun azimuth: %f,\n"
+"   sun angle above horz.(refraction corrected): %f\n"
+msgstr ""
+" Posição solar: azimute: %f,\n"
+"   ângulo do sol sobre o horizonte(corrigido da refração): %f\n"
+msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
+msgstr " Hora do Nascente (sem refração): %02d:%02d:%02d\n"
+msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
+msgstr " Hora do Poente (sem refração): %02d:%02d:%02d\n"
+msgid "No map calculation requested. Finished.\n"
+msgstr "Nenhum cálculo de mapa solicitado. Concluído.\n"
+#, fuzzy
+msgid "Can't open range file for %s"
+msgstr "não consegui abrir arquivo de intervalo para %s"
+#, fuzzy
+msgid "<%s> created"
+msgstr "Locação: %s\n"
+msgid "Raster map to be recoded"
+msgstr "Mapa raster a ser recodificado"
+#, fuzzy
+msgid "Raster map to be displayed"
+#, fuzzy
+msgid "Vector output map"
+msgstr "Sem mapa de saída"
+#, fuzzy
+msgid "Rescaling range for output maps (for no rescaling use 0,0)"
+msgstr "Intervalo de transformação da escala de saída (utilizar 0,0 para não transformar)"
+#, fuzzy
+msgid "Failed in attempt to open %s"
+msgstr "Falha abrindo arquivo dig de entrada."
+msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+msgstr "Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas parciais a partir de um mapa raster com valores verdadeiros de elevação. Aspecto é calculado no sentido anti-horário a partir do leste."
+msgid "Output slope filename"
+msgstr "Nome do arquivo de saída de declividade"
+msgid "Output profile curvature filename"
+msgstr "Nome do arquivo de curvatura do perfil"
+msgid "Output tangential curvature filename"
+msgstr "Nome do arquivo de curvatura tangencial"
+msgid "Output first order partial derivative dx (E-W slope) filename"
+msgstr "Nome do arquivo da primeira derivada parcial dx (declive E-W)"
+msgid "Output first order partial derivative dy (N-S slope) filename"
+msgstr "Nome do arquivo da primeira derivada parcial dy (declive N-S)"
+msgid "Output second order partial derivative dxx filename"
+msgstr "Nome do arquivo da segunda derivada parcial dxx"
+msgid "Output second order partial derivative dyy filename"
+msgstr "Nome do arquivo da segunda derivada parcial dyy"
+msgid "Output second order partial derivative dxy filename"
+msgstr "Nome do arquivo da segunda derivada parcial dxy"
+msgid "wrong type: %s"
+msgstr "Tipo incorreta: %s"
+#, fuzzy
+msgid "Creating support files..."
+msgstr "criando arquivos de suporte para %s"
+#, fuzzy
+msgid "Elevation products for mapset [%s] in [%s]"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+msgid "ASPECT [%s] COMPLETE"
+msgstr "ORIENTAÇÃO [%s] COMPLETA"
+msgid "SLOPE [%s] COMPLETE"
+msgstr "DECLIVIDADE [%s] COMPLETA"
+msgid "PROFILE CURVE [%s] COMPLETE"
+msgstr "CURVA DE PERFIL [%s] COMPLETA"
+msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgstr "CURVA TANGENCIAL [%s] COMPLETA"
+msgid "E-W SLOPE [%s] COMPLETE"
+msgstr "DECLIVIDADE E-W [%s] COMPLETA"
+msgid "N-S SLOPE [%s] COMPLETE"
+msgstr "DECLIVIDADE N-S [%s] COMPLETA"
+msgid "DXX [%s] COMPLETE"
+msgstr "DXX [%s] COMPLETA"
+msgid "DYY [%s] COMPLETE"
+msgstr "DYY [%s] COMPLETA"
+msgid "DXY [%s] COMPLETE"
+msgstr "DXY [%s] COMPLETA"
+msgid "Generates a raster map layer showing watershed subbasins."
+msgstr "Gera uma camada raster mostrando as sub-bacias de drenagem."
+msgid "Coded stream network file name"
+msgstr "Nome do arquivo de rede de drenagens"
+msgid "Thinned ridge network file name"
+msgstr "Nome do arquivo com os divisores afinados"
+msgid "Name for the resultant watershed partition file"
+msgstr "Nome do arquivo para a partição de divisores resultante"
+msgid "Name of elevation raster map"
+msgstr "Nome do mapa raster de elevação"
+msgid "Output raster map having shadows"
+msgstr "Saída de raster contendo sombras"
+msgid "B: year (1950..2050)"
+msgstr "B: ano (1950..2050)"
+msgid "B: month (0..12)"
+msgstr "B: mês (0..12)"
+msgid "B: day (0..31)"
+msgstr "B: dia (0..31)"
+msgid "B: hour (0..24)"
+msgstr "B: hora (0..24)"
+#, fuzzy
+msgid "East coordinate (point of interest, default: map center)"
+msgstr "coordenada leste (ponto de interesse, padrão: centro do mapa)"
+#, fuzzy
+msgid "North coordinate (point of interest, default: map center)"
+msgstr "coordenada norte (ponto de interesse, padrão: centro do mapa)"
+msgid "Zero is a real elevation"
+msgstr "Zero é uma elevação real"
+#, fuzzy
+msgid "Band to select"
+msgstr "Nenhum monitor selecionado"
+#, fuzzy
+msgid "It was impossible to create <Auxiliar_outlier_table>."
+msgstr "Impossível criar <Tabela_auxiliar_dos_desvios>"
+#, fuzzy
+msgid "M.Q. solution"
+msgstr "Resolução"
+msgid "3-d data in dxf file. Polyline_flag: %d"
+msgstr "Dados 3D no arquivo dxf. Polyline_flag: %d"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+msgstr "Não consegui abrir o arquivo de células para [%s]"
+msgid "Signed data (high bit means negative value)"
+msgstr "Dado 'signed' (bit alto significa valor negativo)"
+msgid "Number of bytes per cell (1, 2, 4)"
+msgstr "Número de bytes por célula (1, 2, 4)"
+#, fuzzy
+msgid "You have to provide all limits of geographic region (n,s,e,w)"
+msgstr "Limite Sul da região geográfica (limite externo)"
+#, fuzzy
+msgid "Illegal number of rows <%s>"
+msgstr "ATENÇÃO: nome de subgrupo ilegal <%s>."
+#, fuzzy
+msgid "Illegal number of columns <%s>"
+msgstr "Número máximo de iterações: %d\n"
+#, fuzzy
+msgid "Using rows=%d cols=%d\n"
+msgstr "%d raster%s, %d vetor%s\n"
+#, fuzzy
+msgid "Conversion failed at row %d"
+msgstr "conversão"
+#, fuzzy
+msgid "Can't read row in input elevation map"
+msgstr "não consigo ler linha no mapa de elevação"
+#, fuzzy
+msgid "Exporting raster as double values (bytes=%d)"
+msgstr "Coluna %d definida como inteiro só possui valores double"
+msgid "Reading map"
+msgstr "Lendo mapa"
+#, fuzzy
+msgid "<Auxiliar_edge_table> created in database."
+msgstr "Tabela <%s> não existe no banco de dados <%s>"
+#, fuzzy
+msgid "Creating auxiliar table for archiving overlapping zones"
+msgstr "Criando tabela auxiliar para arquivar zonas adjacentes"
+#, fuzzy
+msgid "Unable to open table <%s_edge_Interpolation>"
+msgstr "Não consegui abrir arquivo de saída."
+msgid "Cross Validation was success!"
+msgstr "Validação cruzada obteve sucesso!"
+msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
+msgstr "Interpolação: A resolução da região é demasiado elevada: %d células. Considere alterá-la."
+#, fuzzy
+msgid "Name of output vector area map"
+msgstr "Nome do mapa vetorial (2d) de entrada"
+#, fuzzy
+msgid "Cannot open vector map <%s>"
+msgstr "Nome do mapa de pontos de saída"
+msgid "Could not open <%s>"
+msgstr "Não consegui abrir <%s>"
+#, fuzzy
+msgid "vector, projection"
+msgstr "Fonte"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
+msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+msgid "Duplicate area centroids"
+msgstr "Não consegui calcular área do centróide."
+msgid "Number of column used as x coordinate (first column is 1) for points mode"
+msgstr "Número da coluna usada como coordenada x (primeira coluna é 1) para o modo de pontos"
+#, fuzzy
+msgid "It was impossible to open table"
+msgstr "não consegui criar %s"
+#, fuzzy
+msgid "Spline type of interpolation"
+msgstr "Saída é o erro de interpolação"
+#, fuzzy
+msgid "Selects data from table."
+msgstr "Selecionar dados do banco"
+msgid "Output drain raster map"
+msgstr "Gera mapa raster de drenagem"
+#, fuzzy
+msgid "Source map is: Integer cell type"
+msgstr "Fonte mapear é Inteiro célula"
+#, fuzzy
+msgid "Source map is: Floating point (float) cell type"
+msgstr "Fonte mapear é Flutuante célula"
+#, fuzzy
+msgid "Source map is: Floating point (double) cell type"
+#, fuzzy
+msgid "Reading %s"
+msgstr "\rLendo arquivo [%s] ..."
+#, fuzzy
+msgid "Error getting input null cells"
+msgstr "Erro"
+#, fuzzy
+msgid "Can't find %d,%d:%f"
+msgstr "Não encontrei %s"
+#, fuzzy
+msgid "Unable to open MASK"
+msgstr "Não consegui ler MASK"
+#, fuzzy
+msgid "unable to open MASK"
+#, fuzzy
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, comprimento do dia) são guardados num arquivo texto. Alternativamente, um horário local pode ser especificado para calcular ângulo de incidência e/ou mapas de irradiância. O efeito de sombreamento da topografia também pode ser opcionalmente incorporado."
+#, fuzzy
+msgid "incidout requres time parameter to be set"
+msgstr "parâmetro para"
+#, fuzzy
+msgid "Mode 2: integrated daily irradiation"
+msgstr "Modo dia de ano"
+msgid "Output more comments (default=quiet)"
+msgstr "Retorna mais comentários (padrão = quieto)"
+msgid "Cannot open database %s by driver %s"
+msgstr "Não conseguir abrir banco de dados %s com driver %s"
+#, fuzzy
+msgid "Cannot select attributes: %s"
+msgstr "Não consegui selecionar atributo."
+msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr "Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou \"none\""
+#, fuzzy
+msgid "Output inverse raster map after IFFT"
+msgstr "Título do raster de saída após ifft"
+msgid "Power 2 values : [%d] rows [%d] columns."
+msgstr "Valores ao quadrado : [%d} linhas [%d] colunas."
+msgid "Reading the raster maps..."
+msgstr "Lendo mapas raster..."
+msgid "Rotating data arrays..."
+msgstr "Rotacionando arranjos de dados ... "
+msgid "Inverse FFT completed..."
+msgstr "FFT inversa concluída..."
+msgid "Unable to open output file."
+msgid "Transform successful."
+msgstr "Transformada bem sucedida"
+msgid "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color transformation function."
+msgstr "Função de transformação de cor de um mapa raster: matiz - intensidade-saturação (his) para vermelho-verde-azul (rgb)."
+#, fuzzy
+msgid "Intensity map name"
+msgstr "Nome do mapa raster"
+#, fuzzy
+msgid "Saturation map name"
+#, fuzzy
+msgid "Output map representing the red"
+msgstr "Mapa de saída no qual os pontos serão gravados"
+#, fuzzy
+msgid "Output map representing the green"
+#, fuzzy
+msgid "Output map representing the blue"
+msgstr "Formato para relatar a declividade"
+#, fuzzy
+msgid "Cannot read row from raster map"
+msgstr "Criando %i mapas raster\n"
+#, fuzzy
+msgid "Cannot write row to raster map"
+msgstr "Não consegui criar arquivo raster [%s]."
+msgid "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color transformation function"
+msgstr "Função de transformação de cor de um mapa raster: vermelho-verde-azul (rgb) para matiz-intensidade-saturação (his)"
+#, fuzzy
+msgid "Green input raster map"
+#, fuzzy
+msgid "Blue input raster map"
+#, fuzzy
+msgid "Output intensity raster map"
+msgstr "Gera arquivo com a declividade"
+#, fuzzy
+msgid "Output saturation raster map"
+msgid "Class transition statistics."
+msgstr "Estatísticas de transição de classe."
+msgid "Transition probabilities: %f %f %f; %f"
+msgstr "Probabilidades de transição: %f %f %f; %f"
+msgid "get_img: out of memory."
+msgstr "get_img: Memória Esgotada! (Out of Memory)"
+#, fuzzy
+msgid "Subgroup [%s] in group [%s] contains no files."
+msgstr "Subgrupo [%s] no grupo [%s] não contém arquivos."
+msgid "Writing [%s] ..."
+msgstr "Escrevendo [%s]..."
+#, fuzzy
+msgid "Name of imagery signaturefile"
+msgstr "arquivo de assinatura"
+msgid "Subgroup [%s] not found."
+msgstr "Subrupo <%s> não encontrado."
+msgid "Signature file [%s] is missing or not readable."
+msgstr "Arquivo de assinatura [%s] faltando ou é ilegível."
+#, fuzzy
+msgid "Calculating eigenvalues and eigenvectors..."
+msgstr "Calculando média das classes ..."
+msgid "Ordering eigenvalues in descending order..."
+msgstr "Ordenando os valores próprios por ordem decrescente..."
+msgid "Transposing eigen matrix..."
+msgstr "Transportando a matriz dos valores próprios e vectores próprios..."
+#, fuzzy
+msgid "Cannot write color table of raster map <%s>"
+msgstr "Não consegui escrever em <%s>"
+msgid "Calculating class mean ..."
+msgid "Calculating class covariance matrix..."
+msgstr "Calculando matriz de covariância de classes..."
+#, fuzzy
+msgid "Imagery group"
+msgstr "Nome do grupo de imagens"
+#, fuzzy
+msgid "Subgroup containing image files"
+msgstr "subgrupo contendo arquivos de imagem"
+#, fuzzy
+msgid "Resultant signature file"
+msgstr "arquivo de assinatura resultante"
+msgid "%d classes."
+msgstr "%d classes."
+msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
+msgstr "Não consegui escrever arquivo de assinatura [%s] para o subgrupo [%s], no grupo [%s]."
+msgid "Initializing data...\n"
+msgstr "Inicializando dados ...\n"
+msgid "Reading the raster map..."
+msgstr "Lendo mapa raster..."
+msgid "FFT completed..."
+msgstr "FFT concluída..."
+#, fuzzy
+msgid ""
+"\n"
+" group <%s> not found"
+msgstr ""
+"\n"
+"grupo <%s> não encontrado"
+msgid "subgroup <%s> not found"
+msgstr "subrupo <%s> não encontrado"
+#, fuzzy
+msgid "Subgroup [%s] doesn't have any files"
+msgstr "Subgrupo [%s] não possui nenhum arquivo"
+#, fuzzy
+msgid "The subgroup must have at least 2 files to run %s"
+msgstr "O subgrupo deve possuir pelo menos 2 arquivos para executar %s."
+msgid "Unable to proceed"
+msgstr "Impossível prosseguir"
+msgid "Group of imagery files to be clustered"
+msgstr "Grupo de arquivos de imagens a ser agrupados"
+msgid "Subgroup name in the above group"
+msgstr "Nome do subgrupo do grupo acima"
+#, fuzzy
+msgid "Output file to contain final report"
+msgstr "Nome de arquivo de saída para conter relatório"
+#, fuzzy
+msgid ""
+"\n"
+"<%s> -- illegal value of min_size"
+msgstr ""
+"\n"
+"<%s> -- valor ilegal de min_size"
+msgid "Can't creat reportfile: "
+msgstr "Não consegui criar relatório: "
+msgid "Reading image ... "
+msgstr "Lendo imagem ... "
+#, fuzzy
+msgid "Unable to read head of %s"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+msgid "Unable to write temp file: %s"
+msgstr "Não consegui escrever o arquivo temporário."
+#, fuzzy
+msgid "Unable to open map %s"
+msgstr "não consegui abrir [%s]"
+#, fuzzy
+msgid "Unable to write row %d"
+msgid "group=[%s] - not found."
+msgstr "Grupo=[%s] - não encontrado."
+msgid "subgroup=[%s] (of group [%s]) - not found."
+msgstr "Subrupo=[%s] (do grupo [%s]) - não encontrado."
+msgid "Can't read signature file [%s]."
+msgstr "Não consegui ler o arquivo de assinatura [%s]."
+msgid "[%s] has more than 255 signatures."
+msgstr "%s tem mais de 255 assinaturas."
+#, fuzzy
+msgid "Unable to create reject layer [%s]."
+msgstr "Não consegui criar camada de rejeição [%s]."
+msgid "Imagery group to be classified"
+msgstr "Grupo de imagens a ser classificado"
+msgid "Subgroup containing image files to be classified"
+msgstr "subgrupo contendo arquivos de imagem a classificar"
+msgid "Signatures to use for classification"
+msgstr "Assinaturas para usar na classificação"
+msgid "Raster map to hold classification results"
+msgstr "Mapa raster para o resultado da classificação"
+#, fuzzy
+msgid "raster, imagery, fusion"
+msgstr "Inportação de vetor incompleta"
+#, fuzzy
+msgid "ERROR: Problem opening output file."
+msgstr "Não consegui abrir arquivo de saída <%s>."
+msgid "Name of fractal surface raster layer"
+msgstr "Nome da camada raster da superfície fractal"
+#, fuzzy
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr "Explicitamente cria o arquivo bitmap 3D com valores NULL"
+#, fuzzy
+msgid "Creation option to the output format driver. Multiple options may be listed."
+msgstr "para Múltipla"
+#, fuzzy
+msgid "Density of output walkers"
+msgstr "Nome do arquivo de saída"
+#, fuzzy
+msgid "File [%s] not found"
+msgstr "raster <%s> não encontrado"
+#, fuzzy
+msgid "Unable to open file [%s]"
+msgstr "Não consegui abrir o arquivo de células [%s]"
+#, fuzzy
+msgid "Failed to guess file format"
+msgstr "para site"
+#, fuzzy
+msgid "Reading sites map (%s) ..."
+msgstr "Lendo arquivo dig_att...\n"
+#, fuzzy
+msgid "You are not outputting any raster or vector points maps"
+msgstr "Você não está gerando nenhum arquivo raster ou vetorial"
+#, fuzzy
+msgid "%s=%s - illegal value"
+msgstr "%s=%s - nome ilegal"
+#, fuzzy
+msgid "Unable to read current region parameters"
+msgstr "Mostra os parâmetros de conexão atuais e finaliza"
+#, fuzzy
+msgid "Cannot open cover raster map <%s>"
+msgstr "Não consegui abrir arquivo de células [%s]"
+msgid "Cannot open database <%s> by driver <%s>"
+#, fuzzy
+msgid "No map specified"
+msgstr "Mapa(s) de entrada não especificado(s)."
+#, fuzzy
+msgid "%s - unable to remove color table"
+#, fuzzy
+msgid "%s - color table not found"
+msgstr "%s: %s - mapa raster não encontrado"
+#, fuzzy
+msgid "Can't make random color table for floating point map"
+msgstr "argumento val é necessário para mapas de ponto flutuante!"
+#, fuzzy
+msgid "Can't make grey.eq color table for floating point map"
+#, fuzzy
+msgid "Can't make logarithmic color table for floating point map"
+#, fuzzy
+msgid "%s - unknown color request"
+msgstr "%s - cor desconhecida\n"
+#, fuzzy
+msgid "Starting map [%s]"
+#, fuzzy
+msgid "Percent done:"
+msgstr "Porcentagem completada: "
+#, fuzzy
+msgid "Unable to properly read input raster map"
+msgstr "Não consegui abrir os arquivos das bandas."
+#, fuzzy
+msgid "Unable to properly write output raster map"
+msgstr "Não consegui abrir o arquivo de assinatura de saída."
+#, fuzzy
+msgid "SECTION %d beginning: Closing Maps."
+msgstr "Fechando Mapas."
+#, fuzzy
+msgid "SECTION %d beginning: Watershed determination."
+msgstr ""
+"\n"
+"SEÇÃO %d iniciando: Determinação de divisores."
+#, fuzzy
+msgid "problem w/ astar algorithm"
+msgstr "algoritmo"
+#, fuzzy
+msgid "Could not read range file"
+msgstr "Não consegui ler arquivo de limite"
+#, fuzzy
+msgid "Reading data: "
+msgstr "Rotacionando dados ... "
+msgid "Name of raster map layer to be used for <%s>"
+msgstr "Nome do mapa raster a ser usado para <%s>"
+#, fuzzy
+msgid "%d points converted to centroids"
+msgstr "%-5d pontos lidos para a memória\n"
+#, fuzzy
+msgid "%d centroids converted to points"
+msgstr "%-5d centroides escritos en el archivo de salida.\n"
+#, fuzzy
+msgid "%d lines converted to boundaries"
+msgstr "Arquivo raster para importar"
+#, fuzzy
+msgid "%d boundaries converted to lines"
+#, fuzzy
+msgid "CrossCorrelation: %d points read in region.\n"
+msgstr "%d pontos fora da região atual."
+#, fuzzy
+msgid "CrossCorrelation: Cannot read field info"
+msgstr "Não consegui ler campo info"
+#, fuzzy
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
+#, fuzzy
+msgid "CrossCorrelation: Column type not supported"
+msgstr "Tipo de coluna não suportado"
+#, fuzzy
+msgid "CrossCorrelation: Cannot select data from table"
+msgstr "Não consegui selecionar dados da tabela"
+#, fuzzy
+msgid "CrossCorrelation: %d records selected from table"
+msgstr "%d registros selecionados da tabela"
+#, fuzzy
+msgid "CrossCorrelation: No record for point (cat = %d)"
+msgstr "Sem registros para a linha (cat = %d)"
+msgid "CrossCorrelation: Mean = %.5lf\n"
+msgstr "Correlação cruzada: Média = %.5lf\n"
+#, fuzzy
+msgid "CrossCorrelation: lambda_i = %.3f\n"
+#, fuzzy
+msgid ""
+"\n"
+"Results are over.\n"
+msgstr ""
+"\n"
+"Resultados finais.\n"
+#, fuzzy
+msgid "From type"
+msgstr "Tipo desconhecido"
+#, fuzzy
+msgid "From layer"
+msgstr "Consultar"
+#, fuzzy
+msgid "The column must be type integer or string"
+msgstr "Nome da coluna (tipo deve ser numérico)"
+#, fuzzy
+msgid "Select type"
+msgstr "Tipo de feição"
+#, fuzzy
+msgid "Cannot select records from database"
+msgid "Cannot fetch data"
+msgstr "Não consegui obter os dados"
+#, fuzzy
+msgid "Calculating costs from centres..."
