[GRASS-SVN] r47421 - grass/trunk/general/g.parser
    svn_grass at osgeo.org
    Thu Aug  4 04:42:59 EDT 2011
Author: martinl
Date: 2011-08-04 01:42:58 -0700 (Thu, 04 Aug 2011)
New Revision: 47421
Added:
   grass/trunk/general/g.parser/global.h
   grass/trunk/general/g.parser/parse.c
   grass/trunk/general/g.parser/proto.h
   grass/trunk/general/g.parser/revoke.c
   grass/trunk/general/g.parser/standard_option.c
   grass/trunk/general/g.parser/translate.c
   grass/trunk/general/g.parser/main.c
g.parser: support standard options
	  major code reorgranization
Added: grass/trunk/general/g.parser/global.h
--- grass/trunk/general/g.parser/global.h	                        (rev 0)
+++ grass/trunk/general/g.parser/global.h	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,24 @@
+#include <stdio.h>
+#include <grass/gis.h>
+enum state
+    S_TOPLEVEL,
+    S_MODULE,
+    S_FLAG,
+    S_OPTION
+struct context
+    struct GModule *module;
+    struct Option *option;
+    struct Flag *flag;
+    struct Option *first_option;
+    struct Flag *first_flag;
+    int state;
+    FILE *fp;
+    int line;
+extern int translate_output;
Property changes on: grass/trunk/general/g.parser/global.h
___________________________________________________________________
Added: svn:mime-type
   + text/x-chdr
Added: svn:eol-style
   + native
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c	2011-08-04 08:41:27 UTC (rev 47420)
+++ grass/trunk/general/g.parser/main.c	2011-08-04 08:42:58 UTC (rev 47421)
@@ -16,366 +16,23 @@
  *               for details.
-#include <stdio.h>
 #include <stdlib.h>
-#include <string.h>
 #include <unistd.h>
-#include <ctype.h>
+#include <string.h>
-#include <grass/gis.h>
 #include <grass/glocale.h>
-enum state
-    S_TOPLEVEL,
-    S_MODULE,
-    S_FLAG,
-    S_OPTION
+#include "proto.h"
-struct context
-    struct GModule *module;
-    struct Option *option;
-    struct Flag *flag;
-    struct Option *first_option;
-    struct Flag *first_flag;
-    int state;
-    FILE *fp;
-    int line;
+int translate_output;
-int translate_output = 0;
-/* Returns translated version of a string.
-   If global variable to output strings for translation is set it spits them out */
-char *translate(const char *arg)
-    static const char *domain;
-    if (*arg && translate_output) {
-	fputs(arg, stdout);
-	fputs("\n", stdout);
-#if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
-    if (!domain) {
-	domain = getenv("GRASS_TRANSLATION_DOMAIN");
-	if (domain)
-	    G_putenv("GRASS_TRANSLATION_DOMAIN", "grassmods");
-	else
-	    domain = PACKAGE;
-    return G_gettext(domain, arg);
-#else
-    return arg;
-#endif
-static int parse_boolean(struct context *ctx, const char *arg)
-    if (G_strcasecmp(arg, "yes") == 0)
-	return YES;
-    if (G_strcasecmp(arg, "no") == 0)
-	return NO;
-    fprintf(stderr, _("Unknown boolean value \"%s\" at line %d\n"),
-	    arg, ctx->line);
-    return NO;
-static void parse_toplevel(struct context *ctx, const char *cmd)
-    if (G_strcasecmp(cmd, "module") == 0) {
-	ctx->state = S_MODULE;
-	ctx->module = G_define_module();
-	return;
-    if (G_strcasecmp(cmd, "flag") == 0) {
-	ctx->state = S_FLAG;
-	ctx->flag = G_define_flag();
-	if (!ctx->first_flag)
-	    ctx->first_flag = ctx->flag;
-	return;
-    if (G_strcasecmp(cmd, "option") == 0) {
-	ctx->state = S_OPTION;
-	ctx->option = G_define_option();
-	if (!ctx->first_option)
-	    ctx->first_option = ctx->option;
-	return;
-    fprintf(stderr, _("Unknown command \"%s\" at line %d\n"), cmd, ctx->line);
-static void parse_module(struct context *ctx, const char *cmd,
-			 const char *arg)
-    /* Label and description can be internationalized */
-    if (G_strcasecmp(cmd, "label") == 0) {
