[GRASS-SVN] r46097 - grass/trunk/lib/python
svn_grass at osgeo.org
Mon Apr 25 05:51:58 EDT 2011
Author: martinl
Date: 2011-04-25 02:51:58 -0700 (Mon, 25 Apr 2011)
New Revision: 46097
grass/trunk/lib/python/core.py
pythonlib: partly revert r46061 (ScriptException -> ScriptError)
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2011-04-25 09:44:27 UTC (rev 46096)
+++ grass/trunk/lib/python/core.py 2011-04-25 09:51:58 UTC (rev 46097)
@@ -13,14 +13,14 @@
@endcode
-(C) 2008-2010 by the GRASS Development Team
+(C) 2008-2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@author Glynn Clements
@author Martin Landa <landa.martin gmail.com>
- at author Michael Barton <michael.barton at asu.edu>
+ at author Michael Barton <michael.barton asu.edu>
import os
@@ -40,11 +40,11 @@
# subprocess wrapper that uses shell on Windows
class Popen(subprocess.Popen):
- def __init__(self, args, bufsize=0, executable=None,
- stdin=None, stdout=None, stderr=None,
- preexec_fn=None, close_fds=False, shell=None,
- cwd=None, env=None, universal_newlines=False,
- startupinfo=None, creationflags=0):
+ def __init__(self, args, bufsize = 0, executable = None,
+ stdin = None, stdout = None, stderr = None,
+ preexec_fn = None, close_fds = False, shell = None,
+ cwd = None, env = None, universal_newlines = False,
+ startupinfo = None, creationflags = 0):
if shell == None:
shell = (sys.platform == "win32")
@@ -58,7 +58,7 @@
PIPE = subprocess.PIPE
STDOUT = subprocess.STDOUT
-class ScriptException(Exception):
+class ScriptError(Exception):
def __init__(self, msg):
self.value = msg
@@ -361,7 +361,7 @@
global raise_on_error
if raise_on_error:
- raise ScriptException(msg)
+ raise ScriptError(msg)
else:
message(msg, flag = 'e')
@@ -376,7 +376,7 @@
def set_raise_on_error(raise_exp = True):
"""!Define behaviour on error (error() called)
- @param raise_exp True to raise ScriptException instead of calling
+ @param raise_exp True to raise ScriptError instead of calling
error()
@return current status
@@ -953,7 +953,7 @@
datum = None, desc = None):
"""!Create new location
- Raise ScriptException on error.
+ Raise ScriptError on error.
@param dbase path to GRASS database
@param location location name to create
@@ -1015,7 +1015,7 @@
set = 'GISDBASE=%s' % gisdbase)
if ps.returncode != 0 and error:
- raise ScriptException(repr(error))
+ raise ScriptError(repr(error))
try:
fd = codecs.open(os.path.join(dbase, location,
@@ -1027,12 +1027,12 @@
fd.write(os.linesep)
fd.close()
except OSError, e:
- raise ScriptException(repr(e))
+ raise ScriptError(repr(e))
def _create_location_xy(database, location):
"""!Create unprojected location
@param database GRASS database where to create new location
@@ -1074,7 +1074,7 @@
os.chdir(cur_dir)
except OSError, e:
# interface to g.version
