[GRASS-SVN] r47381 - in grass/branches/releasebranch_6_4/scripts:
v.db.addtable v.db.dropcol v.db.droptable v.db.renamecol
v.db.univar v.db.update
svn_grass at osgeo.org
Wed Aug 3 12:33:44 EDT 2011
Author: neteler
Date: 2011-08-03 09:33:44 -0700 (Wed, 03 Aug 2011)
New Revision: 47381
grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol
grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable
grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
added support for layer selection and column name in wxGUI
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable
--- grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addtable/v.db.addtable 2011-08-03 16:33:44 UTC (rev 47381)
@@ -33,7 +33,7 @@
#%end
#%option
#% key: layer
-#% type: integer
+#% gisprompt: old_layer,layer,layer
#% description: Layer where to add new attribute table
#% answer: 1
#% required : no
Modified: grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.dropcol/v.db.dropcol 2011-08-03 16:33:44 UTC (rev 47381)
@@ -33,7 +33,7 @@
#%option
#% key: layer
-#% type: integer
#% description: Layer where to drop column
#% answer: 1
#% required : no
@@ -41,14 +41,14 @@
#%option
#% key: column
-#% type: string
-#% description: Name of the column
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#% description: Name of the column to drop
#% required : yes
#%end
if [ -z "$GISBASE" ] ; then
- echo 'You must be in GRASS GIS to run this program' >&2
+ echo "You must be in GRASS GIS to run this program." 1>&2
exit 1
fi
Modified: grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable
--- grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.droptable/v.db.droptable 2011-08-03 16:33:44 UTC (rev 47381)
@@ -1,5 +1,5 @@
#!/bin/sh
# MODULE: v.db.droptable
@@ -37,7 +37,7 @@
#%end
#%option
#% key: layer
-#% type: integer
#% description: Layer from which to drop linked attribute table
#% answer: 1
#% required : no
@@ -132,7 +132,7 @@
fi
# write cmd history:
- v.support "${GIS_OPT_MAP}" cmdhist="${CMDLINE}"
+ v.support map="${GIS_OPT_MAP}" cmdhist="${CMDLINE}"
else
g.message "Leaving map/table unchanged."
Modified: grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.renamecol/v.db.renamecol 2011-08-03 16:33:44 UTC (rev 47381)
@@ -33,7 +33,7 @@
#%end
#%option
#% key: layer
-#% type: integer
#% description: Layer where to rename column
#% answer: 1
#% required : no
Modified: grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
--- grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2011-08-03 16:33:44 UTC (rev 47381)
@@ -31,7 +31,7 @@
#%End
#%option
#% key: column
-#% type: string
#% description: Column on which to calculate statistics (must be numeric)
#% required : yes
#%end
@@ -57,7 +57,7 @@
exit 1
-fi
+fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
Modified: grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update
--- grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2011-08-03 16:16:39 UTC (rev 47380)
+++ grass/branches/releasebranch_6_4/scripts/v.db.update/v.db.update 2011-08-03 16:33:44 UTC (rev 47381)
@@ -27,8 +27,8 @@
#%end
#%option
#% key: layer
-#% type: integer
#% description: Layer to which the table to be changed is connected
#% answer: 1
#% required : no