-	ctx->module->label = translate(strdup(arg));
-	return;
-    if (G_strcasecmp(cmd, "description") == 0) {
-	ctx->module->description = translate(strdup(arg));
-	return;
-    if (G_strcasecmp(cmd, "keywords") == 0) {
-	G_add_keyword(translate(strdup(arg)));
-	return;
-    if (G_strcasecmp(cmd, "end") == 0) {
-	ctx->state = S_TOPLEVEL;
-	return;
-    fprintf(stderr, _("Unknown module parameter \"%s\" at line %d\n"),
-	    cmd, ctx->line);
-static void parse_flag(struct context *ctx, const char *cmd, const char *arg)
-    if (G_strcasecmp(cmd, "key") == 0) {
-	ctx->flag->key = arg[0];
-	return;
-    if (G_strcasecmp(cmd, "suppress_required") == 0) {
-	ctx->flag->suppress_required = parse_boolean(ctx, arg);
-	return;
-    if (G_strcasecmp(cmd, "answer") == 0) {
-	ctx->flag->answer = atoi(arg);
-	return;
-    /* Label, description, and guisection can all be internationalized */
-	ctx->flag->label = translate(strdup(arg));
-	return;
-	ctx->flag->description = translate(strdup(arg));
-	return;
-    if (G_strcasecmp(cmd, "guisection") == 0) {
-	ctx->flag->guisection = translate(strdup(arg));
-	return;
-	return;
-    fprintf(stderr, _("Unknown flag parameter \"%s\" at line %d\n"),
-	    cmd, ctx->line);
-static int parse_type(struct context *ctx, const char *arg)
-    if (G_strcasecmp(arg, "integer") == 0)
-	return TYPE_INTEGER;
-    if (G_strcasecmp(arg, "double") == 0)
-	return TYPE_DOUBLE;
-    if (G_strcasecmp(arg, "string") == 0)
-	return TYPE_STRING;
-    fprintf(stderr, _("Unknown type \"%s\" at line %d\n"), arg, ctx->line);
-static void parse_option(struct context *ctx, const char *cmd,
-			 const char *arg)
-	ctx->option->key = strdup(arg);
-	return;
-    if (G_strcasecmp(cmd, "type") == 0) {
-	ctx->option->type = parse_type(ctx, arg);
-	return;
-    if (G_strcasecmp(cmd, "required") == 0) {
-	ctx->option->required = parse_boolean(ctx, arg);
-	return;
-    if (G_strcasecmp(cmd, "multiple") == 0) {
-	ctx->option->multiple = parse_boolean(ctx, arg);
-	return;
-    if (G_strcasecmp(cmd, "options") == 0) {
-	ctx->option->options = strdup(arg);
-	return;
-    if (G_strcasecmp(cmd, "key_desc") == 0) {
-	ctx->option->key_desc = strdup(arg);
-	return;
-    /* Label, description, descriptions, and guisection can all be internationalized */
-	ctx->option->label = translate(strdup(arg));
-	return;
-	ctx->option->description = translate(strdup(arg));
-	return;
-    if (G_strcasecmp(cmd, "descriptions") == 0) {
-	ctx->option->descriptions = translate(strdup(arg));
-	return;
-	ctx->option->answer = strdup(arg);
-	return;
-    if (G_strcasecmp(cmd, "gisprompt") == 0) {
-	ctx->option->gisprompt = strdup(arg);
-	return;
-	ctx->option->guisection = translate(strdup(arg));
-	return;
-    if (G_strcasecmp(cmd, "guidependency") == 0) {
-	ctx->option->guidependency = translate(strdup(arg));
-	return;
-	return;
-    fprintf(stderr, _("Unknown option parameter \"%s\" at line %d\n"),
-	    cmd, ctx->line);
-static int print_options(const struct context *ctx)
-    const char *overwrite = getenv("GRASS_OVERWRITE");
-    const char *verbose = getenv("GRASS_VERBOSE");
-    printf("@ARGS_PARSED@\n");
-    if (overwrite)
-	printf("GRASS_OVERWRITE=%s\n", overwrite);
-    if (verbose)
-	printf("GRASS_VERBOSE=%s\n", verbose);
-    for (flag = ctx->first_flag; flag; flag = flag->next_flag)
-	printf("flag_%c=%d\n", flag->key, flag->answer ? 1 : 0);
-    for (option = ctx->first_option; option; option = option->next_opt)
-	printf("opt_%s=%s\n", option->key,
-	       option->answer ? option->answer : "");
-    return EXIT_SUCCESS;
-static int reinvoke_script(const struct context *ctx, const char *filename)
-    /* Because shell from MINGW and CygWin converts all variables
-     * to uppercase it was necessary to use uppercase variables.
