[GRASS-SVN] r46129 - grass/branches/develbranch_6/imagery/i.atcorr
svn_grass at osgeo.org
Thu Apr 28 08:27:22 EDT 2011
Author: mmetz
Date: 2011-04-28 05:27:22 -0700 (Thu, 28 Apr 2011)
New Revision: 46129
grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
always optimize
Modified: grass/branches/develbranch_6/imagery/i.atcorr/main.cpp
--- grass/branches/develbranch_6/imagery/i.atcorr/main.cpp 2011-04-28 12:23:31 UTC (rev 46128)
+++ grass/branches/develbranch_6/imagery/i.atcorr/main.cpp 2011-04-28 12:27:22 UTC (rev 46129)
@@ -53,6 +53,9 @@
/* TICache: create 1 km bins for visibility */
#define BIN_VIS 1.
+/* uncomment to disable cache usage */
+/* #define _NO_OPTIMIZE_ */
/* Input options and flags */
struct Options
@@ -92,7 +95,7 @@
static void adjust_region(char *, const char *);
static CELL round_c(FCELL);
static void write_fp_to_cell(int, FCELL *);
-static void process_raster(int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
+static void process_raster(int, InputMask, ScaleRange, int, int, int, bool, ScaleRange);
static void copy_colors(char *, const char *, char *);
static void define_module(void);
static struct Options define_options(void);
@@ -239,7 +242,7 @@
static void process_raster(int ifd, InputMask imask, ScaleRange iscale,
int ialt_fd, int ivis_fd, int ofd, bool oflt,
- ScaleRange oscale, bool optimize)
+ ScaleRange oscale)
FCELL* buf; /* buffer for the input values */
FCELL* alt = NULL; /* buffer for the elevation values */
@@ -247,6 +250,12 @@
FCELL prev_alt = -1.f;
FCELL prev_vis = -1.f;
int row, col, nrows, ncols;
+ /* switch on optimization automatically if elevation and/or visibility map is given */
+ bool optimize = (ialt_fd >= 0 || ivis_fd >= 0);
+#ifdef _NO_OPTIMIZE_
+ optimize = false;
+#endif
/* do initial computation with global elevation and visibility values */
TransformInput ti;
@@ -288,8 +297,8 @@
/* loop over all the values in the row */
for(col = 0; col < ncols; col++)
- if(vis && G_is_f_null_value(&vis[col]) ||
- alt && G_is_f_null_value(&alt[col]) ||
+ if((vis && G_is_f_null_value(&vis[col])) ||
+ (alt && G_is_f_null_value(&alt[col])) ||
G_is_f_null_value(&buf[col]))
G_set_f_null_value(&buf[col], 1);
@@ -627,17 +636,14 @@
if(opts.etmbefore->answer) imask = (InputMask)(imask | ETM_BEFORE);
if(opts.etmafter->answer) imask = (InputMask)(imask | ETM_AFTER);
- if ((ialt_fd >= 0 || ivis_fd >= 0) && !opts.optimize->answer) {
- G_message(_("An elevation and/or visibility map is given, but the optimization flag is not set."));
- G_message(_("This can take some time."));
+ if (opts.optimize->answer)
+ G_important_message(_("Optimization is switched on automatically, the -o flag has no effect"));
- /* switch on optimization automatically if elevation and/or visibility map is given? */
/* process the input raster and produce our atmospheric corrected output raster. */
G_message(_("Atmospheric correction..."));
process_raster(iimg_fd, imask, iscale, ialt_fd, ivis_fd,
- oimg_fd, opts.oflt->answer, oscale, opts.optimize->answer);
+ oimg_fd, opts.oflt->answer, oscale);
/* Close the input and output file descriptors */
