[GRASS-SVN] r47347 - grass/trunk/raster/r.watershed/ram
Tue Aug 2 07:54:07 EDT 2011
Author: mmetz
Date: 2011-08-02 04:54:07 -0700 (Tue, 02 Aug 2011)
New Revision: 47347
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/close_maps.c
   grass/trunk/raster/r.watershed/ram/def_basin.c
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/do_cum.c
   grass/trunk/raster/r.watershed/ram/find_pour.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/ram/over_cells.c
   grass/trunk/raster/r.watershed/ram/split_str.c
fix depression handling (ram)
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2011-08-02 11:54:07 UTC (rev 47347)
@@ -94,7 +94,7 @@
 /* do_astar.c */
 int do_astar(void);
-int add_pt(int, int, CELL, CELL);
+int add_pt(int, int, CELL);
 int drop_pt(void);
 int sift_up(int, CELL);
 double get_slope(int, int, int, int, CELL, CELL);
Modified: grass/trunk/raster/r.watershed/ram/close_maps.c
--- grass/trunk/raster/r.watershed/ram/close_maps.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/close_maps.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -27,157 +27,128 @@
     sum = sum_sqr = stddev = 0.0;
     if (wat_flag) {
 	fd = Rast_open_new(wat_name, DCELL_TYPE);
-	    if (abs_acc) {
-		G_warning("Writing out only positive flow accumulation values.");
-		G_warning("Cells with a likely underestimate for flow accumulation can no longer be identified.");
-		for (r = 0; r < nrows; r++) {
-		    Rast_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
-		    for (c = 0; c < ncols; c++) {
-			dvalue = wat[SEG_INDEX(wat_seg, r, c)];
-			if (Rast_is_d_null_value(&dvalue) == 0 && dvalue) {
-			    dvalue = ABS(dvalue);
-			    dbuf[c] = dvalue;
-			    sum += dvalue;
-			    sum_sqr += dvalue * dvalue;
+	if (abs_acc) {
+	    G_warning("Writing out only positive flow accumulation values.");
+	    G_warning("Cells with a likely underestimate for flow accumulation can no longer be identified.");
+	    for (r = 0; r < nrows; r++) {
+		Rast_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
+		for (c = 0; c < ncols; c++) {
+		    dvalue = wat[SEG_INDEX(wat_seg, r, c)];
+		    if (Rast_is_d_null_value(&dvalue) == 0 && dvalue) {
+			dvalue = ABS(dvalue);
+			dbuf[c] = dvalue;
+			sum += dvalue;
+			sum_sqr += dvalue * dvalue;
-		    Rast_put_row(fd, dbuf, DCELL_TYPE);
+		Rast_put_row(fd, dbuf, DCELL_TYPE);
-	    else {
-			    dbuf[c] = dvalue;
-			    sum += dvalue;
+	else {
+			dbuf[c] = dvalue;
+			sum += dvalue;
-	    Rast_close(fd);
+	Rast_close(fd);
-	    stddev =
-		sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
-	    G_debug(1, "stddev: %f", stddev);
+	stddev =
+	    sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
+	G_debug(1, "stddev: %f", stddev);
-	    /* set nice color rules: yellow, green, cyan, blue, black */
+	/* set nice color rules: yellow, green, cyan, blue, black */
-	    lstddev = log(stddev);
+	lstddev = log(stddev);
-	    Rast_read_fp_range(wat_name, this_mapset, &accRange);
-	    min = max = 0;
-	    Rast_get_fp_range_min_max(&accRange, &min, &max);
+	Rast_read_fp_range(wat_name, this_mapset, &accRange);
+	min = max = 0;
+	Rast_get_fp_range_min_max(&accRange, &min, &max);
-	    Rast_init_colors(&colors);
+	Rast_init_colors(&colors);
-	    if (min < 0) {