+msgstr "Calculando médias das classes ..."
+#, fuzzy
+msgid "Feature id(s)"
+msgid "Input vector was not found."
+msgstr "Vetor de entrada não foi encontrado."
+msgid "Cannot open dig_cats file."
+msgstr "Não consegui abrir arquivo dig_cats."
+msgid "Cannot open database %s"
+msgstr "Não consegui abrir o banco de dados %s"
+msgid "Cannot insert into table: %s"
+msgstr "Não consigo inserir na tabela: %s"
+#, fuzzy
+msgid "Removed vertices: %5d"
+msgstr "Removendo centróides duplicados ..."
+#, fuzzy
+msgid "Removed vertices"
+#, fuzzy
+msgid "Arc layer (network)"
+msgstr "Consultar"
+#, fuzzy
+msgid "Node layer (points)"
+msgstr "Nome da camada a usar para MATIZ (HUE)"
+#, fuzzy
+msgid "Reading data from the map..."
+#, fuzzy
+msgid "Query layer (used by 'query' option)"
+msgstr "Camada de pesquisa. Usada pela opção 'query'."
+#, fuzzy
+msgid "%d categories read from map"
+msgstr "%d distâncias lidas do mapa."
+#, fuzzy
+msgid "%d update/insert errors"
+msgstr "%d atualizar erros"
+msgid ""
+"Operator defines required relation between features. A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.\n"
+"\t overlap: features partially or completely overlap"
+msgstr ""
+"O operador define relações requeridas entre feições. Uma feição é escrita para a saída se o resultaddo da operação 'entradaA operador entradaB' for verdadeiro. Uma feição de entrada pode ser considerada verdadeira se a categoria da camada estiver definida.\n"
+"\tsopreposição: feições parcial ou completamente sobrepostas"
+msgid "Processing ainput lines ..."
+msgstr "Processando linhas de entradaA ..."
+#, fuzzy
+msgid "Processing ainput areas ..."
+msgid "Writing attributes ..."
+msgstr "Escrevendo atributos ..."
+#, fuzzy
+msgid "Current region does not include the entire input vector map <%s>"
+msgstr "Não consegui encontrar o mapa vetorial de entrada <%s>"
+#, fuzzy
+msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condição 'where' opcional (sem a cláusula 'WHERE'), p.ex.:\n"
+#, fuzzy
+msgid "Vector map to display thematically"
+msgstr "Vetor mapear para exibir"
+#, fuzzy
+msgid "Vector map type"
+#, fuzzy
+msgid "Layer to use for thematic display"
+msgstr "Camada para exibir"
+#, fuzzy
+msgid "Icon size for point data (minimum icon size/line width for graduated points/lines)"
+msgstr "Ícone ícone largura pontos"
+#, fuzzy
+msgid "Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color."
+msgstr "Cor área G Definir para."
+#, fuzzy
+msgid "Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color."
+#, fuzzy
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr "para"
+#, fuzzy
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "para padrão atual Pesquisa"
+#, fuzzy
+msgid "Output separator (default: newline)"
+msgstr "Caractere separador (padrão: tab)"
+#, fuzzy
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr "para remover"
+#, fuzzy
+msgid "3d raster to remove"
+msgstr "Arquivo raster binário a importar"
+#, fuzzy
+msgid "Vector to remove"
+msgstr "ícone para remover"
+#, fuzzy
+msgid "Region to remove"
+#, fuzzy
+msgid "Label to remove"
+#, fuzzy
+msgid "3dview to remove"
+#, fuzzy
+msgid "Group to remove"
+#, fuzzy
+msgid "raster input maps"
+#, fuzzy
+msgid "Keep band numbers instead of using band color names."
+msgstr "Manter os números das bandas em vez de usar os nomes das cores"
+#, fuzzy
+msgid "Output field seperator"
+msgstr "Separador de campo"
+#, fuzzy
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE and DATE)"
+msgstr "Nome de tipos ativo banco de dados todos Suporte NÚM.INT"
+#, fuzzy
+msgid "Memory allocation error"
+msgstr "Memória"
+#, fuzzy
+msgid "Saving new map"
+#, fuzzy
+msgid "Output raster map with lake"
+msgstr "Mapa raster de saída"
+#, fuzzy
+msgid "Cannot write lake raster map <%s>!"
+#, fuzzy
+msgid "Terrain raster map <%s> not found!"
+msgstr "mapa raster <%s> não encontrado"
+#, fuzzy
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "Não consegui abrir arquivo raster [%s]!"
+#, fuzzy
+msgid "Seed map <%s> not found!"
+#, fuzzy
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "Não consegui abrir o arquivo %s"
+#, fuzzy
+msgid "Failure to allocate memory for row pointers"
+msgstr "Não consegui alocar memória para 'string'"
+#, fuzzy
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "Erro na leitura do mapa raster de entrada."
+#, fuzzy
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "Erro lendo arquivo raster [%s]."
+#, fuzzy
+msgid "Cannot write lake raster map <%s@%s>!"
+#, fuzzy
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr "nível de em:"
+#, fuzzy
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Erro na escrita do arquivo 'colr' para <%s>."
+#, fuzzy
+msgid "All done."
+msgstr "Todos."
+#, fuzzy
+msgid "Name of the vector points map with x,y locations"
+msgstr "Nome do arquivo vetor com dados de entrada"
+#, fuzzy
+msgid "Number of time iterations (sec.)"
+msgstr "Número de pontos de interpolação"
+#, fuzzy
+msgid "Multiscale simulation"
+msgstr "local do banco de dados"
+#, fuzzy
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "Nome do arquivo raster de elevação para entrada (metros)"
+#, fuzzy
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "Nome do raster de entrada"
+msgid "Raster input maps(s)"
+msgstr "Mapas raster de entrada"
+msgid "Output file name"
+#, fuzzy
+msgid "%s: can't read fp range for [%s]"
+msgstr "%s: não consegui criar %s"
+#, fuzzy
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "Mapa raster [%s] existe no grupo."
+#, fuzzy
+msgid "Error reading '%s' map"
+msgstr "Erro lendo coringa."
+#, fuzzy
+msgid "G_put_raster_row failed (file system full?)"
+msgstr "G"
+msgid "Run verbosly"
+msgstr "Executar verbosamente"
+#, fuzzy
+msgid "Threshold distance"
+msgstr "Unidade de distância"
+msgid "Cannot execute: %s"
+msgstr "Não consegui executar: %s"
+#, fuzzy
+msgid "Cannot link table: %s"
+msgstr "Não consegui abrir tabela %s"
+msgid "DXF input file"
+msgstr "Arquivo de entrada DXF"
+#, fuzzy
+msgid "Cannot open dxf file <%s>"
+msgstr "Não consegui abrir o arquivo [%s]"
+#, fuzzy
+msgid "Cannot open new vector map <%s>"
+msgstr "%s: Novo arquivo vetorial não pode ser aberto"
+#, fuzzy
+msgid "Conversion of <%s> to vector map:"
+msgstr ""
+"\n"
+" Conversão de %s para mapa vetorial:  "
+msgid "Create 3D file"
+msgstr "Criar arquivo 3D"
+#, fuzzy
+msgid "Do not print polyline info"
+msgstr "Não criar topologia (topology) no modo de pontos"
+#, fuzzy
+msgid "Hilight color for text"
+msgstr "Cor de realce para texto"
+#, fuzzy
+msgid "Line: %d\n"
+msgstr "Altura da linha: %f\n"
+#, fuzzy
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Memória insuficiente para alocação da estrutura de dados"
+#, fuzzy
+msgid "imagery group"
+msgid "imagery subgroup"
+msgstr "Subgrupo de imagens"
+msgid "output raster map"
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr "Extensão do arquivo de saída (arquivo(s) + extensão)"
+#, fuzzy
+msgid "Illegal file name for real part: %s"
+msgstr "%s: %s - nome ilegal para parte real\n"
+#, fuzzy
+msgid "Illegal file name for imaginary part: %s"
+msgstr "%s: %s - nome ilegal para parte imaginária\n"
+msgid "** Can't read signature file <%s> **"
+msgstr "** Não consigo ler arquivo de assinatura <%s> **"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr ""
+"\n"
+"<%s> -- nome ilegal de arquivo com assinatura resultante"
+msgid "Raster file(s) for Elevation"
+msgstr "Arquivos raster para elevação"
+msgid "Raster file(s) for Color"
+msgstr "Arquivos raster para cor"
+msgid "Raster map to zoom into"
+msgstr "Mapa raster para aproximar"
+msgid "Save the current region to region definition file"
+msgstr "Guarda a região atual no arquivo de definições de região"
+#, fuzzy
+msgid "No LatLong information for XY-Projection"
+msgstr "Opção Geo-Grid não disponível para projeção XY"
+#, fuzzy
+msgid "Could not open input file <%s>."
+msgstr "Não consegui abrir arquivo vetorial <%s>"
+#, fuzzy
+msgid "No such monitor as '%s'"
+msgstr "[%s]: cor não existe"
+#, fuzzy
+msgid "Error - No such monitor as '%s'"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+"\a\n"
+"** Os seguintes arquivos raster no subgrupo [%s] não existem:"
+msgid "       %s"
+msgstr "       %s"
+msgid "Removing files from group"
+msgstr "Removendo arquivos do grupo"
+#, fuzzy
+msgid "Adding files to group [%s]"
+msgstr "Adicionando arquivos ao subgrupo [%s]"
+msgid "Adding files to subgroup [%s]"
+msgid "Writing group REF"
+msgstr "Escrevendo grupo REF"
+msgid "Writing subgroup REF"
+msgstr "Escrevendo subgrupo REF"
+msgid "Found file <%s@%s> in group."
+msgstr "Arquivo %s@%s encontrado no grupo."
+#, fuzzy
+msgid "Found file <%s@%s> in subgroup."
+msgid ""
+"Projection of input dataset and current location appear to match.\n"
+"Proceeding with import...\n"
+msgstr ""
+"Projeção dos dados de entrada e locação atual parecem combinar.\n"
+"Continuando com a importação...\n"
+#, fuzzy
+msgid "%s: percent complete: "
+#, fuzzy
+msgid "Raster map not found."
+msgstr "Mapa raster [%s] não encontrado"
+#, fuzzy
+msgid "%s: can't read range for [%s]"
+#, fuzzy
+msgid "Raster file [%s] not found"
+#, fuzzy
+msgid "It was not possible writing in <%s>."
+msgstr "Não foi possível escrever na <%s>.."
+#, fuzzy
+msgid "\rDuplicate area centroids: %5d"
+#, fuzzy
+msgid "Cannot create table: '%s'"
+msgstr "Não consegui criar a tabela %s"
+#, fuzzy
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Não consegui ler de <%s>"
+#, fuzzy
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "Não consegui abrir arquivo ASCII [%s]"
+#, fuzzy
+msgid "Unable to write line %d"
+#, fuzzy
+msgid "Unknown query tool '%s'"
+#, fuzzy
+msgid "If 'list', 'file' and 'where' options are not specified, all features of given type and layer are extracted. Categories are not changed in that case."
+msgstr "Seleciona objetos vetoriais a partir de um mapa vetorial existente e cria um novo mapa contendo apenas os objetos selecionados. Se as opções 'list', 'file' e 'where' não forem especificadas, todas as feições de uma camada e tipo fornecidos serão extraídos, neste caso as categorias não são alteradas."
+#, fuzzy
+msgid "No layer database connection"
+msgstr "Sem conexão ao banco de dados."
+#, fuzzy
+msgid "Load categories from the database (table = %s, db = %s)."
+msgstr "Carregas cats do banco de dados (tabela=%s, bd=%s).\n"
+#, fuzzy
+msgid "%d categories loaded from the database"
+msgstr "%d categorias carregadas da tabela\n"
+msgid "Cannot create layer"
+msgstr "Não consegui criar camada"
+#, fuzzy
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Arquivo de vetores [%s] não está disponível"
+#, fuzzy
+msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
+msgstr "Carregar valores do vetor para o banco de dados. Nos valores de categoria carregados/impressos, '-1' é usado para 'sem categoria' e 'null'/'-' se a categoria não for encontrada ou múltiplas categorias forem encontradas"
+#, fuzzy
+msgid "Column type [%d] not supported"
+#, fuzzy
+msgid "Cannot read map header for <%s>"
+#, fuzzy
+msgid "Cannot read category file for <%s>"
+msgstr "Editar arquivo de categorias para [%s]?"
+#, fuzzy
+msgid "Print;Shell Script"
+msgstr "Mostra contagem de células"
+msgid "Creating support files for [%s]."
+msgstr "Criando arquivos de suporte para [%s]."
+msgid "%s: <%s> raster map not found"
+msgstr "%s: <%s> mapa raster não encontrado"
+msgid "%s: <%s> raster map exists already"
+msgstr "%s: <%s> mapa raster já existe"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s>"
+#, fuzzy
+msgid "%s - map not found"
+#, fuzzy
+msgid "%s not found"
+msgstr "[%s] não encontrado."
+#, fuzzy
+msgid "Could not access %s layer"
+#, fuzzy
+msgid "Vector map %s - not found"
+msgstr "mapa vetorial <%s> não encontrado"
+msgid "Raster map containing elevation data"
+msgstr "Mapa raster contendo dados de elevação"
+msgid "Raster map name for storing results"
+msgstr "Nome do mapa raster para guardar os resultados"
+msgid "Height of the viewing location"
+msgstr "Altura do local de visada"
+#, fuzzy
+msgid "%s: <%s> cellfile not found"
+msgid "Cell file [%s] not found\n"
+msgstr "Arquivo de células [%s] não encontrado\n"
+#, fuzzy
+msgid "rgb cell map [%s] not found\n"
+msgstr "Arquivo de células [%s] não encontrado"
+#, fuzzy
+msgid "vector cell map [%s] not found\n"
+#, fuzzy
+msgid "%s - %s not found"
+msgid "raster map <%s> not found"
+msgid "can't read header for <%s> in <%s>"
+msgstr "não consegui ler cabeçalho para <%s> em <%s>"
+#, fuzzy
+msgid "region <%s> not found"
+msgstr "região <%s> não encontrada"
+msgid "can't read region <%s> in <%s>"
+msgstr "Não consegui ler região <%s> em <%s>"
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "Não consegui abrir arquivo 3dview  <%s> em <%s>"
+msgid "can't read 3dview file <%s> in <%s>"
+msgstr "Não consegui ler arquivo 3dview <%s> em <%s>"
+#, fuzzy
+msgid "can't open vector map <%s> in <%s>"
+msgstr "Não consegui abrir mapa raster [%s]."
+msgid "invalid region: %s"
+msgstr "região inválida: %s"
+#, fuzzy
+msgid "Creating support files"
+msgid "can't open %s"
+msgstr "não consegui abrir %s"
+msgid "%s file [%s] not found!"
+msgstr "%s arquivo [%s] não encontrado!"
+#, fuzzy
+msgid "%s: %s - map not found"
+#, fuzzy
+msgid "%s: unable to open %s"
+msgstr "não consegui abrir <%s>"
+#, fuzzy
+msgid "%s - not found"
+#, fuzzy
+msgid "Cannot read %s"
+#, fuzzy
+msgid "map layer [%s] not legal for GRASS"
+msgstr "mapear não"
+#, fuzzy
+msgid "[%s] map not found."
+#, fuzzy
+msgid "[%s] map not found"
+#, fuzzy
+msgid "elevation file [%s] not found"
+msgid "min computed aspect %.4f  max computed aspect %.4f"
+msgstr "mín. orientação calculada %.4f  máx. orientação calculada %.4f"
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "mín. declividade calculada %.4f  máx. declividade calculada %.4f"
+#, fuzzy
+msgid "Cannot describe table <%s>"
+msgstr "Não consegui descrever a tabela %s"
+#, fuzzy
+msgid "Cannot insert values: %s"
+#, fuzzy
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s foi fornecido um número ilegal de pontos [%d]"
+#, fuzzy
+msgid "Unable to open database %s by driver %s"
+#, fuzzy
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Nenhuma conexão a banco de dados foi definida. Execute db.connect"
+msgid "Could not find input %s"
+msgstr "Não consegui encontrar entrada %s"
+msgid "Could not open input"
+msgstr "Não consegui abrir entrada"
+msgid "Could not open output"
+msgstr "Não consegui abrir saída"
+msgid "Could not find input map <%s>"
+msgstr "Não consegui encontrar o mapa de entrada <%s>"
+msgid "Unkown item type in pad: %s"
+msgstr "Tipo desconhecido no bloco: %s"
+msgid "Database connection not defined\n"
+msgstr "Conexão com banco de dados não definida\n"
+#, fuzzy
+msgid "Can't read header for <%s> in <%s>"
+#, fuzzy
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "Não consegui ler cabeçalho para raster 3D <%s> em <%s>"
+#, fuzzy
+msgid "Can't write region <%s>"
+msgstr "não consegui escrever região <%s>"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** entrada inválida **"
+msgid "No graphics device selected."
+msgstr "Nenhum dispositivo gráfico selecionado."
+msgid "Unable to read raster row."
+msgstr "Não consegui ler arquivo raster agora."
+msgid "Training map [%s] not found."
+msgstr "Mapa de treinamento <%s> não encontrado"
+#, fuzzy
+msgid "%s map not found"
+#, fuzzy
+msgid "input raster map"
+#, fuzzy
+msgid "Illegal file name: %s"
+msgstr "nome de arquivo ilegal [%s]."
+#, fuzzy
+msgid "Condition for update (everything after the 'where' sql statement; ex: cat=1 or col1/col2>1)"
+msgstr "após instrução"
+msgid "Cannot get layer info for vector map"
+msgstr "Não consegui obter informações de camada para o mapa vetorial"
+#, fuzzy
+msgid "Cannot open raster map <%s> in <%s>"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
+msgid "%s: %s - raster map not found"
+msgid "%s: %s - illegal name"
+msgstr "%s: %s - nome ilegal"
+msgid "%s: ERROR reading category file for %s"
+msgstr "%s: ERRO lendo arquivo de categorias para %s"
+#, fuzzy
+msgid "%s: %s - not found"
+#, fuzzy
+msgid "%s: %s - illegal units"
+#, fuzzy
+msgid "%s: %s - can't open"
+#, fuzzy
+msgid "Reading input map (%s)    ... "
+#, fuzzy
+msgid "%s - ERROR reading %s"
+msgstr "%s: ERRO executando comando %s"
+#, fuzzy
+msgid "%s: %s - can't create raster map"
+msgstr "%s: %s em %s - não consegui ler arquivo de categoria"
+#, fuzzy
+msgid "Writing output map (%s)   ... "
+msgstr "Escrevendo arquivo raster %i\n"
+#, fuzzy
+msgid "%s - ERROR re-reading %s"
+#, fuzzy
+msgid "%s - ERROR writing %s"
+#, fuzzy
+msgid "Reading raster map... "
+#, fuzzy
+msgid "Writing raster map... "
+msgstr "Escrevendo novo arquivo...\n"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Lista de categorias: p.ex.: 1,3-8,13"
+msgid "Output separator character (default: tab)"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s> in <%s>"
+#, fuzzy
+msgid "Cannot find file %s"
+#, fuzzy
+msgid "Cannot get header for %s"
+#, fuzzy
+msgid "Cannot create raster map %s"
+#, fuzzy
+msgid "Cannot create vector map %s"
+#, fuzzy
+msgid "Cannot create raster map '%s'"
+#, fuzzy
+msgid "Number of raster rows to hold in memory"
+msgstr "Número de linhas para manter na memória"
+#, fuzzy
+msgid "Print raster map title only"
+msgstr "Imprime apenas o tipo do mapa raster"
+#, fuzzy
+msgid "unknown type: %d"
+msgstr "Tipo desconhecido: %c"
+msgid "Cannot open raster map [%s]"
+#, fuzzy
+msgid "Cannot get raster band."
+msgstr "Não consegui abrir mapa raster"
+#, fuzzy
+msgid "Cannot allocate buffer for reading null values."
+#, fuzzy
+msgid "Cannot read GRASS raster."
+msgstr "Não consegui ler raster"
+#, fuzzy
+msgid "Cannot get [%s] driver"
+msgstr "Não consegui criar árvore"
+#, fuzzy
+msgid "Couldn't set geo transform."
+msgstr "Não consegui ler linha do arquivo raster \n"
+#, fuzzy
+msgid "Couldn't set projection."
+msgstr "Fonte"
+#, fuzzy
+msgid "Cannot export [%s] raster map."
+#, fuzzy
+msgid "Cannot create [%s] raster map using [%s] driver."
+#, fuzzy
+msgid "Cannot read header of raster map <%s>"
+#, fuzzy
+msgid "Cannot open TIFF file <%s>"
+#, fuzzy
+msgid "Reading raster map"
+#, fuzzy
+msgid "Cannot open output map."
+#, fuzzy
+msgid "Illegal file name. Please try another."
+msgstr "Nome ilegal do arquivo de saída"
+#, fuzzy
+msgid "%s: can't open %s"
+#, fuzzy
+msgid "memory allocation failure"
+msgstr "Memória"
+#, fuzzy
+msgid "Can't find data map."
+msgstr "Não consegui listar os bancos de dados."
+#, fuzzy
+msgid "Can't find clump map."
+msgstr "Não encontrei mapa de células de entrada."
+#, fuzzy
+msgid "Output terrain only vector map name"
+#, fuzzy
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
+#, fuzzy
+msgid "Rebuilding topology ..."
+#, fuzzy
+msgid "Removing duplicates ..."
+#, fuzzy
+msgid "Attaching islands ..."
+msgstr "Anexando categorias...\n"
+#, fuzzy
+msgid "Attaching centroids ..."
