[GRASS-SVN] r47373 - grass-addons/raster/r.basin
svn_grass at osgeo.org
Wed Aug 3 09:55:19 EDT 2011
Author: madi
Date: 2011-08-03 06:55:19 -0700 (Wed, 03 Aug 2011)
New Revision: 47373
grass-addons/raster/r.basin/r.basin.py
print statements replaced by grass.message
Modified: grass-addons/raster/r.basin/r.basin.py
--- grass-addons/raster/r.basin/r.basin.py 2011-08-03 12:53:10 UTC (rev 47372)
+++ grass-addons/raster/r.basin/r.basin.py 2011-08-03 13:55:19 UTC (rev 47373)
@@ -70,7 +70,7 @@
from numpy import zeros
if not os.environ.has_key("GISBASE"):
- print "You must be in GRASS GIS to run this program."
+ grass.message( "You must be in GRASS GIS to run this program." )
sys.exit(1)
def main():
@@ -122,7 +122,7 @@
dict_region = grass.parse_key_val(info_region, ':')
resolution = float(dict_region['nsres'])
th = 1000000 / (resolution**2)
- print 'threshold : ', th
+ grass.message( "threshold : %s" % th )
else :
th = options['threshold']
@@ -134,7 +134,7 @@
# Delineation of basin
grass.run_command('r.stream.basins', dir = r_drainage , basins = r_basin , coors = '%s,%s' % (east , north) )
- print "Delineation of basin done"
+ grass.message( "Delineation of basin done" )
# Backup and mask
elevation_name = r_elevation = r_elevation.split('@')[0]
@@ -157,7 +157,7 @@
grass.run_command('v.to.db', map = v_basin , type = 'line,boundary' , layer = 1, qlayer = 1, option = 'perimeter' , units = 'kilometers', columns = 'cat', qcolumn = 'cat')
# Creation of order maps: strahler, horton, hack, shreeve
- print 'creating', r_hack
+ grass.message( "Creating %s" % r_hack )
grass.run_command('r.stream.order', stream = r_stream_e , dir = r_drainage_e , strahler = r_strahler , shreve = r_shreve , horton = r_horton , hack = r_hack )
# Distance to outlet
@@ -242,7 +242,7 @@
D_topo = float(grass.read_command('v.info', map = v_mainchannel_dim, layer = 1, flags = 't').split('\n')[2].split('=')[1])
except:
D_topo = 1
- print 'Topological Diameter = WARNING'
+ grass.message( "Topological Diameter = WARNING" )
# Mean slope of mainchannel
grass.run_command('v.to.points', flags='n', input = v_mainchannel_dim, output = v_mainchannel_dim+'_point', type = 'line')
@@ -262,7 +262,7 @@
pendenze.append(pendenza)
mainchannel_slope = sum(pendenze) / len(pendenze) * 100
except :
- print 'Mean slope of mainchannel = WARNING'
+ grass.message( "Mean slope of mainchannel = WARNING" )
# Elongation Ratio
R_al = (2 * math.sqrt( area_basin / math.pi) ) / mainchannel
@@ -299,7 +299,7 @@
# Statistics
stream_stats = grass.read_command('r.stream.stats', stream = r_strahler, dir = r_drainage_e, dem = r_elevation+'_crop' )
- print 'output r.stream.stats', stream_stats
+ grass.message( "output r.stream.stats %s" % stream_stats )
stream_stats_summary = stream_stats.split('\n')[4].split('|')
stream_stats_mom = stream_stats.split('\n')[8].split('|')
Max_order , Num_streams , Len_streams , Stream_freq = stream_stats_summary[0] , stream_stats_summary[1] , stream_stats_summary[2] , stream_stats_summary[5]
@@ -382,45 +382,44 @@
parametri_bacino["Slope_ratio"] = float(Slope_ratio)
parametri_bacino["drainage_density"] = float(drainage_density)
parametri_bacino["FSF"] = float(FSF)
- print "\n"
- print "##################################"
- print "Morphometric parameters of basin :"
- print "##################################\n"
- print "Easting Centroid of basin : " , basin_east
- print "Northing Centroid of Basin : " , basin_north
- print "Rectangle containing basin (N-W) : " , nw
- print "Rectangle containing basin (S-E) : " , se
- print "Area of basin [km^2] : " , '%.2f' % area_basin
- print "Perimeter of basin [km] : " , '%.2f' % perimeter_basin
- print "Max Elevation [m s.l.m.] : " , '%.2f' % H1
- print "Min Elevation [m s.l.m.]: " , '%.2f' % H2
