[GRASS-SVN] r46099 - grass/branches/develbranch_6/lib/python
Mon Apr 25 06:01:33 EDT 2011
Author: martinl
Date: 2011-04-25 03:01:33 -0700 (Mon, 25 Apr 2011)
New Revision: 46099
   grass/branches/develbranch_6/lib/python/core.py
pythonlib: sync core.py with trunk
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2011-04-25 09:57:46 UTC (rev 46098)
+++ grass/branches/develbranch_6/lib/python/core.py	2011-04-25 10:01:33 UTC (rev 46099)
@@ -45,10 +45,10 @@
                  preexec_fn = None, close_fds = False, shell = None,
                  cwd = None, env = None, universal_newlines = False,
                  startupinfo = None, creationflags = 0):
 	if shell == None:
 	    shell = (sys.platform == "win32")
 	subprocess.Popen.__init__(self, args, bufsize, executable,
                                   stdin, stdout, stderr,
                                   preexec_fn, close_fds, shell,
@@ -94,12 +94,6 @@
 	return _make_val(list(val))
     return str(val)
-def _get_error(string):
-    try:
-        return string.split('\n')[-2]
-    except:
-        return ''
 def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
     """!Return a list of strings suitable for use as the args parameter to
     Popen() or call(). Example:
@@ -187,23 +181,9 @@
     @return exit code (0 for success)
-    if get_raise_on_error():
-        kwargs['stderr'] = PIPE
-        env = os.getenv('GRASS_MESSAGE_FORMAT')
-        os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
     ps = start_command(*args, **kwargs)
-        err = ps.communicate()[1]
-        if env:
-            os.environ['GRASS_MESSAGE_FORMAT'] = env
-        if ps.returncode != 0:
-            raise ScriptError(_("Error in %s(%s): %s") % ('run_command', args[0], _get_error(err)))
-        return ps.returncode
-    else:
-        return ps.wait()
+    return ps.wait()
 def pipe_command(*args, **kwargs):
     """!Passes all arguments to start_command(), but also adds
     "stdout = PIPE". Returns the Popen object.
@@ -250,22 +230,8 @@
     @return stdout
     ps = pipe_command(*args, **kwargs)
-        out, err = ps.communicate()
-        if env:
-            raise ScriptError(_("Error in %s(%s): %s") % ('read_command', args[0], _get_error(err)))
-        return _decode(out)
-    else:
-        return _decode(ps.communicate()[0])
+    return _decode(ps.communicate()[0])
 def parse_command(*args, **kwargs):
     """!Passes all arguments to read_command, then parses the output by
@@ -308,26 +274,11 @@
     @return return code
     stdin = kwargs['stdin']
     p = feed_command(*args, **kwargs)
     p.stdin.write(stdin)
-        err = p.communicate()[1]
-        if env:
-        p.stdin.close()
-        if p.returncode != 0:
-            raise ScriptError(_("Error in %s(%s): %s") % ('write_command', args[0], _get_error(err)))
-        return p.returncode
-    else:
-        p.stdin.close()
-        return p.wait()
+    p.stdin.close()
+    return p.wait()
 def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
     """!Interface to os.execvpe(), but with the make_command() interface.
@@ -433,17 +384,7 @@
     global raise_on_error
     tmp_raise = raise_on_error
     raise_on_error = raise_exp
-    return tmp_raise
-def get_raise_on_error():
-    """!Get raise_on_error status
-    @return True to raise exception
-    global raise_on_error
-    return raise_on_error
 # interface to g.parser
 def _parse_opts(lines):
@@ -1143,8 +1084,8 @@
     @code
     version()
-    {'date': '2011', 'libgis_revision': '38990', 'version': '6.5.svn',
-     'libgis_date': '2009-09-05 19:01:13 +0200 (Sat, 05 Sep 2009)'}
+    {'date': '2011', 'libgis_revision': '45093 ', 'version': '6.5.svn',
+     'libgis_date': '2011-01-20 13:10:50 +0100 (Thu, 20 Jan 2011) ', 'revision': '45136'}
     @endcode
     return parse_command('g.version',