+#, fuzzy
+msgid "Error allocating memory for `lines_visited'"
+#, fuzzy
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Número mínimo de pixels numa classe"
+msgid "Cannot open select cursor"
+msgstr "Não consegui abrir cursor de seleção"
+#, fuzzy
+msgid "Cannot get layer info"
+msgstr "Não consegui obter informações sobre a ligação ao BD"
+msgid "cell file [%s] not found"
+msgid "can't open raster map [%s]"
+#, fuzzy
+msgid "Cannot rewrite line %d"
+msgstr "Não consegui criar índice"
+#, fuzzy
+msgid "For tool 'add', see also 'thresh' parameter"
+msgstr "Não copiar tabela (veja também o parâmetro 'new')"
+#, fuzzy
+msgid "Close boundaries"
+msgstr "não consegui atualizar limites"
+#, fuzzy
+msgid "Cannot copy line %d, editing terminated"
+msgid "No layer database connection."
+#, fuzzy
+msgid "Cannot snap lines %d,%d"
+#, fuzzy
+msgid "%d lines modified"
+msgstr "%-5d linhas mortas ignoradas\n"
+#, fuzzy
+msgid "Could not open ASCII file <%s>"
+msgid "Print vector map region only"
+msgstr "Imprime apenas a região do mapa vetorial"
+#, fuzzy
+msgid "Cannot open vector map <%s> at topo level [%d]"
+#, fuzzy
+msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot select attribute."
+#, fuzzy
+msgid "Creating vector grid..."
+msgstr "criando novo arquivo cats ..."
+#, fuzzy
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "Não consegui encontrar o arquivo vetorial %s"
+#, fuzzy
+msgid "Could not find input map <%s>."
+#, fuzzy
+msgid "[%d] features written"
+msgstr "%d pontos escritos no vetor"
+#, fuzzy
+msgid "Parameter <%s> not set"
+#, fuzzy
+msgid "Output map where segments will be written"
+#, fuzzy
+msgid "Cannot get layer information for vector map"
+msgid "<%s> cellfile not found"
+msgstr "<%s>: arquivo de células não encontrado"
+msgid "Not able to open vector map <%s>"
+msgstr "Não consegui abrir mapa vetorial <%s>"
+msgid "No table."
+msgstr "Sem tabela"
+msgid "Can't read raster"
+msgid "driver name"
+msgstr "nome do driver"
+msgid "Driver name"
+msgstr "Nome do Driver"
+msgid "Cannot list databases."
+msgid "database location"
+msgid "Table name, select all from this table"
+msgstr "Nome da tabela, selecionar tudo desta tabela"
+msgid "output field separator"
+msgstr "delimitador de campo na saída"
+msgid "output vertical record separator"
+msgstr "delimitador vertical de registro na saída"
+msgid "null value indicator"
+msgstr "indicador de valor nulo"
+msgid "do not include column names in output"
+msgstr "não incluir nomes das colunas na saída"
+msgid "vertical output (instead of horizontal)"
+msgstr "saída vertical (ao invés de horizontal)"
+msgid "Cannot find mapset for %s"
+msgstr "Não encontrei mapset para %s"
+msgid "Cannot open File %s"
+msgid "Not able to open file for [%s]"
+msgstr "Não consegui abrir o arquivo para [%s]"
+msgid "Label file [%s] not available"
+msgstr "Arquivo de rótulos [%s] não disponível"
+msgid "Can't open label file [%s]"
+msgstr "Não consegui abrir arquivo de rótulos [%s]"
+#, fuzzy
+msgid "unable to open [%s] in [%s]"
+#, fuzzy
+msgid "warning: unable to open [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
+#, fuzzy
+msgid "Unable to find input cell map '%s'"
+#, fuzzy
+msgid "Unable to create raster map [%s]"
+#, fuzzy
+msgid "Unable to create output <%s>"
+msgid "Input file [%s] not found."
+msgstr "Arquivo de entrada [%s] não encontrado."
+msgid "Unable to open output file <%s>."
+msgid "Multiplier for ascii data"
+msgstr "Multiplicador para dados ASCII"
+#, fuzzy
+msgid "Could not open temporary file: [%s]"
+#, fuzzy
+msgid "Could not open input file [%s]"
+#, fuzzy
+msgid "unable to create raster"
+#, fuzzy
+msgid "Unable to create output raster map <%s>"
+#, fuzzy
+msgid "%s: Unable to find raster map <%s>"
+#, fuzzy
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+#, fuzzy
+msgid "%s:  Unable to open output raster map <%s>"
+#, fuzzy
+msgid "Vector <%s> could not be opened"
+#, fuzzy
+msgid "No db connection for driver <%s> defined. Run db.connect."
+msgid "Table name"
+msgstr "Nome da Tabela"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr ""
+"Mostra parâmetros da conexão atual e sai (estilo shell script)\n"
+"\tformato:  camada[/nome da camada] tabela chave driver_do_banco_de_dados"
+msgid "x column name"
+msgstr "Nome da coluna x"
+msgid "z column name"
+msgstr "Nome da coluna z"
+#, fuzzy
+msgid "Cannot drop table: %s"
+#, fuzzy
+msgid "Cannot open labels <%s>"
+#, fuzzy
+msgid "Cannot fetch data from table"
+#, fuzzy
+msgid ""
+"OGR output datasource name. For example:\n"
+"\t\tESRI Shapefile: filename or directory for storage\n"
+"\t\tMapInfo File: filename or directory for storage"
+msgstr ""
+"Nome do banco de dados OGR. Exemplos:\n"
+"\t\tShapefile ESRI: diretório contendo shapefiles\n"
+"\t\tArquivo MapInfo: diretório contendo arquivos mapinfo"
+#, fuzzy
+msgid "SVG file <%s> cannot be opened"
+#, fuzzy
+msgid "Querying input '%s' ... "
+#, fuzzy
+msgid "Copying %s input lines ... "
+msgstr "Verificando pontos vetoriais ..."
+#, fuzzy
+msgid "Cannot create table <%s>"
+#, fuzzy
+msgid "no record for cat = %d"
+msgstr "Sem registros para cat = %d"
+#, fuzzy
+msgid "cannot insert row: %s"
+msgstr "Não consegui inserir nova linha: %s"
+#, fuzzy
+msgid "Cannot find line of cat %d"
+#, fuzzy
+msgid "Unalbe to open vector map <%s>"
+#, fuzzy
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgstr "Conexão com banco de dados não definida para a camada <%d>. Execute v.db.connect."
+#, fuzzy
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Transforma uma camada de mapa vetorial de um sistema de coordenadas em outro sistema de coordenadas."
+#, fuzzy
+msgid "ASCII file holding transform coordinates (if not given transformation options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be used instead)"
+msgstr "Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ao invés dos pontos"
+#, fuzzy
+msgid "Raster map <%s>] not found"
+msgid "Cannot start driver '%s'."
+msgstr "Não consegui obter informações do driver '%s'."
+msgid "Cannot describe table"
+msgstr "Não consegui descrever a tabela"
+msgid "Cannot start driver <%s>."
+msgstr "Não consegui iniciar o driver <%s>."
+#, fuzzy
+msgid "[%s] is an illegal name"
+msgstr "[%s] é um nome ilegal"
+msgid "Cannot write to <%s>"
+msgid "Not able to open cellfile for [%s]"
+#, fuzzy
+msgid "Not able to find cellfile [%s]"
+msgid "Raster map [%s] not available"
+msgstr "Arquivo raster [%s] não disponível"
+msgid "Raster file [%s] not available"
+msgid "Raster map [%s] not found"
+#, fuzzy
+msgid "Unable to open raster map [%s]"
+msgid "Vector file [%s] not available"
+msgid "Cannot open driver %s"
+msgstr "Não consegui abrir o driver %s"
+#, fuzzy
+msgid "<%s> illegal name"
+msgid "Out of Memory!\n"
+msgstr "Memória Esgotada! (Out of Memory) \n"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "%s: %s - Impossível abrir o mapa raster de entrada\n"
+msgid "Insufficent memory for allocation of data sturcture"
+msgid "%s: %s - illegal name for output raster map."
+msgstr "%s: %s - Nome ilegal para arquivo raster de saída"
+msgid "Insufficent memory for allocation of data structure."
+#, fuzzy
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "Exporta um raster do GRASS para um arquivo binário"
+msgid "Couldn't find raster map %s"
+msgstr "Não consegui encontrar o arquivo raster %s"
+#, fuzzy
+msgid "%s: <%s> not found"
+#, fuzzy
+msgid "%s: <%s> illegal name"
+#, fuzzy
+msgid "%s: Cannot open <%s>"
+#, fuzzy
+msgid "CREATING SUPPORT FILES ..."
+msgstr "CRIANDO ARQUIVOS DE SUPORTE"
+#, fuzzy
+msgid "<%s> is not a valid GRASS map name"
+msgstr "é não mapear"
+msgid "Cannot find %s"
+msgid "could not read range file"
+msgid "Unable to create raster map [%s]."
+#, fuzzy
+msgid "Filtering [%s] in [%s]"
+#, fuzzy
+msgid "Open raster map %s in %s = %d"
+msgstr "Abrir arquivo 3Draster %s"
+#, fuzzy
+msgid "Swap temp files"
+msgstr "Não consegui abrir arquivo temp %s"
+#, fuzzy
+msgid "Writing [%s]"
+#, fuzzy
+msgid "%s: illegal map name"
+#, fuzzy
+msgid "%s: <%s> illegal file name"
+#, fuzzy
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "Não consegui abrir arquivo de rótulos <%s> no mapset <%s>"
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Converte um arquivo raster do GRASS numa imagem PPM com a resolução da região atualmente definida."
+msgid "Mapset of input map"
+msgstr "Mapset do mapa de entrada"
+#, fuzzy
+msgid "Checking location %s, mapset %s:"
+#, fuzzy
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+#, fuzzy
+msgid "Error writing output map"
+msgstr "Erro tentando ler o arquivo dbmscap\n"
+#, fuzzy
+msgid "<%s> is illegal file name"
+#, fuzzy
+msgid "[%s] is an illegal file name"
+#, fuzzy
+msgid "no rules specified"
+#, fuzzy
+msgid "Can't open temp file [%s]"
+msgstr "Não consegui abrir arquivo temporário [%s]"
+msgid "Names of existing raster maps"
+msgstr "Nomes dos mapas raster existentes"
+#, fuzzy
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
+#, fuzzy
+msgid "%s - illegal name "
+#, fuzzy
+msgid "Couldn't find raster map [%s]"
+#, fuzzy
+msgid "%s in %s -can't open raster map"
+msgstr "%s: ERRO não consegui abrir tempfile"
+#, fuzzy
+msgid "%s - can't create raster map"
+msgid "%s=%s - illegal name"
+msgid "%s: can't create %s"
+msgid "Normalized"
+msgstr "Normalizado"
+#, fuzzy
+msgid "Out of memory!"
+msgstr "Memória Esgotada! (Out of Memory)"
+#, fuzzy
+msgid "Cell file [%s] not found"
+#, fuzzy
+msgid "Can't read current window parameters"
+#, fuzzy
+msgid "Error getting input null cells at row %d from %s"
+msgstr "Erro"
+#, fuzzy
+msgid "[%s] file name not legal"
+#, fuzzy
+msgid "[%s] file name not legal\n"
+#, fuzzy
+msgid "Requested 3d raster map not found <%s>"
+msgstr "Arquivo g3d solicitado não foi encontrado"
+#, fuzzy
+msgid "Could not open output map"
+msgid "unable to close output map"
+msgstr "Não consegui fechar arquivo de saída."
+#, fuzzy
+msgid "Cannot create output map [%s]"
+msgstr "Não consegui criar o mapa de saída [%s]"
+#, fuzzy
+msgid "Database's name couldn't be read"
+msgstr "Conexão com banco de dados não definida"
+#, fuzzy
+msgid "Cannot open vector points map <%s>"
+#, fuzzy
+msgid "Cannot create vector map <%s>"
+#, fuzzy
+msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
+msgid "Vector file [%s] not available in search list"
+msgstr "Arquivo de vetores [%s] não está disponível na lista de busca"
+msgid "Cannot open database <%s>"
+msgstr "Não consegui abrir o banco de dados <%s>"
+msgid "Cannot open table <%s>"
+#, fuzzy
+msgid "Cannot open driver <%s>"
+msgid ""
+"OGR layer name. If not given, all available layers are imported. Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+"Nome da camada OGR. Se não fornecida, todas as camadas serão importadas. Exemplos:\n"
+"\t\tShapefile ESRI: nome do shapefile\n"
+"\t\tArquivo MapInfo: nome do arquivo mapinfo"
+msgid "The vector '%s' already exists."
+msgstr "O vetor '%s' já existe."
+msgid "Could not find input map '%s'."
+msgstr "Não consegui encontrar o mapa de entrada '%s'."
+msgid "Could not find network input map '%s'."
+msgstr "Não consegui encontrar o mapa de entrada da rede '%s'."
+msgid "error opening raster map [%s]."
+msgstr "Erro abrindo arquivo raster [%s]."
+#, fuzzy
+msgid "Topology is not available"
+msgstr "Camada '%s' não disponível"
+msgid "Cannot describe table %s"
+#, fuzzy
+msgid "Patching file <%s@%s>"
+msgstr "    Remendando arquivo %s"
+#, fuzzy
+msgid "[%d] files patched"
+#, fuzzy
+msgid "Column type  not supported"
+msgid "Could not open vector map <%s>"
+msgid "Name of output raster map"
+msgstr "Nome do Raster de saída"
+msgid "Done          "
+msgstr "Concluído"
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
+#, fuzzy
+msgid "Pass [%d] of [%d]:"
+msgstr "classe %d (%d)\n"
+msgid "Illegal output name: '%s'"
+msgstr "Nome ilegal do arquivo de saída: '%s'"
+msgid "Could not close new 3d raster map"
+msgstr "Não consegui fechar o novo mapa g3d"
+msgid "%s: cellfile [%s] not found."
+msgstr "%s: arquivo de células [%s] não encontrado."
+msgid "Unable to open cellfile [%s]."
+msgid "Error reading wildcard."
+msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Seleciona a cor da malha, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "Seleciona a cor da borda, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
+msgid "Border not yet implemented for LatLong locations: border not drawn."
+msgstr "Borda ainda não implementada para locações Lat/Long: borda não desenhada"
+msgid "Unable to open the temporary file."
+msgstr "Não consegui abrir o arquivo temporário."
+msgid "Unable to open raster map [%s]."
+msgid "Unable to find raster [%s]."
+msgstr "Não encontrei arquivo raster [%s]."
+#, fuzzy
+msgid "use regular expression instead of wildcard"
+msgstr "de"
+#, fuzzy
+msgid "name for new raster map"
+msgstr "Nome do novo arquivo raster."
+#, fuzzy
+msgid "Output GRASS image file"
+msgstr "Arquivo KeyFrame de saída"
+#, fuzzy
+msgid "Resulting output grid3D volume"
+msgstr "Resolução do mapa de saída"
+#, fuzzy
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
+#, fuzzy
+msgid "Input vector map"
+msgid "%s: ERROR can't open tempfile"
+msgid "vector map <%s> not found"
+#, fuzzy
+msgid "unable to find raster map [%s]"
+#, fuzzy
+msgid "Both \"-i\" AND \"color\" specified - ignoring color"
+msgstr "Um de!"
+#, fuzzy
+msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
+msgstr "Um de!"
+#, fuzzy
+msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
+msgstr "Um de!"
+#, fuzzy
+msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
+msgstr "Um de!"
+#, fuzzy
+msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
+msgstr "Um de!"
+#, fuzzy
+msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
+msgstr "Um de!"
+#, fuzzy
+msgid "<%s> raster map not found"
+#, fuzzy
+msgid "<%s> unable to open raster map"
+#, fuzzy
+msgid "Cannot find vector map [%s]"
+#, fuzzy
+msgid "%s - can't open raster map"
+#, fuzzy
+msgid "Can't get row %d from raster map %s"
+#, fuzzy
+msgid "%s - raster map not found"
+msgid "string representing no data cell value"
+msgstr "texto representando célula sem valores de dado"
+#, fuzzy
+msgid "File name of classification result"
+msgid "File name of reference classes"
+msgstr "Nome do arquivo para as classes de referência"
+msgid "wide report, 132 columns (default: 80)"
+msgstr "relatório largo, 132 colunas (padrão: 80)"
+msgid "quiet"
+msgstr "silencioso"
+#, fuzzy
+msgid "<%s> - illegal output file name"
+msgid "%s: <%s> reference map not found"
+msgstr "%s: <%s> mapa de referência não encontrado"
+msgid "Base raster map"
+msgstr "Mapa raster base"
+#, fuzzy
+msgid "%s: raster map not found"
+msgid "Raster map that represents the elevation, used for the 3D information"
+msgstr "Mapa raster que representa a elevação, usado para informação 3D"
+#, fuzzy
+msgid "Problem opening input file [%s]"
+msgstr "Erro abrindo arquivo [%s]"
+#, fuzzy
+msgid "Problem opening output file [%s]"
+#, fuzzy
+msgid "can't write category file for <%s>"
+#, fuzzy
+msgid "%s: can't open tempfile"
+#, fuzzy
+msgid "Unable to read row %d in raster map [%s]"
+msgid "Elevation map"
+msgstr "Mapa de elevação"
+msgid "Output verbosely"
+msgstr "Saída verbosa"
+#, fuzzy
+msgid "Can't open raster map %s"
+msgid "CREATING SUPPORT FILES"
+msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
+msgstr "PRODUTOS DE ELEVAÇÃO para o mapset [%s] em [%s]"
+#, fuzzy
+msgid "It could not be find input map <%s>"
+msgstr "não consegui encontrar o mapa de entrada <%s>"
+#, fuzzy
+msgid "It could not be found input map <%s>"
+#, fuzzy
+msgid "Cannot find input map <%s>"
+#, fuzzy
+msgid "Input vector map <%s> not found."
+msgid "Category ranges: e.g. 1,3-8,13"
+msgstr "Intervalo de categorias: p.ex.: 1,3-8,13"
+msgid "Writing attributes ...\n"
+msgstr "Escrevendo atributos ...\n"
+#, fuzzy
+msgid "Could not open ascii file <%s>"
+#, fuzzy
+msgid "Could not open temp file <%s>"
+msgid "List available formats and exit"
+msgstr "Lista formatos disponíveis e finaliza"
+#, fuzzy
+msgid "Vector map <%s> not fould"
+#, fuzzy
+msgid "SVG output file"
+msgid "Could not find vector '%s'"
+msgstr "Não consegui encontrar o arquivo vetorial '%s'"
+msgid "Could not find vector map %s"
+#, fuzzy
+msgid "Unable to get row %d from <%s>"
+msgid "driver name:"
+msgstr "nome do driver:"
+msgid "Unable to allocate memory."
+msgstr "Não consegui alocar memória."
+#, fuzzy
+msgid "Path to an output file"
+#, fuzzy
+msgid " %d rows, %d cols."
+#, fuzzy
+msgid ""
+"Integer cell type.\n"
+"Writing"
+msgstr "Inteiro célula."
+#, fuzzy
+msgid ""
+"Float cell type.\n"
+"Writing"
+msgstr "célula."
+#, fuzzy
+msgid ""
+"Double cell type.\n"
+"Writing"
+msgstr "Duplo célula."
+msgid "Raster output file"
+msgstr "Arquivo raster de saída"
+#, fuzzy
+msgid "Pass #%d (of %d) ... "
+#, fuzzy
+msgid "Writing raster map ... "
+#, fuzzy
+msgid "Verbose mode."
+msgstr "Modo verboso"
+#, fuzzy
+msgid ""
+"Unexpected data in vector head:\n"
+"%s"
+msgid "Keep existing color table"
+msgstr "Manter a tabela de cores existente"
+msgid "List rules"
+msgstr "Lista de regras"
+msgid "Unknown keyword [%s] in vector head."
+msgstr "Palavra desconhecia [%s] no cabeçalho do vetor."
+msgid "Can't open temp file %s"
+#, fuzzy
+msgid "Organization where raster map was created"
+msgstr "Nome do mapa raster para ser reescalonado"
+#, fuzzy
+msgid "%s in %s - can't read header file"
+#, fuzzy
+msgid "%s - unable to create raster map"
+#, fuzzy
+msgid "%s - unable to create category file"
+#, fuzzy
+msgid "verbose mode"
+#, fuzzy
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "Não criar tabela de atributo."
+#, fuzzy
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "Nome do mapa de pontos vetorias para editar a tabela de atributos"
+msgid "Name of existing raster map to be displayed"
+msgstr "Nome de um mapa raster para exibir"
+#, fuzzy
+msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
+msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
+msgid "could not find input map <%s>"
+msgid "unable to open raster map [%s]"
+msgstr "não consegui abrir o arquivo de células [%s]"
+msgid "cannot get layer info for vector map"
+msgstr "não consegui obter informações de camada para o mapa vetorial"
+msgid "cannot open database %s by driver %s"
+msgstr "não conseguir abrir banco de dados %s com driver %s"
+msgid "cannot select data from table"
+msgstr "não consegui selecionar dados da tabela"
+msgid "cannot create table: %s"
+msgstr "não consegui criar a tabela: %s"
+msgid "cannot create index"
+msgstr "não consegui criar índice"
+msgid "cannot grant privileges on table %s"
+msgstr "não posso dar privilégios na tabela %s"
+#, fuzzy
+msgid "column type  not supported"
+msgid "Cannot find vector map"
+msgstr "Não consegui encontrar mapa vetorial"
+msgid "Cannot find raster map"
+msgstr "Não encontrei mapa raster"
+msgid "Cannot open raster map"
+msgid "#%s"
+msgstr "#%s"
+#, fuzzy
+msgid "Error while reading cell map."
+#, fuzzy
+msgid "Error while writing new cell map."
+msgstr "Erro na remoção do antigo mapa de células MASK."
+#, fuzzy
+msgid "Error in opening output file <%s>"
+#, fuzzy
+msgid "Unable to find input cell map <%s>"
+#, fuzzy
+msgid "Error in opening input file <%s>"
+msgid "Unable to open cell man <%s> for input.\n"
+msgstr "Não consegui abrir mapa de células<%s> para entrada.\n"
+msgid "Unable to open cell map <%s> for output.\n"
+msgstr "Não consegui abrir mapa de células <%s> para saída.\n"
+#, fuzzy
+msgid "Unable to read map raster row %d"
+#, fuzzy
+msgid "Unable to write color table to raster [%s]"
+msgstr "Não consegui ler arquivo de cores."