-     * Set both until all scripts are updated */
-    for (flag = ctx->first_flag; flag; flag = flag->next_flag) {
-	char buff[16];
-	sprintf(buff, "GIS_FLAG_%c=%d", flag->key, flag->answer ? 1 : 0);
-	putenv(G_store(buff));
-	sprintf(buff, "GIS_FLAG_%c=%d", toupper(flag->key),
-		flag->answer ? 1 : 0);
-	G_debug(2, "set %s", buff);
-    for (option = ctx->first_option; option; option = option->next_opt) {
-	char upper[4096];
-	char *str;
-	G_asprintf(&str, "GIS_OPT_%s=%s", option->key,
-	putenv(str);
-	strcpy(upper, option->key);
-	G_str_to_upper(upper);
-	G_asprintf(&str, "GIS_OPT_%s=%s", upper,
-	G_debug(2, "set %s", str);
-	putenv(str);
-#ifdef __MINGW32__
-	/* execlp() and _spawnlp ( _P_OVERLAY,..) do not work, they return
-	 * immediately and that breaks scripts running GRASS scripts
-	 * because they dont wait until GRASS script finished */
-	/* execlp( "sh", "sh", filename, "@ARGS_PARSED@", NULL); */
-	/* _spawnlp ( _P_OVERLAY, filename, filename, "@ARGS_PARSED@", NULL ); */
-	int ret;
-	char *shell = getenv("GRASS_SH");
-	if (shell == NULL)
-	    shell = "sh";
-	ret = G_spawn(shell, shell, filename, "@ARGS_PARSED@", NULL);
-	G_debug(1, "ret = %d", ret);
-	if (ret == -1) {
-	    perror(_("G_spawn() failed"));
-	    return EXIT_FAILURE;
-#else
-    execl(filename, filename, "@ARGS_PARSED@", NULL);
-    perror(_("execl() failed"));
-#endif
 int main(int argc, char *argv[])
     struct context ctx;
     const char *filename;
-    int standard_output = 0;
+    int standard_output;
     ctx.module = NULL;
     ctx.option = NULL;
     ctx.flag = NULL;
@@ -383,17 +40,19 @@
     ctx.first_flag = NULL;
     ctx.state = S_TOPLEVEL;
+    standard_output = translate_output = FALSE;
     /* Detect request to get strings to translate from a file */
     /* It comes BEFORE the filename to completely avoid confusion with parser.c behaviours */
     if (argc >= 2 && (strcmp(argv[1], "-t") == 0)) {
 	/* Turn on translation output */
-	translate_output = 1;
+	translate_output = TRUE;
 	argv++, argc--;
     if (argc >= 2 && (strcmp(argv[1], "-s") == 0)) {
 	/* write to stdout rather than re-invoking */
-	standard_output = 1;
+	standard_output = TRUE;
 	argv++, argc--;
Added: grass/trunk/general/g.parser/parse.c
--- grass/trunk/general/g.parser/parse.c	                        (rev 0)
+++ grass/trunk/general/g.parser/parse.c	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,250 @@
+#include <stdlib.h>
+#include "proto.h"
+#include <grass/glocale.h>
+int parse_boolean(struct context *ctx, const char *arg)
+    if (G_strcasecmp(arg, "yes") == 0)
+	return YES;
+    if (G_strcasecmp(arg, "no") == 0)
+	return NO;
+    fprintf(stderr, _("Unknown boolean value \"%s\" at line %d\n"),
+	    arg, ctx->line);
+    return NO;
+void parse_toplevel(struct context *ctx, const char *cmd)
+    char **tokens;
+    if (G_strcasecmp(cmd, "module") == 0) {
+	ctx->state = S_MODULE;
+	ctx->module = G_define_module();
+	return;
+    if (G_strcasecmp(cmd, "flag") == 0) {
+	ctx->state = S_FLAG;
+	ctx->flag = G_define_flag();
+	if (!ctx->first_flag)
+	    ctx->first_flag = ctx->flag;
+	return;
