[GRASS-SVN] r47339 - in grass/trunk/general: g.mremove g.remove
svn_grass at osgeo.org
Mon Aug 1 12:28:17 EDT 2011
Author: martinl
Date: 2011-08-01 09:28:17 -0700 (Mon, 01 Aug 2011)
New Revision: 47339
grass/trunk/general/g.mremove/main.c
grass/trunk/general/g.remove/main.c
g.mremove: minor clean up of g.remove and g.mremove
Modified: grass/trunk/general/g.mremove/main.c
--- grass/trunk/general/g.mremove/main.c 2011-08-01 15:45:36 UTC (rev 47338)
+++ grass/trunk/general/g.mremove/main.c 2011-08-01 16:28:17 UTC (rev 47339)
@@ -17,11 +17,11 @@
* PURPOSE: lets users remove GRASS database files
- * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2011 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -46,15 +46,17 @@
struct Flag *force;
struct Flag *basemap;
} flag;
- const char *mapset, *location_path;
+ const char *mapset;
char *name, path[GPATH_MAX], **files;
- char *alias;
- int num_files, rast, result = EXIT_SUCCESS;
+ const struct list *option;
+ int num_files, rast, result;
int i, j, n, nlist;
void *filter;
G_gisinit(argv[0]);
+ result = EXIT_SUCCESS;
module = G_define_module();
G_add_keyword(_("general"));
G_add_keyword(_("map management"));
@@ -62,8 +64,7 @@
G_add_keyword(_("multi"));
module->description =
_("Removes data base element files from "
- "the user's current mapset.");
+ "the user's current mapset using regular expressions.");
flag.regex = G_define_flag();
flag.regex->key = 'r';
flag.regex->description =
@@ -81,8 +82,9 @@
flag.basemap = G_define_flag();
flag.basemap->key = 'b';
- flag.basemap->description = _("Remove base maps");
+ flag.basemap->description = _("Remove base raster maps");
+ flag.basemap->guisection = _("Raster");
M_read_list(FALSE, &nlist);
opt = (struct Option **)G_calloc(nlist, sizeof(struct Option *));
@@ -95,10 +97,11 @@
exit(EXIT_FAILURE);
if (flag.regex->answer && flag.extended->answer)
- G_fatal_error(_("-r and -e are mutually exclusive"));
+ G_fatal_error(_("-%c and -%c are mutually exclusive"),
+ flag.regex->key, flag.extended->key);
if (!flag.force->answer)
- G_message(_("The following files would be deleted:"));
+ G_message(_("The following data base element files would be deleted:"));
for (n = 0; n < nlist; n++) {
o = opt[n];
@@ -106,16 +109,15 @@
G_free((char *)o->description);
- location_path = G_location_path();
mapset = G_mapset();
- alias = M_get_list(n)->alias;
+ option = M_get_list(n);
if (opt[n]->answers) {
G_file_name(path, M_get_list(n)->element[0], "", mapset);
if (access(path, 0) != 0)
continue;
- rast = !G_strcasecmp(alias, "rast");
+ rast = !G_strcasecmp(option->alias, "rast");
for (i = 0; (name = opt[n]->answers[i]); i++) {
if (!flag.regex->answer && !flag.extended->answer)
filter = G_ls_glob_filter(name, 0);
@@ -132,7 +134,7 @@
for (j = 0; j < num_files; j++) {
if (!flag.force->answer) {
- fprintf(stdout, "%s/%s@%s\n", alias, files[j],
+ fprintf(stdout, "%s/%s@%s\n", option->alias, files[j],
mapset);
continue;
@@ -148,8 +150,8 @@
- G_message(" ");
- G_message(_("You must use the force flag to actually remove them. Exiting."));
+ G_important_message(_("You must use the force flag (-%c) to actually "
+ "remove them. Exiting."), flag.force->key);
exit(result);
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2011-08-01 15:45:36 UTC (rev 47338)
+++ grass/trunk/general/g.remove/main.c 2011-08-01 16:28:17 UTC (rev 47339)
@@ -1,4 +1,4 @@
* MODULE: cmd
@@ -86,15 +86,15 @@
int i, n, nlist;
struct GModule *module;
- struct Option **parm, *p;
+ struct Option **parm;
struct Flag *force_flag;
const char *name, *mapset;
- const char *location_path;
- int result = EXIT_SUCCESS;
- int force = 0;
+ int result;
G_gisinit(argv[0]);
@@ -107,28 +107,24 @@
force_flag = G_define_flag();
force_flag->key = 'f';
- force_flag->description = _("Force remove");
+ force_flag->description = _("Force removal for base raster maps");
parm = (struct Option **)G_calloc(nlist, sizeof(struct Option *));
- p = parm[n] = M_define_option(n, "removed", YES);
+ parm[n] = M_define_option(n, "removed", YES);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (force_flag->answer)
- force = 1;
if (parm[n]->answers)
for (i = 0; (name = parm[n]->answers[i]); i++) {
if (G_strcasecmp(M_get_list(n)->alias, "rast") == 0 &&
- check_reclass(name, mapset, force))
+ check_reclass(name, mapset, force_flag->answer))
continue;
if (M_do_remove(n, name) == 1) {
