[GRASS-SVN] r47463 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Aug 5 14:39:16 EDT 2011
Author: annakrat
Date: 2011-08-05 11:39:15 -0700 (Fri, 05 Aug 2011)
New Revision: 47463
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxNviz: first and imperfect implementation of thematic mapping (only color so far) for points
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -36,18 +36,21 @@
import menuform
from debug import Debug as Debug
from preferences import globalSettings as UserSettings
+from nviz_mapdisp import wxUpdateProperties
class ColorTable(wx.Frame):
- def __init__(self, parent, raster, id = wx.ID_ANY, title = _("Set color table"),
+ def __init__(self, parent, raster, nviz = False, id = wx.ID_ANY, title = _("Set color table"),
style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
**kwargs):
"""!Dialog for interactively entering rules for map management
commands
@param raster True to raster otherwise vector
+ @param nviz True if ColorTable is called from nviz thematic mapping
self.parent = parent # GMFrame
self.raster = raster
+ self.nviz = nviz # called from nviz - thematic mapping
wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
@@ -94,8 +97,7 @@
if self.raster:
self.SetTitle(_('Create new color table for raster map'))
else:
- self.SetTitle(_('Create new color table for vector map'))
+ self.SetTitle(_('Create new color table for vector map'))
# layout
self.__doLayout()
@@ -117,28 +119,32 @@
self.Bind(wx.EVT_COMBOBOX, self.OnColumnSelection, self.cb_vcol)
self.Bind(wx.EVT_COMBOBOX, self.OnRGBColSelection, self.cb_vrgb)
self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.btn_addCol)
+ if not self.nviz:
+ # set map layer from layer tree, first selected,
+ # if not the right type, than select another
+ if self.raster:
+ elem = 'raster'
+ else:
+ elem = 'vector'
+ try:
+ sel = self.parent.curr_page.maptree.layer_selected
+ if sel and self.parent.curr_page.maptree.GetPyData(sel)[0]['type'] == elem:
+ layer = sel
+ else:
+ layer = self.parent.curr_page.maptree.FindItemByData(key = 'type', value = elem)
+ except:
+ layer = None
+ if layer:
+ mapLayer = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer']
+ name = mapLayer.GetName()
+ type = mapLayer.GetType()
+ self.selectionInput.SetValue(name)
+ self.inmap = name
+ else:
+ self.inmap = self.parent.GetLayerData(nvizType = 'vector', nameOnly = True)
+ self.OnSelectionInput(None)
+ self.nvizInfo.SetLabel(_("Set color rules for vector map %s:") % self.inmap)
- # set map layer from layer tree, first selected,
- # if not the right type, than select another
- if self.raster:
- elem = 'raster'
- else:
- elem = 'vector'
- try:
- sel = self.parent.curr_page.maptree.layer_selected
- if sel and self.parent.curr_page.maptree.GetPyData(sel)[0]['type'] == elem:
- layer = sel
- else:
- layer = self.parent.curr_page.maptree.FindItemByData(key = 'type', value = elem)
- except:
- layer = None
- if layer:
- mapLayer = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer']
- name = mapLayer.GetName()
- type = mapLayer.GetType()
- self.selectionInput.SetValue(name)
- self.inmap = name
self.SetMinSize(self.GetSize())
self.CentreOnScreen()
@@ -202,6 +208,9 @@
self.btn_addCol.SetToolTipString(_("Add GRASSRGB column to current attribute table."))