+    if (G_strncasecmp(cmd, "option", strlen("option")) == 0) {
+	ctx->state = S_OPTION;
+	tokens = G_tokenize(cmd, " ");
+	if (G_number_of_tokens(tokens) > 1) {
+	    /* standard option */
+	    ctx->option = define_standard_option(tokens[1]);
+	else {
+	    ctx->option = G_define_option();
+	if (!ctx->first_option)
+		ctx->first_option = ctx->option;
+	G_free_tokens(tokens);
+	return;
+    fprintf(stderr, _("Unknown command \"%s\" at line %d\n"), cmd, ctx->line);
+void parse_module(struct context *ctx, const char *cmd,
+		  const char *arg)
+    /* Label and description can be internationalized */
+    if (G_strcasecmp(cmd, "label") == 0) {
+	ctx->module->label = translate(strdup(arg));
+	return;
+    if (G_strcasecmp(cmd, "description") == 0) {
+	ctx->module->description = translate(strdup(arg));
+	return;
+    if (G_strcasecmp(cmd, "keywords") == 0) {
+	G_add_keyword(translate(strdup(arg)));
+	return;
+    if (G_strcasecmp(cmd, "end") == 0) {
+	ctx->state = S_TOPLEVEL;
+	return;
+    fprintf(stderr, _("Unknown module parameter \"%s\" at line %d\n"),
+	    cmd, ctx->line);
+void parse_flag(struct context *ctx, const char *cmd, const char *arg)
+    if (G_strcasecmp(cmd, "key") == 0) {
+	ctx->flag->key = arg[0];
+	return;
+    if (G_strcasecmp(cmd, "suppress_required") == 0) {
+	ctx->flag->suppress_required = parse_boolean(ctx, arg);
+	return;
+    if (G_strcasecmp(cmd, "answer") == 0) {
+	ctx->flag->answer = atoi(arg);
+	return;
+    /* Label, description, and guisection can all be internationalized */
+	ctx->flag->label = translate(strdup(arg));
+	return;
+	ctx->flag->description = translate(strdup(arg));
+	return;
+    if (G_strcasecmp(cmd, "guisection") == 0) {
+	ctx->flag->guisection = translate(strdup(arg));
+	return;
+	return;
+    fprintf(stderr, _("Unknown flag parameter \"%s\" at line %d\n"),
+	    cmd, ctx->line);
+int parse_type(struct context *ctx, const char *arg)
+    if (G_strcasecmp(arg, "integer") == 0)
+	return TYPE_INTEGER;
+    if (G_strcasecmp(arg, "double") == 0)
+	return TYPE_DOUBLE;
+    if (G_strcasecmp(arg, "string") == 0)
+	return TYPE_STRING;
+    fprintf(stderr, _("Unknown type \"%s\" at line %d\n"), arg, ctx->line);
+void parse_option(struct context *ctx, const char *cmd,
+		  const char *arg)
+	ctx->option->key = strdup(arg);
+	return;
+    if (G_strcasecmp(cmd, "type") == 0) {
+	ctx->option->type = parse_type(ctx, arg);
+	return;
+    if (G_strcasecmp(cmd, "required") == 0) {
+	ctx->option->required = parse_boolean(ctx, arg);
+	return;
+    if (G_strcasecmp(cmd, "multiple") == 0) {
+	ctx->option->multiple = parse_boolean(ctx, arg);
+	return;
+    if (G_strcasecmp(cmd, "options") == 0) {
+	ctx->option->options = strdup(arg);
+	return;
+    if (G_strcasecmp(cmd, "key_desc") == 0) {
+	ctx->option->key_desc = strdup(arg);
+	return;
+    /* Label, description, descriptions, and guisection can all be internationalized */
+	ctx->option->label = translate(strdup(arg));
+	return;
+	ctx->option->description = translate(strdup(arg));
+	return;
+    if (G_strcasecmp(cmd, "descriptions") == 0) {
+	ctx->option->descriptions = translate(strdup(arg));
+	return;
+	ctx->option->answer = strdup(arg);