- print "Elevation Difference [m]: " , '%.2f' % HM
- print "Mean Elevation [m s.l.m.]: " , '%.2f' % mean_elev
- print "Mean Slope : " , mean_slope
- print "Length of Directing Vector [km] : " , '%.2f' % L_orienting_vect
- print "Prevalent Orientation [degree from north, counterclockwise] : " , '%.3f' % prevalent_orientation
- print "Compactness Coefficient : " , '%.2f' % C_comp
- print "Circularity Ratio : " , '%.2f' % R_c
- print "Topological Diameter : " , '%.2f' % D_topo
- print "Elongation Ratio : " , '%.2f' % R_al
- print "Shape Factor : " , '%.2f' % S_f
- print "Concentration Time (Giandotti, 1934) [hr] : " , '%.2f' % t_c
- print "Length of Mainchannel [km] : " , '%.2f' % mainchannel
- print "Mean slope of mainchannel [%]: " , '%.2f' % mainchannel_slope
- print "Mean hillslope length [m] : " , '%.2f' % mean_hillslope_length
- print "Magnitudo : " , '%.0f' % magnitudo
- print "Max order (Strahler) : " , Max_order
- print "Number of streams : " , Num_streams
- print "Total Stream Length [km] : " , Len_streams
- print "First order stream frequency : " , '%.2f' % FSF
- print "Drainage Density [km/km^2]: " , '%.2f' % drainage_density
- print "Bifurcation Ratio (Horton) : " , Bif_ratio
- print "Length Ratio (Horton) : " , Len_ratio
- print "Area ratio (Horton) : " , Area_ratio
- print "Slope ratio (Horton): " , Slope_ratio, "\n"
- #print parametri_bacino
- grass.run_command('g.message' , message = 'Done!')
+ grass.message( "\n" )
+ grass.message( "##################################" )
+ grass.message( "Morphometric parameters of basin :" )
+ grass.message( "##################################\n" )
+ grass.message( "Easting Centroid of basin : %s " % basin_east )
+ grass.message( "Northing Centroid of Basin : %s " % basin_north )
+ grass.message( "Rectangle containing basin N-W : %s , %s " % nw )
+ grass.message( "Rectangle containing basin S-E : %s , %s " % se )
+ grass.message( "Area of basin [km^2] : %s " % area_basin )
+ grass.message( "Perimeter of basin [km] : %s " % perimeter_basin )
+ grass.message( "Max Elevation [m s.l.m.] : %s " % H1 )
+ grass.message( "Min Elevation [m s.l.m.]: %s " % H2 )
+ grass.message( "Elevation Difference [m]: %s " % HM )
+ grass.message( "Mean Elevation [m s.l.m.]: %s " % mean_elev )
+ grass.message( "Mean Slope : %s " % mean_slope )
+ grass.message( "Length of Directing Vector [km] : %s " % L_orienting_vect )
+ grass.message( "Prevalent Orientation [degree from north, counterclockwise] : %s " % prevalent_orientation )
+ grass.message( "Compactness Coefficient : %s " % C_comp )
+ grass.message( "Circularity Ratio : %s " % R_c )
+ grass.message( "Topological Diameter : %s " % D_topo )
+ grass.message( "Elongation Ratio : %s " % R_al )
+ grass.message( "Shape Factor : %s " % S_f )
+ grass.message( "Concentration Time (Giandotti, 1934) [hr] : %s " % t_c )
+ grass.message( "Length of Mainchannel [km] : %s " % mainchannel )
+ grass.message( "Mean slope of mainchannel [percent] : %f " % mainchannel_slope )
+ grass.message( "Mean hillslope length [m] : %s " % mean_hillslope_length )
+ grass.message( "Magnitudo : %s " % magnitudo )
+ grass.message( "Max order (Strahler) : %s " % Max_order )
+ grass.message( "Number of streams : %s " % Num_streams )
+ grass.message( "Total Stream Length [km] : %s " % Len_streams )
+ grass.message( "First order stream frequency : %s " % FSF )
+ grass.message( "Drainage Density [km/km^2] : %s " % drainage_density )
+ grass.message( "Bifurcation Ratio (Horton) : %s " % Bif_ratio )
+ grass.message( "Length Ratio (Horton) : %s " % Len_ratio )
+ grass.message( "Area ratio (Horton) : %s " % Area_ratio )
+ grass.message( "Slope ratio (Horton): %s " % Slope_ratio )
+ grass.message( "Done!")
if __name__ == "__main__":
options, flags = grass.parser()
