[GRASS-SVN] r47393 - grass/trunk/general/g.parser
svn_grass at osgeo.org
Wed Aug 3 13:55:32 EDT 2011
Author: martinl
Date: 2011-08-03 10:55:32 -0700 (Wed, 03 Aug 2011)
New Revision: 47393
grass/trunk/general/g.parser/main.c
g.parser: use EXIT_SUCCESS/FAILURE
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2011-08-03 17:47:09 UTC (rev 47392)
+++ grass/trunk/general/g.parser/main.c 2011-08-03 17:55:32 UTC (rev 47393)
@@ -9,7 +9,7 @@
* Paul Kelly <paul-grass stjohnspoint.co.uk>,
* Radim Blazek <radim.blazek gmail.com>
* PURPOSE:
- * COPYRIGHT: (C) 2001-2007, 2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2007, 2010-2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -275,7 +275,7 @@
return;
- fprintf(stderr, "Unknown option parameter \"%s\" at line %d\n",
+ fprintf(stderr, _("Unknown option parameter \"%s\" at line %d\n"),
cmd, ctx->line);
@@ -301,7 +301,7 @@
printf("opt_%s=%s\n", option->key,
option->answer ? option->answer : "");
- return 0;
+ return EXIT_SUCCESS;
static int reinvoke_script(const struct context *ctx, const char *filename)
@@ -357,16 +357,16 @@
ret = G_spawn(shell, shell, filename, "@ARGS_PARSED@", NULL);
G_debug(1, "ret = %d", ret);
if (ret == -1) {
- perror("G_spawn() failed");
- return 1;
+ perror(_("G_spawn() failed"));
+ return EXIT_FAILURE;
- return ret;
#else
execl(filename, filename, "@ARGS_PARSED@", NULL);
- perror("execl() failed");
- return 1;
+ perror(_("execl() failed"));
#endif
@@ -400,9 +400,9 @@
if ((argc < 2) || ((strcmp(argv[1], "help") == 0) ||
(strcmp(argv[1], "-help") == 0) ||
(strcmp(argv[1], "--help") == 0))) {
- fprintf(stderr, "Usage: %s [-t] [-s] <filename> [<argument> ...]\n",
- argv[0]);
- return 1;
+ fprintf(stderr, "%s: %s [-t] [-s] <filename> [<argument> ...]\n",
+ _("Usage:"), argv[0]);
+ exit(EXIT_FAILURE);
filename = argv[1];
@@ -411,8 +411,8 @@
ctx.fp = fopen(filename, "r");
if (!ctx.fp) {
- perror("Unable to open script file");
- return 1;
+ perror(_("Unable to open script file"));
G_gisinit((char *)filename);
@@ -426,9 +426,9 @@
arg = strchr(buff, '\n');
if (!arg) {
- fprintf(stderr, "Line too long or missing newline at line %d\n",
+ fprintf(stderr, _("Line too long or missing newline at line %d\n"),
ctx.line);
- return 1;
*arg = '\0';
@@ -463,17 +463,17 @@
if (fclose(ctx.fp) != 0) {
- perror("Error closing script file");
- return 1;
+ perror(_("Error closing script file"));
/* Stop here successfully if all that was desired was output of text to translate */
/* Continuing from here would get argc and argv all wrong in G_parser. */
if (translate_output)
- return EXIT_SUCCESS;
+ exit(EXIT_SUCCESS);
if (G_parser(argc, argv))
- return 1;
return standard_output
? print_options(&ctx)
