[GRASS-SVN] r46115 - grass-addons/display/d.barb
svn_grass at osgeo.org
Wed Apr 27 04:36:46 EDT 2011
Author: hamish
Date: 2011-04-27 01:36:46 -0700 (Wed, 27 Apr 2011)
New Revision: 46115
grass-addons/display/d.barb/description.html
grass-addons/display/d.barb/draw.c
grass-addons/display/d.barb/grid.c
grass-addons/display/d.barb/local_proto.h
grass-addons/display/d.barb/main.c
grass-addons/display/d.barb/points.c
spelling, run grass_indent.sh
Modified: grass-addons/display/d.barb/description.html
--- grass-addons/display/d.barb/description.html 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/description.html 2011-04-27 08:36:46 UTC (rev 46115)
@@ -7,12 +7,14 @@
<h2>NOTES</h2>
-Cartesian aspect is measures in degreess CCW from the positive x-axis (east).
-Compass aspect is measures in degreess CW from north.
+Cartesian aspect is measured in degrees CCW from the positive x-axis (east).
+Compass aspect is measured in degrees CW from north.
<P>
+<!--I haven't added this yet, and I'm not sure that if I will. Leaning towards not.
Rendering is scaled so largest stick covers 20% of the display frame
for arrows and straws, use the scale parameter to adjust from there.
<P>
Wind barbs are all of equal length, but that length may be adjusted
by the scale parameter.
<P>
@@ -34,7 +36,7 @@
<h2>EXAMPLES</h2>
-<h4>Sparse staion data from vector maps</h4>
+<h4>Sparse station data from vector maps</h4>
First prepare some dummy data, then plot it.
<div class="code"><pre>
@@ -51,7 +53,7 @@
aspect=compass style=barb
</pre></div>
-<h4>Eularian field from raster grid</h4>
+<h4>Eulerian field from raster grid</h4>
# r.surf.volcano module from GRASS-addons
g.region -d
@@ -62,7 +64,7 @@
</pre></div>
<!-- useful, but not really needed
-<h4>Create polar coordinate maps from cartesian components</h4>
+<h4>Create polar coordinate maps from Cartesian components</h4>
MAPu=velocity.u
@@ -127,4 +129,3 @@
<br>
<p>
<i>Last changed: $Date$</i></p>
Modified: grass-addons/display/d.barb/draw.c
--- grass-addons/display/d.barb/draw.c 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/draw.c 2011-04-27 08:36:46 UTC (rev 46115)
@@ -202,9 +202,9 @@
-/* draws the stem and tail of a wind barb centered at e,n.
+/* draws the stem and tail of a wind barb centred at e,n.
radius is scaling in display pixels, velocity is assumed as knots,
- angle is cartesian convention CCW from positive x-axis */
+ angle is Cartesian convention CCW from positive x-axis */
void draw_feather(double easting, double northing, double radius,
double velocity, double compass_deg)
@@ -648,7 +648,7 @@
R_polygon_abs(xi, yi, 4);
- /* barb rendering currenly saturates at 150 kts */
+ /* barb rendering currently saturates at 150 kts */
return;
Modified: grass-addons/display/d.barb/grid.c
--- grass-addons/display/d.barb/grid.c 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/grid.c 2011-04-27 08:36:46 UTC (rev 46115)
@@ -32,7 +32,7 @@
G_fatal_error(_("Problem reading range file"));
G_get_fp_range_min_max(&range, &mag_min, &mag_max);
- if(style != TYPE_BARB) {
+ if (style != TYPE_BARB) {
scale *= 1.5 / fabs(mag_max);
G_debug(3, "scaling=%.2f rast_max=%.2f", scale, mag_max);
@@ -69,7 +69,7 @@
G_get_raster_row(dir_u_fd, dir_u_raster_row, row, dir_u_raster_type);
dir_u_ptr = dir_u_raster_row;
- // should magnitude be manditory?
