[GRASS-SVN] r46108 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Apr 26 11:12:27 EDT 2011
Author: martinl
Date: 2011-04-26 08:12:27 -0700 (Tue, 26 Apr 2011)
New Revision: 46108
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py
fix #1352 (Mismatch between overwrite parameter in GCPManager and v.transform)
use gcmd.GMessage instead of wx.MessageBox
(merge r46107 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py 2011-04-26 15:06:53 UTC (rev 46107)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py 2011-04-26 15:12:27 UTC (rev 46108)
@@ -172,16 +172,12 @@
if self.wizard.RunWizard(self.startpage):
success = self.OnWizFinished()
if success == False:
- wx.MessageBox(parent=self.parent,
- message=_("Georectifying setup canceled."),
- caption=_("Georectify"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ gcmd.GMessage(parent = self.parent,
+ message = _("Georectifying setup canceled."))
self.Cleanup()
else:
self.Cleanup()
@@ -398,7 +394,9 @@
def OnMapset(self, event):
"""!Sets source mapset for map(s) to georectify"""
if self.xylocation == '':
- wx.MessageBox(_('You must select a valid location before selecting a mapset'))
+ gcmd.GMessage(_('You must select a valid location '
+ 'before selecting a mapset'),
+ parent = self)
return
self.xymapset = event.GetString()
@@ -409,7 +407,9 @@
def OnPageChanging(self, event=None):
if event.GetDirection() and \
(self.xylocation == '' or self.xymapset == ''):
- wx.MessageBox(_('You must select a valid location and mapset in order to continue'))
+ 'and mapset in order to continue'),
+ parent = self)
event.Veto()
return
@@ -531,12 +531,16 @@
if event.GetDirection() and self.xygroup == '':
- wx.MessageBox(_('You must select a valid image/map group in order to continue'))
+ gcmd.GMessage(_('You must select a valid image/map '
+ 'group in order to continue'),
+ parent = self)
event.Veto()
return
if event.GetDirection() and self.extension == '':
- wx.MessageBox(_('You must enter an map name extension in order to continue'))
+ gcmd.GMessage(_('You must enter an map name '
+ 'extension in order to continue'),
+ parent = self)
event.Veto()
return
@@ -673,7 +677,9 @@
global tgt_map
if event.GetDirection() and (src_map == ''):
- wx.MessageBox(_('You must select a source map in order to continue'))
+ gcmd.GMessage(_('You must select a source map '
+ 'in order to continue'),
+ parent = self)
event.Veto()
return
@@ -694,12 +700,10 @@
if ret:
self.parent.src_maps = ret.splitlines()
else:
- wx.MessageBox(parent=self,
- caption=_("Select maps to display"),
- message=_('No maps in selected group <%s>. \n'
- 'Please edit group or select another group.') %
- self.parent.grouppage.xygroup,
- style=wx.ICON_ERROR | wx.ID_OK | wx.CENTRE)
+ gcmd.GError(parent = self,
+ message = _('No maps in selected group <%s>.\n'
+ 'Please edit group or select another group.') %
+ self.parent.grouppage.xygroup)
return
# filter out all maps not in group
@@ -944,8 +948,8 @@
minNumOfItems = self.OnGROrder(None)
if self.list.GetItemCount() <= minNumOfItems:
- wx.MessageBox(parent=self, message=_("At least %d GCPs required. Operation cancelled.") % minNumOfItems,
- caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
+ gcmd.GMessage(parent = self,
+ message=_("At least %d GCPs required. Operation cancelled.") % minNumOfItems)
return
key = self.list.DeleteGCPItem()
@@ -1032,10 +1036,9 @@
n_idx = 4
if not mapWin:
- message="%s%s." % (_("mapwin not defined for "),
- str(idx)),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ message="%s%s." % (_("mapwin not defined for "),
+ str(idx)))
return
#for gcp in self.mapcoordlist:
@@ -1172,10 +1175,9 @@
f.write(coord0 + ' ' + coord1 + ' ' + coord2 + ' ' + coord3 + ' ' + check + '\n')
except IOError, err:
- message="%s <%s>. %s%s" % (_("Writing POINTS file failed"),
- self.file['points'], os.linesep, err),
+ message="%s <%s>. %s%s" % (_("Writing POINTS file failed"),
+ self.file['points'], os.linesep, err))