+#, fuzzy
+msgid "Cannot find map %s"
+#, fuzzy
+msgid "Cannot open map %s"
+msgid "Name of predefined rules file"
+msgstr "Nome arquivo de regras predefinidas"
+#, fuzzy
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "** atenção: valor(es) R:G:B está(ão) fora dos limites [0..255]: %d:%d:%d **\n"
+#, fuzzy
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr "** atenção: valor(es) R G B está(ão) fora dos limites [0..255]: %d %d %d **\n"
+#, fuzzy
+msgid "no such value"
+msgstr "** atenção: o valor não existe **\n"
+#, fuzzy
+msgid "%s:line %d:%s"
+msgstr "%s:linha %d:%s\n"
+#, fuzzy
+msgid "bad color specification"
+msgstr "** Especificação de cor incorreta **\n"
+#, fuzzy
+msgid "%s - unknown color"
+msgid "Valid colors are:\n"
+msgstr "Cores válidas são:\n"
+#, fuzzy
+msgid "Unable to find base map <%s>"
+#, fuzzy
+msgid "Unable to find cover map <%s>"
+#, fuzzy
+msgid "%s: reading category file for %s"
+#, fuzzy
+msgid "%s: unable to open raster map [%s]"
+#, fuzzy
+msgid "%s: unable to create raster map [%s]"
+#, fuzzy
+msgid "Unable to open database %s with driver %s"
+#, fuzzy
+msgid "%s: Unable to read raster map [%s]"
+#, fuzzy
+msgid "%s: unable to open raster map <%s>"
+#, fuzzy
+msgid "%s: Failed to read raster row %d"
+msgid "Unable to find [%s]."
+msgstr "Não consegui encontrar [%s]"
+#, fuzzy
+msgid "Unable to read cats table for %s"
+#, fuzzy
+msgid "Could not open raster <%s>"
+msgstr "Não consegui abrir mapa %s\n"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "Coordenadas de tela para posicionar a legenda (porcentagem)"
+msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
+msgstr "Nome da fonte (não interativo, ver a opção '-l') ou caminho para a fonte TrueType (incluindo nome do arquivo)"
+#, fuzzy
+msgid "%s: o_open_file: raster map %s not found"
+#, fuzzy
+msgid "%s: o_open_file: could not open raster map %s in %s"
+msgstr "Não consegui abrir mapa raster [%s] em [%s]"
+#, fuzzy
+msgid "No record for category for [%d]"
+#, fuzzy
+msgid "Error reading ASCII file <%s>"
+msgstr "Erro na leitura do arquivo de categorias para <%s>."
+#, fuzzy
+msgid "Error reading categories: <%s>"
+#, fuzzy
+msgid "No lines found"
+msgstr ""
+"\n"
+"Nenhuma camada DXF encontrada!\n"
+#, fuzzy
+msgid "List of point coordinates. Required for add and move actions."
+msgstr "Selecione tipo: linha ou área"
+#, fuzzy
+msgid "Assign cats to boundaries too"
+#, fuzzy
+msgid "Could not find input vector '%s'"
+msgstr "Não consegui encontrar o mapa vetorial de entrada %s"
+#, fuzzy
+msgid "Failed opening output vector map '%s'"
+msgstr "Falha abrindo arquivo dig de entrada."
+msgid "Do not create attribute table."
+msgid "Could not find input %s\n"
+msgstr "Não consegui encontrar a entrada %s\n"
+#, fuzzy
+msgid "Error reading ascii file: [%s]"
+#, fuzzy
+msgid "List vector maps in input location and exit (a dummy value must be given for input)"
+msgstr "Mostra os arquivos raster na locação de entrada e encerra"
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
+msgstr "Permite ao usuário pesquisar um mapa vetorial interativamente em locais selecionados pelo usuário dentro da região geográfica atual."
+#, fuzzy
+msgid "| Tool                            | Threshold     |"
+msgstr "                Mapa Atual                  Novo Mapa\n"
+#, fuzzy
+msgid "| Break                           |  "
+msgstr ""
+"                          VERIFICAÇÃO DOS ERROS NO MAPA\n"
+"\n"
+#, fuzzy
+msgid "| Prune                           |  "
+msgstr ""
+"\n"
+msgid "Patch complete. %d files patched."
+msgstr "Remendo completp. %d arquivos remendados."
+msgid "%s: <%s> vector map not found"
+msgstr "%s: <%s> mapa vetor não encontrado"
+#, fuzzy
+msgid "Vector <%s> could not be open"
+#, fuzzy
+msgid "Raster <%s> could not be open."
+#, fuzzy
+msgid "CrossCorrelation()"
+msgstr "Correlação"
+#, fuzzy
+msgid "Interpolation: Setting regions and boxes"
+msgstr "Ajustando janela de mapa"
+#, fuzzy
+msgid "Interpolation: nsply = %d"
+msgstr "Método de intepolação a usar"
+#, fuzzy
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+#, fuzzy
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+#, fuzzy
+msgid "%s: Dropping <s>"
+#, fuzzy
+msgid "Interpolation was a success!"
+#, fuzzy
+msgid "CrossCorrelation: %d points read in region. "
+#, fuzzy
+msgid "CrossCorrelation: It shouldn't take too long."
+msgid "Subgroup [%s] doesn't have any files."
+msgid "Subgroup [%s] only has 1 file."
+msgstr "Subgrupo [%s] só contém 1 arquivo"
+#, fuzzy
+msgid "%s -- illegal output file name"
+#, fuzzy
+msgid "Sorry, with method '%s' you have to define an output map."
+msgstr "mapear."
+msgid "%s: %s in %s - can't read category file"
+#, fuzzy
+msgid "Maximum number of iteration"
+msgstr "Número de iterações máximas"
+msgid "Finished.\n"
+msgstr "Concluído.\n"
+#, fuzzy
+msgid "Existing raster map name"
+msgstr "Nome de um arquivo raster existente"
+#, fuzzy
+msgid "%s - can't read raster cellhd"
+#, fuzzy
+msgid "error reading cell data"
+#, fuzzy
+msgid "Done!"
+msgstr "Concluído."
+#, fuzzy
+msgid "No line found."
+msgstr "Não encontrado.\n"
+#, fuzzy
+msgid "Nothing Found."
+#, fuzzy
+msgid "Do not build topology."
+#, fuzzy
+msgid "No features found"
+msgid "Could not open ascii file [%s]"
+msgid "vector map to be created"
+msgstr "Arquivo vetorial para criar"
+msgid "%s: Cannot open dxf file"
+msgstr "%s: Arquivo dxf não pode ser aberto"
+#, fuzzy
+msgid "Conversion of [%s] to vector map ..."
+msgstr ""
+"\n"
+#, fuzzy
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr "é de"
+#, fuzzy
+msgid "%s: - no such database %s\n"
+#, fuzzy
+msgid "must be even number of names"
+msgstr "de"
+#, fuzzy
+msgid "ERROR: <%s> not found\n"
+#, fuzzy
+msgid "ERROR: <%s> illegal name\n"
+msgid "Cannot open toolbox: %s"
+msgstr "Não consegui abrir a caixa de ferramentas: %s"
+msgid "Cannot open toolbox."
+msgstr "Não consegui abrir a caixa de ferramentas"
+msgid "Could not find input map <%s>\n"
+msgstr "Não consegui encontrar o mapa de entrada <%s>\n"
+msgid "'%s' has finished the transformation of the vectors.\n"
+msgstr "'%s' concluiu a transformação dos vetores.\n"
+msgid ""
+"                          CHECK MAP RESIDUALS\n"
+"\n"
+msgstr ""
+"\n"
+msgid "                Current Map                  New Map\n"
+msgid " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
+msgstr "Ponto      coord X   coordY |       coord X   coord Y    |      resíduos\n"
+msgid "  Residual mean average   : %f\n"
+msgstr "  Erro médio   : %f\n"
+msgid "Vector map(s) -- source for composite"
+msgstr "Mapa vetorial -- fonte para composição"
+msgid "New vector composite"
+msgstr "Novo vetor composto"
+msgid "Append files to existing file"
+msgstr "Adicionar arquivos a um arquivo existente"
+#, fuzzy
+msgid "No database updates."
+msgstr "banco de dados"
+#, fuzzy
+msgid "Adding new features to vector file ..."
+msgid "Vector map '%s' not found"
+msgstr "mapa vetorial '%s' não encontrado"
+#, fuzzy
+msgid "Input aspect file"
+msgstr "Nome do arquivo de saída de direção da encosta"
+#, fuzzy
+msgid "Input barrier file"
+msgstr "Arquivo de entrada"
+#, fuzzy
+msgid "Quiet operation"
+msgstr "Agregar"
+#, fuzzy
+msgid "Display Reference Information"
+msgstr "Posição de referência"
+#, fuzzy
+msgid "Aspect file's resolution differs from                        current region resolution"
+msgstr "atual"
+#, fuzzy
+msgid "%s\n"
+msgstr " %s\n"
+#, fuzzy
+msgid "ILLEGAL Resolution!"
+msgstr "Resolução"
+#, fuzzy
+msgid "output layer name"
+msgid "Hit RETURN -->"
+msgstr "Pressione RETURN -->"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist."
+msgstr ""
+"\a\n"
+"** A seguinte arquivo de células do subgrupo [%s] não existe."
+msgid "The subgroup must have at least 2 files to run %s."
+msgid ""
+"\n"
+"If you continue the mask will be removed."
+msgstr ""
+"\n"
+"Se continuar a máscara será removida."
+msgid "Did not find input cell map."
+msgid "Imagery files subgroup"
+msgstr "Subgrupo de arquivos de imagem"
+msgid "Warning: illegal group name <%s>."
+msgstr "ATENÇÃO: nome de grupo ilegal <%s>."
+msgid "Warning: illegal output file name <%s>."
+msgstr "ATENÇÃO: nome de arquivo de saída ilegal <%s>."
+msgid "An output cell map name is required."
+msgstr "Um nome de mapa de células de saída é necessário."
+msgid "The output cell map name can not be longer than 12 characters."
+msgstr "Nome do mapa de células de saída não pode ser maior que 12 letras."
+msgid "L: from  M: to R: quit\n"
+msgstr "L: de  M: a R: sair\n"
+msgid "Category <%d>: Area fill color and background color are the same!"
+msgstr "Categoria <%d>: Cor de preenchimento e fundo são iguais!"
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr "CAtegoria <%d>: Cor da linha e do fundo são iguai"
+msgid "Line color and background color are the same!"
+msgstr "Cor da linha e do fundo são iguais!"
+msgid "Area fill color and background color are the same!"
+msgstr "Cor de preenchimento e do fundo são iguais!"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "Data, data1/data2, ou nenhum"
+#, fuzzy
+msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
+msgstr "G3dToRaster: Escrevendo %i mapas raster com linhas %i colunas."
+msgid ""
+"\n"
+"Done\n"
+msgstr ""
+"\n"
+"Concluído\n"
+#, fuzzy
+msgid "Writing VTK VoxelData\n"
+msgstr "Escrevendo DadoImagem VTK"
+#, fuzzy
+msgid "Open vector 3d raster map %s"
+#, fuzzy
+msgid "Open 3d raster map %s"
+msgid ""
+"OGR datasource name.\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr ""
+"Nome do banco de dados OGR.\n"
+msgid "Name of vector output file"
+msgstr "Nome do arquivo vetor de saída"
+msgid "Vector import complete"
+#, fuzzy
+msgid "Required parameter <points> not set"
+msgstr "signature: pontos do perímetro fora de ordem."
+#, fuzzy
+msgid "ERROR: A line needs at least 2 points"
+msgstr "Você precisa inserir ao menos %d pontos."
+#, fuzzy
+msgid "ERROR: An area needs at least 3 points"
+#, fuzzy
+msgid "Unknown GIS formats"
+msgstr "Carimbo de hora desconhecido"
+#, fuzzy
+msgid "Unable to create raster map for [%s]"
+msgstr "Não consegui criar arquivo [%s]"
+#, fuzzy
+msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
+msgstr "RasterToG3D: Escrevendo %i mapas raster com linhas %i colunas."
+msgid "Writing g3d slice %i\n"
+msgstr "Escrevendo fatia g3d %i\n"
+msgid "error opening 3d raster map"
+msgstr "Erro abrindo arquivo g3d"
+msgid "Done\n"
+msgstr "Concluído\n"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr "Ler mapas fp como inteiros (usar regras de quantização do mapa)"
+msgid "Name for the resulting raster map"
+msgstr "Nome para o mapa raster resultante"
+#, fuzzy
+msgid "Open Raster file %s in Mapset %s"
+msgstr "Abrir arquivo raster %s"
+#, fuzzy
+msgid "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and count %i."
+#, fuzzy
+msgid "Open 3d raster map %s\n"
+#, fuzzy
+msgid "Open elev raster map %s\n"
+msgstr "Gera mapa raster de elevação"
+msgid "Could not open map %s\n"
+#, fuzzy
+msgid "Either -i flag and/or profile parameter must be used."
+msgstr "Flag -i e/ou parâmetro de trajeto devem ser usado"
+msgid "Bin raster map to be imported"
+msgid "Output partial derivatives instead"
+msgstr "Gera derivadas parciais em vez"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr "O tamanho da região é menor que minreg, nada a exibir.\n"
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr "O tamanho da região é maior que maxreg, nada a exibir.\n"
+msgid "Draw geographic grid"
+msgstr "Desenhar malha geográfica"
+#, fuzzy
+msgid "convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
+msgstr "todos para em atual"
+#, fuzzy
+msgid "name for new binary vector map (omit for display to stdout)"
+#, fuzzy
+msgid "Query layer"
+msgstr "Consultar"
+#, fuzzy
+msgid "Query column name"
+msgstr "Nome da coluna y"
+#, fuzzy
+msgid "Save graphic legend output in tlegend.txt file for d.graph display in GIS Manager"
+msgstr "Salvar em gráfico exibir em Gerente"
+msgid "No output maps"
+msgstr "Sem mapas de saída"
+msgid "any,grid3,3d raster"
+msgstr "qualquer, grid3, raster 3d"
+msgid "Name for G3d raster map"
+msgstr "Nome do mapa raster G3d"
+#, fuzzy
+msgid "output 3d raster map which will be filled with the 2D raster slices"
+msgstr "Saída de mapa 3dcell que será preenchido com as fatias raster 2D"
+#, fuzzy
+msgid "CREATING SUPPORT FILES FOR %s"
+#, fuzzy
+msgid "done."
+msgid "GRASS module to create a fractal surface of a given fractal dimension. Uses spectral synthesis method. Can create intermediate layers showing the build up of different spectral coefficients (see Saupe, pp.106-107 for an example of this). Use this module to generate naturally looking synthetical elevation models (DEM)."
+msgstr "Módulo GRASS para calcular uma superfície fractal com as dimensões dadas. Usa o método da síntese espectral. Pode criar camadas intermediárias mostrando a acumulação dos diferentes coeficientes espectrais (veja Saupe, pp.106-107 para um exemplo) Use esse método para gerar modelos de elevação (DEM) sintéticos com aparência natural."
+msgid "Quiet mode"
+msgstr "Modo silencioso"
+#, fuzzy
+msgid ""
+"\n"
+"SECTION 2: A * Search.                      Percent complete: "
+msgstr "Pesquisar Por cento "
+#, fuzzy
+msgid ""
+"\n"
+"\n"
+"SECTION %d: Closing Maps."
+#, fuzzy
+msgid ""
+"\n"
+"SECTION 3: Accumulating Surface Flow.       Percent complete: "
+msgstr "Por cento "
+#, fuzzy
+msgid ""
+"\n"
+"\n"
+"SECTION 2: A * Search.                      Percent complete:"
+msgstr "Pesquisar Por cento:"
+#, fuzzy
+msgid "    segments in row:\t%d"
+msgstr "em"
+#, fuzzy
+msgid "segments in columns:\t%d"
+msgstr "em"
+msgid "     total segments:\t%d"
+msgstr "     total de segmentos:\t%d"
+msgid "      open segments:\t%d"
+msgstr "      segmentos abertos:\t%d"
+#, fuzzy
+msgid "Running: %s"
+msgstr "Executando"
+#, fuzzy
+msgid "Print the input data extent in shell script style"
+msgstr "Mostra as estatísticas em estilo shell script"
+msgid "Maximum distance"
+msgstr "Distância máxima"
+msgid "Do not rebuild and store the topology at the end"
+msgstr "Não reconstruir e armazenar a topologia ao final"
+#, fuzzy
+msgid "Unable to open rules file <%s>"
+#, fuzzy
+msgid "Poorly placed psuedo control points. "
+msgstr "Não pontos"
+#, fuzzy
+msgid "No active psuedo control points"
+#, fuzzy
+msgid "Parsing bytes per cell"
+msgstr "        Número de bytes por célula"
+#, fuzzy
+msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+msgstr "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+#, fuzzy
+msgid "Displays vector data in the active frame on the graphics monitor."
+msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
+#, fuzzy
+msgid "raster, vector, visualization"
+#, fuzzy
+msgid "Cannot generate the transformation equation."
+msgstr "Não consegui obter informações da camada para o mapa vetorial"
+#, fuzzy
+msgid "%s@%s: projection doesn't match current settings"
+#, fuzzy
+msgid "%s@%s: zone doesn't match current settings"
+#, fuzzy
+msgid "raster, terrain analysis"
+msgstr "Estatísticas de transição de classe."
+#, fuzzy
+msgid "Name of input vector points map"
+msgstr "Nome do mapa vetorial (2d) de entrada"
+#, fuzzy
+msgid "Eigen values:"
+msgstr "Valor dos padrões de bits"
+#, fuzzy
+msgid "Use regular expression instead of wildcard"
+msgstr "de"
+#, fuzzy
+msgid "Icon to remove"
+#, fuzzy
+msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p(ercent_cover)"
+msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
+#, fuzzy
+msgid "Writing %s"
+msgstr "Escrevendo [%s]..."
+#, fuzzy
+msgid "To layer"
+msgstr "Consultar"
+#, fuzzy
+msgid "vector, attribute table"
+msgstr "Mostra atributos do vetor"
+#, fuzzy
+msgid ""
+"Line: %d  \n"
+"Type: %s  \n"
+"Left: %d  \n"
+"Right: %d  \n"
+msgstr "Linha: %d  Tipo: %s  Esquerda: %d  Direita: %d  "
+#, fuzzy
+msgid ""
+"Node[%d]: %d  \n"
+"Number of lines: %d  \n"
+"Coordinates: %.6f, %.6f, %.6f\n"
+msgstr "  Nó[%d]: %d  Número de linhas: %d  Coordenadas %.6f, %.6f %.6f\n"
+#, fuzzy
+msgid ""
+"Line: %5d  \n"
+"Angle: %.8f\n"
+msgstr "    Linha: %5d  Ângulo: %.8f\n"
+#, fuzzy
+msgid ""
+"Area: %d  \n"
+"Number of isles: %d\n"
+msgstr "Área: %d  Número de ilhas: %d\n"
+msgid "%s: %s - Unable to find the real-image map."
+msgstr "%s: %s - Não encontrei o mapa imagem real."
+msgid "%s: %s - Unable to find the imaginary-image."
+msgstr "%s: %s - Não encontrei o mapa imaginário"
+#, fuzzy
+msgid "Hue map name"
+msgstr "%s=%s - nome ilegal"
+#, fuzzy
+msgid "Red input raster map"
+msgstr "Mapa raster de entrada"
+#, fuzzy
+msgid "1 class."
+msgstr "%d classes."
+msgid "** Can't open seed singature file <%s> **"
+msgstr "** Não consigo semear arquivo de assinatura <%s> **"
+#, fuzzy
+msgid "Error writing result map file!"
+#, fuzzy
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Skipping [%s]..."
+msgstr "Passando [%s]..."
+#, fuzzy
+msgid "Name of the resultant map"
+msgstr "Nome do mapa resultante"
+#, fuzzy
+msgid "Unable to connect line id %d to line %d"
+#, fuzzy
+msgid "Unable to delete line %d"
+#, fuzzy
+msgid "Done"
+msgid "Cannot open OGR data source '%s'"
+msgstr "Não consegui abrir fonte de dados OGR '%s'"
+#, fuzzy
+msgid "Column(s)"
+msgstr "coluna(s)"
+#, fuzzy
+msgid "Unable to read category file for raster map <%s>"
+#, fuzzy
+msgid "Reading %s ... "
+msgstr "Lendo imagem ... "
+msgid "%s in %s: %s"
+msgstr "%s:em %s: %s"
+#, fuzzy
+msgid "cannot read head of %s"
+msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
+#, fuzzy
+msgid "Reading raster map <%s> ..."
+msgstr "Lendo arquivo dig_att...\n"
+msgid "No record for cat = %d"
+#, fuzzy
+msgid "Vector map <%s> not found in current mapset"
+msgid "Database connection not defined for layer <%d>"
+msgstr "Conexão com banco de dados não definida para camada <%d>"
+#, fuzzy
+msgid "Editing tool"
+#, fuzzy
+msgid "Input map containing lines"
+msgstr "Mapa de entrada contendo linhas"
+#, fuzzy
+msgid "Cannot open file for <%s>"
+msgid "Name of the random surface to be produced"
+msgstr "Nome da superfície aleatória a produzir"
+msgid "Cannot open file [%s]"
+#, fuzzy
+msgid "Read coordinates from standard input"
+msgstr "Obtém coordenadas a partir da \"entrada padrão\" (stdin)"
+#, fuzzy
+msgid "%s - illegal name"
+#, fuzzy
+msgid "Error reading map %s"
+#, fuzzy
+msgid "Closing raster map"
+msgstr "Mapa raster de cobertura"
+#, fuzzy
+msgid "Could not close the 3d raster map"
+msgid "Can't create output map"
+msgstr "Não consegui criar o mapa de saída"
+#, fuzzy
+msgid "name for new vector map"
+#, fuzzy
+msgid "Cover raster map"
+msgstr "Mapa de cobertura"
+msgid "Topographic index ln(a/tanB) map"
+msgstr "Mapa de índice topográfico [ln(a/tanB)]"
+msgid "No input coordinates provided"
+msgstr "Coordenadas de entrada não foram informadas"
+msgid "Database name:"
+msgstr "Banco de dados:"
+#, fuzzy
+msgid "Path to the input file"
+#, fuzzy
+msgid "Name of the output walkers site file"
+msgstr "Nome do raster de saída"
+msgstr "tipo de coluna não suportado"
+#, fuzzy
+msgid "%s - too many patch files. only %d allowed"
+msgstr "correção"
+#, fuzzy
+msgid "category [%d]"
+msgstr ""
+"Camada: %d\n"
+"categoria: %d\n"
+#, fuzzy
+msgid "Interpolation()"
+#, fuzzy
+msgid "Calculation time"
+msgstr "Calculando médias das classes ..."
