[GRASS-SVN] r47424 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 4 05:08:03 EDT 2011
Author: annakrat
Date: 2011-08-04 02:08:03 -0700 (Thu, 04 Aug 2011)
New Revision: 47424
grass/trunk/gui/wxpython/gui_modules/colorrules.py
wxGUI: reorganize layout code to be more readable
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-04 08:57:06 UTC (rev 47423)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-04 09:08:03 UTC (rev 47424)
@@ -89,80 +89,17 @@
# reference to layer with preview
self.layer = None
+ # set title
if self.raster:
self.SetTitle(_('Create new color table for raster map'))
- crlabel = _('Enter raster category values or percents')
else:
self.SetTitle(_('Create new color table for vector map'))
- crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
- # top controls
- if self.raster:
- maplabel = _('Select raster map:')
- else:
- maplabel = _('Select vector map:')
- inputBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = " %s " % maplabel)
- self.inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
- if self.raster:
- elem = 'cell'
- else:
- elem = 'vector'
- self.selectionInput = gselect.Select(parent = self, id = wx.ID_ANY,
- size = globalvar.DIALOG_GSELECT_SIZE,
- type = elem)
- self.ovrwrtcheck = wx.CheckBox(parent = self, id = wx.ID_ANY,
- label = _('replace existing color table'))
- self.ovrwrtcheck.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
- if self.raster:
- self.btnSave = wx.Button(parent = self, id = wx.ID_SAVE)
- self.btnSave.SetToolTipString(_('Save color table to file'))
- if not self.raster:
- self.cb_vl_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('Layer:'))
- self.cb_vc_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('Attribute column:'))
- self.cb_vrgb_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = _('RGB color column:'))
- self.cb_vlayer = gselect.LayerSelect(self)
- self.cb_vcol = gselect.ColumnSelect(self)
- self.cb_vrgb = gselect.ColumnSelect(self)
- # color table and preview window
- self.cr_label = wx.StaticText(parent = self, id = wx.ID_ANY,
- label = crlabel)
- self.cr_panel = self._colorRulesPanel()
- # add two rules as default
- self.AddRules(2)
- self.numRules = wx.SpinCtrl(parent = self, id = wx.ID_ANY,
- min = 1, max = 1e6)
- # initialize preview display
- self.InitDisplay()
- self.preview = BufferedWindow(self, id = wx.ID_ANY, size = (400, 300),
- Map = self.Map)
- self.preview.EraseMap()
- self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
- self.btnApply = wx.Button(parent = self, id = wx.ID_APPLY)
- self.btnOK = wx.Button(parent = self, id = wx.ID_OK)
- self.btnOK.SetDefault()
- self.btnOK.Enable(False)
- self.btnApply.Enable(False)
- self.btnPreview = wx.Button(parent = self, id = wx.ID_ANY,
- label = _("Preview"))
- self.btnPreview.Enable(False)
- self.btnAdd = wx.Button(parent = self, id = wx.ID_ADD)
- self.helpbtn = wx.Button(parent = self, id = wx.ID_HELP)
+ # layout
+ self.__doLayout()
# bindings
- self.Bind(wx.EVT_BUTTON, self.OnHelp, self.helpbtn)
+ self.Bind(wx.EVT_BUTTON, self.OnHelp, self.btnHelp)
self.selectionInput.Bind(wx.EVT_TEXT, self.OnSelectionInput)
self.Bind(wx.EVT_BUTTON, self.OnCancel, self.btnCancel)
self.Bind(wx.EVT_BUTTON, self.OnApply, self.btnApply)
@@ -192,92 +129,199 @@
self.inmap = name
self.OnSelectionInput(None)
- # layout
- self.__doLayout()
self.SetMinSize(self.GetSize())
self.CentreOnScreen()
self.Show()
+ def _createMapSelection(self):
+ """!Create map selection part of dialog"""
+ # top controls
