[GRASS-SVN] r46119 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Thu Apr 28 06:58:44 EDT 2011
Author: mmetz
Date: 2011-04-28 03:58:44 -0700 (Thu, 28 Apr 2011)
New Revision: 46119
grass/trunk/vector/v.out.ogr/attrb.c
grass/trunk/vector/v.out.ogr/local_proto.h
grass/trunk/vector/v.out.ogr/main.c
partially revert r45044, because attributes where mixed up: select only attributes for current cat, not attributes for all cats
Modified: grass/trunk/vector/v.out.ogr/attrb.c
--- grass/trunk/vector/v.out.ogr/attrb.c 2011-04-27 15:51:08 UTC (rev 46118)
+++ grass/trunk/vector/v.out.ogr/attrb.c 2011-04-28 10:58:44 UTC (rev 46119)
@@ -4,7 +4,7 @@
int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
int doatt, int nocat, OGRFeatureH Ogr_feature, int *noatt,
- int *fout, dbCursor cursor)
+ int *fout)
int j, ogrfieldnum;
int colsqltype, colctype, more;
@@ -12,10 +12,12 @@
dbString dbstring;
dbColumn *Column;
dbValue *Value;
+ char buf[SQL_BUFFER_SIZE];
+ dbCursor cursor;
G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
db_init_string(&dbstring);
/* Attributes */
/* Reset */
if (!doatt) {
@@ -28,58 +30,80 @@
/* Read & set attributes */
if (cat >= 0) { /* Line with category */
if (doatt) {
+ /* Fetch all attribute records for cat <cat> */
+ /* opening and closing the cursor is slow,
+ * but the cursor really needs to be opened for each cat separately */
+ sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key, cat);
+ G_debug(2, "SQL: %s", buf);
+ db_set_string(&dbstring, buf);
+ if (db_open_select_cursor
+ (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+ G_fatal_error(_("Cannot select attributes for cat = %d"),
+ cat);
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+ G_fatal_error(_("Unable to fetch data from table"));
+ if (!more) {
+ /* start from the beginning in case multiple grass vector features
+ * share the same category */
- if (!more) {
- /* start from the beginning in case multiple grass vector features
- * share the same category */
- if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
- G_fatal_error(_("Unable to fetch data from table"));
- if (!more) {
- /* G_warning ("No database record for cat = %d", cat); */
- /* Set at least key column to category */
- if (!nocat) {
- ogrfieldnum =
- OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
- OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
- (*noatt)++;
- else {
- G_fatal_error(_("No database record for cat = %d and export of 'cat' disabled"),
- cat);
+ if (!more) {
+ /* G_warning ("No database record for cat = %d", cat); */
+ /* Set at least key column to category */
+ if (!nocat) {
+ ogrfieldnum =
+ OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
+ OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
+ (*noatt)++;
else {
- Table = db_get_cursor_table(&cursor);
- for (j = 0; j < ncol; j++) {
- Column = db_get_table_column(Table, j);
- Value = db_get_column_value(Column);
- db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
- G_debug(2, "col %d : val = %s", j,
- db_get_string(&dbstring));
+ G_fatal_error(_("No database record for cat = %d and export of 'cat' disabled"),
+ cat);
+ else {
+ Table = db_get_cursor_table(&cursor);
+ for (j = 0; j < ncol; j++) {
+ Column = db_get_table_column(Table, j);
+ Value = db_get_column_value(Column);
+ db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
+ G_debug(2, "col %d : val = %s", j,
+ db_get_string(&dbstring));
- colsqltype = db_get_column_sqltype(Column);
- colctype = db_sqltype_to_Ctype(colsqltype);
- G_debug(2, " colctype = %d", colctype);
+ colsqltype = db_get_column_sqltype(Column);
+ colctype = db_sqltype_to_Ctype(colsqltype);