-		if (min < (-stddev - 1)) {
-		    clr_min = min - 1;
-		    clr_max = -stddev - 1;
-		    Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0,
-					      0, 0, &colors);
-		clr_min = -stddev - 1.;
-		clr_max = -1. * exp(lstddev * 0.75);
+	if (min < 0) {
+	    if (min < (-stddev - 1)) {
+		clr_min = min - 1;
+		clr_max = -stddev - 1;
-					  0, 255, &colors);
-		clr_min = clr_max;
-		clr_max = -1. * exp(lstddev * 0.5);
-		Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0,
-					  255, 255, &colors);
-		clr_max = -1. * exp(lstddev * 0.35);
-		Rast_add_d_color_rule(&clr_min, 0, 255, 255, &clr_max, 0,
-					  255, 0, &colors);
-		clr_max = -1.;
-		Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 255,
-					  255, 0, &colors);
+					  0, 0, &colors);
-	    clr_min = -1.;
-	    clr_max = 1.;
-	    Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 255,
-				      255, 0, &colors);
-	    clr_min = 1;
-	    clr_max = exp(lstddev * 0.35);
-	    Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 0,
-				      255, 0, &colors);
+	    clr_min = -stddev - 1.;
+	    clr_max = -1. * exp(lstddev * 0.75);
+	    Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0,
+				      0, 255, &colors);
 	    clr_min = clr_max;
-	    clr_max = exp(lstddev * 0.5);
-	    Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 0,
+	    clr_max = -1. * exp(lstddev * 0.5);
+	    Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0,
 				      255, 255, &colors);
 	    clr_min = clr_max;
-	    clr_max = exp(lstddev * 0.75);
+	    clr_max = -1. * exp(lstddev * 0.35);
-				      0, 255, &colors);
+				      255, 0, &colors);
 	    clr_min = clr_max;
-	    clr_max = stddev + 1.;
-	    Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0, 0,
-				      0, &colors);
+	    clr_max = -1.;
+	    Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 255,
+				      255, 0, &colors);
+	clr_min = -1.;
+	clr_max = 1.;
+	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 255,
+				  255, 0, &colors);
+	clr_min = 1;
+	clr_max = exp(lstddev * 0.35);
+	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 0,
+				  255, 0, &colors);
+	clr_min = clr_max;
+	clr_max = exp(lstddev * 0.5);
+	Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 0,
+				  255, 255, &colors);
+	clr_max = exp(lstddev * 0.75);
+	Rast_add_d_color_rule(&clr_min, 0, 255, 255, &clr_max, 0,
+				  0, 255, &colors);
+	clr_max = stddev + 1.;
+	Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0, 0,
+				  0, &colors);
-	    if (max > 0 && max > stddev + 1) {
-		clr_min = stddev + 1;
-		clr_max = max + 1;
-		Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0, 0,
-					  0, &colors);
-	    Rast_write_colors(wat_name, this_mapset, &colors);
+	if (max > 0 && max > stddev + 1) {
+	    clr_min = stddev + 1;
+	    clr_max = max + 1;
+	    Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0, 0,
+				      0, &colors);
+	Rast_write_colors(wat_name, this_mapset, &colors);
     /* TODO: elevation == NULL -> drainage direction == NULL (wat == 0 where ele == NULL) */
     /* keep drainage direction == 0 for real depressions */
     if (asp_flag) {
 	fd = Rast_open_c_new(asp_name);
-		Rast_set_c_null_value(buf, ncols);	/* reset row to all NULL */
