[GRASS-SVN] r47434 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Aug 4 10:11:23 EDT 2011
Author: martinl
Date: 2011-08-04 07:11:23 -0700 (Thu, 04 Aug 2011)
New Revision: 47434
grass/trunk/gui/wxpython/gui_modules/psmap.py
grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: fix gettext warnings
Modified: grass/trunk/gui/wxpython/gui_modules/psmap.py
--- grass/trunk/gui/wxpython/gui_modules/psmap.py 2011-08-04 13:45:23 UTC (rev 47433)
+++ grass/trunk/gui/wxpython/gui_modules/psmap.py 2011-08-04 14:11:23 UTC (rev 47434)
@@ -1098,7 +1098,7 @@
self.SetCursor(self.cursors["sizenwse"])
self.parent.SetStatusText(_('Click and drag to resize object'), 0)
else:
- self.parent.SetStatusText(_(''), 0)
+ self.parent.SetStatusText('', 0)
self.SetCursor(self.cursors["default"])
elif event.LeftDown():
Modified: grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py
--- grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py 2011-08-04 13:45:23 UTC (rev 47433)
+++ grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py 2011-08-04 14:11:23 UTC (rev 47434)
@@ -738,7 +738,8 @@
scale = 1/float(scaleText)
if abs(scale - self.instruction['scale']) > (0.01 * scale):
- GWarning(_("Scale has changed, old value: %s\nnew value: %s") % (scale, self.instruction['scale']))
+ GWarning(_("Scale has changed, old value: %(old)s\nnew value: %(new)s") % \
+ { 'old' : scale, 'new' : self.instruction['scale'] })
except (ValueError, IndexError):
GError(_("Failed to read instruction %s.\nUse 1:25000 notation.") % instruction)
return False
@@ -748,15 +749,17 @@
if len(maploc) >= 2:
if abs(self.instruction['rect'].Get()[0] - float(maploc[0])) > 0.5 or \
abs(self.instruction['rect'].Get()[1] - float(maploc[1])) > 0.5:
- GWarning(_("Map frame position changed, old value: %s %s\nnew value: %s %s") % \
- (maploc[0], maploc[1], self.instruction['rect'].Get()[0], self.instruction['rect'].Get()[1]))
+ GWarning(_("Map frame position changed, old value: %(old1)s %(old2)s\nnew value: %(new1)s %(new2)s") % \
+ { 'old1' : maploc[0], 'old2' : maploc[1],
+ 'new1' : self.instruction['rect'].Get()[0], 'new2' : self.instruction['rect'].Get()[1] })
#instr['rect'] = wx.Rect2D(float(maploc[0]), float(maploc[1]), self.instruction['rect'][2], self.instruction['rect'][3])
if len(maploc) == 4:
if abs(self.instruction['rect'].Get()[2] - float(maploc[2])) > 0.5 or \
abs(self.instruction['rect'].Get()[3] - float(maploc[3])) > 0.5:
- GWarning(_("Map frame size changed, old value: %s %s\nnew value: %s %s") %(
- maploc[2], maploc[3], self.instruction['rect'].Get()[2], self.instruction['rect'].Get()[3]))
+ GWarning(_("Map frame size changed, old value: %(old1)s %(old2)s\nnew value: %(new1)s %(new2)s") % \
+ { 'old1' : maploc[2], 'old2' : maploc[3],
+ 'new1' : self.instruction['rect'].Get()[2], 'new2' : self.instruction['rect'].Get()[3] })
#instr['rect'] = wx.Rect2D(*map(float, maploc))
self.instruction.update(instr)
return True
@@ -801,7 +804,8 @@
instr[key] = float(value)
break
except KeyError:
- GError(_("Failed to read instruction %s.\nUnknown format %s") % (instruction, format))
+ GError(_("Failed to read instruction %(file)s.\nUnknown format %(for)s") % \
+ { 'file' : instruction, 'for' : format })
return False
else:
@@ -2208,8 +2212,8 @@
stype = 'region'
self.select.SetElementList(type = stype)
self.mapText.SetLabel(self.mapOrRegionText[1])
- self.select.SetToolTipString(_(""))
+ self.select.SetToolTipString("")
for each in self.mapSizer.GetChildren():
each.GetWindow().Enable()
for each in self.centerSizer.GetChildren():
@@ -3815,7 +3819,8 @@
rasterType = getRasterType(map = self.currRaster)
self.rasterCurrent = wx.StaticText(panel, id = wx.ID_ANY,
- label = _("%s: type %s" % (self.currRaster, rasterType)))
+ label = _("%(rast)s: type %(type)s") % { 'rast' : self.currRaster,
+ 'type' : rasterType })
self.rasterSelect = Select(panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
type = 'raster', multiple = False,
updateOnPopup = True, onPopup = None)
@@ -4523,9 +4528,10 @@
currRaster = raster['raster']
else:
currRaster = None
rasterType = getRasterType(map = currRaster)
- self.rasterCurrent.SetLabel(_("%s: type %s") % (currRaster, str(rasterType)))
+ self.rasterCurrent.SetLabel(_("%(rast)s: type %(type)s") % \
+ { 'rast' : currRaster, 'type' : str(rasterType) })
# vector legend
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2011-08-04 13:45:23 UTC (rev 47433)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2011-08-04 14:11:23 UTC (rev 47434)
@@ -154,8 +154,9 @@
**self.cmd[1])
if ret != 0:
- raise gcmd.GException(value = _("'%s' failed. Details: %s") % (self.cmd[0], msg))
+ raise gcmd.GException(value = _("'%(cmd)s' failed. Details: %(det)s") % \
+ { 'cmd' : self.cmd[0], 'det' : msg })
except gcmd.GException, e:
print >> sys.stderr, e.value
# clean up after problems
@@ -563,8 +564,8 @@
for k, v in data.iteritems():
fd.write('%s=%s\n' % (k.strip(), str(v).strip()))
except IOError, e:
- grass.warning(_("Unable to open file '%s' for writting. Details: %s") % \
- (self.envfile, e))
+ grass.warning(_("Unable to open file '%(file)s' for writting. Details: %(det)s") % \
+ { 'cmd' : self.envfile, 'det' : e })
return
fd.close()
@@ -877,8 +878,8 @@
gcmd.RunCommand('g.gisenv',
set = 'MONITOR_%s_CMDFILE=%s' % (self.monitor, self.cmdfile))
except IOError, e:
- grass.warning(_("Unable to read cmdfile '%s'. Details: %s") % \
- (self.cmdfile, e))
+ grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
+ { 'cmd' : self.cmdfile, 'det' : e })
return
fd.close()
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2011-08-04 13:45:23 UTC (rev 47433)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2011-08-04 14:11:23 UTC (rev 47434)
@@ -298,7 +298,7 @@
map = fullname,
fs = ';')
if ret != 0:
- sys.stderr.write(_("Vector map <%s>: %s\n") % (fullname, msg))
+ sys.stderr.write(_("Vector map <%(map)s>: %(msg)s\n") % { 'map' : fullname, 'msg' : msg })
return layers
else:
Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
