[GRASS-SVN] r47455 - grass-addons/grass7/gui/wxpython/wx.wms
svn_grass at osgeo.org
Thu Aug 4 16:08:31 EDT 2011
Author: sudeepsingh
Date: 2011-08-04 13:08:31 -0700 (Thu, 04 Aug 2011)
New Revision: 47455
Removed:
grass-addons/grass7/gui/wxpython/wx.wms/map.png
grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml
grass-addons/grass7/gui/wxpython/wx.wms/TODO
grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Closing of add server bug fixed, TODO file updated
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml
--- grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml 2011-08-04 20:06:40 UTC (rev 47454)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml 2011-08-04 20:08:31 UTC (rev 47455)
@@ -1,78 +1,68 @@
<serverinfo>
- <server id="cd">
+ <server id="123">
<servername>
- cd
+ 123
</servername>
<serverurl>
- cswd
+ 123
</serverurl>
<username>
+ 123
</username>
<password>
+ 123
</password>
</server>
- <server id="āšņ ēčžģ1">
+ <server id="asd">
<servername>
- āšņ ēčžģ1
+ asd
</servername>
<serverurl>
- 12
+ asd
</serverurl>
<username>
+ asd
</username>
<password>
+ asd
</password>
</server>
- <server id="ڝڍڑڭڏڧڲ">
+ <server id="āšņ ēčžģ12">
<servername>
- ڝڍڑڭڏڧڲ
+ āšņ ēčžģ12
</servername>
<serverurl>
- asdasd
+ asd12
</serverurl>
<username>
</username>
<password>
</password>
</server>
- <server id="āšņ ēčžģ">
+ <server id="ڝڍڑڭڏڧڲ">
<servername>
- āšņ ēčžģ
+ ڝڍڑڭڏڧڲ
</servername>
<serverurl>
- asd
+ asdasd
</serverurl>
<username>
</username>
<password>
</password>
</server>
- <server id="qw">
+ <server id="āšņ ēčžģ">
<servername>
- qw
+ āšņ ēčžģ
</servername>
<serverurl>
- qw1
+ asd
</serverurl>
<username>
</username>
<password>
</password>
</server>
- <server id="a3">
- <servername>
- a3
- </servername>
- <serverurl>
- b3
- </serverurl>
- <username>
- c3
- </username>
- <password>
- d3
- </password>
- </server>
<server id="GISNetServer">
<servername>
GISNetServer
@@ -87,18 +77,4 @@
password
</password>
</server>
- <server id="a2">
- <servername>
- a2
- </servername>
- <serverurl>
- b2
- </serverurl>
- <username>
- c2
- </username>
- <password>
- d2
- </password>
- </server>
</serverinfo>
Modified: grass-addons/grass7/gui/wxpython/wx.wms/TODO
--- grass-addons/grass7/gui/wxpython/wx.wms/TODO 2011-08-04 20:06:40 UTC (rev 47454)
+++ grass-addons/grass7/gui/wxpython/wx.wms/TODO 2011-08-04 20:08:31 UTC (rev 47455)
@@ -4,8 +4,23 @@
ڝڍڑڭڏڧڲڝڍڑڭڏڧڲ
Arabic String or any right indented string doesnt work quite well with the current version.
-2.On closing add server window, main window also closes. To be fixed.
+2.Resizing not being done properly
3.Coding Standards of wxgui programming not followed exactly till now. Code to be modified soon for that.
+4.UserName Password not checked if they are required by a particular server or not, currently hard coded.
+5.Layers fetched are not being displayed hierarchly, bug known, to be fixed.
More to be added...
+Things done
+1.[Fixed]Username checked for delimeter presence
+2.[Fixed]On closing add server window, main window also closes.
+3.[Fixed]In addserver.py when pressing the quit button or closing it, main wmsmenu window closes, and it gives an error of maximum recurssion depth reached error.
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py 2011-08-04 20:06:40 UTC (rev 47454)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py 2011-08-04 20:08:31 UTC (rev 47455)
@@ -3,6 +3,7 @@
# generated by wxGlade 0.6.3 on Thu Jul 14 06:22:35 2011
import wx
+from wx.lib.pubsub import Publisher
from BeautifulSoup import BeautifulSoup, Tag, NavigableString, BeautifulStoneSoup
from ServerInfoAPIs import addServerInfo, removeServerInfo, updateServerInfo, initServerInfoBase, getAllRows
from LoadConfig import loadConfigFile
@@ -54,7 +55,7 @@
if( not loadConfigFile(self)):
print 'Config File Error, Unable to start application...'
self.Close()
self.soup = initServerInfoBase('ServersList.xml')
self.Bind(wx.EVT_CLOSE, self.OnQuit)
self.__populate_URL_List(self.ServerList)
@@ -159,6 +160,10 @@
def OnSave(self, event): # wxGlade: ServerAdd.<event_handler>
#print "Event handler `OnSave' not implemented"
newServerName = unicode(self.ServerNameText.GetValue())
+ if(newServerName.count(self.name_url_delimiter)>0):
+ print "Warning: UserName cannot consist of "+self.name_url_delimiter
+ print "Please give another username, save failed..."