+#, fuzzy
+msgid "History line too long: truncating to %d characters"
+msgstr "Histórico para"
+msgid "Name of output 3d raster map"
+msgstr "Nome do arquivo G3D de saída"
+#, fuzzy
+msgid "input layer name"
+msgstr "Nome da tabela de entrada"
+msgid "Raster elevation file name"
+msgstr "Nome do Arquivo raster de elevação"
+#, fuzzy
+msgid "Loading maps: "
+msgstr "Lendo mapa"
+#, fuzzy
+msgid "Raster to remove"
+#, fuzzy
+msgid "Name of the output walkers vector points map"
+#, fuzzy
+msgid "Input raster map being fft"
+msgstr "Arquivo raster de entrada sendo FFT"
+#, fuzzy
+msgid "File containing initial signatures"
+msgstr "Arquivo contém assinaturas resultantes"
+#, fuzzy
+msgid "Name of input raster map(s)"
+msgstr "Nome do Raster de entrada"
+#, fuzzy
+msgid "Unable to open file: <%s>"
+msgstr "Não consegui abrir o arquivo de células [%s]"
+msgid "Attribute column(s)"
+msgstr "Coluna(s) de atributo(s)"
+msgid "database name"
+#, fuzzy
+msgid "Finished"
 #~ msgid "Raster file(s) for View%d"
 #~ msgstr "Arquivos raster para visualizar %d"
@@ -33124,11 +36765,11 @@
 #~ msgstr "Formato OGR."
 #~ msgid "Print vector history instead of info"
-#~ msgstr "Mostra histórico do vetor ao invés de informações"
+#~ msgstr "Imprime histórico do vetor ao invés de informações"
 #, fuzzy
 #~ msgid "Print topology information only"
-#~ msgstr "Mostrar informação topológica (depuração)"
+#~ msgstr "Imprime apenas informação topológica"
 #~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
 #~ msgstr "Arquivo contendo instruções de mapeamento (ou use 'input=-' para entrar do teclado)"
@@ -33170,18 +36811,6 @@
 #~ msgid "Name of filter file"
 #~ msgstr "Nome do arquivo de filtro"
-#, fuzzy
-#~ msgid "Location of input raster map"
-#~ msgstr "Localização do mapa de entrada"
-#, fuzzy
-#~ msgid "Mapset of input raster map"
-#~ msgstr "Nome do Raster de entrada"
-#, fuzzy
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "Mapa raster de entrada"
 #~ msgid "Quiet - suppress progress report"
 #~ msgstr "Quieto - suprime relatório de progresso"
@@ -33197,55 +36826,10 @@
 #~ msgid "Exporting to GDAL raster"
 #~ msgstr "Não consegui escrever em <%s>"
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, dianum %d, hora: %02i:%02i:%02i (hora decimal: %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr " long: %f, lat: %f, fuso horário: %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " Posição solar: azimute: %f,\n"
-#~ "   ângulo do sol sobre o horizonte(corrigido da refração): %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Hora do Nascente (sem refração): %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " Hora do Poente (sem refração): %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "Nenhum cálculo de mapa solicitado. Concluído.\n"
-#, fuzzy
-#~ msgid "Can't open range file for %s"
-#~ msgstr "não consegui abrir arquivo de intervalo para %s"
-#, fuzzy
-#~ msgid "<%s> created"
-#~ msgstr "Locação: %s\n"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "Mapa raster a ser recodificado"
 #~ msgid "Overlay (non-null values only)"
 #~ msgstr "Overlay (apenas valores não nulos)"
 #, fuzzy
-#~ msgid "Raster map to be displayed"
-#, fuzzy
-#~ msgid "Vector output map"
-#~ msgstr "Sem mapa de saída"
-#, fuzzy
-#~ msgid "Rescaling range for output maps (for no rescaling use 0,0)"
-#~ msgstr "Intervalo de transformação da escala de saída (utilizar 0,0 para não transformar)"
-#, fuzzy
 #~ msgid "Error while writing to temp file"
 #~ msgstr "Erro na leitura do arquivo de assinaturas."
@@ -33261,9 +36845,8 @@
 #~ msgid "Failed writing raster map row %ld"
 #~ msgstr "Lendo arquivo dig_att...\n"
-#, fuzzy
 #~ msgid "Not enough room in history file"
-#~ msgstr "Memória insuficiente para az"
+#~ msgstr "espaço insuficiente no arquivo de histórico"
 #, fuzzy
 #~ msgid "Your mapset search list:\n"
@@ -33292,75 +36875,6 @@
 #~ msgstr "Não existe mapa vectorial para interpolar. A interpolação será efectuada utilizando <%s> mapa vectorial"
 #, fuzzy
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "Falha abrindo arquivo dig de entrada."
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas parciais a partir de um mapa raster com valores verdadeiros de elevação. Aspecto é calculado no sentido anti-horário a partir do leste."
-#~ msgid "Output slope filename"
-#~ msgstr "Nome do arquivo de saída de declividade"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "Nome do arquivo de curvatura do perfil"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "Nome do arquivo de curvatura tangencial"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Nome do arquivo da primeira derivada parcial dx (declive E-W)"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Nome do arquivo da primeira derivada parcial dy (declive N-S)"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "Nome do arquivo da segunda derivada parcial dxx"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "Nome do arquivo da segunda derivada parcial dyy"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "Nome do arquivo da segunda derivada parcial dxy"
-#~ msgid "wrong type: %s"
-#~ msgstr "Tipo incorreta: %s"
-#, fuzzy
-#~ msgid "Creating support files..."
-#~ msgstr "criando arquivos de suporte para %s"
-#, fuzzy
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "Não consegui abrir mapa raster [%s] em [%s]"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "ORIENTAÇÃO [%s] COMPLETA"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "DECLIVIDADE [%s] COMPLETA"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "CURVA DE PERFIL [%s] COMPLETA"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "CURVA TANGENCIAL [%s] COMPLETA"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "DECLIVIDADE E-W [%s] COMPLETA"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "DECLIVIDADE N-S [%s] COMPLETA"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] COMPLETA"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] COMPLETA"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] COMPLETA"
-#, fuzzy
 #~ msgid "Input elevation map"
 #~ msgstr "Nome do Arquivo raster de elevação"
@@ -33372,18 +36886,6 @@
 #~ msgid "Layer number of data column"
 #~ msgstr "Camada para"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Gera uma camada raster mostrando as sub-bacias de drenagem."
-#~ msgid "Coded stream network file name"
-#~ msgstr "Nome do arquivo de rede de drenagens"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "Nome do arquivo com os divisores afinados"
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "Nome do arquivo para a partição de divisores resultante"
 #, fuzzy
 #~ msgid "Name of the elevation raster map [m]"
 #~ msgstr "Nome do raster de entrada"
@@ -33415,36 +36917,7 @@
 #~ msgid "Output flowline vector map"
 #~ msgstr "Gera arquivo com a declividade"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "Nome do mapa raster de elevação"
-#~ msgid "Output raster map having shadows"
-#~ msgstr "Saída de raster contendo sombras"
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: ano (1950..2050)"
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: mês (0..12)"
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: dia (0..31)"
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: hora (0..24)"
 #, fuzzy
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "coordenada leste (ponto de interesse, padrão: centro do mapa)"
-#, fuzzy
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "coordenada norte (ponto de interesse, padrão: centro do mapa)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "Zero é uma elevação real"
-#, fuzzy
 #~ msgid "Verbose output (also print out sun position etc.)"
 #~ msgstr "Saída detalhada (também imprime posição do sol, etc)"
@@ -33548,14 +37021,6 @@
 #~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
 #~ msgstr "Converte um arquivo raster do GRASS numa imagem PPM com a resolução da região atualmente definida."
-#, fuzzy
-#~ msgid "Band to select"
-#~ msgstr "Nenhum monitor selecionado"
-#, fuzzy
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "Impossível criar <Tabela_auxiliar_dos_desvios>"
 #~ msgid "If set to 0, z coordinates are used. (3D vector only)"
 #~ msgstr "Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
@@ -33563,13 +37028,6 @@
 #~ msgstr "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
 #, fuzzy
-#~ msgid "M.Q. solution"
-#~ msgstr "Resolução"
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr "Dados 3D no arquivo dxf. Polyline_flag: %d"
-#, fuzzy
 #~ msgid "Import SRTM HGT files into GRASS"
 #~ msgstr "Importar"
@@ -33597,28 +37055,23 @@
 #~ msgid "Unable to close elevation map"
 #~ msgstr "Não consegui fechar mapa de elevação"
-#, fuzzy
 #~ msgid "unable to close input raster map"
-#~ msgstr "Não consegui fechar mapa de entrada"
+#~ msgstr "Não consegui fechar mapa raster de entrada"
-#, fuzzy
 #~ msgid "Could not open map %s"
-#~ msgstr "Não consegui abrir mapa %s\n"
+#~ msgstr "Não consegui abrir mapa %s"
 #~ msgid "unable to close top raster map"
-#~ msgstr "Não consegui fechar mapa raster de cima"
+#~ msgstr "Não consegui fechar mapa raster de topo"
-#, fuzzy
 #~ msgid "unable to close bottom raster map"
 #~ msgstr "Não consegui fechar mapa raster de baixo"
-#, fuzzy
 #~ msgid "Could not get top raster row \n"
-#~ msgstr "Não consegui ler linha do arquivo raster \n"
+#~ msgstr "Não consegui obter o raster do topo agora\n"
-#, fuzzy
 #~ msgid "Could not get bottom raster row \n"
+#~ msgstr "Não consegui obter raster de baixo agora\n"
 #~ msgid "Unable to write raster row"
 #~ msgstr "Não consegui escrever linha do raster"
@@ -33645,13 +37098,9 @@
 #, fuzzy
 #~ msgid "Cannot open raster map <%s>"
-#~ msgstr "Não consegui abrir arquivo de células [%s]"
+#~ msgstr "Não consegui abrir arquivo de células <%s>"
 #, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#~ msgstr "Não consegui abrir o arquivo de células para [%s]"
-#, fuzzy
 #~ msgid "Cannot create category file of <%s>"
 #~ msgstr "Editar arquivo de categorias para [%s]?"
@@ -33699,33 +37148,7 @@
 #~ msgid "Failed writing output raster map row %d"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "Dado 'signed' (bit alto significa valor negativo)"
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "Número de bytes por célula (1, 2, 4)"
 #, fuzzy
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Limite Sul da região geográfica (limite externo)"
-#, fuzzy
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "ATENÇÃO: nome de subgrupo ilegal <%s>."
-#, fuzzy
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "Número máximo de iterações: %d\n"
-#, fuzzy
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "%d raster%s, %d vetor%s\n"
-#, fuzzy
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "conversão"
-#, fuzzy
 #~ msgid "Error writing category file for <%s>"
 #~ msgstr "Erro na escrita do arquivo de categorias para <%s>."
@@ -33735,9 +37158,8 @@
 #~ msgid "Overwrite output map file"
 #~ msgstr "Sobrescrever arquivo de saída"
-#, fuzzy
 #~ msgid "Setting window header"
-#~ msgstr "Mapa raster dos pontos iniciais"
+#~ msgstr "Ajustando cabaçalho da janela"
 #, fuzzy
 #~ msgid "Cannot get row"
@@ -33854,21 +37276,14 @@
 #~ msgid "Cannot read cover raster row [%d]"
 #~ msgstr "Não consegui ler arquivo raster agora."
-#, fuzzy
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "não consigo ler linha no mapa de elevação"
-#, fuzzy
 #~ msgid "Error reading 'hue' map"
-#~ msgstr "Erro na leitura do mapa raster de entrada."
+#~ msgstr "Erro na leitura do mapa de 'matiz'"
-#, fuzzy
 #~ msgid "Error reading 'intensity' map"
+#~ msgstr "Erro na leitura do mapa de 'intensidade'"
-#, fuzzy
 #~ msgid "Error reading 'saturation' map"
+#~ msgstr "Erro na leitura do mapa de 'saturação"
 #, fuzzy
 #~ msgid "Unable to read raster <map %d of %d> row %d"
@@ -33901,13 +37316,6 @@
 #~ msgstr "Erro escrevendo linha nula [%d]."
 #, fuzzy
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "Coluna %d definida como inteiro só possui valores double"
-#~ msgid "Reading map"
-#~ msgstr "Lendo mapa"
-#, fuzzy
 #~ msgid "Unable to read raster map row %d "
 #~ msgstr "Não consegui criar arquivo raster [%s]."
@@ -33977,7 +37385,7 @@
 #, fuzzy
 #~ msgid "Can't create raster map <%s>"
-#~ msgstr "Não consegui criar arquivo raster [%s]."
+#~ msgstr "Não consegui criar arquivo raster <%s>."
 #, fuzzy
 #~ msgid "Quant table not changed for %s"
@@ -34132,24 +37540,6 @@
 #~ msgstr "Pontos a ser perturbados espacialmente"
 #, fuzzy
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "Tabela <%s> não existe no banco de dados <%s>"
-#, fuzzy
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "Criando tabela auxiliar para arquivar zonas adjacentes"
-#, fuzzy
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Não consegui abrir arquivo de saída."
-#~ msgid "Cross Validation was success!"
-#~ msgstr "Validação cruzada obteve sucesso!"
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "Interpolação: A resolução da região é demasiado elevada: %d células. Considere alterá-la."
-#, fuzzy
 #~ msgid "Finding nearest lines..."
 #~ msgstr "Encontrando classes de treinamento..."
@@ -34232,14 +37622,6 @@
 #, fuzzy
-#~ msgid "Name of output vector area map"
-#~ msgstr "Nome do mapa vetorial (2d) de entrada"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "Nome do mapa de pontos de saída"
-#, fuzzy
 #~ msgid "Unable to open SVG file <%s>"
 #~ msgstr "Não consegui abrir o arquivo de células [%s]"
@@ -34323,9 +37705,6 @@
 #~ msgid "Error writing cell map during transform."
 #~ msgstr "Erro na escrita do mapa de células durante a transformação."
-#~ msgid "Could not open <%s>"
-#~ msgstr "Não consegui abrir <%s>"
 #~ msgid "Could not read from <%s>"
 #~ msgstr "Não consegui ler de <%s>"
@@ -34372,7 +37751,6 @@
 #~ msgid "raster3d, voxel, export"
 #~ msgstr "raster3d, voxel, export"
-#, fuzzy
 #~ msgid "raster3d, voxel"
 #~ msgstr "raster3d, voxel"
@@ -34501,7 +37879,7 @@
 #, fuzzy
 #~ msgid "raster, import"
-#~ msgstr "Inportação de vetor incompleta"
+#~ msgstr "raster, import"
 #, fuzzy
 #~ msgid "raster, imagery"
@@ -34591,10 +37969,6 @@
 #~ msgstr "Arquivo vetorial para criar"
 #, fuzzy
-#~ msgid "vector, projection"
-#~ msgstr "Fonte"
-#, fuzzy
 #~ msgid "Name of input point vector map"
@@ -34651,18 +38025,11 @@
 #~ msgid "vector, raster, conversion"
 #~ msgstr "Estatísticas de transição de classe."
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
 #, fuzzy
 #~ msgid "vector, path, visibility"
 #, fuzzy
-#~ msgid "Duplicate area centroids"
-#~ msgstr "Não consegui calcular área do centróide."
-#, fuzzy
 #~ msgid "vector, transformation, 3D"
 #~ msgstr "Número de pontos de interpolação"
@@ -34682,9 +38049,6 @@
 #~ msgid "ASCII file to be imported, if not given reads from standard input"
 #~ msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Número da coluna usada como coordenada x (primeira coluna é 1) para o modo de pontos"
 #, fuzzy
 #~ msgid "Error reading ASCII file: (bad type) [%s]"
 #~ msgstr "Erro na leitura do arquivo de categorias para <%s>."
@@ -34726,25 +38090,14 @@
 #~ msgid "vector, raster, attribute table"
 #~ msgstr "tabela de atributos, vetor, raster"
-#, fuzzy
-#~ msgid "It was impossible to open table"
-#~ msgstr "não consegui criar %s"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "Saída é o erro de interpolação"
-#, fuzzy
 #~ msgid "vector, metadata, history"
+#~ msgstr "vetor, metadados, histórico"
-#, fuzzy
 #~ msgid "Layer:           %s"
-#~ msgstr "Concluído"
+#~ msgstr "Camada:           %s"
-#, fuzzy
 #~ msgid "Mapset:          %s"
-#~ msgstr "Mapset:   %s\n"
+#~ msgstr "Mapset:          %s"
 #, fuzzy
 #~ msgid "Location:        %s"
@@ -34846,13 +38199,6 @@
 #~ msgstr "Esquema do banco de dados. Não use essa opção se esquemas não forem suportados pelo driver/servidor de banco de dados"
 #, fuzzy
-#~ msgid "Selects data from table."
-#~ msgstr "Selecionar dados do banco"
-#~ msgid "Output drain raster map"
-#~ msgstr "Gera mapa raster de drenagem"
-#, fuzzy
 #~ msgid "Unused; retained for compatibility purposes, will be removed in future"
 #~ msgstr "em"
@@ -34900,30 +38246,6 @@
 #, fuzzy
-#~ msgid "Source map is: Integer cell type"
-#~ msgstr "Fonte mapear é Inteiro célula"
-#, fuzzy
-#~ msgid "Source map is: Floating point (float) cell type"
-#~ msgstr "Fonte mapear é Flutuante célula"
-#, fuzzy
-#~ msgid "Source map is: Floating point (double) cell type"
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "\rLendo arquivo [%s] ..."
-#, fuzzy
-#~ msgid "Error getting input null cells"
-#~ msgstr "Erro"
-#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#~ msgstr "Não encontrei %s"
-#, fuzzy
 #~ msgid "%s higher above pointer wrong"
 #~ msgstr "Altura da câmera sobre o terreno"
@@ -34935,14 +38257,6 @@
 #~ msgid "raster, random, cell"
 #~ msgstr "Mapa raster a ser amostrado"
-#, fuzzy
-#~ msgid "Unable to open MASK"
-#~ msgstr "Não consegui ler MASK"
-#, fuzzy
-#~ msgid "unable to open MASK"
 #~ msgid "Output map: useful for visual display of results"
 #~ msgstr "Mapa de saída: útil para exibição visual dos resultados"
@@ -34970,22 +38284,10 @@
 #, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, comprimento do dia) são guardados num arquivo texto. Alternativamente, um horário local pode ser especificado para calcular ângulo de incidência e/ou mapas de irradiância. O efeito de sombreamento da topografia também pode ser opcionalmente incorporado."
-#, fuzzy
 #~ msgid "Name of the longitude input raster map [decimal degrees]"
 #~ msgstr "Nome do arquivo raster com as latitudes [graus decimais]"
 #, fuzzy
-#~ msgid "incidout requres time parameter to be set"
-#~ msgstr "parâmetro para"
-#, fuzzy
-#~ msgid "Mode 2: integrated daily irradiation"
-#~ msgstr "Modo dia de ano"
-#, fuzzy
 #~ msgid "raster, metadata"
@@ -35017,20 +38319,7 @@
 #~ msgid "raster, DEM, fractal"
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "Retorna mais comentários (padrão = quieto)"
-#~ msgid "Cannot open database %s by driver %s"
-#~ msgstr "Não conseguir abrir banco de dados %s com driver %s"
 #, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#~ msgstr "Não consegui selecionar atributo."
-#~ msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-#~ msgstr "Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou \"none\""
-#, fuzzy
 #~ msgid "Removing %s <%s>"
@@ -35046,215 +38335,20 @@
 #~ msgid "<%s> nothing removed"
 #~ msgstr "[%s] não encontrado."
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "Título do raster de saída após ifft"
-#~ msgid "Power 2 values : [%d] rows [%d] columns."
-#~ msgstr "Valores ao quadrado : [%d} linhas [%d] colunas."
-#~ msgid "Reading the raster maps..."
-#~ msgstr "Lendo mapas raster..."
-#~ msgid "Rotating data arrays..."
-#~ msgstr "Rotacionando arranjos de dados ... "
-#~ msgid "Inverse FFT completed..."
-#~ msgstr "FFT inversa concluída..."
-#~ msgid "Unable to open output file."
-#~ msgid "Transform successful."
-#~ msgstr "Transformada bem sucedida"
-#~ msgid "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color transformation function."
-#~ msgstr "Função de transformação de cor de um mapa raster: matiz - intensidade-saturação (his) para vermelho-verde-azul (rgb)."
-#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "Nome do mapa raster"
-#, fuzzy
-#~ msgid "Saturation map name"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "Mapa de saída no qual os pontos serão gravados"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "Formato para relatar a declividade"
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "Criando %i mapas raster\n"
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#~ msgid "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color transformation function"
-#~ msgstr "Função de transformação de cor de um mapa raster: vermelho-verde-azul (rgb) para matiz-intensidade-saturação (his)"
-#, fuzzy
-#~ msgid "Green input raster map"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "Gera arquivo com a declividade"
-#, fuzzy
-#~ msgid "Output saturation raster map"
 #~ msgid "pyramid constructed."
 #~ msgstr "pirâmide construída."
-#~ msgid "Class transition statistics."
-#~ msgstr "Estatísticas de transição de classe."
-#~ msgid "Transition probabilities: %f %f %f; %f"
-#~ msgstr "Probabilidades de transição: %f %f %f; %f"
-#~ msgid "get_img: out of memory."
-#~ msgstr "get_img: Memória Esgotada! (Out of Memory)"
-#, fuzzy
-#~ msgid "Subgroup [%s] in group [%s] contains no files."
-#~ msgstr "Subgrupo [%s] no grupo [%s] não contém arquivos."
-#~ msgid "Writing [%s] ..."
-#~ msgstr "Escrevendo [%s]..."