+	    Rast_set_c_null_value(buf, ncols);	/* reset row to all NULL */
+		if (!Rast_is_d_null_value(&dvalue))
 		    buf[c] = asp[SEG_INDEX(asp_seg, r, c)];
-		Rast_put_row(fd, buf, CELL_TYPE);
-	    Rast_close(fd);
+	    Rast_put_row(fd, buf, CELL_TYPE);
+	Rast_close(fd);
 	Rast_make_aspect_colors(&colors, 0, 8);
 	Rast_write_colors(asp_name, this_mapset, &colors);
     G_free(asp);
-    /* visual output no longer needed */
-    if (dis_flag) {
-	fd = Rast_open_c_new(dis_name);
-	    if (bas_thres <= 0)
-		bas_thres = 60;
-		    buf[c] = wat[SEG_INDEX(wat_seg, r, c)];
-		    if (buf[c] < 0) {
-			buf[c] = 0;
-		    else {
-			value = FLAG_GET(swale, r, c);
-			if (value) {
-			    buf[c] = bas_thres;
-	    Rast_close(fd);
-	Rast_make_rainbow_colors(&colors, 1, 120);
-	Rast_write_colors(dis_name, this_mapset, &colors);
     flag_destroy(swale);
        Rast_free_colors(&colors);
@@ -186,31 +157,27 @@
     if (ls_flag) {
 	fd = Rast_open_new(ls_name, DCELL_TYPE);
-		    dbuf[c] = l_s[SEG_INDEX(l_s_seg, r, c)];
+		dbuf[c] = l_s[SEG_INDEX(l_s_seg, r, c)];
-	    Rast_close(fd);
+	Rast_close(fd);
 	G_free(l_s);
     if (sl_flag) {
 	fd = Rast_open_new(sl_name, DCELL_TYPE);
-		    dbuf[c] = s_l[SEG_INDEX(s_l_seg, r, c)];
-		    if (dbuf[c] > max_length)
-			dbuf[c] = max_length;
+		dbuf[c] = s_l[SEG_INDEX(s_l_seg, r, c)];
+		if (dbuf[c] > max_length)
+		    dbuf[c] = max_length;
-	    Rast_close(fd);
+	Rast_close(fd);
     if (sl_flag || ls_flag || sg_flag)
@@ -218,15 +185,13 @@
     if (sg_flag) {
 	fd = Rast_open_new(sg_name, DCELL_TYPE);
-		    dbuf[c] = s_g[SEG_INDEX(s_g_seg, r, c)];
+		dbuf[c] = s_g[SEG_INDEX(s_g_seg, r, c)];
-	    Rast_close(fd);
+	Rast_close(fd);
 	G_free(s_g);
Modified: grass/trunk/raster/r.watershed/ram/def_basin.c
--- grass/trunk/raster/r.watershed/ram/def_basin.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/def_basin.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -14,6 +14,8 @@
 	for (r = row - 1, rr = 0; rr < 3; r++, rr++) {
 	    for (c = col - 1, cc = 0; cc < 3; c++, cc++) {
 		if (r >= 0 && c >= 0 && r < nrows && c < ncols) {
+		    if (r == row && c == col)
+			continue;
 		    value = asp[SEG_INDEX(asp_seg, r, c)];
 		    if (value < -1)
 			value = -value;
@@ -44,6 +46,8 @@
+			continue;
 		    direction = asp[SEG_INDEX(asp_seg, r, c)];
 		    if (direction == drain[rr][cc]) {
 			thisdir = updrain[rr][cc];
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -153,7 +153,7 @@
 		/* add neighbour as new point if not in the list */
 		if (is_in_list == 0 && skip_diag == 0) {
-		    add_pt(upr, upc, alt_nbr[ct_dir], alt_val);
+		    add_pt(upr, upc, alt_nbr[ct_dir]);
 		    /* set flow direction */
 		    asp[index_up] = drain[upr - r + 1][upc - c + 1];
@@ -165,6 +165,10 @@
 			if (wat[index_doer] > 0)
 			    wat[index_doer] = -wat[index_doer];
+		    /* neighbour is inside real depression, not yet worked */
+		    else if (asp[index_up] == 0) {
+			asp[index_up] = drain[upr - r + 1][upc - c + 1];
 	    }    /* end if in region */
 	}    /* end sides */
@@ -205,7 +209,7 @@
 /* add point routine for min heap */
-int add_pt(int r, int c, CELL ele, CELL downe)
+int add_pt(int r, int c, CELL ele)
     FLAG_SET(in_list, r, c);
Modified: grass/trunk/raster/r.watershed/ram/do_cum.c