+ return
print newServerName
print 'check12'
if(self.servers.has_key(newServerName)):
@@ -186,17 +191,24 @@
if(update):
if(updateServerInfo(self.soup, self.soup.serverinfo, newServerName, newUrl, newUserName, newPassword)):
print 'update save successful'
+ self.saveXMLData()
+ msg = self.servers
+ Publisher().sendMessage(("update.serverList"), msg)
else:
print 'update save not successful'
else:
if(addServerInfo(self.soup, self.soup.serverinfo, newServerName, newUrl, newUserName, newPassword)):
print 'soup save successfully'
else:
print "False returned by addServerInfo, save not successful"
f = open('serverList.txt','a')
f.write(newServerName+" "+newUrl+ " "+newUserName+" "+newPassword+"\n")
f.close()
self.selectedURL = newUrl
print self.selectedURL
print self.servers
@@ -221,6 +233,9 @@
self.URLText.Clear()
self.UsernameText.Clear()
print self.servers
else:
print 'No server selected'
#print "Event handler `OnRemove' not implemented"
@@ -234,13 +249,21 @@
event.Skip()
- def OnQuit(self, event): # wxGlade: ServerAdd.<event_handler>
- print 'onQuit pressed'
+ def saveXMLData(self):
xml = self.soup.prettify()
f = open('ServersList.xml','w')
f.write(xml)
f.close()
+ def OnQuit(self, event): # wxGlade: ServerAdd.<event_handler>
+ print 'onQuit pressed'
+ self.Destroy()
+ #exit()
+ #self.Close()
'''out = open('serverList.txt','w')
for k,v in self.servers.iteritems():
out.write(v.servername+" "+v.url+" "+v.username+" "+v.password+"\n")
@@ -268,12 +291,11 @@
print "Wrong format of URL selected"
#self.ServerNameText.SetValue(self.servers)
- print "Event handler `OnServerList' not implemented"
event.Skip()
# end of class ServerAdd
-def AddServerFrame():
+def AddServerFrame(parentWMS):
app = wx.PySimpleApp(0)
wx.InitAllImageHandlers()
frame_2 = ServerAdd(None, -1, "")
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/map.png
(Binary files differ)
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-08-04 20:06:40 UTC (rev 47454)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py 2011-08-04 20:08:31 UTC (rev 47455)
@@ -4,6 +4,7 @@
import wx
from wxPython.wx import *
from urllib2 import Request, urlopen, URLError, HTTPError
from parse import parsexml, isServiceException, populateLayerTree
from WMSMapDisplay import NewImageFrame
@@ -56,8 +57,8 @@
self.__populate_Url_List(self.ServerList)
self.selectedURL="No server selected"
self.layerTreeRoot = self.LayerTree.AddRoot("Layers")
+ Publisher().subscribe(self.updateServerList, ("update.serverList"))
#items = ["a", "b", "c"]
#itemId = self.LayerTree.AppendItem(self.layerTreeRoot, "item")
#self.LayerTree.AppendItem(itemId, "inside")
@@ -95,9 +96,13 @@
sizer_1.Fit(self)
self.Layout()
# end wxGlade
- def update_Url_List(self, name):
- ComboBox = self.ServerList
- ComboBox.Append(name)
+ def __update_Url_List(self, ComboBox):
+ ComboBox.Clear()
+ for key, value in self.servers.items():
+ ComboBox.Append(value.servername+self.name_url_delimiter+value.url)
+ #ComboBox.Append(value.servername+" "+self.name_url_delimiter+" "+value.url)
+ print self.servers
+ return
@@ -280,11 +285,25 @@
#print "Event handler `OnLayerTreeSelChanged' not implemented"
event.Skip()
+ def updateServerList(self, msg):
+ Shows the frame and shows the message sent in the
+ text control
+ print 'yoyo'
+ self.servers = msg.data
+ self.__update_Url_List(self.ServerList)
+ print 'yoyo'
+ #frame = self.GetParent()
+ #frame.Show()
def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
- AddServerFrame()
+ print 'before add server call'
+ AddServerFrame(self)
+ #print 'after add server call'
#print "Event handler `OnAddServer' not implemented"
- event.Skip()
+ #event.Skip()
+ return
# end of class wmsFrame
#Sudeep's Code Starts