+	return;
+    if (G_strcasecmp(cmd, "gisprompt") == 0) {
+	ctx->option->gisprompt = strdup(arg);
+	return;
+	ctx->option->guisection = translate(strdup(arg));
+	return;
+    if (G_strcasecmp(cmd, "guidependency") == 0) {
+	ctx->option->guidependency = translate(strdup(arg));
+	return;
+	return;
+    fprintf(stderr, _("Unknown option parameter \"%s\" at line %d\n"),
+	    cmd, ctx->line);
+int print_options(const struct context *ctx)
+    const char *overwrite = getenv("GRASS_OVERWRITE");
+    const char *verbose = getenv("GRASS_VERBOSE");
+    printf("@ARGS_PARSED@\n");
+    if (overwrite)
+	printf("GRASS_OVERWRITE=%s\n", overwrite);
+    if (verbose)
+	printf("GRASS_VERBOSE=%s\n", verbose);
+    for (flag = ctx->first_flag; flag; flag = flag->next_flag)
+	printf("flag_%c=%d\n", flag->key, flag->answer ? 1 : 0);
+    for (option = ctx->first_option; option; option = option->next_opt)
+	printf("opt_%s=%s\n", option->key,
+	       option->answer ? option->answer : "");
+    return EXIT_SUCCESS;
Property changes on: grass/trunk/general/g.parser/parse.c
   + text/x-csrc
   + native
Added: grass/trunk/general/g.parser/proto.h
--- grass/trunk/general/g.parser/proto.h	                        (rev 0)
+++ grass/trunk/general/g.parser/proto.h	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,19 @@
+#include "global.h"
+/* parse.c */
+int parse_boolean(struct context *, const char *);
+void parse_toplevel(struct context *, const char *);
+void parse_module(struct context *, const char *, const char *);
+void parse_flag(struct context *, const char *, const char *);
+int parse_type(struct context *, const char *);
+void parse_option(struct context *, const char *, const char *);
+int print_options(const struct context *);
+/* revoke.c */
+int reinvoke_script(const struct context *, const char *);
+/* standard_option.c */
+struct Option *define_standard_option(const char *);
+/* translate.c */
+char *translate(const char *);
Property changes on: grass/trunk/general/g.parser/proto.h
   + text/x-chdr
   + native
Added: grass/trunk/general/g.parser/revoke.c
--- grass/trunk/general/g.parser/revoke.c	                        (rev 0)
+++ grass/trunk/general/g.parser/revoke.c	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,74 @@
+#include <ctype.h>
+#include <unistd.h>
+#include "proto.h"
+int reinvoke_script(const struct context *ctx, const char *filename)
+    /* Because shell from MINGW and CygWin converts all variables
+     * to uppercase it was necessary to use uppercase variables.
+     * Set both until all scripts are updated */
+    for (flag = ctx->first_flag; flag; flag = flag->next_flag) {
+	char buff[16];
+	sprintf(buff, "GIS_FLAG_%c=%d", flag->key, flag->answer ? 1 : 0);
+	putenv(G_store(buff));
+	sprintf(buff, "GIS_FLAG_%c=%d", toupper(flag->key),
+		flag->answer ? 1 : 0);
+	G_debug(2, "set %s", buff);
+    for (option = ctx->first_option; option; option = option->next_opt) {
+	char upper[4096];
+	char *str;
+	G_asprintf(&str, "GIS_OPT_%s=%s", option->key,
+	putenv(str);
+	strcpy(upper, option->key);
+	G_str_to_upper(upper);
+	G_asprintf(&str, "GIS_OPT_%s=%s", upper,