# layout
+ inputBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("Select vector columns"))
+ inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
vSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
vSizer.Add(self.cb_vl_label, pos = (0, 0),
flag = wx.ALIGN_CENTER_VERTICAL)
@@ -217,8 +226,10 @@
vSizer.Add(self.btn_addCol, pos = (2, 2),
+ inputSizer.Add(item = vSizer,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 5)
- return vSizer
+ return inputSizer
def _createColorRulesPanel(self):
"""!Create rules panel"""
@@ -275,6 +286,16 @@
mapSelection = self._createMapSelection()
sizer.Add(item = mapSelection, proportion = 0,
flag = wx.ALL | wx.EXPAND, border = 5)
+ if self.nviz:
+ sizerNviz = wx.BoxSizer(wx.HORIZONTAL)
+ self.nvizInfo = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('')) # set later
+ sizerNviz.Add(self.nvizInfo, proportion = 0, flag = wx.LEFT | wx.EXPAND, border = 0)
+ sizer.Add(item = sizerNviz, proportion = 0,
+ flag = wx.LEFT | wx.BOTTOM | wx.EXPAND, border = 5)
+ sizer.Hide(mapSelection)
+ # doesn't work
+ sizer.Layout()
# set vector attributes
@@ -345,6 +366,7 @@
flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
self.SetSizer(sizer)
+ sizer.Layout()
sizer.Fit(self)
self.Layout()
@@ -588,9 +610,9 @@
except ValueError:
self.properties['min'] = self.properties['max'] = ''
- if self.properties['min'] and self.properties['max']:
+ if self.properties['min'] or self.properties['max']:
if ctype == int:
- self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s, range: %d - %d )")
+ self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s, range: %d - %d)")
% (type, self.properties['min'], self.properties['max']))
elif ctype == float:
self.cr_label.SetLabel(_("Enter vector attribute values or ranges (type: %s, range: %.1f - %.1f )")
@@ -729,10 +751,22 @@
@return True on success otherwise False
ret = self.CreateColorTable()
- display = self.parent.GetLayerTree().GetMapDisplay()
- if display and display.IsAutoRendered():
- display.GetWindow().UpdateMap(render = True)
+ if not ret:
+ GMessage(parent = self, message = _("No color rules given."))
+ if not self.nviz:
+ display = self.parent.GetLayerTree().GetMapDisplay()
+ if display and display.IsAutoRendered():
+ display.GetWindow().UpdateMap(render = True)
+ else:
+ data = self.parent.GetLayerData(nvizType = 'vector')
+ data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
+ data['vector']['points']['thematic']['rgbcolumn'] = self.properties['rgb']
+ data['vector']['points']['thematic']['update'] = None
+ event = wxUpdateProperties(data = data)
+ wx.PostEvent(self.parent.mapWindow, event)
+ self.parent.mapWindow.Refresh(False)
return ret
def OnOK(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -1563,6 +1563,7 @@
'update' in data['width'] or \
'update' in data['marker'] or \
'update' in data['color']:
ret = self._display.SetVectorPointMode(id, data['color']['value'],
data['width']['value'], float(data['size']['value']),
data['marker']['value'] + 1)
@@ -1586,6 +1587,16 @@
data['height']['value'])
data['height'].pop('update')
+ # thematic
+ if 'update' in data['thematic']:
+ if data['thematic']['use']:
+ self._display.SetStyleThematic(id = id, layer = data['thematic']['layer'],
+ color = data['thematic']['rgbcolumn'],
+ size = data['thematic']['sizecolumn'])
+ else:
+ self._display.UnsetStyleThematic(id = id, layer = data['thematic']['layer'])
+ data['thematic'].pop('update')
# surface
if 'update' in data['mode']:
for item in range(len(data['mode']['surface']['value'])):
@@ -1599,7 +1610,7 @@
self._display.UnsetVectorPointSurface(id, sid)
break
data['mode'].pop('update')
def GetLayerNames(self, type):
"""!Return list of map layer names of given type"""
layerName = []
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -46,6 +46,7 @@
import globalvar
import gselect
import gcmd
+import colorrules
try:
from nviz_mapdisp import wxUpdateView, wxUpdateLight, wxUpdateProperties,\
@@ -1207,8 +1208,12 @@
box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
label = " %s " % (_("Vector points")))
boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ vertSizer = wx.BoxSizer(wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
- gridSizer.AddGrowableCol(5)
+ gridSizer.AddGrowableCol(0)
+ gridSizer.AddGrowableCol(2)
+ gridSizer.AddGrowableCol(4)
+ gridSizer.AddGrowableCol(6)
# icon size
gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
@@ -1246,51 +1251,69 @@
wx.ALIGN_LEFT,