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#~ msgstr "arquivo de assinatura"
 #~ msgid "Run quietly"
 #~ msgstr "Executa silenciosamente"
-#~ msgid "Subgroup [%s] not found."
-#~ msgstr "Subrupo <%s> não encontrado."
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "Arquivo de assinatura [%s] faltando ou é ilegível."
-#, fuzzy
-#~ msgid "Calculating eigenvalues and eigenvectors..."
-#~ msgstr "Calculando média das classes ..."
-#~ msgid "Ordering eigenvalues in descending order..."
-#~ msgstr "Ordenando os valores próprios por ordem decrescente..."
-#~ msgid "Transposing eigen matrix..."
-#~ msgstr "Transportando a matriz dos valores próprios e vectores próprios..."
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#~ msgstr "Não consegui escrever em <%s>"
-#~ msgid "Calculating class mean ..."
-#~ msgid "Calculating class covariance matrix..."
-#~ msgstr "Calculando matriz de covariância de classes..."
-#, fuzzy
-#~ msgid "Imagery group"
-#~ msgstr "Nome do grupo de imagens"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "subgrupo contendo arquivos de imagem"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#~ msgstr "arquivo de assinatura resultante"
-#~ msgid "%d classes."
-#~ msgstr "%d classes."
-#~ msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
-#~ msgstr "Não consegui escrever arquivo de assinatura [%s] para o subgrupo [%s], no grupo [%s]."
 #~ msgid "Range of values in output display files"
 #~ msgstr "Limite dos valores nos arquivos de saída"
-#~ msgid "Initializing data...\n"
-#~ msgstr "Inicializando dados ...\n"
-#~ msgid "Reading the raster map..."
-#~ msgstr "Lendo mapa raster..."
-#~ msgid "FFT completed..."
-#~ msgstr "FFT concluída..."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ " group <%s> not found"
-#~ msgstr ""
-#~ "\n"
-#~ "grupo <%s> não encontrado"
-#~ msgid "subgroup <%s> not found"
-#~ msgstr "subrupo <%s> não encontrado"
-#, fuzzy
-#~ msgid "Subgroup [%s] doesn't have any files"
-#~ msgstr "Subgrupo [%s] não possui nenhum arquivo"
-#, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s"
-#~ msgstr "O subgrupo deve possuir pelo menos 2 arquivos para executar %s."
-#~ msgid "Unable to proceed"
-#~ msgstr "Impossível prosseguir"
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "Grupo de arquivos de imagens a ser agrupados"
-#~ msgid "Subgroup name in the above group"
-#~ msgstr "Nome do subgrupo do grupo acima"
-#, fuzzy
-#~ msgid "Output file to contain final report"
-#~ msgstr "Nome de arquivo de saída para conter relatório"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal value of min_size"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- valor ilegal de min_size"
-#~ msgid "Can't creat reportfile: "
-#~ msgstr "Não consegui criar relatório: "
-#~ msgid "Reading image ... "
-#~ msgstr "Lendo imagem ... "
-#, fuzzy
 #~ msgid "Creates control points on an image to be ortho-rectified."
 #~ msgstr "Marque os pontos de controle no solo para retificar a imagem."
 #, fuzzy
-#~ msgid "Unable to read head of %s"
-#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
-#, fuzzy
 #~ msgid "Menu driver for the photo imagery programs."
 #~ msgstr "Barra de menu para os programas de imagem-fotografia."
@@ -35263,50 +38357,6 @@
 #~ msgstr "Nome de destino da locação da imagem"
 #, fuzzy
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "Não consegui escrever o arquivo temporário."
-#, fuzzy
-#~ msgid "Unable to open map %s"
-#~ msgstr "não consegui abrir [%s]"
-#, fuzzy
-#~ msgid "Unable to write row %d"
-#~ msgid "group=[%s] - not found."
-#~ msgstr "Grupo=[%s] - não encontrado."
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#~ msgstr "Subrupo=[%s] (do grupo [%s]) - não encontrado."
-#~ msgid "Can't read signature file [%s]."
-#~ msgstr "Não consegui ler o arquivo de assinatura [%s]."
-#~ msgid "[%s] has more than 255 signatures."
-#~ msgstr "%s tem mais de 255 assinaturas."
-#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
-#~ msgstr "Não consegui criar camada de rejeição [%s]."
-#~ msgid "Imagery group to be classified"
-#~ msgstr "Grupo de imagens a ser classificado"
-#~ msgid "Subgroup containing image files to be classified"
-#~ msgstr "subgrupo contendo arquivos de imagem a classificar"
-#~ msgid "Signatures to use for classification"
-#~ msgstr "Assinaturas para usar na classificação"
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "Mapa raster para o resultado da classificação"
-#, fuzzy
-#~ msgid "raster, imagery, fusion"
-#, fuzzy
 #~ msgid "1st map for mosaic (top of image stack)."
 #~ msgstr "mapear topo de imagem."
@@ -35330,23 +38380,12 @@
 #~ msgid "Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#~ msgstr "Não consegui abrir arquivo de saída <%s>."
-#~ msgid "Name of fractal surface raster layer"
-#~ msgstr "Nome da camada raster da superfície fractal"
 #~ msgid "Sums up the raster cell values."
 #~ msgstr "Soma os valores das células do raster"
 #~ msgid "Name of incidence or density file."
 #~ msgstr "Nome do arquivo de incidência ou densidade."
-#, fuzzy
-#~ msgid "Creates explicitly the NULL-value bitmap file."
-#~ msgstr "Explicitamente cria o arquivo bitmap 3D com valores NULL"
 #~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
 #~ msgstr "Acha a média de valores nas áreas de mesma categoria num mapa de cobertura, dado um mapa base especificado pelo usuário."
@@ -35354,134 +38393,24 @@
 #~ msgstr "%s: ERRO executando comando %s"
 #, fuzzy
-#~ msgid "Creation option to the output format driver. Multiple options may be listed."
-#~ msgstr "para Múltipla"
-#, fuzzy
 #~ msgid "Metadata key passed on the output dataset if possible"
 #~ msgstr "ativo"
 #, fuzzy
-#~ msgid "Density of output walkers"
-#~ msgstr "Nome do arquivo de saída"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#~ msgstr "raster <%s> não encontrado"
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#~ msgstr "Não consegui abrir o arquivo de células [%s]"
-#, fuzzy
-#~ msgid "Failed to guess file format"
-#~ msgstr "para site"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "Lendo arquivo dig_att...\n"
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "Você não está gerando nenhum arquivo raster ou vetorial"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#~ msgstr "%s=%s - nome ilegal"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#~ msgstr "Mostra os parâmetros de conexão atuais e finaliza"
-#, fuzzy
 #~ msgid "Unable to get current region"
 #~ msgstr "Não consegui atualizar região atual"
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgid "Cannot open database <%s> by driver <%s>"
 #~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
 #~ msgstr "Encontra a mediana dos valores num mapa com áreas designadas com o mesmo valor de categoria a partir de um mapa base especificado pelo usuário."
-#, fuzzy
 #~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr "Editar arquivo de categorias para [%s]?"
+#~ msgstr "Não consegui ler rótulos de categoria do mapa raster <%s>"
 #, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "Mapa(s) de entrada não especificado(s)."
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#, fuzzy
-#~ msgid "%s - color table not found"
-#~ msgstr "%s: %s - mapa raster não encontrado"
-#, fuzzy
-#~ msgid "Can't make random color table for floating point map"
-#~ msgstr "argumento val é necessário para mapas de ponto flutuante!"
-#, fuzzy
-#~ msgid "Can't make grey.eq color table for floating point map"
-#, fuzzy
-#~ msgid "Can't make logarithmic color table for floating point map"
-#, fuzzy
-#~ msgid "%s - unknown color request"
-#~ msgstr "%s - cor desconhecida\n"
-#, fuzzy
-#~ msgid "Starting map [%s]"
-#, fuzzy
-#~ msgid "Percent done:"
-#~ msgstr "Porcentagem completada: "
-#, fuzzy
 #~ msgid "Unable to read current window parameters"
 #, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#~ msgstr "Não consegui abrir os arquivos das bandas."
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#~ msgstr "Não consegui abrir o arquivo de assinatura de saída."
-#, fuzzy
-#~ msgid "SECTION %d beginning: Closing Maps."
-#~ msgstr "Fechando Mapas."
-#, fuzzy
-#~ msgid "SECTION %d beginning: Watershed determination."
-#~ msgstr ""
-#~ "\n"
-#~ "SEÇÃO %d iniciando: Determinação de divisores."
-#, fuzzy
-#~ msgid "problem w/ astar algorithm"
-#~ msgstr "algoritmo"
-#, fuzzy
-#~ msgid "Could not read range file"
-#~ msgstr "Não consegui ler arquivo de limite"
-#, fuzzy
-#~ msgid "Reading data: "
-#~ msgstr "Rotacionando dados ... "
-#, fuzzy
 #~ msgid "Rowio_setup failed"
 #~ msgstr "Cópia da tabela falhou"
@@ -35489,99 +38418,10 @@
 #~ msgid "Rowio_get failed"
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "Nome do mapa raster a ser usado para <%s>"
 #~ msgid "Elevation map not found"
 #~ msgstr "Mapa de elevação não encontrado"
 #, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "%-5d pontos lidos para a memória\n"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "%-5d centroides escritos en el archivo de salida.\n"
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#~ msgstr "Arquivo raster para importar"
-#, fuzzy
-#~ msgid "%d boundaries converted to lines"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#~ msgstr "%d pontos fora da região atual."
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot read field info"
-#~ msgstr "Não consegui ler campo info"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "Tipo de coluna não suportado"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Não consegui selecionar dados da tabela"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d records selected from table"
-#~ msgstr "%d registros selecionados da tabela"
-#, fuzzy
-#~ msgid "CrossCorrelation: No record for point (cat = %d)"
-#~ msgstr "Sem registros para a linha (cat = %d)"
-#~ msgid "CrossCorrelation: Mean = %.5lf\n"
-#~ msgstr "Correlação cruzada: Média = %.5lf\n"
-#, fuzzy
-#~ msgid "CrossCorrelation: lambda_i = %.3f\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Results are over.\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Resultados finais.\n"
-#, fuzzy
-#~ msgid "From type"
-#~ msgstr "Tipo desconhecido"
-#, fuzzy
-#~ msgid "From layer"
-#~ msgstr "Consultar"
-#, fuzzy
-#~ msgid "The column must be type integer or string"
-#~ msgstr "Nome da coluna (tipo deve ser numérico)"
-#, fuzzy
-#~ msgid "Select type"
-#~ msgstr "Tipo de feição"
-#, fuzzy
-#~ msgid "Cannot select records from database"
-#~ msgid "Cannot fetch data"
-#~ msgstr "Não consegui obter os dados"
-#, fuzzy
-#~ msgid "Calculating costs from centres..."
-#~ msgstr "Calculando médias das classes ..."
-#, fuzzy
 #~ msgid "vector, editing, digitization"
@@ -35599,22 +38439,6 @@
 #~ msgstr "Mapa não existe. Adicione a opção -n para criar um novo mapa"
 #, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgid "Input vector was not found."
-#~ msgstr "Vetor de entrada não foi encontrado."
-#~ msgid "Cannot open dig_cats file."
-#~ msgstr "Não consegui abrir arquivo dig_cats."
-#~ msgid "Cannot open database %s"
-#~ msgstr "Não consegui abrir o banco de dados %s"
-#~ msgid "Cannot insert into table: %s"
-#~ msgstr "Não consigo inserir na tabela: %s"
-#, fuzzy
 #~ msgid "%s: Unable to read font definition file; use the default"
 #~ msgstr "%s: Não consegui ler o arquivo de definição FreeType, usando padrão"
@@ -35623,63 +38447,6 @@
 #~ msgstr "%s: Nenhum arquivo de definição FreeType"
 #, fuzzy
-#~ msgid "Removed vertices: %5d"
-#~ msgstr "Removendo centróides duplicados ..."
-#, fuzzy
-#~ msgid "Removed vertices"
-#, fuzzy
-#~ msgid "Arc layer (network)"
-#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "Nome da camada a usar para MATIZ (HUE)"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "Camada de pesquisa. Usada pela opção 'query'."
-#, fuzzy
-#~ msgid "%d categories read from map"
-#~ msgstr "%d distâncias lidas do mapa."
-#, fuzzy
-#~ msgid "%d update/insert errors"
-#~ msgstr "%d atualizar erros"
-#~ msgid ""
-#~ "Operator defines required relation between features. A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined.\n"
-#~ "\t overlap: features partially or completely overlap"
-#~ msgstr ""
-#~ "O operador define relações requeridas entre feições. Uma feição é escrita para a saída se o resultaddo da operação 'entradaA operador entradaB' for verdadeiro. Uma feição de entrada pode ser considerada verdadeira se a categoria da camada estiver definida.\n"
-#~ "\tsopreposição: feições parcial ou completamente sobrepostas"
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "Processando linhas de entradaA ..."
-#, fuzzy
-#~ msgid "Processing ainput areas ..."
-#~ msgid "Writing attributes ..."
-#~ msgstr "Escrevendo atributos ..."
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "Não consegui encontrar o mapa vetorial de entrada <%s>"
-#, fuzzy
-#~ msgid "Elevation raster map <%s> does not cover the entire area of the input vector map <%s>. "
-#, fuzzy
 #~ msgid "Unable to read color file"
 #~ msgstr "Não consegui ler arquivo de cores."
@@ -35687,13 +38454,6 @@
 #~ msgid "Unable to read raster row"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condição 'where' opcional (sem a cláusula 'WHERE'), p.ex.:\n"
 #~ msgid "Illegal output file name"
 #~ msgstr "Nome ilegal do arquivo de saída"
@@ -35850,74 +38610,6 @@
 #~ msgstr "Texto para exibir"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Vetor mapear para exibir"
-#, fuzzy
-#~ msgid "Vector map type"
-#, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Camada para exibir"
-#, fuzzy
-#~ msgid "Icon size for point data (minimum icon size/line width for graduated points/lines)"
-#~ msgstr "Ícone ícone largura pontos"
-#, fuzzy
-#~ msgid "Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color."
-#~ msgstr "Cor área G Definir para."
-#, fuzzy
-#~ msgid "Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color."
-#, fuzzy
-#~ msgid "Apply regular expressions and wildcards to g.list"
-#~ msgstr "para"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "para padrão atual Pesquisa"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Caractere separador (padrão: tab)"
-#, fuzzy
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "para remover"
-#, fuzzy
-#~ msgid "3d raster to remove"
-#~ msgstr "Arquivo raster binário a importar"
-#, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "ícone para remover"
-#, fuzzy
-#~ msgid "Region to remove"
-#, fuzzy
-#~ msgid "Label to remove"
-#, fuzzy
-#~ msgid "3dview to remove"
-#, fuzzy
-#~ msgid "Group to remove"
-#, fuzzy
-#~ msgid "raster input maps"
-#, fuzzy
 #~ msgid "Use image list and not group"
 #~ msgstr "Uso imagem não"
@@ -35926,10 +38618,6 @@
 #~ msgstr "Seleção pontos"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Manter os números das bandas em vez de usar os nomes das cores"
-#, fuzzy
 #~ msgid "Calculate new raster map from a r.mapcalc expression."
 #~ msgstr "mapear"
@@ -35954,10 +38642,6 @@
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Separador de campo"
-#, fuzzy
 #~ msgid "Percentile to calculate (requires -e flag)"
 #~ msgstr "para calcular"
@@ -35998,10 +38682,6 @@
 #~ msgstr "de"
 #, fuzzy
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE and DATE)"
-#~ msgstr "Nome de tipos ativo banco de dados todos Suporte NÚM.INT"
-#, fuzzy
 #~ msgid "%s: [%s] not found"
@@ -36084,68 +38764,6 @@
 #~ msgstr "Não consegui abrir mapa raster [%s]."
 #, fuzzy
-#~ msgid "Memory allocation error"
-#~ msgstr "Memória"
-#, fuzzy
-#~ msgid "Saving new map"
-#, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "Mapa raster de saída"
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
-#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "mapa raster <%s> não encontrado"
-#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Não consegui abrir arquivo raster [%s]!"
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Não consegui abrir o arquivo %s"
-#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Não consegui alocar memória para 'string'"
-#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr "Erro lendo arquivo raster [%s]."
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#, fuzzy
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr "nível de em:"
-#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Erro na escrita do arquivo 'colr' para <%s>."
-#, fuzzy
-#~ msgid "All done."
-#~ msgstr "Todos."
-#, fuzzy
 #~ msgid "%s: base raster map not found"
 #~ msgstr "%s: <%s> mapa raster não encontrado"
@@ -36157,26 +38775,6 @@
 #~ msgid "%s: base map and output map must be different"
 #~ msgstr "mapear!"
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nome do arquivo vetor com dados de entrada"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Número de pontos de interpolação"
-#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "local do banco de dados"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nome do arquivo raster de elevação para entrada (metros)"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nome do raster de entrada"
 #~ msgid "Quietly"
 #~ msgstr "Silenciosamente"
@@ -36195,9 +38793,8 @@
 #~ msgid "Illegal output file name <%s>"
-#, fuzzy
 #~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "mapear!"
+#~ msgstr "Mapa base e mapa de saída <%s> devem ser diferentes"
 #~ msgid "Not enough memory for zero_array_cell"
 #~ msgstr "Memória insuficiente para zerro_array_cell"
@@ -36205,23 +38802,7 @@
 #~ msgid "Not enough disk space -- cannot write files"
 #~ msgstr "Espaço em disco insuficiente -- não posso escrever arquivos"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mapas raster de entrada"
-#~ msgid "Output file name"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: não consegui criar %s"
-#, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "Mapa raster [%s] existe no grupo."
-#, fuzzy
 #~ msgid "RGB raster map <%s> not found"
@@ -36331,7 +38912,7 @@
 #~ msgstr "** Apenas valores positivos, por favor!"
 #~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Qual arquivo raster precisa de histórico atualizado?"
+#~ msgstr "Qual mapa raster precisa de histórico atualizado?"
 #~ msgid "Raster file [%s] not found. Exiting."
 #~ msgstr "Arquivo Raster <%s> não encontrado. Saindo."
@@ -36412,11 +38993,11 @@
 #, fuzzy
 #~ msgid "Category file for <%s> not updated"
-#~ msgstr "Arquivo de categorias para [%s] não atualizado."
+#~ msgstr "Arquivo de categorias para <%s> não atualizado."
 #, fuzzy
 #~ msgid "Category file for <%s> updated"
-#~ msgstr "Arquivo de categorias para [%s] atualizado."
+#~ msgstr "Arquivo de categorias para <%s> atualizado."
 #~ msgid "Title, in quotes"
 #~ msgstr "Título, entre aspas"
@@ -36443,17 +39024,6 @@
 #~ msgid "Apply filter only to zero data values"
 #~ msgstr "Aplicar filtro somente para valores zerados"
-#, fuzzy
-#~ msgid "Error reading '%s' map"
-#~ msgstr "Erro lendo coringa."
-#, fuzzy
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "G"
-#~ msgid "Run verbosly"
-#~ msgstr "Executar verbosamente"
 #~ msgid "Run VERBOSELY"
@@ -36466,45 +39036,10 @@
 #~ msgstr "mapa vetorial <%s> não encontrado"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unidade de distância"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Não consegui executar: %s"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Não consegui abrir tabela %s"
-#~ msgid "DXF input file"
-#~ msgstr "Arquivo de entrada DXF"
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "Não consegui abrir o arquivo [%s]"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "%s: Novo arquivo vetorial não pode ser aberto"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr ""
-#~ "\n"
-#~ " Conversão de %s para mapa vetorial:  "
-#, fuzzy
 #~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgid "Create 3D file"
-#~ msgstr "Criar arquivo 3D"
 #, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "Não criar topologia (topology) no modo de pontos"
-#, fuzzy
 #~ msgid "Network input map <%s> not found"
@@ -36517,31 +39052,6 @@
 #~ msgid "Please answer yes or no"
 #~ msgstr "Por favor responda Sim ou Não"
-#, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Cor de realce para texto"
-#, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "Altura da linha: %f\n"
-#, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Memória insuficiente para alocação da estrutura de dados"
-#, fuzzy
-#~ msgid "imagery group"
-#~ msgid "imagery subgroup"
-#~ msgstr "Subgrupo de imagens"
-#~ msgid "output raster map"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "Extensão do arquivo de saída (arquivo(s) + extensão)"
 #~ msgid "name=%s\n"
 #~ msgstr "nome=%s\n"
@@ -36555,24 +39065,6 @@
 #~ msgstr "uso: %s arquivo [prompt %%x %%y]\n"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "%s: %s - nome ilegal para parte real\n"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "%s: %s - nome ilegal para parte imaginária\n"
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** Não consigo ler arquivo de assinatura <%s> **"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nome ilegal de arquivo com assinatura resultante"
-#, fuzzy
 #~ msgid "Illegal group name <%s>"
 #~ msgstr "Nome ilegal do arquivo de saída: '%s'"
@@ -36580,12 +39072,6 @@
 #~ msgid "Illegal signature file name <%s>"
 #~ msgstr "ATENÇÃO: nome de arquivo de assinatura ilegal <%s>."
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Arquivos raster para elevação"
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "Arquivos raster para cor"
 #~ msgid "Setting map window"
 #~ msgstr "Ajustando janela de mapa"
@@ -37005,2263 +39491,15 @@
 #~ msgid "The projection information will not be updated."
 #~ msgstr "não."
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Mapa raster para aproximar"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Guarda a região atual no arquivo de definições de região"
 #, fuzzy
 #~ msgid "<%s> is an illegal region name"
 #~ msgstr "<%s> - nome de região ilegal"
 #, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Opção Geo-Grid não disponível para projeção XY"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "Não consegui abrir arquivo vetorial <%s>"
-#, fuzzy
-#~ msgid "No such monitor as '%s'"
-#~ msgstr "[%s]: cor não existe"
-#, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Os seguintes arquivos raster no subgrupo [%s] não existem:"
-#~ msgid "       %s"
-#~ msgstr "       %s"
-#~ msgid "Removing files from group"
-#~ msgstr "Removendo arquivos do grupo"
-#, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Adicionando arquivos ao subgrupo [%s]"
-#~ msgid "Adding files to subgroup [%s]"
-#~ msgid "Writing group REF"
-#~ msgstr "Escrevendo grupo REF"
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Escrevendo subgrupo REF"
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Arquivo %s@%s encontrado no grupo."
