[GRASS-SVN] r47407 - grass/trunk/general/g.parser
svn_grass at osgeo.org
Wed Aug 3 16:14:37 EDT 2011
Author: martinl
Date: 2011-08-03 13:14:37 -0700 (Wed, 03 Aug 2011)
New Revision: 47407
grass/trunk/general/g.parser/main.c
g.parser: strcasecmp -> G_strcasecmp
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2011-08-03 20:09:05 UTC (rev 47406)
+++ grass/trunk/general/g.parser/main.c 2011-08-03 20:14:37 UTC (rev 47407)
@@ -75,10 +75,10 @@
static int parse_boolean(struct context *ctx, const char *arg)
- if (strcasecmp(arg, "yes") == 0)
+ if (G_strcasecmp(arg, "yes") == 0)
return YES;
- if (strcasecmp(arg, "no") == 0)
+ if (G_strcasecmp(arg, "no") == 0)
return NO;
fprintf(stderr, _("Unknown boolean value \"%s\" at line %d\n"),
@@ -89,13 +89,13 @@
static void parse_toplevel(struct context *ctx, const char *cmd)
- if (strcasecmp(cmd, "module") == 0) {
+ if (G_strcasecmp(cmd, "module") == 0) {
ctx->state = S_MODULE;
ctx->module = G_define_module();
return;
- if (strcasecmp(cmd, "flag") == 0) {
+ if (G_strcasecmp(cmd, "flag") == 0) {
ctx->state = S_FLAG;
ctx->flag = G_define_flag();
if (!ctx->first_flag)
@@ -103,7 +103,7 @@
return;
- if (strcasecmp(cmd, "option") == 0) {
+ if (G_strcasecmp(cmd, "option") == 0) {
ctx->state = S_OPTION;
ctx->option = G_define_option();
if (!ctx->first_option)
@@ -119,22 +119,22 @@
/* Label and description can be internationalized */
- if (strcasecmp(cmd, "label") == 0) {
+ if (G_strcasecmp(cmd, "label") == 0) {
ctx->module->label = translate(strdup(arg));
return;
- if (strcasecmp(cmd, "description") == 0) {
+ if (G_strcasecmp(cmd, "description") == 0) {
ctx->module->description = translate(strdup(arg));
return;
- if (strcasecmp(cmd, "keywords") == 0) {
+ if (G_strcasecmp(cmd, "keywords") == 0) {
G_add_keyword(translate(strdup(arg)));
return;
- if (strcasecmp(cmd, "end") == 0) {
+ if (G_strcasecmp(cmd, "end") == 0) {
ctx->state = S_TOPLEVEL;
return;
@@ -145,38 +145,38 @@
static void parse_flag(struct context *ctx, const char *cmd, const char *arg)
- if (strcasecmp(cmd, "key") == 0) {
+ if (G_strcasecmp(cmd, "key") == 0) {
ctx->flag->key = arg[0];
return;
- if (strcasecmp(cmd, "suppress_required") == 0) {
+ if (G_strcasecmp(cmd, "suppress_required") == 0) {
ctx->flag->suppress_required = parse_boolean(ctx, arg);
return;
- if (strcasecmp(cmd, "answer") == 0) {
+ if (G_strcasecmp(cmd, "answer") == 0) {
ctx->flag->answer = atoi(arg);
return;
/* Label, description, and guisection can all be internationalized */
ctx->flag->label = translate(strdup(arg));
return;
ctx->flag->description = translate(strdup(arg));
return;
- if (strcasecmp(cmd, "guisection") == 0) {
+ if (G_strcasecmp(cmd, "guisection") == 0) {
ctx->flag->guisection = translate(strdup(arg));
return;
return;
@@ -187,13 +187,13 @@
static int parse_type(struct context *ctx, const char *arg)
- if (strcasecmp(arg, "integer") == 0)
+ if (G_strcasecmp(arg, "integer") == 0)
return TYPE_INTEGER;
- if (strcasecmp(arg, "double") == 0)
+ if (G_strcasecmp(arg, "double") == 0)
return TYPE_DOUBLE;
- if (strcasecmp(arg, "string") == 0)
+ if (G_strcasecmp(arg, "string") == 0)
return TYPE_STRING;
fprintf(stderr, _("Unknown type \"%s\" at line %d\n"), arg, ctx->line);
@@ -204,73 +204,73 @@
static void parse_option(struct context *ctx, const char *cmd,
const char *arg)
ctx->option->key = strdup(arg);
return;
- if (strcasecmp(cmd, "type") == 0) {
+ if (G_strcasecmp(cmd, "type") == 0) {
ctx->option->type = parse_type(ctx, arg);
return;
- if (strcasecmp(cmd, "required") == 0) {
+ if (G_strcasecmp(cmd, "required") == 0) {
ctx->option->required = parse_boolean(ctx, arg);
return;
- if (strcasecmp(cmd, "multiple") == 0) {
+ if (G_strcasecmp(cmd, "multiple") == 0) {
ctx->option->multiple = parse_boolean(ctx, arg);
return;
- if (strcasecmp(cmd, "options") == 0) {
+ if (G_strcasecmp(cmd, "options") == 0) {
ctx->option->options = strdup(arg);
return;
- if (strcasecmp(cmd, "key_desc") == 0) {
+ if (G_strcasecmp(cmd, "key_desc") == 0) {
ctx->option->key_desc = strdup(arg);
return;
/* Label, description, descriptions, and guisection can all be internationalized */
ctx->option->label = translate(strdup(arg));
return;
ctx->option->description = translate(strdup(arg));
return;
- if (strcasecmp(cmd, "descriptions") == 0) {
+ if (G_strcasecmp(cmd, "descriptions") == 0) {
ctx->option->descriptions = translate(strdup(arg));
return;
ctx->option->answer = strdup(arg);
return;
- if (strcasecmp(cmd, "gisprompt") == 0) {
+ if (G_strcasecmp(cmd, "gisprompt") == 0) {
ctx->option->gisprompt = strdup(arg);
return;
ctx->option->guisection = translate(strdup(arg));
return;
- if (strcasecmp(cmd, "guidependency") == 0) {
+ if (G_strcasecmp(cmd, "guidependency") == 0) {
ctx->option->guidependency = translate(strdup(arg));
return;
return;