pos = (0, 4))
- # icon width
- gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
- label = _("width")),
- pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL |
- wx.ALIGN_RIGHT)
- iwidth = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
- initial = 1,
- min = 1,
- max = 1e6)
- iwidth.SetName('value')
- iwidth.SetValue(100)
- self.win['vector']['points']['width'] = iwidth.GetId()
- iwidth.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
- iwidth.Bind(wx.EVT_TEXT, self.OnVectorPoints)
- gridSizer.Add(item = iwidth, pos = (1, 2),
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
+ # icon width - seems to do nothing
+## gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
+## label = _("width")),
+## pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL |
+## wx.ALIGN_RIGHT)
+## iwidth = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
+## initial = 1,
+## min = 1,
+## max = 1e6)
+## iwidth.SetName('value')
+## iwidth.SetValue(100)
+## self.win['vector']['points']['width'] = iwidth.GetId()
+## iwidth.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
+## iwidth.Bind(wx.EVT_TEXT, self.OnVectorPoints)
+## gridSizer.Add(item = iwidth, pos = (1, 2),
+## flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
# icon symbol
label = _("symbol:")),
- pos = (1, 3), flag = wx.ALIGN_CENTER_VERTICAL)
+ pos = (0, 5), flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
isym = wx.Choice (parent = panel, id = wx.ID_ANY, size = (100, -1),
choices = UserSettings.Get(group = 'nviz', key = 'vector',
subkey = ['points', 'marker'], internal = True))
isym.SetName("selection")
self.win['vector']['points']['marker'] = isym.GetId()
isym.Bind(wx.EVT_CHOICE, self.OnVectorPoints)
- gridSizer.Add(item = isym, flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (1, 4))
+ gridSizer.Add(item = isym, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT,
+ pos = (0, 6))
+ # thematic mapping
+ self.win['vector']['points']['thematic'] = {}
+ checkThematic = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("use thematic mapping for vector points"))
+ self.win['vector']['points']['thematic']['check'] = checkThematic.GetId()
+ checkThematic.Bind(wx.EVT_CHECKBOX, self.OnCheckThematic)
+ checkThematic.SetValue(False)
+ gridSizer.Add(item = checkThematic, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT,
+ pos = (1, 1), span = (1, 5))
+ setThematic = wx.Button(parent = panel, id = wx.ID_ANY,
+ label = _("Set options..."))
+ self.win['vector']['points']['thematic']['button'] = setThematic.GetId()
+ setThematic.Bind(wx.EVT_BUTTON, self.OnSetThematic)
+ gridSizer.Add(item = setThematic, flag = wx.ALIGN_CENTER_VERTICAL,
+ pos = (1, 6))
+ vertSizer.Add(gridSizer, proportion = 0, flag = wx.EXPAND, border = 0)
# high
+ gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
+ gridSizer.AddGrowableCol(1)
label = _("Display on surface(s):")),
- pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL,
- span = (1, 5))
+ pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
label = _("Height above surface:")),
- pos = (3, 5), flag = wx.ALIGN_CENTER_VERTICAL)
+ pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL)
surface = wx.CheckListBox(parent = panel, id = wx.ID_ANY, size = (-1, 60),
choices = [], style = wx.LB_NEEDED_SB)
surface.Bind(wx.EVT_CHECKLISTBOX, self.OnVectorSurface)
self.win['vector']['points']['surface'] = surface.GetId()
gridSizer.Add(item = surface,
- pos = (3, 0), span = (3, 5),
+ pos = (1, 0), span = (3, 1),
flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND)
self._createControl(panel, data = self.win['vector']['points'], name = 'height', size = -1,
@@ -1301,12 +1324,13 @@
self.FindWindowById(self.win['vector']['points']['height']['text']).SetValue(0)
gridSizer.Add(item = self.FindWindowById(self.win['vector']['points']['height']['slider']),
- pos = (4, 5),flag = wx.EXPAND|wx.ALIGN_CENTER_VERTICAL)
+ pos = (2, 1),flag = wx.EXPAND|wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(item = self.FindWindowById(self.win['vector']['points']['height']['text']),
- pos = (5, 5),
+ pos = (3, 1),
flag = wx.ALIGN_CENTER)
- boxSizer.Add(item = gridSizer, proportion = 1,
+ boxSizer.Add(item = vertSizer, proportion = 1,
flag = wx.ALL | wx.EXPAND, border = 3)
pageSizer.Add(item = boxSizer, proportion = 0,
flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
@@ -1827,9 +1851,11 @@
return panel
- def GetLayerData(self, nvizType):