+ G_debug(2, " colctype = %d", colctype);
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
- db_get_column_name
- (Column));
- G_debug(2, " column = %s -> fieldnum = %d",
- db_get_column_name(Column), ogrfieldnum);
+ if (nocat && strcmp(Fi->key, db_get_column_name(Column)) == 0)
+ continue;
- /* Reset */
- if ( ( ( nocat ) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
- /* if this is 'cat', then execute the following only if the '-s' flag was NOT given*/
- OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+ ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
+ db_get_column_name
+ (Column));
+ G_debug(2, " column = %s -> fieldnum = %d",
+ db_get_column_name(Column), ogrfieldnum);
+ if (ogrfieldnum < 0) {
+ G_debug(4, "Could not get OGR field number for column %s",
+ db_get_column_name(Column));
+ continue;
- /* prevent writing NULL values */
- if (!db_test_value_isnull(Value)) {
- if ( ( (nocat) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
+ /* Reset */
+ if ((nocat && strcmp(Fi->key, db_get_column_name(Column)) == 0) == 0) {
+ /* if this is 'cat', then execute the following only if the '-s' flag was NOT given*/
+ OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+ /* prevent writing NULL values */
+ if (!db_test_value_isnull(Value)) {
switch (colctype) {
case DB_C_TYPE_INT:
@@ -107,8 +131,9 @@
+ db_close_cursor(&cursor);
else { /* Use cat only */
ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, "cat");
Modified: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h 2011-04-27 15:51:08 UTC (rev 46118)
+++ grass/trunk/vector/v.out.ogr/local_proto.h 2011-04-28 10:58:44 UTC (rev 46119)
@@ -25,7 +25,7 @@
/* attributes.c */
- int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature, int *, int *, dbCursor cursor);
+ int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature, int *, int *);
/* list.c */
char *OGR_list_write_drivers();
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2011-04-27 15:51:08 UTC (rev 46118)
+++ grass/trunk/vector/v.out.ogr/main.c 2011-04-28 10:58:44 UTC (rev 46119)
@@ -38,7 +38,8 @@
struct Flags flags;
- char key1[SQL_BUFFER_SIZE], key2[SQL_BUFFER_SIZE]; struct Key_Value *projinfo, *projunits;
+ char key1[SQL_BUFFER_SIZE], key2[SQL_BUFFER_SIZE];
+ struct Key_Value *projinfo, *projunits;
struct Cell_head cellhd;
char **tokens;
@@ -55,7 +56,6 @@
dbTable *Table;
dbString dbstring;
dbColumn *Column;
- dbCursor cursor;
int fout, fskip; /* features written/ skip */
int nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
@@ -627,6 +627,9 @@
OGR_Fld_Create(db_get_column_name(Column),
ogr_ftype);
OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
+ G_debug(0, "OGR field: %s, column %s", OGR_Fld_GetNameRef(Ogr_field), db_get_column_name(Column));
OGR_Fld_Destroy(Ogr_field);
if (keycol == -1)
@@ -638,18 +641,6 @@
fout = fskip = nocat = noatt = nocatskip = 0;
- /* Fetch all attribute records */
- if (doatt) {
- sprintf(buf, "SELECT * FROM %s", Fi->table);
- G_debug(2, "SQL: %s", buf);
- db_set_string(&dbstring, buf);
- if (db_open_select_cursor
- (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
- G_fatal_error(_("Cannot select attributes for cat = %d"),
- cat);
if (OGR_L_TestCapability(Ogr_layer, OLCTransactions))
OGR_L_StartTransaction(Ogr_layer);
@@ -726,7 +717,7 @@
mk_att(cat, Fi, Driver, ncol, doatt, flags.nocat->answer,
- Ogr_feature, &noatt, &fout, cursor);
+ Ogr_feature, &noatt, &fout);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
@@ -801,7 +792,7 @@
@@ -861,7 +852,7 @@
@@ -916,7 +907,7 @@
@@ -944,7 +935,6 @@
Vect_close(&In);
if (doatt) {
- db_close_cursor(&cursor);
db_close_database(Driver);
db_shutdown_driver(Driver);