-#, fuzzy
-#~ msgid "Found file <%s@%s> in subgroup."
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr ""
-#~ "Projeção dos dados de entrada e locação atual parecem combinar.\n"
-#~ "Continuando com a importação...\n"
-#, fuzzy
 #~ msgid "not found\n"
 #, fuzzy
-#~ msgid "%s: percent complete: "
-#, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "Mapa raster [%s] não encontrado"
-#, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "Não foi possível escrever na <%s>.."
-#, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Não consegui criar a tabela %s"
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Não consegui ler de <%s>"
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "Não consegui abrir arquivo ASCII [%s]"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#, fuzzy
-#~ msgid "If 'list', 'file' and 'where' options are not specified, all features of given type and layer are extracted. Categories are not changed in that case."
-#~ msgstr "Seleciona objetos vetoriais a partir de um mapa vetorial existente e cria um novo mapa contendo apenas os objetos selecionados. Se as opções 'list', 'file' e 'where' não forem especificadas, todas as feições de uma camada e tipo fornecidos serão extraídos, neste caso as categorias não são alteradas."
-#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Sem conexão ao banco de dados."
-#, fuzzy
-#~ msgid "Load categories from the database (table = %s, db = %s)."
-#~ msgstr "Carregas cats do banco de dados (tabela=%s, bd=%s).\n"
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d categorias carregadas da tabela\n"
-#~ msgid "Cannot create layer"
-#~ msgstr "Não consegui criar camada"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Arquivo de vetores [%s] não está disponível"
-#, fuzzy
-#~ msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-#~ msgstr "Carregar valores do vetor para o banco de dados. Nos valores de categoria carregados/impressos, '-1' é usado para 'sem categoria' e 'null'/'-' se a categoria não for encontrada ou múltiplas categorias forem encontradas"
-#, fuzzy
-#~ msgid "Column type [%d] not supported"
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "Mostra contagem de células"
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Criando arquivos de suporte para [%s]."
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "%s: <%s> mapa raster não encontrado"
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "%s: <%s> mapa raster já existe"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#, fuzzy
-#~ msgid "%s - map not found"
-#, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "[%s] não encontrado."
-#, fuzzy
-#~ msgid "Could not access %s layer"
-#, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "mapa vetorial <%s> não encontrado"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Mapa raster contendo dados de elevação"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Nome do mapa raster para guardar os resultados"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altura do local de visada"
-#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "Arquivo de células [%s] não encontrado\n"
-#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "Arquivo de células [%s] não encontrado"
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgid "raster map <%s> not found"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "não consegui ler cabeçalho para <%s> em <%s>"
-#, fuzzy
-#~ msgid "region <%s> not found"
-#~ msgstr "região <%s> não encontrada"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "Não consegui ler região <%s> em <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "Não consegui abrir arquivo 3dview  <%s> em <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "Não consegui ler arquivo 3dview <%s> em <%s>"
-#, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "Não consegui abrir mapa raster [%s]."
-#~ msgid "invalid region: %s"
-#~ msgstr "região inválida: %s"
-#, fuzzy
-#~ msgid "Creating support files"
-#~ msgid "can't open %s"
-#~ msgstr "não consegui abrir %s"
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "%s arquivo [%s] não encontrado!"
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "não consegui abrir <%s>"
-#, fuzzy
-#~ msgid "%s - not found"
-#, fuzzy
-#~ msgid "Cannot read %s"
-#, fuzzy
-#~ msgid "map layer [%s] not legal for GRASS"
-#~ msgstr "mapear não"
-#, fuzzy
-#~ msgid "[%s] map not found."
-#, fuzzy
-#~ msgid "[%s] map not found"
-#, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr "mín. orientação calculada %.4f  máx. orientação calculada %.4f"
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "mín. declividade calculada %.4f  máx. declividade calculada %.4f"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Não consegui descrever a tabela %s"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s foi fornecido um número ilegal de pontos [%d]"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "Nenhuma conexão a banco de dados foi definida. Execute db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Não consegui encontrar entrada %s"
-#~ msgid "Could not open input"
-#~ msgstr "Não consegui abrir entrada"
-#~ msgid "Could not open output"
-#~ msgstr "Não consegui abrir saída"
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "Não consegui encontrar o mapa de entrada <%s>"
-#~ msgid "Unkown item type in pad: %s"
-#~ msgstr "Tipo desconhecido no bloco: %s"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "Conexão com banco de dados não definida\n"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "Não consegui ler cabeçalho para raster 3D <%s> em <%s>"
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "não consegui escrever região <%s>"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** entrada inválida **"
-#~ msgid "No graphics device selected."
-#~ msgstr "Nenhum dispositivo gráfico selecionado."
-#~ msgid "Unable to read raster row."
-#~ msgstr "Não consegui ler arquivo raster agora."
-#~ msgid "Training map [%s] not found."
-#~ msgstr "Mapa de treinamento <%s> não encontrado"
-#, fuzzy
-#~ msgid "%s map not found"
-#, fuzzy
-#~ msgid "input raster map"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "nome de arquivo ilegal [%s]."
-#, fuzzy
-#~ msgid "Condition for update (everything after the 'where' sql statement; ex: cat=1 or col1/col2>1)"
-#~ msgstr "após instrução"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Não consegui obter informações de camada para o mapa vetorial"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
-#~ msgid "%s: %s - raster map not found"
-#~ msgid "%s: %s - illegal name"
-#~ msgstr "%s: %s - nome ilegal"
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "%s: ERRO lendo arquivo de categorias para %s"
-#, fuzzy
-#~ msgid "%s: %s - not found"
-#, fuzzy
-#~ msgid "%s: %s - illegal units"
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: ERRO executando comando %s"
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "%s: %s em %s - não consegui ler arquivo de categoria"
-#, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "Escrevendo arquivo raster %i\n"
-#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
-#, fuzzy
-#~ msgid "%s - ERROR writing %s"
-#, fuzzy
-#~ msgid "Reading raster map... "
-#, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "Escrevendo novo arquivo...\n"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Lista de categorias: p.ex.: 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#, fuzzy
-#~ msgid "Cannot find file %s"
-#, fuzzy
-#~ msgid "Cannot get header for %s"
-#, fuzzy
-#~ msgid "Cannot create raster map %s"
-#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Número de linhas para manter na memória"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Imprime apenas o tipo do mapa raster"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Tipo desconhecido: %c"
-#~ msgid "Cannot open raster map [%s]"
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "Não consegui abrir mapa raster"
-#, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Não consegui ler raster"
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Não consegui criar árvore"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
-#, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "Fonte"
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#, fuzzy
-#~ msgid "Reading raster map"
-#, fuzzy
-#~ msgid "Cannot open output map."
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#~ msgstr "Nome ilegal do arquivo de saída"
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#, fuzzy
-#~ msgid "memory allocation failure"
-#, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "Não consegui listar os bancos de dados."
-#, fuzzy
-#~ msgid "Can't find clump map."
-#~ msgstr "Não encontrei mapa de células de entrada."
-#, fuzzy
-#~ msgid "Output terrain only vector map name"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#~ msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Anexando categorias...\n"
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Número mínimo de pixels numa classe"
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Não consegui abrir cursor de seleção"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Não consegui obter informações sobre a ligação ao BD"
-#~ msgid "cell file [%s] not found"
-#~ msgid "can't open raster map [%s]"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Não consegui criar índice"
-#, fuzzy
-#~ msgid "For tool 'add', see also 'thresh' parameter"
-#~ msgstr "Não copiar tabela (veja também o parâmetro 'new')"
-#, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "não consegui atualizar limites"
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgid "No layer database connection."
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d linhas mortas ignoradas\n"
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgid "Print vector map region only"
-#~ msgstr "Imprime apenas a região do mapa vetorial"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgid "Cannot select attribute."
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "criando novo arquivo cats ..."
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Não consegui encontrar o arquivo vetorial %s"
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-#, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d pontos escritos no vetor"
-#, fuzzy
-#~ msgid "Parameter <%s> not set"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#, fuzzy
-#~ msgid "Cannot get layer information for vector map"
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "<%s>: arquivo de células não encontrado"
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Não consegui abrir mapa vetorial <%s>"
-#~ msgid "No table."
-#~ msgstr "Sem tabela"
-#~ msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nome do driver"
-#~ msgid "Driver name"
-#~ msgstr "Nome do Driver"
-#~ msgid "Cannot list databases."
-#~ msgid "database location"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nome da tabela, selecionar tudo desta tabela"
-#~ msgid "output field separator"
-#~ msgstr "delimitador de campo na saída"
-#~ msgid "output vertical record separator"
-#~ msgstr "delimitador vertical de registro na saída"
-#~ msgid "null value indicator"
-#~ msgstr "indicador de valor nulo"
-#~ msgid "do not include column names in output"
-#~ msgstr "não incluir nomes das colunas na saída"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "saída vertical (ao invés de horizontal)"
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Não encontrei mapset para %s"
-#~ msgid "Cannot open File %s"
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "Não consegui abrir o arquivo para [%s]"
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Arquivo de rótulos [%s] não disponível"
-#~ msgid "Can't open label file [%s]"
-#~ msgstr "Não consegui abrir arquivo de rótulos [%s]"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgid "Unable to open raster map [%s] in [%s]"
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to create output <%s>"
-#~ msgid "Input file [%s] not found."
-#~ msgstr "Arquivo de entrada [%s] não encontrado."
-#~ msgid "Unable to open output file <%s>."
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "Multiplicador para dados ASCII"
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-#, fuzzy
-#~ msgid "unable to create raster"
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgid "Table name"
-#~ msgstr "Nome da Tabela"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Mostra parâmetros da conexão atual e sai (estilo shell script)\n"
-#~ "\tformato:  camada[/nome da camada] tabela chave driver_do_banco_de_dados"
-#~ msgid "x column name"
-#~ msgstr "Nome da coluna x"
-#~ msgid "z column name"
-#~ msgstr "Nome da coluna z"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#, fuzzy
-#~ msgid "Cannot fetch data from table"
-#, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "Nome do banco de dados OGR. Exemplos:\n"
-#~ "\t\tShapefile ESRI: diretório contendo shapefiles\n"
-#~ "\t\tArquivo MapInfo: diretório contendo arquivos mapinfo"
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Verificando pontos vetoriais ..."
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-#, fuzzy
-#~ msgid "no record for cat = %d"
-#~ msgstr "Sem registros para cat = %d"
-#, fuzzy
-#~ msgid "cannot insert row: %s"
-#~ msgstr "Não consegui inserir nova linha: %s"
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#, fuzzy
-#~ msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr "Conexão com banco de dados não definida para a camada <%d>. Execute v.db.connect."
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Transforma uma camada de mapa vetorial de um sistema de coordenadas em outro sistema de coordenadas."
-#, fuzzy
-#~ msgid "ASCII file holding transform coordinates (if not given transformation options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be used instead)"
-#~ msgstr "Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ao invés dos pontos"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Não consegui obter informações do driver '%s'."
-#~ msgid "Cannot describe table"
-#~ msgstr "Não consegui descrever a tabela"
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Não consegui iniciar o driver <%s>."
-#, fuzzy
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] é um nome ilegal"
-#~ msgid "Cannot write to <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
-#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "Arquivo raster [%s] não disponível"
-#~ msgid "Raster file [%s] not available"
-#~ msgid "Raster map [%s] not found"
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#~ msgid "Vector file [%s] not available"
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Não consegui abrir o driver %s"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Memória Esgotada! (Out of Memory) \n"
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "%s: %s - Impossível abrir o mapa raster de entrada\n"
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#~ msgid "%s: %s - illegal name for output raster map."
-#~ msgstr "%s: %s - Nome ilegal para arquivo raster de saída"
-#~ msgid "Insufficent memory for allocation of data structure."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "Exporta um raster do GRASS para um arquivo binário"
-#~ msgid "Couldn't find raster map %s"
-#~ msgstr "Não consegui encontrar o arquivo raster %s"
-#, fuzzy
-#~ msgid "%s: <%s> not found"
-#, fuzzy
-#~ msgid "%s: <%s> illegal name"
-#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
-#, fuzzy
-#~ msgid "CREATING SUPPORT FILES ..."
-#~ msgstr "CRIANDO ARQUIVOS DE SUPORTE"
-#, fuzzy
-#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "é não mapear"
-#~ msgid "Cannot find %s"
-#~ msgid "could not read range file"
-#~ msgid "Unable to create raster map [%s]."
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#~ msgstr "Não consegui abrir mapa raster [%s] em [%s]"
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "Abrir arquivo 3Draster %s"
-#, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "Não consegui abrir arquivo temp %s"
-#, fuzzy
-#~ msgid "Writing [%s]"
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "Não consegui abrir arquivo de rótulos <%s> no mapset <%s>"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Converte um arquivo raster do GRASS numa imagem PPM com a resolução da região atualmente definida."
-#~ msgid "Mapset of input map"
-#~ msgstr "Mapset do mapa de entrada"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "Mapa raster de entrada"
-#, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "Erro tentando ler o arquivo dbmscap\n"
-#, fuzzy
-#~ msgid "<%s> is illegal file name"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#, fuzzy
-#~ msgid "no rules specified"
-#, fuzzy
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "Não consegui abrir arquivo temporário [%s]"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "Nomes dos mapas raster existentes"
-#, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr "Não consegui abrir arquivo de entrada <%s@%s>."
-#, fuzzy
-#~ msgid "%s - illegal name "
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-#, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "%s: ERRO não consegui abrir tempfile"
-#, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgid "%s=%s - illegal name"
-#~ msgid "%s: can't create %s"
-#~ msgid "Normalized"
-#~ msgstr "Normalizado"
-#, fuzzy
-#~ msgid "Out of memory!"
-#~ msgstr "Memória Esgotada! (Out of Memory)"
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#, fuzzy
-#~ msgid "Can't read current window parameters"
-#, fuzzy
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr "Erro"
-#, fuzzy
-#~ msgid "[%s] file name not legal"
-#, fuzzy
-#~ msgid "[%s] file name not legal\n"
-#, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "Arquivo g3d solicitado não foi encontrado"
-#, fuzzy
-#~ msgid "Could not open output map"
-#~ msgid "unable to close output map"
-#~ msgstr "Não consegui fechar arquivo de saída."
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "Não consegui criar o mapa de saída [%s]"
-#, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "Conexão com banco de dados não definida"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#, fuzzy
-#~ msgid "Interpolation: No database connection for driver <%s> defined. Run db.connect"
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr "Arquivo de vetores [%s] não está disponível na lista de busca"
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "Não consegui abrir o banco de dados <%s>"
-#~ msgid "Cannot open table <%s>"
-#, fuzzy
-#~ msgid "Cannot open driver <%s>"
-#~ msgid ""
-#~ "OGR layer name. If not given, all available layers are imported. Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "Nome da camada OGR. Se não fornecida, todas as camadas serão importadas. Exemplos:\n"
-#~ "\t\tShapefile ESRI: nome do shapefile\n"
-#~ "\t\tArquivo MapInfo: nome do arquivo mapinfo"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "O vetor '%s' já existe."
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "Não consegui encontrar o mapa de entrada '%s'."
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "Não consegui encontrar o mapa de entrada da rede '%s'."
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Erro abrindo arquivo raster [%s]."
-#, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "Camada '%s' não disponível"
-#~ msgid "Cannot describe table %s"
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "    Remendando arquivo %s"
-#, fuzzy
-#~ msgid "[%d] files patched"
-#, fuzzy
-#~ msgid "Column type  not supported"
-#~ msgid "Could not open vector map <%s>"
-#~ msgid "Name of output raster map"
-#~ msgstr "Nome do Raster de saída"
-#~ msgid "Done          "
-#~ msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
-#, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "classe %d (%d)\n"
-#~ msgid "Illegal output name: '%s'"
-#~ msgstr "Nome ilegal do arquivo de saída: '%s'"
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "Não consegui fechar o novo mapa g3d"
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "%s: arquivo de células [%s] não encontrado."
-#~ msgid "Unable to open cellfile [%s]."
-#~ msgid "Error reading wildcard."
-#~ msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Seleciona a cor da malha, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
-#~ msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "Seleciona a cor da borda, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr "Borda ainda não implementada para locações Lat/Long: borda não desenhada"
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Não consegui abrir o arquivo temporário."
-#~ msgid "Unable to open raster map [%s]."
-#~ msgid "Unable to find raster [%s]."
-#~ msgstr "Não encontrei arquivo raster [%s]."
-#, fuzzy
-#~ msgid "use regular expression instead of wildcard"
-#~ msgstr "de"
-#, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "Nome do novo arquivo raster."
-#, fuzzy
-#~ msgid "Output GRASS image file"
-#~ msgstr "Arquivo KeyFrame de saída"
-#, fuzzy
-#~ msgid "Resulting output grid3D volume"
-#~ msgstr "Resolução do mapa de saída"
-#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nome para novo arquivo PPM. (use out=- para saída padrão)"
-#, fuzzy
-#~ msgid "Input vector map"
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgid "vector map <%s> not found"
-#, fuzzy
-#~ msgid "unable to find raster map [%s]"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"color\" specified - ignoring color"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
-#~ msgstr "Um de!"
-#, fuzzy
-#~ msgid "<%s> raster map not found"
-#, fuzzy
-#~ msgid "<%s> unable to open raster map"
-#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#, fuzzy
-#~ msgid "%s - can't open raster map"
-#, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
-#~ msgstr "texto representando célula sem valores de dado"
-#, fuzzy
-#~ msgid "File name of classification result"
-#~ msgid "File name of reference classes"
-#~ msgstr "Nome do arquivo para as classes de referência"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "relatório largo, 132 colunas (padrão: 80)"
-#~ msgid "quiet"
-#~ msgstr "silencioso"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "%s: <%s> mapa de referência não encontrado"
-#~ msgid "Base raster map"
-#~ msgstr "Mapa raster base"
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgid "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr "Mapa raster que representa a elevação, usado para informação 3D"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "Erro abrindo arquivo [%s]"
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#, fuzzy
-#~ msgid "%s: can't open tempfile"
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
-#~ msgstr "Mapa de elevação"
-#~ msgid "Output verbosely"
-#~ msgstr "Saída verbosa"
-#, fuzzy
-#~ msgid "Can't open raster map %s"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "PRODUTOS DE ELEVAÇÃO para o mapset [%s] em [%s]"
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-#~ msgstr "não consegui encontrar o mapa de entrada <%s>"
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "Intervalo de categorias: p.ex.: 1,3-8,13"
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Escrevendo atributos ...\n"
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgid "List available formats and exit"
-#~ msgstr "Lista formatos disponíveis e finaliza"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#, fuzzy
-#~ msgid "SVG output file"
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Não consegui encontrar o arquivo vetorial '%s'"
-#~ msgid "Could not find vector map %s"
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgid "driver name:"
-#~ msgstr "nome do driver:"
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Não consegui alocar memória."
-#, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "Não consegui abrir arquivo de saída."
-#, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d raster%s, %d vetor%s\n"
-#, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr "Inteiro célula."
-#, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr "célula."
-#, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr "Duplo célula."
-#~ msgid "Raster output file"
-#~ msgstr "Arquivo raster de saída"
-#, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-#, fuzzy
-#~ msgid "Writing raster map ... "
-#, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "Modo verboso"
-#, fuzzy
-#~ msgid ""
-#~ "Unexpected data in vector head:\n"
-#~ "%s"
-#~ msgid "Keep existing color table"
-#~ msgstr "Manter a tabela de cores existente"
-#~ msgid "List rules"
-#~ msgstr "Lista de regras"
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "Palavra desconhecia [%s] no cabeçalho do vetor."
-#~ msgid "Can't open temp file %s"
-#, fuzzy
-#~ msgid "Organization where raster map was created"
-#~ msgstr "Nome do mapa raster para ser reescalonado"
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#~ msgstr "Não consegui criar arquivo raster [%s]."
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#, fuzzy
-#~ msgid "verbose mode"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "Não criar tabela de atributo."
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr "Nome do mapa de pontos vetorias para editar a tabela de atributos"
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nome de um mapa raster para exibir"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
-#~ msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
-#~ msgid "could not find input map <%s>"
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "não consegui abrir o arquivo de células [%s]"
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "não consegui obter informações de camada para o mapa vetorial"
-#~ msgid "cannot open database %s by driver %s"
-#~ msgstr "não conseguir abrir banco de dados %s com driver %s"
-#~ msgid "cannot select data from table"
-#~ msgstr "não consegui selecionar dados da tabela"
-#~ msgid "cannot create table: %s"
-#~ msgstr "não consegui criar a tabela: %s"
-#~ msgid "cannot create index"
-#~ msgstr "não consegui criar índice"
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "não posso dar privilégios na tabela %s"
-#, fuzzy
-#~ msgid "column type  not supported"
-#~ msgid "Cannot find vector map"
-#~ msgstr "Não consegui encontrar mapa vetorial"
-#~ msgid "Cannot find raster map"
-#~ msgstr "Não encontrei mapa raster"
-#~ msgid "Cannot open raster map"
-#~ msgid "#%s"
-#~ msgstr "#%s"
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "Erro na leitura do mapa raster de entrada."
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Erro na remoção do antigo mapa de células MASK."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "Não consegui abrir mapa de células<%s> para entrada.\n"
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#~ msgstr "Não consegui abrir mapa de células <%s> para saída.\n"
-#, fuzzy
-#~ msgid "Unable to read map raster row %d"
-#, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Não consegui ler arquivo de cores."
-#, fuzzy
-#~ msgid "Cannot find map %s"
-#~ msgstr "Não encontrei %s"
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nome arquivo de regras predefinidas"
-#, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "** atenção: valor(es) R:G:B está(ão) fora dos limites [0..255]: %d:%d:%d **\n"
-#, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr "** atenção: valor(es) R G B está(ão) fora dos limites [0..255]: %d %d %d **\n"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** atenção: o valor não existe **\n"
-#, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:linha %d:%s\n"
-#, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** Especificação de cor incorreta **\n"
-#, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Cores válidas são:\n"
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "Não conseguir abrir banco de dados %s com driver %s"
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#~ msgid "Unable to find [%s]."