+ def GetLayerData(self, nvizType, nameOnly = False):
"""!Get nviz data"""
name = self.FindWindowById(self.win[nvizType]['map']).GetValue()
+ if nameOnly:
+ return name
if nvizType == 'surface' or nvizType == 'fringe':
return self.mapWindow.GetLayerByName(name, mapType = 'raster', dataType = 'nviz')
@@ -3158,6 +3184,33 @@
if self.mapDisplay.statusbarWin['render'].IsChecked():
self.mapWindow.Refresh(False)
+ def OnCheckThematic(self, event):
+ """!Switch on/off thematic mapping"""
+ check = self.win['vector']['points']['thematic']['check']
+ button = self.win['vector']['points']['thematic']['button']
+ if self.FindWindowById(check).GetValue():
+ checked = True
+ else:
+ checked = False
+ self.FindWindowById(button).Enable(checked)
+ data = self.GetLayerData('vector')
+ data['vector']['points']['thematic']['use'] = checked
+ # update properties
+ wx.PostEvent(self.mapWindow, event)
+ if self.mapDisplay.statusbarWin['render'].IsChecked():
+ self.mapWindow.Refresh(False)
+ def OnSetThematic(self, event):
+ """!Set options for thematic points"""
+ ctable = colorrules.ColorTable(self, raster = False, nviz = True)
+ ctable.CentreOnScreen()
+ ctable.Show()
def UpdateIsosurfButtons(self, list):
"""!Enable/disable buttons 'add', 'delete',
'move up', 'move down'"""
@@ -4251,6 +4304,7 @@
win.SetValue(color)
else:
win.SetValue(data['points'][prop]['value'])
+ self.OnCheckThematic(None)
# height
for type in ('slider', 'text'):
win = self.FindWindowById(self.win['vector']['points']['height'][type])
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -533,6 +533,8 @@
'marker' : 2,
'color' : (0, 0, 255, 255), # blue
'height' : 0,
+ 'rgbcolumn': None,
+ 'sizecolumn': None,
'volume' : {
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -480,10 +480,12 @@
iview['twist']['max'] = self.__processLayerNvizNode(node_twist, 'max', int)
node_zexag = node_view.find('z-exag')
view['z-exag'] = {}
+ iview['z-exag'] = {}
view['z-exag']['value'] = self.__processLayerNvizNode(node_zexag, 'value', int)
view['z-exag']['step'] = self.__processLayerNvizNode(node_zexag, 'step', int)
view['z-exag']['min'] = self.__processLayerNvizNode(node_zexag, 'min', int)
view['z-exag']['max'] = self.__processLayerNvizNode(node_zexag, 'max', int)
+ iview['z-exag']['original'] = self.__processLayerNvizNode(node_zexag, 'original', float)
node_focus = node_view.find('focus')
iview['focus'] = {}
iview['focus']['x'] = self.__processLayerNvizNode(node_focus, 'x', int)
@@ -735,10 +737,16 @@
# height
data['height'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
subkey=['points', 'height']) }
+ data['thematic'] = {'rgbcolumn' : UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'rgbcolumn']),
+ 'sizecolumn' : UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'sizecolumn']),
+ 'layer': 1,
+ 'use' : False}
if 'object' in data:
for attrb in ('size', 'width', 'marker',
- 'color', 'surface', 'height'):
+ 'color', 'surface', 'height', 'thematic'):
data[attrb]['update'] = None
def GetDrawMode(self, mode=None, style=None, shade=None, string=False):
@@ -1109,7 +1117,7 @@
marker))
self.indent += 4
for name in data[attrb].iterkeys():
- if name in ('object', 'marker'):
+ if name in ('object', 'marker', 'thematic'):
continue
if name == 'mode':
self.file.write('%s<%s type="%s">\n' % (' ' * self.indent, name,
@@ -1193,6 +1201,7 @@
self.file.write('%s<step>%d</step>\n' % (' ' * self.indent, view['z-exag']['step']))
self.file.write('%s<min>%d</min>\n' % (' ' * self.indent, view['z-exag']['min']))
self.file.write('%s<max>%d</max>\n' % (' ' * self.indent, view['z-exag']['max']))
+ self.file.write('%s<original>%d</original>\n' % (' ' * self.indent, iview['z-exag']['original']))
self.indent -= 4
self.file.write('%s</z-exag>\n' % (' ' * self.indent))
# focus (look here)
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-05 13:52:49 UTC (rev 47462)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2011-08-05 18:39:15 UTC (rev 47463)
@@ -940,6 +940,15 @@
return 1
+ def SetStyleThematic(self, id, layer, color = None, width = None, size = None, symbol = None):
+ """!Set thematic style for vector points"""
+ GP_set_style_thematic(id, layer, color, width, size, symbol)
+ def UnsetStyleThematic(self, id, layer):
+ """!Set thematic style None for vector points"""
+ # this should be done in another way
+ GP_set_style_thematic(id, layer, None, None, None, None)
def UnsetVectorPointSurface(self, id, surf_id):
"""!Unset reference surface of vector set (points)