+ if self.raster:
+ maplabel = _('Select raster map:')
+ else:
+ maplabel = _('Select vector map:')
+ inputBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % maplabel)
+ self.inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
+ if self.raster:
+ elem = 'cell'
+ else:
+ elem = 'vector'
+ self.selectionInput = gselect.Select(parent = self, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = elem)
+ if self.raster:
+ self.ovrwrtcheck = wx.CheckBox(parent = self, id = wx.ID_ANY,
+ label = _('replace existing color table'))
+ self.ovrwrtcheck.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
- def __doLayout(self):
- sizer = wx.BoxSizer(wx.VERTICAL)
- # input
+ if self.raster:
+ self.btnSave = wx.Button(parent = self, id = wx.ID_SAVE)
+ self.btnSave.SetToolTipString(_('Save color table to file'))
+ # layout
self.inputSizer.Add(item = self.selectionInput,
flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
- replaceSizer.Add(item = self.ovrwrtcheck, proportion = 1,
- flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
if self.raster:
+ replaceSizer.Add(item = self.ovrwrtcheck, proportion = 1,
+ flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL, border = 1)
replaceSizer.Add(item = self.btnSave, proportion = 0,
flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
self.inputSizer.Add(item = replaceSizer, proportion = 1,
flag = wx.ALL | wx.EXPAND, border = 0)
+ return self.inputSizer
+ def _createVectorAttrb(self):
+ """!Create part of dialog with layer/column selection"""
+ self.cb_vl_label = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('Layer:'))
+ self.cb_vc_label = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('Attribute column:'))
+ self.cb_vrgb_label = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('RGB color column:'))
+ self.cb_vlayer = gselect.LayerSelect(self)
+ self.cb_vcol = gselect.ColumnSelect(self)
+ self.cb_vrgb = gselect.ColumnSelect(self)
+ # layout
+ vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ vSizer.Add(self.cb_vl_label, pos = (0, 0),
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ vSizer.Add(self.cb_vlayer, pos = (0, 1),
+ vSizer.Add(self.cb_vc_label, pos = (0, 2),
+ vSizer.Add(self.cb_vcol, pos = (0, 3),
+ vSizer.Add(self.cb_vrgb_label, pos = (1, 2),
+ vSizer.Add(self.cb_vrgb, pos = (1, 3),
+ return vSizer
+ def _createColorRulesPanel(self):
+ """!Create rules panel"""
+ cr_panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY,
+ size = (180, 300),
+ style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
+ cr_panel.SetupScrolling(scroll_x = False)
+ self.cr_sizer = wx.GridBagSizer(vgap = 2, hgap = 4)
+ cr_panel.SetSizer(self.cr_sizer)
+ cr_panel.SetAutoLayout(True)
+ return cr_panel
+ def _createPreview(self):
+ """!Create preview"""
+ # initialize preview display
+ self.InitDisplay()
+ self.preview = BufferedWindow(self, id = wx.ID_ANY, size = (400, 300),
+ Map = self.Map)
+ self.preview.EraseMap()
+ def _createButtons(self):
+ """!Create buttons for leaving dialog"""
+ self.btnHelp = wx.Button(parent = self, id = wx.ID_HELP)
+ self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
+ self.btnApply = wx.Button(parent = self, id = wx.ID_APPLY)
+ self.btnOK = wx.Button(parent = self, id = wx.ID_OK)
+ self.btnOK.SetDefault()
+ self.btnOK.Enable(False)
+ self.btnApply.Enable(False)
+ self.btnPreview.Enable(False)
+ # layout
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(self.btnHelp,
+ flag = wx.LEFT | wx.RIGHT, border = 5)