+	G_debug(2, "set %s", str);
+	putenv(str);
+#ifdef __MINGW32__
+	/* execlp() and _spawnlp ( _P_OVERLAY,..) do not work, they return
+	 * immediately and that breaks scripts running GRASS scripts
+	 * because they dont wait until GRASS script finished */
+	/* execlp( "sh", "sh", filename, "@ARGS_PARSED@", NULL); */
+	/* _spawnlp ( _P_OVERLAY, filename, filename, "@ARGS_PARSED@", NULL ); */
+	int ret;
+	char *shell = getenv("GRASS_SH");
+	if (shell == NULL)
+	    shell = "sh";
+	ret = G_spawn(shell, shell, filename, "@ARGS_PARSED@", NULL);
+	G_debug(1, "ret = %d", ret);
+	if (ret == -1) {
+	    perror(_("G_spawn() failed"));
+	    return EXIT_FAILURE;
+#else
+    execl(filename, filename, "@ARGS_PARSED@", NULL);
+    perror(_("execl() failed"));
+#endif
Property changes on: grass/trunk/general/g.parser/revoke.c
   + text/x-csrc
   + native
Added: grass/trunk/general/g.parser/standard_option.c
--- grass/trunk/general/g.parser/standard_option.c	                        (rev 0)
+++ grass/trunk/general/g.parser/standard_option.c	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,116 @@
+#include "proto.h"
+struct Option *define_standard_option(const char *name)
+    int key;
+    struct Option *opt;
+    key = G_OPT_UNDEFINED;
+    if (G_strcasecmp(name, "G_OPT_DB_WHERE") == 0)
+	key = G_OPT_DB_WHERE;
+    else if (G_strcasecmp(name, "G_OPT_DB_TABLE") == 0)
+	key = G_OPT_DB_TABLE;
+    else if (G_strcasecmp(name, "G_OPT_DB_DRIVER") == 0)
+	key = G_OPT_DB_DRIVER;
+    else if (G_strcasecmp(name, "G_OPT_DB_DATABASE") == 0)
+	key = G_OPT_DB_DATABASE;
+    else if (G_strcasecmp(name, "G_OPT_DB_SCHEMA") == 0)
+	key = G_OPT_DB_SCHEMA;
+    else if (G_strcasecmp(name, "G_OPT_DB_COLUMN") == 0)
+	key = G_OPT_DB_COLUMN;
+    else if (G_strcasecmp(name, "G_OPT_DB_COLUMNS") == 0)
+	key = G_OPT_DB_COLUMNS;
+    else if (G_strcasecmp(name, "G_OPT_I_GROUP") == 0)
+	key = G_OPT_I_GROUP;
+    else if (G_strcasecmp(name, "G_OPT_I_SUBGROUP") == 0)
+	key = G_OPT_I_SUBGROUP;
+    else if (G_strcasecmp(name, "G_OPT_R_INPUT") == 0)
+	key = G_OPT_R_INPUT;
+    else if (G_strcasecmp(name, "G_OPT_R_INPUTS") == 0)
+	key = G_OPT_R_INPUTS;
+    else if (G_strcasecmp(name, "G_OPT_R_OUTPUT") == 0)
+	key = G_OPT_R_OUTPUT;
+    else if (G_strcasecmp(name, "G_OPT_R_MAP") == 0)
+	key = G_OPT_R_MAP;
+    else if (G_strcasecmp(name, "G_OPT_R_MAPS") == 0)
+	key = G_OPT_R_MAPS;
+    else if (G_strcasecmp(name, "G_OPT_R_BASE") == 0)
+	key = G_OPT_R_BASE;
+    else if (G_strcasecmp(name, "G_OPT_R_COVER") == 0)
+	key = G_OPT_R_COVER;
+    else if (G_strcasecmp(name, "G_OPT_R_ELEV") == 0)
+	key = G_OPT_R_ELEV;
+    else if (G_strcasecmp(name, "G_OPT_R_ELEVS") == 0)
+	key = G_OPT_R_ELEVS;
+    else if (G_strcasecmp(name, "G_OPT_R3_INPUT") == 0)
+	key = G_OPT_R3_INPUT;
+    else if (G_strcasecmp(name, "G_OPT_R3_INPUTS") == 0)
+	key = G_OPT_R3_INPUTS;
+    else if (G_strcasecmp(name, "G_OPT_R3_OUTPUT") == 0)
+	key = G_OPT_R3_OUTPUT;
+    else if (G_strcasecmp(name, "G_OPT_R3_MAP") == 0)
+	key = G_OPT_R3_MAP;
+    else if (G_strcasecmp(name, "G_OPT_R3_MAPS") == 0)
+	key = G_OPT_R3_MAPS;
+    else if (G_strcasecmp(name, "G_OPT_R3_TYPE") == 0)