return
f.close()
@@ -1198,17 +1200,15 @@
#targetMapWin = self.parent.curr_page.maptree.mapdisplay.MapWindow
if not sourceMapWin:
- message="%s. %s%s" % (_("source mapwin not defined"),
- os.linesep, err),
+ message = "%s. %s%s" % (_("source mapwin not defined"),
+ os.linesep, err))
if not targetMapWin:
- message="%s. %s%s" % (_("target mapwin not defined"),
- os.linesep, err),
+ message="%s. %s%s" % (_("target mapwin not defined"),
+ os.linesep, err))
try:
f = open(self.file['points'], 'r')
GCPcnt = 0
@@ -1233,10 +1233,9 @@
GCPcnt += 1
- message="%s <%s>. %s%s" % (_("Reading POINTS file failed"),
+ message = "%s <%s>. %s%s" % (_("Reading POINTS file failed"),
return
f.close()
@@ -1305,14 +1304,12 @@
(self.GCPcount < 6 and self.gr_order == 2) or \
(self.GCPcount < 10 and self.gr_order == 3):
if msg:
- caption=_("RMS Error"),
+ gcmd.GWarning(parent = self,
message=_('Insufficient points defined and active (checked) '
'for selected rectification method.\n'
'3+ points needed for 1st order,\n'
'6+ points for 2nd order, and\n'
- '10+ points for 3rd order.'),
- style=wx.ICON_INFORMATION | wx.ID_OK | wx.CENTRE)
+ '10+ points for 3rd order.'))
return False
else:
return True
@@ -1390,14 +1387,14 @@
self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
switchPage = True)
msg = err = ''
ret, out, err = gcmd.RunCommand('v.transform',
- flags = 'o',
+ overwrite = True,
input = vect,
output = self.outname,
pointsfile = self.file['points'],
getErrorMsg = True, read = True)
if ret == 0:
self.VectGRList.append(self.outname)
# note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
@@ -1407,7 +1404,7 @@
self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
self.outname)
self.parent.goutput.WriteError(err)
# FIXME
# Copying database information not working.
# Does not copy from xy location to current location
@@ -1456,10 +1453,11 @@
# TODO: connect vectors to copied tables with v.db.connect
- wx.MessageBox('For all vector maps georectified successfully, ' + '\n' +
- 'you will need to copy any attribute tables' + '\n' +
- 'and reconnect them to the georectified vectors')
+ gcmd.GMessage(_('For all vector maps georectified successfully,') + '\n' +
+ _('you will need to copy any attribute tables') + '\n' +
+ _('and reconnect them to the georectified vectors'),
+ parent = self)
self.grwiz.SwitchEnv('target')
def OnGeorectDone(self, **kargs):
@@ -1524,7 +1522,6 @@
def OnQuit(self, event):
"""!Quit georectifier"""
ret = wx.MessageBox(parent=self,
caption=_("Quit GCP Manager"),
message=_('Save ground control points?'),
@@ -1605,11 +1602,9 @@
if ret:
errlist = ret.splitlines()
else:
- message=_('Could not calculate RMS Error. \n'
- 'Possible error with g.transform.'),
+ message=_('Could not calculate RMS Error.\n'
+ 'Possible error with g.transform.'))
return
# insert error values into GCP list for checked items
@@ -1732,11 +1727,9 @@
if ret:
else:
- caption=_("Adjust GCP Displays "),
- message=_('Could not calculate new extends. \n'
+ message=_('Could not calculate new extends.\n'
return
# fist corner
@@ -2080,10 +2073,8 @@
values = dlg.GetValues() # string
if len(values) == 0:
- caption=_("Edit GCP"),
- message=_("Invalid coordinate value. Operation cancelled."),
- style=wx.CENTRE | wx.ICON_ERROR | wx.ID_OK)
+ message=_("Invalid coordinate value. Operation cancelled."))
else:
for i in range(len(values)):
if values[i] != coords[i]:
@@ -2655,17 +2646,13 @@
self.sdfactor = float(event.GetString())
if self.sdfactor <= 0:
- caption=_("Update settings"),
- message=_('RMS threshold factor must be > 0'),
+ message=_('RMS threshold factor must be > 0'))
elif self.sdfactor < 1:
- message=_('RMS threshold factor is < 1\n'
- 'Too many points might be highlighted'),
- style=wx.ICON_EXCLAMATION | wx.ID_OK | wx.CENTRE)
+ message=_('RMS threshold factor is < 1\n'
+ 'Too many points might be highlighted'))
def OnSrcSelection(self,event):
"""!Source map to display selected"""
global src_map