+ btnSizer.Add(self.btnCancel,
+ btnSizer.Add(self.btnApply,
+ btnSizer.Add(self.btnOK,
+ return btnSizer
+ def __doLayout(self):
+ """!Do main layout"""
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # map selection
+ mapSelection = self._createMapSelection()
+ sizer.Add(item = mapSelection, proportion = 0,
+ flag = wx.ALL | wx.EXPAND, border = 5)
+ # set vector attributes
+ if not self.raster:
+ vectorAttrb = self._createVectorAttrb()
+ sizer.Add(item = vectorAttrb, proportion = 0,
# body & preview
bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
row = 0
+ # label with range
+ if self.raster:
+ crlabel = _('Enter raster category values or percents')
+ else:
+ crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
+ self.cr_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = crlabel)
bodySizer.Add(item = self.cr_label, pos = (row, 0), span = (1, 3),
flag = wx.ALL, border = 5)
+ row += 1
- vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- vSizer.Add(self.cb_vl_label, pos = (0, 0),
- flag = wx.ALIGN_CENTER_VERTICAL)
- vSizer.Add(self.cb_vlayer, pos = (0, 1),
- vSizer.Add(self.cb_vc_label, pos = (0, 2),
- vSizer.Add(self.cb_vcol, pos = (0, 3),
- vSizer.Add(self.cb_vrgb_label, pos = (1, 2),
- vSizer.Add(self.cb_vrgb, pos = (1, 3),
- row += 1
- bodySizer.Add(item = vSizer, pos = (row, 0), span = (1, 3))
- row += 1
+ # color table
+ self.cr_panel = self._createColorRulesPanel()
bodySizer.Add(item = self.cr_panel, pos = (row, 0), span = (1, 2))
+ # add two rules as default
+ self.AddRules(2)
+ # preview window
+ self._createPreview()
bodySizer.Add(item = self.preview, pos = (row, 2),
flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 10)
bodySizer.AddGrowableRow(row)
bodySizer.AddGrowableCol(2)
+ row += 1
- row += 1
+ # add rules
+ self.numRules = wx.SpinCtrl(parent = self, id = wx.ID_ANY,
+ min = 1, max = 1e6)
+ self.btnAdd = wx.Button(parent = self, id = wx.ID_ADD)
bodySizer.Add(item = self.numRules, pos = (row, 0),
+ bodySizer.Add(item = self.btnAdd, pos = (row, 1))
- bodySizer.Add(item = self.btnAdd, pos = (row, 1))
+ # preview button
+ self.btnPreview = wx.Button(parent = self, id = wx.ID_ANY,
+ label = _("Preview"))
bodySizer.Add(item = self.btnPreview, pos = (row, 2),
flag = wx.ALIGN_RIGHT)
- btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(self.helpbtn,
- flag = wx.LEFT | wx.RIGHT, border = 5)
- btnSizer.Add(self.btnCancel,
- btnSizer.Add(self.btnApply,
- btnSizer.Add(self.btnOK,
- sizer.Add(item = self.inputSizer, proportion = 0,
- flag = wx.ALL | wx.EXPAND, border = 5)
sizer.Add(item = bodySizer, proportion = 1,
+ # buttons
+ btnSizer = self._createButtons()
sizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
- style = wx.LI_HORIZONTAL),
- proportion = 0,
- flag = wx.EXPAND | wx.ALL, border = 5)
+ style = wx.LI_HORIZONTAL), proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 5)
sizer.Add(item = btnSizer, proportion = 0,
flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
@@ -286,19 +330,6 @@
sizer.Fit(self)
self.Layout()
- def _colorRulesPanel(self):
- """!Create rules panel"""
- cr_panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY,
- size = (180, 300),
- style = wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
- cr_panel.SetupScrolling(scroll_x = False)
- self.cr_sizer = wx.GridBagSizer(vgap = 2, hgap = 4)
- cr_panel.SetSizer(self.cr_sizer)
- cr_panel.SetAutoLayout(True)
- return cr_panel
def OnAddRules(self, event):
"""!Add rules button pressed"""
nrules = self.numRules.GetValue()