+ // should magnitude be mandatory?
if (mag_v_map) {
G_get_raster_row(mag_v_fd, mag_v_raster_row, row,
mag_v_raster_type);
@@ -124,29 +124,29 @@
continue;
- if(is_component) {
+ if (is_component) {
/* convert u,v to dir,mag */
- r = sqrt(length*length + aspect_f*aspect_f);
+ r = sqrt(length * length + aspect_f * aspect_f);
theta = R2D(atan2(length, aspect_f));
length = r;
aspect_f = theta;
- if(aspect_f < 0)
+ if (aspect_f < 0)
aspect_f += 360;
else if (aspect_f > 360)
aspect_f -= 360;
- /* convert cartesian to compass convention */
+ /* convert Cartesian to compass convention */
if (aspect_type == TYPE_GRASS)
aspect_f = 90 - aspect_f;
- if(aspect_f < 0)
+ if (aspect_f < 0)
aspect_f += 360;
aspect_f -= 360;
- if(reverse)
- aspect_f += 180;
+ if (reverse)
+ aspect_f += 180;
if (aspect_f > 360)
aspect_f -= 360;
Modified: grass-addons/display/d.barb/local_proto.h
--- grass-addons/display/d.barb/local_proto.h 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/local_proto.h 2011-04-27 08:36:46 UTC (rev 46115)
@@ -10,7 +10,7 @@
#define TYPE_BARB 1
#define TYPE_ARROW 2
-#define RpD ((2 * M_PI) / 360.) /* radians/degree */
+#define RpD ((2 * M_PI) / 360.) /* radians/degree */
#define D2R(d) (double)(d * RpD) /* degrees->radians */
#define R2D(d) (double)(d / RpD) /* radians->degrees */
@@ -18,7 +18,8 @@
void do_barb_grid(char *, char *, int, int, int, double, int, int, int);
/* points.c */
-void do_barb_points(char *, int, char *, char *, int, int, int, double, int, int);
+void do_barb_points(char *, int, char *, char *, int, int, int, double, int,
+ int);
int count_pts_in_region(struct Map_info *);
void fill_arrays(struct Map_info *, int, char *, char *, int, double *,
double *, double *, double *);
Modified: grass-addons/display/d.barb/main.c
--- grass-addons/display/d.barb/main.c 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/main.c 2011-04-27 08:36:46 UTC (rev 46115)
@@ -154,8 +154,7 @@
/* TODO */
from_to = G_define_flag();
from_to->key = 'r';
- from_to->label =
- _("Rotate direction 180 degrees");
+ from_to->label = _("Rotate direction 180 degrees");
from_to->description =
_("Useful for switching between atmospheric and oceanographic conventions");
@@ -184,7 +183,7 @@
strncpy(dir_u_map, dir_opt->answer, sizeof(dir_u_map) - 1);
strncpy(mag_v_map, magn_opt->answer, sizeof(mag_v_map) - 1);
- dir_u_map[sizeof(dir_u_map) - 1] = '\0'; /* strncpy() doesn't null-terminate on overflow */
+ dir_u_map[sizeof(dir_u_map) - 1] = '\0'; /* strncpy() doesn't null-terminate on overflow */
mag_v_map[sizeof(mag_v_map) - 1] = '\0';
if (vinput_opt->answer)
Modified: grass-addons/display/d.barb/points.c
--- grass-addons/display/d.barb/points.c 2011-04-27 08:22:31 UTC (rev 46114)
+++ grass-addons/display/d.barb/points.c 2011-04-27 08:36:46 UTC (rev 46115)
@@ -254,15 +254,15 @@
Mags[i] = cvarr_mag_v.ctype == DB_C_TYPE_INT ?
(double)cv_mag_v->val.i : cv_mag_v->val.d;
if (!is_uv) {
- if (Mags[i] < 0) /* magnitude is scalar and can only be positive */
+ if (Mags[i] < 0) /* magnitude is scalar and can only be positive */
Mags[i] = 0;
- if(is_uv) {
+ if (is_uv) {
/* now that we have the data loaded, cycle back and process it */
theta = R2D(atan2(Mags[i], Dirs[i]));
- r = sqrt(Dirs[i]*Dirs[i] + Mags[i]*Mags[i]);
+ r = sqrt(Dirs[i] * Dirs[i] + Mags[i] * Mags[i]);
Dirs[i] = theta;
Mags[i] = r;