+	key = G_OPT_R3_TYPE;
+    else if (G_strcasecmp(name, "G_OPT_R3_PRECISION") == 0)
+	key = G_OPT_R3_PRECISION;
+    else if (G_strcasecmp(name, "G_OPT_R3_COMPRESSION") == 0)
+	key = G_OPT_R3_COMPRESSION;
+    else if (G_strcasecmp(name, "G_OPT_R3_TILE_DIMENSION") == 0)
+	key = G_OPT_R3_TILE_DIMENSION;
+    else if (G_strcasecmp(name, "G_OPT_V_INPUT") == 0)
+	key = G_OPT_V_INPUT;
+    else if (G_strcasecmp(name, "G_OPT_V_INPUTS") == 0)
+	key = G_OPT_V_INPUTS;
+    else if (G_strcasecmp(name, "G_OPT_V_OUTPUT") == 0)
+	key = G_OPT_V_OUTPUT;
+    else if (G_strcasecmp(name, "G_OPT_V_MAP") == 0)
+	key = G_OPT_V_MAP;
+    else if (G_strcasecmp(name, "G_OPT_V_MAPS") == 0)
+	key = G_OPT_V_MAPS;
+    else if (G_strcasecmp(name, "G_OPT_V_TYPE") == 0)
+	key = G_OPT_V_TYPE;
+    else if (G_strcasecmp(name, "G_OPT_V3_TYPE") == 0)
+	key = G_OPT_V3_TYPE;
+    else if (G_strcasecmp(name, "G_OPT_V_FIELD") == 0)
+	key = G_OPT_V_FIELD;
+    else if (G_strcasecmp(name, "G_OPT_V_FIELD_ALL") == 0)
+	key = G_OPT_V_FIELD_ALL;
+    else if (G_strcasecmp(name, "G_OPT_V_CAT") == 0)
+	key = G_OPT_V_CAT;
+    else if (G_strcasecmp(name, "G_OPT_V_CATS") == 0)
+	key = G_OPT_V_CATS;
+    else if (G_strcasecmp(name, "G_OPT_V_ID") == 0)
+	key = G_OPT_V_ID;
+    else if (G_strcasecmp(name, "G_OPT_V_IDS") == 0)
+	key = G_OPT_V_IDS;
+    else if (G_strcasecmp(name, "G_OPT_F_INPUT") == 0)
+	key = G_OPT_F_INPUT;
+    else if (G_strcasecmp(name, "G_OPT_F_OUTPUT") == 0)
+	key = G_OPT_F_OUTPUT;
+    else if (G_strcasecmp(name, "G_OPT_F_SEP") == 0)
+	key = G_OPT_F_SEP;
+    else if (G_strcasecmp(name, "G_OPT_C_FG") == 0)
+	key = G_OPT_C_FG;
+    else if (G_strcasecmp(name, "G_OPT_C_BG") == 0)
+	key = G_OPT_C_BG;
+    else if (G_strcasecmp(name, "G_OPT_M_UNITS") == 0)
+	key = G_OPT_M_UNITS;
+    else if (G_strcasecmp(name, "G_OPT_M_DATATYPE") == 0)
+	key = G_OPT_M_DATATYPE;
+    else if (G_strcasecmp(name, "G_OPT_M_MAPSET") == 0)
+	key = G_OPT_M_MAPSET;
+    else if (G_strcasecmp(name, "G_OPT_M_EN") == 0)
+	key = G_OPT_M_EN;
+    if (key == G_OPT_UNDEFINED)
+	opt = G_define_option();
+    else
+	opt = G_define_standard_option(key);
+    return opt;
Property changes on: grass/trunk/general/g.parser/standard_option.c
   + text/x-csrc
   + native
Added: grass/trunk/general/g.parser/translate.c
--- grass/trunk/general/g.parser/translate.c	                        (rev 0)
+++ grass/trunk/general/g.parser/translate.c	2011-08-04 08:42:58 UTC (rev 47421)
@@ -0,0 +1,31 @@
+#include "proto.h"
+/* Returns translated version of a string.
+   If global variable to output strings for translation is set it spits them out */
+char *translate(const char *arg)
+    static const char *domain;
+    if (*arg && translate_output) {
+	fputs(arg, stdout);
+	fputs("\n", stdout);
+#if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
+    if (!domain) {
+	domain = getenv("GRASS_TRANSLATION_DOMAIN");
+	if (domain)
+	    G_putenv("GRASS_TRANSLATION_DOMAIN", "grassmods");
+	else
+	    domain = PACKAGE;
+    return G_gettext(domain, arg);
+#else
+    return arg;
+#endif
Property changes on: grass/trunk/general/g.parser/translate.c
   + text/x-csrc
   + native