-#~ msgstr "Não consegui encontrar [%s]"
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "Não consegui abrir mapa %s\n"
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "Coordenadas de tela para posicionar a legenda (porcentagem)"
-#~ msgid "Font name (not supported interactively, see also -l flag) or path to TrueType font (including file name)"
-#~ msgstr "Nome da fonte (não interativo, ver a opção '-l') ou caminho para a fonte TrueType (incluindo nome do arquivo)"
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "Erro na leitura do arquivo de categorias para <%s>."
-#, fuzzy
-#~ msgid "Error reading categories: <%s>"
-#, fuzzy
-#~ msgid "No lines found"
-#~ msgstr ""
-#~ "\n"
-#~ "Nenhuma camada DXF encontrada!\n"
-#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "Selecione tipo: linha ou área"
-#, fuzzy
-#~ msgid "Assign cats to boundaries too"
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "Não consegui encontrar o mapa vetorial de entrada %s"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "Falha abrindo arquivo dig de entrada."
-#~ msgid "Do not create attribute table."
-#~ msgid "Could not find input %s\n"
-#~ msgstr "Não consegui encontrar a entrada %s\n"
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid "List vector maps in input location and exit (a dummy value must be given for input)"
-#~ msgstr "Mostra os arquivos raster na locação de entrada e encerra"
-#~ msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
-#~ msgstr "Permite ao usuário pesquisar um mapa vetorial interativamente em locais selecionados pelo usuário dentro da região geográfica atual."
-#, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "                Mapa Atual                  Novo Mapa\n"
-#, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr ""
-#~ "                          VERIFICAÇÃO DOS ERROS NO MAPA\n"
-#~ "\n"
-#, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr ""
-#~ "\n"
-#~ msgid "Patch complete. %d files patched."
-#~ msgstr "Remendo completp. %d arquivos remendados."
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "%s: <%s> mapa vetor não encontrado"
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "Correlação"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "Ajustando janela de mapa"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "Método de intepolação a usar"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgid "Subgroup [%s] doesn't have any files."
-#~ msgstr "Subgrupo [%s] não possui nenhum arquivo"
-#~ msgid "Subgroup [%s] only has 1 file."
-#~ msgstr "Subgrupo [%s] só contém 1 arquivo"
-#, fuzzy
-#~ msgid "%s -- illegal output file name"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr "mapear."
-#~ msgid "%s: %s in %s - can't read category file"
-#, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "Número de iterações máximas"
-#~ msgid "Finished.\n"
-#~ msgstr "Concluído.\n"
-#, fuzzy
-#~ msgid "Existing raster map name"
-#~ msgstr "Nome de um arquivo raster existente"
-#, fuzzy
-#~ msgid "%s - can't read raster cellhd"
-#, fuzzy
-#~ msgid "error reading cell data"
-#, fuzzy
-#~ msgid "Done!"
-#~ msgstr "Concluído."
-#, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Não encontrado.\n"
-#, fuzzy
-#~ msgid "Nothing Found."
-#, fuzzy
-#~ msgid "Do not build topology."
-#, fuzzy
-#~ msgid "No features found"
-#~ msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgstr "Arquivo vetorial para criar"
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "%s: Arquivo dxf não pode ser aberto"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr ""
-#~ "\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr "é de"
-#, fuzzy
-#~ msgid "%s: - no such database %s\n"
-#, fuzzy
-#~ msgid "must be even number of names"
-#~ msgstr "de"
-#, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Não consegui abrir a caixa de ferramentas: %s"
-#~ msgid "Cannot open toolbox."
-#~ msgstr "Não consegui abrir a caixa de ferramentas"
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "Não consegui encontrar o mapa de entrada <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s' concluiu a transformação dos vetores.\n"
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ msgid "                Current Map                  New Map\n"
-#~ msgid " POINT      X coord    Y coord  |        X coord   Y coord    |      residuals\n"
-#~ msgstr "Ponto      coord X   coordY |       coord X   coord Y    |      resíduos\n"
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "  Erro médio   : %f\n"
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "Mapa vetorial -- fonte para composição"
-#~ msgid "New vector composite"
-#~ msgstr "Novo vetor composto"
-#~ msgid "Append files to existing file"
-#~ msgstr "Adicionar arquivos a um arquivo existente"
-#, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "banco de dados"
-#, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "mapa vetorial '%s' não encontrado"
-#, fuzzy
-#~ msgid "Input aspect file"
-#~ msgstr "Nome do arquivo de saída de direção da encosta"
-#, fuzzy
-#~ msgid "Input barrier file"
-#~ msgstr "Arquivo de entrada"
-#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "Agregar"
-#, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "Posição de referência"
-#, fuzzy
-#~ msgid "Aspect file's resolution differs from                        current region resolution"
-#~ msgstr "atual"
-#, fuzzy
-#~ msgid "%s\n"
-#~ msgstr " %s\n"
-#, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Resolução"
-#, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "Nome do arquivo de saída"
-#~ msgid "Hit RETURN -->"
-#~ msgstr "Pressione RETURN -->"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr ""
-#~ "\a\n"
-#~ "** A seguinte arquivo de células do subgrupo [%s] não existe."
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr "O subgrupo deve possuir pelo menos 2 arquivos para executar %s."
-#~ msgid ""
-#~ "\n"
-#~ "If you continue the mask will be removed."
-#~ msgstr ""
-#~ "\n"
-#~ "Se continuar a máscara será removida."
-#~ msgid "Did not find input cell map."
-#~ msgid "Imagery files subgroup"
-#~ msgstr "Subgrupo de arquivos de imagem"
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "ATENÇÃO: nome de grupo ilegal <%s>."
-#~ msgid "Warning: illegal output file name <%s>."
-#~ msgstr "ATENÇÃO: nome de arquivo de saída ilegal <%s>."
-#~ msgid "An output cell map name is required."
-#~ msgstr "Um nome de mapa de células de saída é necessário."
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr "Nome do mapa de células de saída não pode ser maior que 12 letras."
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: de  M: a R: sair\n"
-#~ msgid "Category <%d>: Area fill color and background color are the same!"
-#~ msgstr "Categoria <%d>: Cor de preenchimento e fundo são iguais!"
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "CAtegoria <%d>: Cor da linha e do fundo são iguai"
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "Cor da linha e do fundo são iguais!"
-#~ msgid "Area fill color and background color are the same!"
-#~ msgstr "Cor de preenchimento e do fundo são iguais!"
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "Data, data1/data2, ou nenhum"
-#, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr "G3dToRaster: Escrevendo %i mapas raster com linhas %i colunas."
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Concluído\n"
-#, fuzzy
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "Escrevendo DadoImagem VTK"
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-#, fuzzy
-#~ msgid "Open 3d raster map %s"
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
-#~ msgstr ""
-#~ "Nome do banco de dados OGR.\n"
-#~ msgid "Name of vector output file"
-#~ msgstr "Nome do arquivo vetor de saída"
-#~ msgid "Vector import complete"
-#~ msgstr "Inportação de vetor incompleta"
-#, fuzzy
-#~ msgid "Required parameter <points> not set"
-#~ msgstr "signature: pontos do perímetro fora de ordem."
-#, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "Você precisa inserir ao menos %d pontos."
-#, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#, fuzzy
-#~ msgid "Unknown GIS formats"
-#~ msgstr "Carimbo de hora desconhecido"
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Não consegui criar arquivo [%s]"
-#, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr "RasterToG3D: Escrevendo %i mapas raster com linhas %i colunas."
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "Escrevendo fatia g3d %i\n"
-#~ msgid "error opening 3d raster map"
-#~ msgstr "Erro abrindo arquivo g3d"
-#~ msgid "Done\n"
-#~ msgstr "Concluído\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "Ler mapas fp como inteiros (usar regras de quantização do mapa)"
-#~ msgid "Name for the resulting raster map"
-#~ msgstr "Nome para o mapa raster resultante"
-#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "Abrir arquivo raster %s"
-#, fuzzy
-#~ msgid "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and count %i."
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "Gera mapa raster de elevação"
-#~ msgid "Could not open map %s\n"
-#, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "Flag -i e/ou parâmetro de trajeto devem ser usado"
-#~ msgid "Bin raster map to be imported"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "Gera derivadas parciais em vez"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "O tamanho da região é menor que minreg, nada a exibir.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr "O tamanho da região é maior que maxreg, nada a exibir.\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Desenhar malha geográfica"
-#, fuzzy
-#~ msgid "convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
-#~ msgstr "todos para em atual"
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "Query layer"
-#~ msgstr "Consultar"
-#, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "Nome da coluna y"
-#, fuzzy
-#~ msgid "Save graphic legend output in tlegend.txt file for d.graph display in GIS Manager"
-#~ msgstr "Salvar em gráfico exibir em Gerente"
-#~ msgid "No output maps"
-#~ msgstr "Sem mapas de saída"
-#~ msgid "any,grid3,3d raster"
-#~ msgstr "qualquer, grid3, raster 3d"
-#~ msgid "Name for G3d raster map"
-#~ msgstr "Nome do mapa raster G3d"
-#, fuzzy
-#~ msgid "output 3d raster map which will be filled with the 2D raster slices"
-#~ msgstr "Saída de mapa 3dcell que será preenchido com as fatias raster 2D"
-#, fuzzy
-#~ msgid "CREATING SUPPORT FILES FOR %s"
-#, fuzzy
-#~ msgid "done."
-#~ msgid "GRASS module to create a fractal surface of a given fractal dimension. Uses spectral synthesis method. Can create intermediate layers showing the build up of different spectral coefficients (see Saupe, pp.106-107 for an example of this). Use this module to generate naturally looking synthetical elevation models (DEM)."
-#~ msgstr "Módulo GRASS para calcular uma superfície fractal com as dimensões dadas. Usa o método da síntese espectral. Pode criar camadas intermediárias mostrando a acumulação dos diferentes coeficientes espectrais (veja Saupe, pp.106-107 para um exemplo) Use esse método para gerar modelos de elevação (DEM) sintéticos com aparência natural."
-#~ msgid "Quiet mode"
-#~ msgstr "Modo silencioso"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete: "
-#~ msgstr "Pesquisar Por cento "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION %d: Closing Maps."
-#~ msgstr "Fechando Mapas."
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 3: Accumulating Surface Flow.       Percent complete: "
-#~ msgstr "Por cento "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete:"
-#~ msgstr "Pesquisar Por cento:"
-#, fuzzy
-#~ msgid "    segments in row:\t%d"
-#~ msgstr "em"
-#, fuzzy
-#~ msgid "segments in columns:\t%d"
-#~ msgstr "em"
-#~ msgid "     total segments:\t%d"
-#~ msgstr "     total de segmentos:\t%d"
-#~ msgid "      open segments:\t%d"
-#~ msgstr "      segmentos abertos:\t%d"
-#, fuzzy
-#~ msgid "Running: %s"
-#~ msgstr "Executando"
-#, fuzzy
-#~ msgid "Print the input data extent in shell script style"
-#~ msgstr "Mostra as estatísticas em estilo shell script"
-#~ msgid "Maximum distance"
-#~ msgstr "Distância máxima"
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "Não reconstruir e armazenar a topologia ao final"
-#, fuzzy
 #~ msgid "display, export"
 #~ msgstr "Exibir"
@@ -39277,13 +39515,12 @@
 #~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#, fuzzy
 #~ msgid "Base raster map <%s> not found"
+#~ msgstr "Mapa raster base <%s> não encontrado"
 #, fuzzy
 #~ msgid "Color table for <%s> updated"
-#~ msgstr "Arquivo de cores para [%s] atualizado."
+#~ msgstr "Arquivo de cores para <%s> atualizado."
 #~ msgid "Error reading raster map [%s]."
@@ -39316,10 +39553,6 @@
 #~ msgstr "Fonte"
 #, fuzzy
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "Não consegui abrir o arquivo de células [%s]"
-#, fuzzy
 #~ msgid "No attribute table found"
 #~ msgstr "Coluna(s) de atributo(s)"
@@ -39390,14 +39623,6 @@
 #~ msgstr "Grupo <%s> não encontrado."
 #, fuzzy
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "Não pontos"
-#, fuzzy
-#~ msgid "No active psuedo control points"
-#, fuzzy
 #~ msgid "Interactively select or modify the imagery group target."
 #~ msgstr "Selecionar trajeto interativamente"
@@ -39430,9 +39655,8 @@
 #~ msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
 #~ msgstr "Converte um arquivo texto raster ASCII 3D para uma camada de mapa raster 3D (binário)."
-#, fuzzy
 #~ msgid "Recharge raster map in m^3/s"
-#~ msgstr "Lendo arquivo dig_att...\n"
+#~ msgstr "Recarregar o mapa raster em m^3/s"
 #~ msgid ""
 #~ "Cannot create mask file: G3D_MASK already exists!\n"
@@ -39447,9 +39671,8 @@
 #~ msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
 #~ msgstr "Exporta mapa raster do GRASS para arquivo GRIDATB.FOR (TOPMODEL)"
-#, fuzzy
 #~ msgid "Name of base raster map"
-#~ msgstr "Nome do mapa raster"
+#~ msgstr "Nome do mapa raster base"
 #~ msgid "Converts a raster map layer into a height-field file for POVRAY."
 #~ msgstr "Converte uma camada raster num campo de altura (height field) para o POVRAY."
@@ -39465,10 +39688,6 @@
 #~ msgid "Unable to find stop vector <%s>"
-#, fuzzy
-#~ msgid "Parsing bytes per cell"
-#~ msgstr "        Número de bytes por célula"
 #~ msgid "Update the statistics (histogram, range) for [%s]? "
 #~ msgstr "Atualizar estatísticas (histograma, intervalo) para [%s]?"
@@ -39880,10 +40099,6 @@
 #~ msgid "Range file for [%s] not available"
 #~ msgstr "Arquivo de categorias para [%s] não disponível"
-#, fuzzy
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
 #~ msgid "List of categories to be displayed (INT maps)"
 #~ msgstr "Lista de categorias para exibir (mapas INT)"
@@ -39891,10 +40106,6 @@
 #~ msgid "Invert catlist"
 #~ msgstr "Inverter catlist"
-#, fuzzy
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
 #~ msgid "Vector map attribute column to use for comparison"
 #~ msgstr "Nome da coluna de atributos do vetor para usar como comparação"
@@ -40141,7 +40352,7 @@
 #, fuzzy
 #~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Imprime informações básicas sobre uma camada de mapa vetorial especificada pelo usuário."
+#~ msgstr "Imprime informações básicas sobre um mapa vetorial especificada pelo usuário."
 #, fuzzy
 #~ msgid "Map format:      %s"
@@ -40199,10 +40410,6 @@
 #~ msgstr "Não consegui determinar o tipo de célula raster."
 #, fuzzy
-#~ msgid "raster, vector, visualization"
-#, fuzzy
 #~ msgid "Verbose module output"
@@ -40462,18 +40669,6 @@
 #~ msgstr "Adicionando arquivos ao grupo [%s]"
 #, fuzzy
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "Não consegui obter informações da camada para o mapa vetorial"
-#, fuzzy
-#~ msgid "%s@%s: projection doesn't match current settings"
-#, fuzzy
-#~ msgid "%s@%s: zone doesn't match current settings"
-#, fuzzy
 #~ msgid "Interactively select or modify the target elevation model."
@@ -40502,251 +40697,6 @@
 #~ msgstr "Impossível abrir arquivo do diretório cell_misc."
 #, fuzzy
-#~ msgid "raster, terrain analysis"
-#~ msgstr "Estatísticas de transição de classe."
-#, fuzzy
-#~ msgid "Name of input vector points map"
-#~ msgstr "Nome do mapa vetorial (2d) de entrada"
-#, fuzzy
-#~ msgid "Eigen values:"
-#~ msgstr "Valor dos padrões de bits"
-#, fuzzy
-#~ msgid "Use regular expression instead of wildcard"
-#~ msgstr "de"
-#, fuzzy
-#~ msgid "Icon to remove"
-#~ msgstr "ícone para remover"
-#, fuzzy
-#~ msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p(ercent_cover)"
-#~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
-#, fuzzy
-#~ msgid "Writing %s"
-#~ msgstr "Escrevendo [%s]..."
-#, fuzzy
-#~ msgid "To layer"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "Mostra atributos do vetor"
-#, fuzzy
-#~ msgid ""
-#~ "Line: %d  \n"
-#~ "Type: %s  \n"
-#~ "Left: %d  \n"
-#~ "Right: %d  \n"
-#~ msgstr "Linha: %d  Tipo: %s  Esquerda: %d  Direita: %d  "
-#, fuzzy
-#~ msgid ""
-#~ "Node[%d]: %d  \n"
-#~ "Number of lines: %d  \n"
-#~ "Coordinates: %.6f, %.6f, %.6f\n"
-#~ msgstr "  Nó[%d]: %d  Número de linhas: %d  Coordenadas %.6f, %.6f %.6f\n"
-#, fuzzy
-#~ msgid ""
-#~ "Line: %5d  \n"
-#~ "Angle: %.8f\n"
-#~ msgstr "    Linha: %5d  Ângulo: %.8f\n"
-#, fuzzy
-#~ msgid ""
-#~ "Area: %d  \n"
-#~ "Number of isles: %d\n"
-#~ msgstr "Área: %d  Número de ilhas: %d\n"
-#~ msgid "%s: %s - Unable to find the real-image map."
-#~ msgstr "%s: %s - Não encontrei o mapa imagem real."
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#~ msgstr "%s: %s - Não encontrei o mapa imaginário"
-#, fuzzy
-#~ msgid "Hue map name"
-#~ msgstr "%s=%s - nome ilegal"
-#, fuzzy
-#~ msgid "Red input raster map"
-#, fuzzy
-#~ msgid "1 class."
-#~ msgstr "%d classes."
-#~ msgid "** Can't open seed singature file <%s> **"
-#~ msgstr "** Não consigo semear arquivo de assinatura <%s> **"
-#, fuzzy
-#~ msgid "Error writing result map file!"
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nome do raster de entrada"
-#~ msgid "Skipping [%s]..."
-#~ msgstr "Passando [%s]..."
-#, fuzzy
-#~ msgid "Name of the resultant map"
-#~ msgstr "Nome do mapa resultante"
-#, fuzzy
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "Não consegui selecionar dados da tabela"
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#, fuzzy
-#~ msgid "Done"
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Não consegui abrir fonte de dados OGR '%s'"
-#, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "coluna(s)"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#~ msgstr "Editar arquivo de categorias para [%s]?"
-#, fuzzy
-#~ msgid "Reading %s ... "
-#~ msgstr "Lendo imagem ... "
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s:em %s: %s"
-#, fuzzy
-#~ msgid "cannot read head of %s"
-#~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#~ msgid "No record for cat = %d"
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "Conexão com banco de dados não definida para camada <%d>"
-#, fuzzy
-#~ msgid "Editing tool"
-#, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "Mapa de entrada contendo linhas"
-#, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "Não consegui abrir o arquivo [%s]"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "Nome da superfície aleatória a produzir"
-#~ msgid "Cannot open file [%s]"
-#, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "Obtém coordenadas a partir da \"entrada padrão\" (stdin)"
-#, fuzzy
-#~ msgid "%s - illegal name"
-#, fuzzy
-#~ msgid "Error reading map %s"
-#~ msgstr "Erro lendo arquivo raster [%s]."
-#, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "Mapa raster de cobertura"
-#, fuzzy
-#~ msgid "Could not close the 3d raster map"
-#~ msgid "Can't create output map"
-#~ msgstr "Não consegui criar o mapa de saída"
-#, fuzzy
-#~ msgid "name for new vector map"
-#, fuzzy
-#~ msgid "Cover raster map"
-#~ msgstr "Mapa de cobertura"
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "Mapa de índice topográfico [ln(a/tanB)]"
-#~ msgid "No input coordinates provided"
-#~ msgstr "Coordenadas de entrada não foram informadas"
-#~ msgid "Database name:"
-#~ msgstr "Banco de dados:"
-#, fuzzy
-#~ msgid "Path to the input file"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgstr "Nome do raster de saída"
-#~ msgstr "tipo de coluna não suportado"
-#, fuzzy
-#~ msgid "%s - too many patch files. only %d allowed"
-#~ msgstr "correção"
-#, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "Camada: %d\n"
-#~ "categoria: %d\n"
-#, fuzzy
-#~ msgid "Interpolation()"
-#, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "Calculando médias das classes ..."
-#, fuzzy
-#~ msgid "History line too long: truncating to %d characters"
-#~ msgstr "Histórico para"
-#~ msgid "Name of output 3d raster map"
-#~ msgstr "Nome do arquivo G3D de saída"
-#, fuzzy
-#~ msgid "input layer name"
-#~ msgstr "Nome da tabela de entrada"
-#, fuzzy
 #~ msgid "<%s> is an ilegal name"
@@ -41030,20 +40980,12 @@
 #~ msgid " 1. nearest neighbor\n"
 #~ msgstr "assumindo amostragem por vizinhança próxima"
-#~ msgid "Raster elevation file name"
-#~ msgstr "Nome do Arquivo raster de elevação"
 #, fuzzy
-#~ msgid "Loading maps: "
-#~ msgstr "Lendo mapa"
-#, fuzzy
 #~ msgid "raster3d, voxel, statistics"
-#, fuzzy
 #~ msgid "Exports a GRASS raster map to a binary array."
+#~ msgstr "Exporta um mapa raster do GRASS para um arquivo binário."
 #, fuzzy
 #~ msgid "raster, color transformation"
@@ -41362,36 +41304,11 @@
 #~ msgid "imagery, classification"
 #~ msgstr "Assinaturas para usar na classificação"
-#, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Arquivo raster binário a importar"
+#~ msgid " EW resolution %s (%lf)"
+#~ msgstr "resolução LO %s (%lf)"
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
+#~ msgid " NS resolution %s (%lf)"
+#~ msgstr "resolução NS %s (%lf)"
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#~ msgstr "Arquivo raster de entrada sendo FFT"
-#, fuzzy
-#~ msgid "File containing initial signatures"
-#~ msgstr "Arquivo contém assinaturas resultantes"
-#, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nome do Raster de entrada"
-#, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgid "Attribute column(s)"
-#~ msgstr "Coluna(s) de atributo(s)"
-#~ msgid "database name"
-#, fuzzy
-#~ msgid "Finished"
+#~ msgid "bottom,top,left,right"
+#~ msgstr "fundo,topo,esquerda,direita"
