[GRASS-SVN] r47368 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 3 08:11:02 EDT 2011
Author: martinl
Date: 2011-08-03 05:11:02 -0700 (Wed, 03 Aug 2011)
New Revision: 47368
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
wxGUI: fix encoding strings
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2011-08-03 11:48:59 UTC (rev 47367)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py 2011-08-03 12:11:02 UTC (rev 47368)
@@ -606,7 +606,7 @@
ps.stdin = None
Debug.msg(3, "gcmd.RunCommand(): decoding string")
- stdout, stderr = map(lambda x: utils.DecodeString(x) if type(x) is types.StringType else x, ps.communicate())
+ stdout, stderr = map(utils.DecodeString, ps.communicate())
ret = ps.returncode
Debug.msg(1, "gcmd.RunCommand(): get return code %d" % ret)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2011-08-03 11:48:59 UTC (rev 47367)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2011-08-03 12:11:02 UTC (rev 47368)
@@ -26,6 +26,7 @@
import threading
import Queue
import codecs
+import locale
import wx
import wx.stc
@@ -357,20 +358,20 @@
def Redirect(self):
"""!Redirect stdout/stderr
- @return True redirected
- @return False failed
if Debug.GetLevel() == 0 and int(grass.gisenv().get('DEBUG', 0)) == 0:
# don't redirect when debugging is enabled
sys.stdout = self.cmd_stdout
sys.stderr = self.cmd_stderr
- return True
else:
- sys.stdout = sys.__stdout__
- sys.stderr = sys.__stderr__
- return False
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ sys.stdout = codecs.getwriter(enc)(sys.__stdout__)
+ sys.stderr = codecs.getwriter(enc)(sys.__stderr__)
+ else:
+ sys.stdout = sys.__stdout__
+ sys.stderr = sys.__stderr__
def WriteLog(self, text, style = None, wrap = None,
switchPage = False):
"""!Generic method for writing log message in
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-08-03 11:48:59 UTC (rev 47367)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2011-08-03 12:11:02 UTC (rev 47368)
@@ -300,7 +300,7 @@
map = fullname,
fs = ';')
if ret != 0:
- sys.stderr.write(_("Vector map <%s>") % fullname + ": " + msg + "\n")
+ sys.stderr.write(_("Vector map <%s>: %s\n") % (fullname, msg))
return layers
Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
@@ -655,22 +655,20 @@
return ret.splitlines()
def DecodeString(string):
- """!Return decoded string
+ """!Decode string using system encoding
- String is decoded as unicode, on failure
- are used system locales.
@param string string to be decoded
@return decoded string
- try:
- return string.decode('utf-8')
- except LookupError:
- enc = locale.getdefaultlocale()[1]
- if enc:
- return string.decode(enc)
+ if not string:
+ return string
+ if enc:
+ Debug.msg(5, "DecodeString(): enc=%s" % enc)
+ return string.decode(enc)
return string
def EncodeString(string):
@@ -680,8 +678,11 @@
@return encoded string
+ if not string:
+ return string
if enc:
+ Debug.msg(5, "EncodeString(): enc=%s" % enc)
return string.encode(enc)
return string