--- grass/trunk/raster/r.watershed/ram/do_cum.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/do_cum.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -53,13 +53,6 @@
 	    wat[down_index] = valued;
 	    valued = ABS(valued) + 0.5;
 	    is_swale = FLAG_GET(swale, r, c);
-	    /* update asp for depression */
-	    if (is_swale && pit_flag) {
-		if (aspect > 0 && asp[down_index] == 0) {
-		    aspect = -aspect;
-		    asp[this_index] = aspect;
 	    if (is_swale || ((int)valued) >= threshold) {
 		FLAG_SET(swale, dr, dc);
@@ -340,13 +333,6 @@
-		if (aspect > 0 && asp[SEG_INDEX(asp_seg, r_max, c_max)] == 0) {
-		    aspect = -aspect;
 	    /* start new stream */
 	    value = ABS(value) + 0.5;
 	    if (!is_swale && (int)value >= threshold && stream_cells < 1 &&
@@ -380,14 +366,10 @@
 double mfd_pow(double base, int exp)
-    int x;
-    double result;
+    int i;
+    double result = base;
-    result = base;
-    if (exp == 1)
-	return result;
-    for (x = 2; x <= exp; x++) {
+    for (i = 2; i <= exp; i++) {
 	result *= base;
     return result;
Modified: grass/trunk/raster/r.watershed/ram/find_pour.c
--- grass/trunk/raster/r.watershed/ram/find_pour.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/find_pour.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -16,7 +16,7 @@
 	northing = window.north - (row + .5) * window.ns_res;
 	for (col = 0; col < ncols; col++) {
 	    value = FLAG_GET(swale, row, col);
-	    if (value && asp[SEG_INDEX(asp_seg, row, col)] < 0) {
+	    if (value && asp[SEG_INDEX(asp_seg, row, col)] <= 0) {
 		basin_num += 2;
 		if (arm_flag) {
 		    easting = window.west + (col + .5) * window.ew_res;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -238,23 +238,7 @@
 	G_free(dbuf);
-    /* depression: drainage direction will be set to zero later */
-    if (pit_flag) {
-	buf = Rast_allocate_c_buf();
-	fd = Rast_open_old(pit_name, "");
-	    Rast_get_c_row(fd, buf, r);
-		asp_value = buf[c];
-		if (!Rast_is_c_null_value(&asp_value) && asp_value)
-		    asp[SEG_INDEX(asp_seg, r, c)] = 1;
-	Rast_close(fd);
-	G_free(buf);
-    /* this is also creating streams... */
+    /* overland blocking map; this is also creating streams... */
     if (ob_flag) {
 	fd = Rast_open_old(ob_name, "");
@@ -302,129 +286,32 @@
     /* heap is empty */
     heap_size = 0;
+    if (pit_flag) {
+	buf = Rast_allocate_c_buf();
+	fd = Rast_open_old(pit_name, "");
+    else
+	buf = NULL;
     first_astar = first_cum = -1;
-    if (MASK_flag) {
-	    G_percent(r, nrows, 3);
-		seg_idx = SEG_INDEX(wat_seg, r, c);
-		if (FLAG_GET(worked, r, c)) {
-		    wat[seg_idx] = 0;
-		else {
-		    if (er_flag)
-			s_l[seg_idx] = half_res;
-		    asp_value = asp[seg_idx];
-		    if (r == 0 || c == 0 || r == nrows - 1 ||
-			c == ncols - 1 || asp_value != 0) {
-			wat_value = wat[seg_idx];
-			if (wat_value > 0)
-			    wat[seg_idx] = -wat_value;
-			/* set depression */
-			if (asp_value) {
-			    asp_value = 0;
-			    wat[seg_idx] = ABS(wat_value);
-			else if (r == 0)
-			    asp_value = -2;
-			else if (c == 0)
-			    asp_value = -4;
-			else if (r == nrows - 1)
-			    asp_value = -6;
-			else if (c == ncols - 1)
-			    asp_value = -8;
-			asp[seg_idx] = asp_value;
-			alt_value = alt[seg_idx];
