[GRASS-SVN] r47429 - grass/branches/develbranch_6/lib/python
Thu Aug 4 08:52:31 EDT 2011
Author: martinl
Date: 2011-08-04 05:52:31 -0700 (Thu, 04 Aug 2011)
New Revision: 47429
   grass/branches/develbranch_6/lib/python/core.py
pythonlib: fix list_grouped() to list all mapsets in the search path
          remove mlist() - can be replaced by mlist_grouped()
	  (merge r47427 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2011-08-04 12:51:08 UTC (rev 47428)
+++ grass/branches/develbranch_6/lib/python/core.py	2011-08-04 12:52:31 UTC (rev 47429)
@@ -618,6 +618,9 @@
     dashes_re = re.compile("^----+$")
     mapset_re = re.compile("<(.*)>")
     result = {}
+    for mapset in mapsets(accessible = True):
+        result[mapset] = []
     mapset = None
     for line in read_command("g.list", type = type).splitlines():
 	if line == "":
@@ -627,7 +630,6 @@
 	m = mapset_re.search(line)
 	if m:
 	    mapset = m.group(1)
-	    result[mapset] = []
 	    continue
         if mapset:
             result[mapset].extend(line.split())
@@ -677,24 +679,6 @@
 # interface to g.mlist
-def mlist(type, pattern = None, mapset = None):
-    """!List of elements
-    @param type element type (rast, vect, rast3d, region, ...)
-    @param pattern pattern string
-    @param mapset mapset name (if not given use search path)
-    @return list of elements
-    result = list()
-    for line in read_command("g.mlist",
-                             type = type,
-                             pattern = pattern,
-                             mapset = mapset).splitlines():
-        result.append(line.strip())
-    return result
 def mlist_grouped(type, pattern = None):
     """!List of elements grouped by mapsets.
@@ -712,20 +696,20 @@
     @return directory of mapsets/elements
-    result = dict()
-    mapset_element = None
+    result = {}
+    mapset = None
     for line in read_command("g.mlist", flags = "m",
                              type = type, pattern = pattern).splitlines():
         try:
-            map, mapset_element = line.split('@')
+            name, mapset = line.split('@')
         except ValueError:
             warning(_("Invalid element '%s'") % line)
             continue
-        if mapset_element in result:
-            result[mapset_element].append(map)
-        else:
-	    result[mapset_element] = [map, ]
+        result[mapset].append(name)
     return result