-			add_pt(r, c, alt_value, alt_value);
-		    else if (FLAG_GET(worked, r - 1, c)) {
-			asp[seg_idx] = -2;
-		    else if (FLAG_GET(worked, r + 1, c)) {
-			asp[seg_idx] = -6;
-		    else if (FLAG_GET(worked, r, c - 1)) {
-			asp[seg_idx] = -4;
-		    else if (FLAG_GET(worked, r, c + 1)) {
-			asp[seg_idx] = -8;
-		    else if (sides == 8 && FLAG_GET(worked, r - 1, c - 1)) {
-			asp[seg_idx] = -3;
-		    else if (sides == 8 && FLAG_GET(worked, r - 1, c + 1)) {
-			asp[seg_idx] = -1;
-		    else if (sides == 8 && FLAG_GET(worked, r + 1, c - 1)) {
-			asp[seg_idx] = -5;
-		    else if (sides == 8 && FLAG_GET(worked, r + 1, c + 1)) {
-			asp[seg_idx] = -7;
+	G_percent(r, nrows, 3);
+	if (pit_flag)
+	    Rast_get_c_row(fd, buf, r);
+	    seg_idx = SEG_INDEX(wat_seg, r, c);
+	    if (FLAG_GET(worked, r, c)) {
+		wat[seg_idx] = 0;
-    else {
+	    else {
+		asp_value = asp[seg_idx];
 		if (er_flag)
+		    c == ncols - 1) {
-		    if (wat_value > 0) {
+		    if (wat_value > 0)
-		    if (asp_value) {
-			asp_value = 0;
-		    else if (r == 0)
+		    if (r == 0)
 			asp_value = -2;
 		    else if (c == 0)
 			asp_value = -4;
@@ -434,14 +321,91 @@
 			asp_value = -8;
+		    add_pt(r, c, alt_value);
+		else if (FLAG_GET(worked, r - 1, c)) {
+		    alt_value = alt[seg_idx];
+		    asp[seg_idx] = -2;
+		    wat_value = wat[seg_idx];
+			wat[seg_idx] = -wat_value;
+		else if (FLAG_GET(worked, r + 1, c)) {
+		    asp[seg_idx] = -6;
+		else if (FLAG_GET(worked, r, c - 1)) {
+		    asp[seg_idx] = -4;
+		else if (FLAG_GET(worked, r, c + 1)) {
+		    asp[seg_idx] = -8;
+		else if (sides == 8 && FLAG_GET(worked, r - 1, c - 1)) {
+		    asp[seg_idx] = -3;
+		else if (sides == 8 && FLAG_GET(worked, r - 1, c + 1)) {
+		    asp[seg_idx] = -1;
+		else if (sides == 8 && FLAG_GET(worked, r + 1, c - 1)) {
+		    asp[seg_idx] = -5;
+		else if (sides == 8 && FLAG_GET(worked, r + 1, c + 1)) {
+		    asp[seg_idx] = -7;
+		/* real depression ? */
+		if (pit_flag && asp[seg_idx] == 0) {
+		    if (!Rast_is_c_null_value(&buf[c]) && buf[c] != 0) {
     G_percent(r, nrows, 1);	/* finish it */
+    if (pit_flag) {
+	Rast_close(fd);
+	G_free(buf);
     return 0;
Modified: grass/trunk/raster/r.watershed/ram/over_cells.c
--- grass/trunk/raster/r.watershed/ram/over_cells.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/over_cells.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -13,6 +13,8 @@
     for (r = row - 1, rr = 0; r <= row + 1; r++, rr++) {
 	for (c = col - 1, cc = 0; c <= col + 1; c++, cc++) {
+		    continue;
 		if (value == drain[rr][cc]) {
 		    overland_cells(r, c, basin_num, haf_num, &new_ele);
@@ -58,6 +60,8 @@
 	for (r = next_r - 1, rr = 0; r <= next_r + 1; r++, rr++) {
 	    for (c = next_c - 1, cc = 0; c <= next_c + 1; c++, cc++) {
+			continue;
 		    idx = SEG_INDEX(bas_seg, r, c);
 		    if (asp[idx] == drain[rr][cc]) {
 			if (top >= ocs_alloced) {
Modified: grass/trunk/raster/r.watershed/ram/split_str.c
--- grass/trunk/raster/r.watershed/ram/split_str.c	2011-08-02 10:25:10 UTC (rev 47346)
+++ grass/trunk/raster/r.watershed/ram/split_str.c	2011-08-02 11:54:07 UTC (rev 47347)
@@ -22,6 +22,8 @@
+		    continue;
 		aspect = asp[SEG_INDEX(asp_seg, r, c)];
 		if (aspect == drain[rr][cc]) {
 		    doit = 1;
